Satel Integra (Security System) with ethernet module Topic is solved
borewicz
Re: Satel Integra (Security System) with ethernet module
Yes it is.
Configuration with dloadx is possible via ethernet (LAN), USB or Satel server.
There's also dedicated app:
VERSA CONTROL autorstwa Satel sp. z o.o.
https://itunes.apple.com/pl/app/versa-c ... ?l=pl&mt=8
fantom
But how do connect versa to Ethernet ? Does it have rj45 or use ethm1 ?
borewicz
RJ45fantom wrote: Sunday 20 August 2017 17:21 But how do connect versa to Ethernet ? Does it have rj45 or use ethm1 ?
sapa
Welcome everybody, I'm a newbie so sorry if my question will be a bit silly and sorry for my english
I've integrated Integra with Domoticz but there is a few problems/questions that I can't find answer in this thread:
1. Is there a posibility to encrypt integration (an option in Dloadx )?
2. I've been looking for posibility to block arm/disarm function in Domoticz - I won't use it so it is unnesessery security risk for me.
3. Which baudrate is correct?
now problems:/
1. I've a lot errors in log:
017-08-26 21:40:23.911 Error: Satel Integra: receive error: other error
2017-08-26 21:40:23.911 Error: Satel Integra: Receive info about zone 121 failed
2017-08-26 21:40:24.212 Error: Satel Integra: receive error: other error
2017-08-26 21:40:24.212 Error: Satel Integra: Receive info about zone 122 failed
2017-08-26 21:40:24.513 Error: Satel Integra: receive error: other error
2017-08-26 21:40:24.513 Error: Satel Integra: Receive info about zone 123 failed
2017-08-26 21:40:24.814 Error: Satel Integra: receive error: other error
2017-08-26 21:40:24.814 Error: Satel Integra: Receive info about zone 124 failed
2017-08-26 21:40:25.055 Error: Satel Integra: receive error: other error
2017-08-26 21:40:25.055 Error: Satel Integra: Receive info about zone 125 failed
2017-08-26 21:40:25.376 Error: Satel Integra: receive error: other error
2017-08-26 21:40:25.376 Error: Satel Integra: Receive info about zone 126 failed
2017-08-26 21:40:25.597 Error: Satel Integra: receive error: other error
2017-08-26 21:40:25.597 Error: Satel Integra: Receive info about zone 127 failed
2017-08-26 21:40:25.858 Error: Satel Integra: receive error: other error
2017-08-26 21:40:25.858 Error: Satel Integra: Receive info about zone 128 failed
and all the time the same from 1 to 128 zone
What could make this errors?
2. After connection with Integra my Domoticz get stuck often - it looks like problem with database connection (everything is empty) or "domoticz offline" - after manualy service restart it is OK for a while (it is so often that i've to stop integration)
My system:
Domoticz 3.8153 @Raspberry Pi 2B
Integra 128WRL v. 1.16 with 4xINT-IORS Extension +INT-E
ETHM 1Plus V. 2.03
Could that problems originate from size of Integra system and Rpi performance?
now problems:/
My system:
ETHM 1Plus V. 2.03
fantom
I am on holiday. I will reply after return.
Fantom
Fantom
fantom
I can't find protocol for Versa Plus.borewicz wrote: Sunday 20 August 2017 12:07 Yes it is.
But i finded, that ETHM1 may be connected to Versa Plus.
Fantom
fantom
Hisapa wrote: Saturday 26 August 2017 22:16 Welcome everybody, I'm a newbie so sorry if my question will be a bit silly and sorry for my english
4. I've a lot errors in log:
5. After connection with Integra my Domoticz get stuck often - it looks like problem with database connection (everything is empty) or "domoticz offline" - after manualy service restart it is OK for a while (it is so often that i've to stop integration)
Ad 1. I have a plan but I don't know when I will do it.
Ad 2. Maybe use Security Panel in Domoticz ? Or set rights for user in Domoticz ? OR check "protected" on device ?
Ad 3. Baudarate ?? Where is this setting ?
Ad 4. All unused output, send error on start. This is normal and i didn't find solution for this problem (not exists in ethm1 protocol). Used outputs - don't log errors.
Ad. 5 I don't understand
Fantom
sapa
Thanks for your answer,]fantom wrote: Sunday 03 September 2017 14:26 Hi
Fantom
Ad 2 - I've thought about permanent disable of this function
Ad 3 - In hardware preferences - maybe you can give us a clear quide how to set all preferences as rate time refresh rate etc
ad 4 - OK
Ad 5 - for me it looks like to much data and system is crashing it is all the time when i've connected integra to domoticz. it works properly for few minutes then crash. Mayby I've some bad setting in hardware preferences ? (screenshot in attachment)
- scrrenshot
- domoticz-integra.JPG (91.71 KiB) Viewed 5225 times
fantom
Ad 2. For me the best methos is set "protected" and set password in settings.
Ad 3. Lol. You have problem with cache or .. I don't know. This page is broken. Pls wiil try refresh www cache etc. Youu see to many fields on this page.
Ad 5. Pls check log after crash.
Fantom
Fantom
sapa
Ad 3 - you've right cache problem;) but still i can't change refresh rate it always back to 1000ms
Ad 5 few lines before crash and the fatal errors (the last line - manual service restart via ssh)
2017-09-05 23:26:37.795 (Integra) General/Alert (Zone:Salon)
2017-09-05 23:26:40.039 (1-wire) Temp (Temp Sypialnia)
2017-09-05 23:26:44.040 (1-wire) Temp (Temp zewnetrzna zachod)
2017-09-05 23:26:44.241 Kodi: Restarting I/O service thread.
2017-09-05 23:26:45.799 (Integra) General/Alert (Zone:Salon)
2017-09-05 23:26:47.040 (1-wire) Temp (Temp Salon)
2017-09-05 23:26:49.801 (Integra) General/Alert (Zone:Salon)
2017-09-05 23:26:50.041 (1-wire) Temp (Temp Sypialnia)
2017-09-05 23:26:54.040 (1-wire) Temp (Temp zewnetrzna zachod)
2017-09-05 23:26:57.797 Satel Integra: Destroy instance
2017-09-05 23:26:57.798 Error: Domoticz received fatal signal 11 !...
2017-09-05 23:26:57.839 Error: /home/pawel/domoticz/domoticz() [0x1cdc48]
2017-09-05 23:26:57.839 Error: /home/pawel/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1cdd00]
2017-09-05 23:26:57.840 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76ac2180]
2017-09-05 23:26:57.840 Error: /home/pawel/domoticz/domoticz(_ZN5boost6detail17sp_counted_impl_pINS_8signals26detail12signal4_implIvP21CDomoticzHardwareBasePKhPKciN$
2017-09-05 23:26:57.840 Error: /home/pawel/domoticz/domoticz(_ZN5boost6detail15sp_counted_base7releaseEv+0x44) [0x1c4088]
2017-09-05 23:26:57.841 Error: /home/pawel/domoticz/domoticz(_ZN5boost6detail15sp_counted_base7releaseEv+0x44) [0x1c4088]
2017-09-05 23:26:57.841 Error: /home/pawel/domoticz/domoticz(_ZN21CDomoticzHardwareBaseD1Ev+0x68) [0x34d600]
2017-09-05 23:26:57.841 Error: /home/pawel/domoticz/domoticz(_ZN12SatelIntegraD1Ev+0x74) [0x448dd0]
2017-09-05 23:26:57.841 Error: /home/pawel/domoticz/domoticz(_ZN12SatelIntegraD0Ev+0xc) [0x448e64]
2017-09-05 23:26:57.841 Error: /home/pawel/domoticz/domoticz(_ZN10MainWorker22RemoveDomoticzHardwareEP21CDomoticzHardwareBase+0x90) [0x20ce7c]
2017-09-05 23:26:57.841 Error: /home/pawel/domoticz/domoticz(_ZN10MainWorker21AddHardwareFromParamsEiRKSsb15_eHardwareTypesS1_tS1_S1_S1_S1_iiiiiiib+0x44) [0x222004]
2017-09-05 23:26:57.842 Error: /home/pawel/domoticz/domoticz(_ZN4http6server10CWebServer18Cmd_UpdateHardwareERNS0_14_tWebEmSessionERKNS0_7requestERN4Json5ValueE+0x5$
2017-09-05 23:26:57.845 Error: /home/pawel/domoticz/domoticz(_ZN4http6server10CWebServer13HandleCommandERKSsRNS0_14_tWebEmSessionERKNS0_7requestERN4Json5ValueE+0x68$
2017-09-05 23:26:57.847 Error: /home/pawel/domoticz/domoticz(_ZN4http6server10CWebServer11GetJSonPageERNS0_14_tWebEmSessionERKNS0_7requestERNS0_5replyE+0x390) [0x2c$
2017-09-05 23:26:57.850 Error: /home/pawel/domoticz/domoticz(_ZNK5boost9function3IvRN4http6server14_tWebEmSessionERKNS2_7requestERNS2_5replyEEclES4_S7_S9_+0x2c) [0x$
2017-09-05 23:26:57.852 Error: /home/pawel/domoticz/domoticz(_ZN4http6server6cWebem20CheckForPageOverrideERNS0_14_tWebEmSessionERNS0_7requestERNS0_5replyE+0x388) [0$
2017-09-05 23:26:57.854 Error: /home/pawel/domoticz/domoticz(_ZN4http6server20cWebemRequestHandler14handle_requestERKNS0_7requestERNS0_5replyE+0x3b0) [0x4dcd1c]
2017-09-05 23:26:57.857 Error: /home/pawel/domoticz/domoticz(_ZN4http6server10connection11handle_readERKN5boost6system10error_codeEj+0x3b0) [0x4cd5b4]
2017-09-05 23:26:57.859 Error: /home/pawel/domoticz/domoticz(_ZN5boost4asio6detail23reactive_socket_recv_opINS0_17mutable_buffers_1ENS_3_bi6bind_tIvNS_4_mfi3mf2IvN4$
2017-09-05 23:26:57.861 Error: /home/pawel/domoticz/domoticz(_ZN5boost4asio6detail15task_io_service3runERNS_6system10error_codeE+0x248) [0x328454]
2017-09-05 23:26:57.863 Error: /home/pawel/domoticz/domoticz(_ZN4http6server11server_base3runEv+0x30) [0x4e7254]
2017-09-05 23:26:57.866 Error: /home/pawel/domoticz/domoticz(_ZN4http6server10CWebServer7Do_WorkEv+0x28) [0x27ff58]
2017-09-05 23:26:57.868 Error: /home/pawel/domoticz/domoticz() [0x5b6730]
2017-09-05 23:28:08.667 RxQueue: queue worker started...
borewicz
Unfortunately there's no open protocol in Versa Plus.fantom wrote: Sunday 03 September 2017 14:18I can't find protocol for Versa Plus.borewicz wrote: Sunday 20 August 2017 12:07 Yes it is.
Fantom
Additional ETHM1 will not change anything because it depends on centrala main board.
fantom
Why is it not works ?borewicz wrote: Friday 08 September 2017 10:06 Additional ETHM1 will not change anything because it depends on centrala main board.
Fantom
borewicz
Satel support told me that INTEGRA main board have got open protocol and VERSA doesn't (ETHM1 module got nothing to do with it)
sapa
Fantom do you have any sugestion what can make that problems?
sapa wrote: Tuesday 05 September 2017 23:41 Ad 3 - you've right cache problem;) but still i can't change refresh rate it always back to 1000ms
Ad 5 few lines before crash and the fatal errors (the last line - manual service restart via ssh)Code: Select all
2017-09-05 23:26:37.795 (Integra) General/Alert (Zone:Salon) 2017-09-05 23:26:40.039 (1-wire) Temp (Temp Sypialnia) 2017-09-05 23:26:44.040 (1-wire) Temp (Temp zewnetrzna zachod) 2017-09-05 23:26:44.241 Kodi: Restarting I/O service thread. 2017-09-05 23:26:45.799 (Integra) General/Alert (Zone:Salon) 2017-09-05 23:26:47.040 (1-wire) Temp (Temp Salon) 2017-09-05 23:26:49.801 (Integra) General/Alert (Zone:Salon) 2017-09-05 23:26:50.041 (1-wire) Temp (Temp Sypialnia) 2017-09-05 23:26:54.040 (1-wire) Temp (Temp zewnetrzna zachod) 2017-09-05 23:26:57.797 Satel Integra: Destroy instance 2017-09-05 23:26:57.798 Error: Domoticz received fatal signal 11 !... 2017-09-05 23:26:57.839 Error: /home/pawel/domoticz/domoticz() [0x1cdc48] 2017-09-05 23:26:57.839 Error: /home/pawel/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1cdd00] 2017-09-05 23:26:57.840 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76ac2180] 2017-09-05 23:26:57.840 Error: /home/pawel/domoticz/domoticz(_ZN5boost6detail17sp_counted_impl_pINS_8signals26detail12signal4_implIvP21CDomoticzHardwareBasePKhPKciN$ 2017-09-05 23:26:57.840 Error: /home/pawel/domoticz/domoticz(_ZN5boost6detail15sp_counted_base7releaseEv+0x44) [0x1c4088] 2017-09-05 23:26:57.840 Error: /home/pawel/domoticz/domoticz(_ZN5boost6detail17sp_counted_impl_pINS_8signals26detail12signal4_implIvP21CDomoticzHardwareBasePKhPKciN$ 2017-09-05 23:26:57.841 Error: /home/pawel/domoticz/domoticz(_ZN5boost6detail15sp_counted_base7releaseEv+0x44) [0x1c4088] 2017-09-05 23:26:57.841 Error: /home/pawel/domoticz/domoticz(_ZN21CDomoticzHardwareBaseD1Ev+0x68) [0x34d600] 2017-09-05 23:26:57.841 Error: /home/pawel/domoticz/domoticz(_ZN12SatelIntegraD1Ev+0x74) [0x448dd0] 2017-09-05 23:26:57.841 Error: /home/pawel/domoticz/domoticz(_ZN12SatelIntegraD0Ev+0xc) [0x448e64] 2017-09-05 23:26:57.841 Error: /home/pawel/domoticz/domoticz(_ZN10MainWorker22RemoveDomoticzHardwareEP21CDomoticzHardwareBase+0x90) [0x20ce7c] 2017-09-05 23:26:57.841 Error: /home/pawel/domoticz/domoticz(_ZN10MainWorker21AddHardwareFromParamsEiRKSsb15_eHardwareTypesS1_tS1_S1_S1_S1_iiiiiiib+0x44) [0x222004] 2017-09-05 23:26:57.842 Error: /home/pawel/domoticz/domoticz(_ZN4http6server10CWebServer18Cmd_UpdateHardwareERNS0_14_tWebEmSessionERKNS0_7requestERN4Json5ValueE+0x5$ 2017-09-05 23:26:57.845 Error: /home/pawel/domoticz/domoticz(_ZN4http6server10CWebServer13HandleCommandERKSsRNS0_14_tWebEmSessionERKNS0_7requestERN4Json5ValueE+0x68$ 2017-09-05 23:26:57.847 Error: /home/pawel/domoticz/domoticz(_ZN4http6server10CWebServer11GetJSonPageERNS0_14_tWebEmSessionERKNS0_7requestERNS0_5replyE+0x390) [0x2c$ 2017-09-05 23:26:57.850 Error: /home/pawel/domoticz/domoticz(_ZNK5boost9function3IvRN4http6server14_tWebEmSessionERKNS2_7requestERNS2_5replyEEclES4_S7_S9_+0x2c) [0x$ 2017-09-05 23:26:57.852 Error: /home/pawel/domoticz/domoticz(_ZN4http6server6cWebem20CheckForPageOverrideERNS0_14_tWebEmSessionERNS0_7requestERNS0_5replyE+0x388) [0$ 2017-09-05 23:26:57.854 Error: /home/pawel/domoticz/domoticz(_ZN4http6server20cWebemRequestHandler14handle_requestERKNS0_7requestERNS0_5replyE+0x3b0) [0x4dcd1c] 2017-09-05 23:26:57.857 Error: /home/pawel/domoticz/domoticz(_ZN4http6server10connection11handle_readERKN5boost6system10error_codeEj+0x3b0) [0x4cd5b4] 2017-09-05 23:26:57.859 Error: /home/pawel/domoticz/domoticz(_ZN5boost4asio6detail23reactive_socket_recv_opINS0_17mutable_buffers_1ENS_3_bi6bind_tIvNS_4_mfi3mf2IvN4$ 2017-09-05 23:26:57.861 Error: /home/pawel/domoticz/domoticz(_ZN5boost4asio6detail15task_io_service3runERNS_6system10error_codeE+0x248) [0x328454] 2017-09-05 23:26:57.863 Error: /home/pawel/domoticz/domoticz(_ZN4http6server11server_base3runEv+0x30) [0x4e7254] 2017-09-05 23:26:57.866 Error: /home/pawel/domoticz/domoticz(_ZN4http6server10CWebServer7Do_WorkEv+0x28) [0x27ff58] 2017-09-05 23:26:57.868 Error: /home/pawel/domoticz/domoticz() [0x5b6730] 2017-09-05 23:28:08.667 RxQueue: queue worker started...
fantom
I'm not Front-end developer. Maybe is bug inf front, but i can't find it
I'm wrote this code but .... i don't know html/js
Fantom
sapa
Thanks Fantom:)
Solution for me was... new instalation of Rasbian and Domoticz. I hadto do this because of other problems but after installing Stretch problem has gone. Now everything seems to be working ok.
florekk
Hello
I have a problem with integra 128 WRL integration with domoticz.
Integra Outputs (but only 105,106, 24,25) hasn't names. Just first two switch outputs from satel has name and corect type (blinds for 105,106 - switch for 24,25).
Outputs type 41,47,14,85,86,99,101 has names and type text.
Whole inputs hasn't names.
My conf:
domoticz 3.8153
Raspi 3B
Integra 128 WRL v. 1.16
ETHM-1 v.2.03
florekk
My conf:
domoticz 3.8153
Raspi 3B
ETHM-1 v.2.03
florekk
fantom
viewtopic.php?f=17&t=4260&start=80#p61894florekk wrote: Wednesday 25 October 2017 9:52 Hello
florekk
Fantom
florekk
It isn't my case, I mean.
I wrote about names and types, not state.
I have a problem during device instalation process. Domoticz can't read names and types.
Logs contains line like:
2017-10-25 12:15:19.464 (Satel Integra 128) General/Alert (Unknown)
2017-10-25 12:15:54.112 (Satel Integra 128) Light/Switch (Unknown)
florekk
florekk
