Page 11 of 17
Re: Alexicz - FREE Domoticz to Alexa Integration
Posted: Sunday 22 December 2019 10:28
by Damsee
If you're having empty devices on your french Amazon account, it seems your default region/country is not set to FR.
Here is my information regarding the region :
- Amazon-Region.png (47.33 KiB) Viewed 2172 times
And i can see my devices as well :
- Amazon-Devices.png (161.95 KiB) Viewed 2172 times
When i'm logging to alexa.amazon.com, Amazon is redirecting me to alexa.amazon.fr and asking to login again to the french site.
In order to solve your issue, you can try to transfert your account :
https://www.amazon.com/gp/help/customer ... =201248840
Or you can leave your account in the US and set the lambda in the US as well as it was working for other users :
trueblueswede wrote: Saturday 08 December 2018 11:41
@Damsee: I got it to work now, Very nice! In case someone runs into the same problem as I did here is what resolved my issues.
For some reason, it did not work to set the skill Language to EN(UK) and host the function in Ireland.
I exported the function and deployed it to Us(Virginia) and created a new skill with Language EN(Us) and voila it started to work.
Hope that helps
Posted: Sunday 22 December 2019 11:46
by DrMacabre
Oki get it now, everything was indeed registered on amazon.com with default region set to France. That’s why it confused me. I have transfered my devices to amazon.fr now. No idea why it was registered on the .com. Might be the time i tried the kindle app on my ipad that is set to US/english. Now i just need to get the skill back. Thank you.
Posted: Sunday 22 December 2019 12:43
by Damsee
You shouldn't have to recreate everything...
Once logged through AWS, you should be able to find your lambda function ; please check again your region (EU / Ireland) following the latest Amazon documentation :
https://developer.amazon.com/en-US/docs ... uages.html
Once logged through
https://developer.amazon.com/alexa/console/ask, you should be able to find your skill.
You can edit it and change the language if needed.
Since you recreated everything, it should be working with an ARN starting with arn:aws:lambda:eu-west-1...
Posted: Sunday 22 December 2019 13:13
by DrMacabre
It worked. Thanks for your help, sorry for bringing the same problem as other users earlier in this topic. I have no idea why everything was registering at amazon.com but still set to France which led to some confusion. May be because i use english/us localization on all my devices here, amazon must have assumed at some point i was in the US.
Posted: Sunday 22 December 2019 14:38
by Damsee
Glad you were able to set it up & running
Amazon accounts management is a mess...
Posted: Sunday 22 December 2019 15:14
by DrMacabre
May be this has been discussed before but all my on/off switch are recognized as dimmer. Is this normal behavior ?
Posted: Sunday 22 December 2019 18:39
by Damsee
DrMacabre wrote: Sunday 22 December 2019 15:14
It might be depending your devices. Alexicz is checking your device properties and set them as dimmable if it finds "HaveDimmer=true".
I have some wall plugs which are not dimmable but the property is true so they appear as dimmer in Alexa ; no worry for me.
Good thing with Alexicz is that you can change the code for your own needs.
Feel free to comment lines 346 to 348 in DomoticzHandler.py file if you dislike that behavior (and remove/rediscover your devices through Alexa).
Posted: Tuesday 24 December 2019 12:16
by DrMacabre
Hello Phil, could you explain a little bit more about how to deploy this ? I have copied the 2 .py from your build into my alexciz but so far, all i can do is turning on and off my LMS players. Is there something else to do to have this working ?
Posted: Tuesday 24 December 2019 14:58
by philchillbill
You should be able to use commands like next, previous, pause, play and stop. If you have a player called bedroom, for example, try 'Alexa, next track on bedroom' or 'Alexa, stop bedroom'. The interfaces I added are defined as:
self.addCapability(AlexaStepSpeaker(self, 'Alexa.StepSpeaker'))
self.addCapability(AlexaPlaybackController(self, 'Alexa.PlaybackController',supportedOperations=['Play','Pause','Stop','Next','Previous']))
check the online docs for those interfaces for the form of the commands.
Posted: Tuesday 24 December 2019 20:36
by DrMacabre
Seems like its not properly discovered, it's a switch here.
"endpointId": "SwitchLight-184",
"friendlyName": "LMS Bedroom",
"description": "Lighting 2",
"manufacturerName": "Logitech Media Server",
"displayCategories": [
"LIGHT"
Posted: Tuesday 24 December 2019 20:47
by philchillbill
DrMacabre wrote:Seems like its not properly discovered, it's a switch here.
"LIGHT"
If you have Domoticz set to French then the strings will not match against the discovery code which only expects English strings. I bet if you switch Domoticz to English and re run Alexa discovery, all will be well.
Posted: Monday 30 December 2019 15:23
by DrMacabre
philchillbill wrote: Tuesday 24 December 2019 20:47
Nope, domoticz is in english here :/
Posted: Monday 30 December 2019 22:04
by philchillbill
Can you post the JSON result from doing a http://your_domoticz_ip:8080/json.htm?type=devices&rid=IDX, where IDX is the IDX of one of your Squeezeboxes in Domoticz? That will help with figuring out how to modify the discovery code to make it work for you.
Posted: Monday 30 December 2019 22:44
by DrMacabre
sure.
"ActTime" : 1577742186,
"AstrTwilightEnd" : "18:58",
"AstrTwilightStart" : "06:48",
"CivTwilightEnd" : "17:39",
"CivTwilightStart" : "08:07",
"DayLength" : "08:19",
"NautTwilightEnd" : "18:19",
"NautTwilightStart" : "07:26",
"ServerTime" : "2019-12-30 22:43:06",
"SunAtSouth" : "12:53",
"Sunrise" : "08:43",
"Sunset" : "17:02",
"app_version" : "4.11590",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Augustus Pablo - East Of The River Nile (2003)",
"Description" : "",
"DimmerType" : "none",
"Favorite" : 1,
"HardwareID" : 7,
"HardwareName" : "Logitech Media Server",
"HardwareType" : "Logitech Media Server",
"HardwareTypeVal" : 60,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "0000007",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2019-12-30 22:42:15",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 15,
"Name" : "LMS Bedroom",
"Notifications" : "false",
"PlanID" : "4",
"PlanIDs" :
4
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Playing",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "AC",
"SwitchType" : "Media Player",
"SwitchTypeVal" : 17,
"Timers" : "false",
"Type" : "Lighting 2",
"TypeImg" : "LogitechMediaServer",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "286",
"YOffset" : "364",
"idx" : "184"
"status" : "OK",
"title" : "Devices"
Posted: Tuesday 31 December 2019 10:45
by philchillbill
Based on your JSON, the code should work as-is. In DomoticzHandler.py, on line 456 we have
elif (switchType.startswith('Media Player')) and (device['HardwareType'].startswith('Logitech')):
endpoint = LMSAlexaEndpoint("LMS-"+endpointId, friendlyName, description, manufacturerName)
endpoint.addCapability(AlexaStepSpeaker(self, 'Alexa.StepSpeaker'))
endpoint.addDisplayCategories("SPEAKER")
The conditions in the elif match correctly. Are you sure you have the dev-phil release from
https://github.com/rimram31/dz_smarthome/releases, because my code is not in the other versions...
Posted: Tuesday 31 December 2019 11:04
by DrMacabre
Yes, I’m 100% sure i have grabbed the py from your release and uploaded it to my function... anyway now the players are gone and i have tried everything to get them back with no success.
Posted: Sunday 05 January 2020 11:32
by philchillbill
I have released a smart home skill for LMS that handles everything my branch of Alexicz did for LMS, and more. The details are at
https://forums.slimdevices.com/showthre ... -for-Alexa
Rather than effectively using Domoticz as a proxy to reach LMS, it uses a direct proxy to LMS to be able to use the jsonrpc interface of LMS more widely. The post above explains it all, including how to link the skill. No developer account needed.
EDIT: It's also available in French (pour nos amis francophones)
Posted: Tuesday 07 January 2020 22:57
by sammyke007
I have been a very happy Controlicz user for a year. It works great with great support from the dev. I just setup Alexicz. Are there any disadvantages when using Alexicz?
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
Posted: Wednesday 08 January 2020 9:56
by philchillbill
sammyke007 wrote: Tuesday 07 January 2020 22:57
Well, it's unsupported so there's no helpdesk and development has stopped too as rimram31 moved on to greater things. The newer smart home interfaces like Range, Mode and Toggle were never implemented in Alexicz. That said, you get the source code so you can do it yourself. In the end, everything Alexa is just moving JSON back and forth...
Posted: Saturday 11 January 2020 15:31
by tarmacalastair
Love the idea of setting this up but Amazon has changed so many of the steps such that the instructions in the PDF are quite out of date now and hard to follow. I will try and update them if I ever get this working.
For now, I've just got to the end of P.14 in the PDF where it says "Congrats: You've done it..." Next it says
Open Alexa app or alexa.amazon.com
Click Skills, then Your Skills
Click Dev Skills - this is where I get stuck. neither my Android Alexa app, nor the website has a button, menu, or anything called Dev Skills.
Any suggestions please?
Thanks.
