Python Plugin: Shelly MQTT
josemi
Re: Python Plugin: Shelly MQTT
Does anybody have working long push in a Shelly 2.5 working as roller mode?
I enable debug option in plugin, but only short push is shown. No longpush device is created in domoticz either.
Gerwin
hello ,
thanks a lot for these nice plugin ,
everything is working except the temperature addon for the shelly 1
is there an opportunity that this addon also available coming in this plugin ??
Gerwin
Gerwin
- bewo
- Domoticz version: 2021.1
Individual projects:
Domoticz on a Intel Xeon Server | AeonLabs Z-Wave Gen.5 | RFXCOM RFXtrx433E USB | ESP-Wifi-Modules | Shellys
Wall-mounted 22" Touch Control Display (self construct) | LUA wind monitor| LUA heating control | and many many more :)
Gerwin
@bewo
Gerwin
Gerwin
djac
Trying to update Plugin but get:
"error: Your local changes to the following files would be overwritten by merge:
plugin.py
Please, commit your changes or stash them before you can merge."
Any suggestions?
plugin.py
Any suggestions?
Domoticz on Rpi, Z-wave, Hue with Philips and Ikea bulbs
Geitje
If you Google it, you find some answers, I warns you probably to prevent to overwrite your local changes. You can solve it. Check out for example:
https://stackoverflow.com/questions/157 ... you-can-me
Zwave, Zigate, RFlink etc.
Gerwin
hello
i have seen that the themperature addon is implemented how can i update ?
can someone explain step by step how to do this
i have a lot of shelly's
Gerwin
Gerwin
Gerwin
I know how to doGerwin wrote: Wednesday 25 March 2020 11:59 hello
Gerwin
works great
Gerwin
- fabry91
- Domoticz version: 2022.2
Hello guys,
I'm trying to get it work, I have a Shelly 1 V3, successfully installed and started the Shelly plugin.
Problem is that I cannot make it work the on/off switch from domoticz to the shelly 1 relay, I'm attaching the configuration of tasmota flashed firmware on my shelly 1 and the logs result when I tried to switch on the mqtt switch created itself by domoticz.
Thank you in advance and stay safe
- mqtt_shelly.jpg (60.48 KiB) Viewed 4523 times
- domoticz_logs.jpg (93.78 KiB) Viewed 4523 times
besix
Hello
The Shelly plugin requires the original soft Shelly.
If you have Tasmota, this is only the mqtt broker but without the Shelly plugin
- fabry91
Thank you very much besix, I didn't understood that It was only for the stock shelly firmware.besix wrote: Monday 30 March 2020 19:41 Hello
I have now successfully started the MQTT Client Gateway and I am now controlling the shelly1 relay!
Thanks!!!
Derik
- Domoticz version: BETA
I now strange only i ask this here..
Is there perhaps some one that have shelly with Domoticz working without a plugin?
It looks to me that shely and Domotiz talk mqtt, this must be possible without a plugin?
Just a nodered or something?
for 1 shely a plugin, that's the point
- LouiS22
Just below this post at python's topicDerik wrote: Sunday 10 May 2020 10:18 I now strange only i ask this here..
viewtopic.php?f=65&t=32616
mattley30
Hi Guys,
I'm trying a scelly 1 with the additional external temperature sensor. inside the shelly1 I regularly display the temperature of 25.8 ° while on Domoticz the component created "LaCrosse TX3" with a value of "0". but I see that the update comes every minute.
Yet doing a dubug the message mqtt arrives.
2020-07-02 20: 05: 44.499 (Shelly Actuators) MQTT message: shellies / shelly1-8CAAB505BBAC / ext_temperature / 0: 25.88
2020-07-02 20: 05: 44.509 (Shelly Actuators) MQTT message: shellies / shelly1-8CAAB505BBAC / ext_temperature_f / 0: 78.58
do you know what it could be?
Mattely30
Mattely30
mattley30
Hello again
problem returned I realized that there was a shelly1 firmware update to do, once updated the temperature sensor data arrived, sorry.
Mattley30
Mattley30
niekbruggeman
I can confirm that the new shelly dimmer 2 works correct with Domoticz.
I use the native firmware of the Shelly, and the Shelly MQTT plugin for Domoticz 2020.2.
Pascal1978
- Domoticz version: 2020.2
I don't know if i'm posting it on the right place here, but i want to control my RGBW2 Shelly device with automatic color change.
i want to setup a sunrise color which flow over to daylight and at a specifick time to sunset and then to moonlight.
I have tried to set it with dzvents, but i don't know the right codes to set the colors let alone how to set it at different times and how to gradient
i want to use it for my aquarium lights.
can anyone help me out or point me in the right direction
thnx
thnx
Gerwin
The Shelly button is that one impemented ???
does someone knows that
Gerwin
Gerwin
Gerwin
you can make groups for each collor you wantPascal1978 wrote: Friday 24 July 2020 22:55 Hello,
thnx
- group1.gif (148.92 KiB) Viewed 4097 times
Delfuego
Hi Pascal,Pascal1978 wrote: Friday 24 July 2020 22:55 Hello,
thnx
You can send a switch command directly to you Shelly RGBW2 device using DzVentz:
devices = {'Switch to call this script'},
domoticz.openURL({url = 'http://192.168.0.50/color/0?turn=on&red=255&green=86&blue=112&white=0'})
}Also check the following links to Shelly documentation:
https://shelly.cloud/documents/develope ... cation.pdf
https://shelly-api-docs.shelly.cloud/?f ... y-overview
Kind regards,
Luuk
