Page 11 of 26
Re: Python Plugin: Shelly MQTT
Posted: Friday 07 February 2020 22:39
by josemi
Does anybody have working long push in a Shelly 2.5 working as roller mode?
I enable debug option in plugin, but only short push is shown. No longpush device is created in domoticz either.
Posted: Wednesday 19 February 2020 9:18
by Gerwin
hello ,
thanks a lot for these nice plugin ,
everything is working except the temperature addon for the shelly 1
is there an opportunity that this addon also available coming in this plugin ??
Gerwin
Posted: Friday 21 February 2020 11:53
by bewo
Posted: Friday 21 February 2020 13:40
by Gerwin
@bewo
Gerwin
Posted: Saturday 29 February 2020 10:56
by djac
Trying to update Plugin but get:
"error: Your local changes to the following files would be overwritten by merge:
plugin.py
Please, commit your changes or stash them before you can merge."
Any suggestions?
Posted: Saturday 29 February 2020 11:03
by Geitje
If you Google it, you find some answers, I warns you probably to prevent to overwrite your local changes. You can solve it. Check out for example:
https://stackoverflow.com/questions/157 ... you-can-me
Posted: Wednesday 25 March 2020 11:59
by Gerwin
hello
i have seen that the themperature addon is implemented how can i update ?
can someone explain step by step how to do this
i have a lot of shelly's
Gerwin
Posted: Thursday 26 March 2020 11:48
by Gerwin
Gerwin wrote: Wednesday 25 March 2020 11:59
hello
Gerwin
I know how to do
works great
Gerwin
Posted: Monday 30 March 2020 18:46
by fabry91
Hello guys,
I'm trying to get it work, I have a Shelly 1 V3, successfully installed and started the Shelly plugin.
Problem is that I cannot make it work the on/off switch from domoticz to the shelly 1 relay, I'm attaching the configuration of tasmota flashed firmware on my shelly 1 and the logs result when I tried to switch on the mqtt switch created itself by domoticz.
Thank you in advance and stay safe
Posted: Monday 30 March 2020 19:41
by besix
Hello
The Shelly plugin requires the original soft Shelly.
If you have Tasmota, this is only the mqtt broker but without the Shelly plugin
Posted: Monday 30 March 2020 21:47
by fabry91
besix wrote: Monday 30 March 2020 19:41
Hello
Thank you very much besix, I didn't understood that It was only for the stock shelly firmware.
I have now successfully started the MQTT Client Gateway and I am now controlling the shelly1 relay!
Thanks!!!
Posted: Sunday 10 May 2020 10:18
by Derik
I now strange only i ask this here..
Is there perhaps some one that have shelly with Domoticz working without a plugin?
It looks to me that shely and Domotiz talk mqtt, this must be possible without a plugin?
Just a nodered or something?
for 1 shely a plugin, that's the point
Posted: Tuesday 12 May 2020 13:33
by LouiS22
Derik wrote: Sunday 10 May 2020 10:18
Just below this post at python's topic
viewtopic.php?f=65&t=32616
Posted: Thursday 02 July 2020 20:12
by mattley30
Hi Guys,
I'm trying a scelly 1 with the additional external temperature sensor. inside the shelly1 I regularly display the temperature of 25.8 ° while on Domoticz the component created "LaCrosse TX3" with a value of "0". but I see that the update comes every minute.
Yet doing a dubug the message mqtt arrives.
2020-07-02 20: 05: 44.499 (Shelly Actuators) MQTT message: shellies / shelly1-8CAAB505BBAC / ext_temperature / 0: 25.88
2020-07-02 20: 05: 44.509 (Shelly Actuators) MQTT message: shellies / shelly1-8CAAB505BBAC / ext_temperature_f / 0: 78.58
do you know what it could be?
Mattely30
Posted: Friday 03 July 2020 9:20
by mattley30
Hello again
problem returned I realized that there was a shelly1 firmware update to do, once updated the temperature sensor data arrived, sorry.
Mattley30
Posted: Sunday 05 July 2020 13:53
by niekbruggeman
I can confirm that the new shelly dimmer 2 works correct with Domoticz.
I use the native firmware of the Shelly, and the Shelly MQTT plugin for Domoticz 2020.2.
Posted: Friday 24 July 2020 22:55
by Pascal1978
I don't know if i'm posting it on the right place here, but i want to control my RGBW2 Shelly device with automatic color change.
i want to setup a sunrise color which flow over to daylight and at a specifick time to sunset and then to moonlight.
I have tried to set it with dzvents, but i don't know the right codes to set the colors let alone how to set it at different times and how to gradient
i want to use it for my aquarium lights.
can anyone help me out or point me in the right direction
thnx
Posted: Thursday 30 July 2020 20:01
by Gerwin
The Shelly button is that one impemented ???
does someone knows that
Gerwin
Posted: Sunday 02 August 2020 8:30
by Gerwin
Pascal1978 wrote: Friday 24 July 2020 22:55
thnx
you can make groups for each collor you want
Posted: Friday 14 August 2020 12:03
by Delfuego
thnx
Hi Pascal,
You can send a switch command directly to you Shelly RGBW2 device using DzVentz:
devices = {'Switch to call this script'},
domoticz.openURL({url = 'http://192.168.0.50/color/0?turn=on&red=255&green=86&blue=112&white=0'})
The gradient effect you have to code yourself I think by sending an updated color to your device every second or so until you reach your desired color.
Also check the following links to Shelly documentation:
https://shelly.cloud/documents/develope ... cation.pdf
https://shelly-api-docs.shelly.cloud/?f ... y-overview
Kind regards,
Luuk
