Page 11 of 19
Re: [REQUEST] Plugin for Tuya
Posted: Monday 15 April 2019 19:01
by merlot
The point is that if I use packet capture with its app I can see the packets that I guess are the ones expected
"result": {
"devId": "51817282840d8e5f63cd",
"dpMaxTime": 1555161839644,
"virtual": false,
"productId": "0fHWRe8ULjtmnBNd",
"dps": {
"22": 626,
"23": 30727,
"1": true,
"24": 17543,
"25": 1190,
"26": 0,
"17": 5,
"18": 0,
"19": 0,
"9": 0,
"20": 0,
"21": 1
"activeTime": 1555161828,
"ip": "89.141.147.40",
"lon": "",
"moduleMap": {
"wifi": {
"upgradeStatus": 3,
"bv": "5.42",
"cdv": "1.0.0",
"pv": "2.2",
"verSw": "1.0.7",
"isOnline": true,
"id": 8256355,
"cadv": ""
"mcu": {
"upgradeStatus": 0,
"cdv": "",
"verSw": "1.0.7",
"isOnline": true,
"id": 8256356,
"cadv": ""
"uuid": "51817282840d8e5f63cd",
"mac": "84:0d:8e:5f:63:cd",
"devAttribute": 3,
"name": "Smart Socket-10A",
"isShare": false,
"timezoneId": "Europe/Madrid",
"iconUrl": "https://images.tuyaeu.com/smart/icon/15324342875tjvmpp9uw8_0.png",
"lat": "",
"runtimeEnv": "prod",
"localKey": "1a9ae1ca27591e4a"
"t": 1555161843633,
"success": true,
"status": "ok"
Is this packet as expected?
Thank you again
Enviado desde mi Redmi Note 4 mediante Tapatalk
Posted: Monday 15 April 2019 19:49
by sincze
That look excellent indeed. But with the provided py script for testing it is not working?? Right?
Posted: Monday 15 April 2019 19:58
by merlot
sincze wrote:That look excellent indeed. But with the provided py script for testing it is not working?? Right?
Yes, it's not working.
I'm using the IP, device ID and localkey you can see in the packet shown.
Have you got any suggestion?
Thank's a lot
Posted: Saturday 20 April 2019 12:43
by merlot
Following my research to try to find out why it's not working in my device, I have activated the Debug=1 and uncommented the Degug level setting in pytuya script.
And I don't understand this difference.
From the Packet Capture of the Smart Life the POST packet payload is:
"postData" = "{"devId":"51817282840d8e5f63cd"}"
However in the debug output of get_dps_py, I can see
DEBUG:pytuya:json_payload=b'{"devId":"51817282840d8e5f63cd","gwId":"51817282840d8e5f63cd"}'
Moreover, the POST in the packet capture seems to be using the URL api.json with several options
[truncated]POST /api.json?appVersion=3.9.1&appRnVersion=5.12&channel=oem&sign=252e265bb7106e66e692cf4766287707d906c691ebe5a971edc62acd4dc1a933&deviceId=bdc1041d291a540b18114de6f5acd3dcb0580c0a6881&platform=Redmi%20Note%204&sid=eu155509I38
But I'm not able to see which URL is using pytuya.
Finally, is the localkey not requiered in the get_dps.py?
Thank you very much
Posted: Saturday 20 April 2019 15:38
by sincze
merlot wrote: Saturday 20 April 2019 12:43
Thank you very much
To discover the url use the app via a fiddler proxy
Posted: Monday 06 May 2019 17:34
by mirmil99
Hello
unfortunately, but Neo DS01W (door/window sensor) does not work;( , no changes in the virtual switch... Of course, everything is properly installed.
2019-05-06 16:50:45.221 Status: (Door_1) Started.
2019-05-06 16:50:45.630 Status: (Door_1) Entering work loop.
2019-05-06 16:50:45.631 Status: (Door_1) Initialized version 1.0.0, author 'tixi_sincze'
(Door_1) Pushing 'onHeartbeatCallback' on to queue
2019-05-06 17:22:25.756 (Door_1) Processing 'onHeartbeatCallback' message
2019-05-06 17:22:25.756 (Door_1) Calling message handler 'onHeartbeat'.
2019-05-06 17:22:25.757 (Door_1) Pushing 'ConnectDirective' on to queue
2019-05-06 17:22:25.757 (Door_1) Processing 'ConnectDirective' message
2019-05-06 17:22:25.757 (Door_1) Transport set to: 'TCP/IP', 192.168.100.28:6668.
2019-05-06 17:22:25.757 (Door_1) Connect directive received, action initiated successfully.
2019-05-06 17:22:26.638 EventSystem: Event triggered: ..................................
2019-05-06 17:22:28.891 (Door_1) Pushing 'onConnectCallback' on to queue
2019-05-06 17:22:28.891 (Door_1) Pushing 'DisconnectedEvent' on to queue
2019-05-06 17:22:28.914 (Door_1) Processing 'onConnectCallback' message
2019-05-06 17:22:28.914 (Door_1) Calling message handler 'onConnect'.
2019-05-06 17:22:28.915 (Door_1) OnConnect Error Status: 113
2019-05-06 17:22:28.915 (Door_1) Processing 'DisconnectedEvent' message
2019-05-06 17:22:28.915 (Door_1) Disconnect event received for '192.168.100.28:6668'.
2019-05-06 17:22:28.915 (Door_1) Pushing 'onDisconnectCallback' on to queue
2019-05-06 17:22:28.915 (Door_1) Processing 'onDisconnectCallback' message
2019-05-06 17:22:28.915 (Door_1) Calling message handler 'onDisconnect'.
2019-05-06 17:23:28.914 (Door_1) Disconnected from: 192.168.100.28:6668
2019-05-06 17:29:26.205 (Door_1) Connect directive received, action initiated successfully.
2019-05-06 17:29:26.205 (Door_1) Processing 'onDisconnectCallback' message
2019-05-06 17:29:26.205 (Door_1) Calling message handler 'onDisconnect'.
2019-05-06 17:29:26.205 (Door_1) Disconnected from: 192.168.100.28:6668
2019-05-06 17:29:26.207 (Door_1) Pushing 'onConnectCallback' on to queue
2019-05-06 17:29:26.207 (Door_1) Pushing 'DisconnectedEvent' on to queue
2019-05-06 17:29:26.255 (Door_1) Processing 'onConnectCallback' message
2019-05-06 17:29:26.255 (Door_1) Calling message handler 'onConnect'.
2019-05-06 17:29:26.255 (Door_1) OnConnect Error Status: 111
2019-05-06 17:29:26.256 (Door_1) Pushing 'ConnectDirective' on to queue
2019-05-06 17:29:26.256 (Door_1) Processing 'DisconnectedEvent' message
2019-05-06 17:29:26.256 (Door_1) Disconnect event received for '192.168.100.28:6668'.
2019-05-06 17:29:26.256 (Door_1) Pushing 'onDisconnectCallback' on to queue
2019-05-06 17:29:26.256 (Door_1) Processing 'ConnectDirective' message
2019-05-06 17:29:26.256 (Door_1) Transport set to: 'TCP/IP', 192.168.100.28:6668.
2019-05-06 17:29:26.256 (Door_1) Connect directive received, action initiated successfully.
2019-05-06 17:29:26.256 (Door_1) Processing 'onDisconnectCallback' message
2019-05-06 17:29:26.256 (Door_1) Calling message handler 'onDisconnect'.
2019-05-06 17:29:26.256 (Door_1) Disconnected from: 192.168.100.28:6668
2019-05-06 17:29:26.261 (Door_1) Pushing 'onConnectCallback' on to queue
2019-05-06 17:29:26.261 (Door_1) Pushing 'DisconnectedEvent' on to queue
2019-05-06 17:29:26.306 (Door_1) Processing 'onConnectCallback' message
2019-05-06 17:29:26.306 (Door_1) Calling message handler 'onConnect'.
2019-05-06 17:29:26.306 (Door_1) OnConnect Error Status: 111
2019-05-06 17:29:26.306 (Door_1) Pushing 'ConnectDirective' on to queue
2019-05-06 17:29:26.306 (Door_1) Processing 'DisconnectedEvent' message
2019-05-06 17:29:26.306 (Door_1) Disconnect event received for '192.168.100.28:6668'.
2019-05-06 17:29:26.306 (Door_1) Pushing 'onDisconnectCallback' on to queue
2019-05-06 17:29:26.306 (Door_1) Processing 'ConnectDirective' message
2019-05-06 17:29:26.306 (Door_1) Transport set to: 'TCP/IP', 192.168.100.28:6668.
2019-05-06 17:29:26.307 (Door_1) Connect directive received, action initiated successfully.
2019-05-06 17:29:26.307 (Door_1) Processing 'onDisconnectCallback' message
2019-05-06 17:29:26.307 (Door_1) Calling message handler 'onDisconnect'.
2019-05-06 17:29:26.307 (Door_1) Disconnected from: 192.168.100.28:6668
2019-05-06 17:29:26.311 (Door_1) Pushing 'onConnectCallback' on to queue
2019-05-06 17:29:26.311 (Door_1) Pushing 'DisconnectedEvent' on to queue
2019-05-06 17:29:26.357 (Door_1) Processing 'onConnectCallback' message
2019-05-06 17:29:26.357 (Door_1) Calling message handler 'onConnect'.
2019-05-06 17:29:26.357 (Door_1) OnConnect Error Status: 111
2019-05-06 17:29:26.357 (Door_1) Pushing 'ConnectDirective' on to queue
2019-05-06 17:29:26.357 (Door_1) Processing 'DisconnectedEvent' message
2019-05-06 17:29:26.357 (Door_1) Disconnect event received for '192.168.100.28:6668'.
2019-05-06 17:29:26.357 (Door_1) Pushing 'onDisconnectCallback' on to queue
2019-05-06 17:29:26.358 (Door_1) Processing 'ConnectDirective' message
2019-05-06 17:29:26.358 (Door_1) Transport set to: 'TCP/IP', 192.168.100.28:6668.
2019-05-06 17:29:26.358 (Door_1) Connect directive received, action initiated successfully.
2019-05-06 17:29:26.358 (Door_1) Processing 'onDisconnectCallback' message
2019-05-06 17:29:26.358 (Door_1) Calling message handler 'onDisconnect'.
2019-05-06 17:29:26.358 (Door_1) Disconnected from: 192.168.100.28:6668
2019-05-06 17:29:26.361 (Door_1) Pushing 'onConnectCallback' on to queue
2019-05-06 17:29:26.361 (Door_1) Pushing 'DisconnectedEvent' on to queue
2019-05-06 17:29:26.408 (Door_1) Processing 'onConnectCallback' message
2019-05-06 17:29:26.408 (Door_1) Calling message handler 'onConnect'.
2019-05-06 17:29:26.408 (Door_1) OnConnect Error Status: 111
2019-05-06 17:29:26.408 (Door_1) Pushing 'ConnectDirective' on to queue
2019-05-06 17:29:26.408 (Door_1) Processing 'DisconnectedEvent' message
2019-05-06 17:29:26.408 (Door_1) Disconnect event received for '192.168.100.28:6668'.
2019-05-06 17:29:26.408 (Door_1) Pushing 'onDisconnectCallback' on to queue
2019-05-06 17:29:26.408 (Door_1) Processing 'ConnectDirective' message
2019-05-06 17:29:26.408 (Door_1) Transport set to: 'TCP/IP', 192.168.100.28:6668.
2019-05-06 17:29:26.409 (Door_1) Connect directive received, action initiated successfully.
2019-05-06 17:29:26.409 (Door_1) Processing 'onDisconnectCallback' message
2019-05-06 17:29:26.409 (Door_1) Calling message handler 'onDisconnect'.
2019-05-06 17:29:26.409 (Door_1) Disconnected from: 192.168.100.28:6668
2019-05-06 17:29:26.410 (Door_1) Pushing 'onConnectCallback' on to queue
2019-05-06 17:29:26.410 (Door_1) Pushing 'DisconnectedEvent' on to queue
2019-05-06 17:29:26.459 (Door_1) Processing 'onConnectCallback' message
2019-05-06 17:29:26.459 (Door_1) Calling message handler 'onConnect'.
2019-05-06 17:29:26.459 (Door_1) OnConnect Error Status: 111
2019-05-06 17:29:26.459 (Door_1) Pushing 'ConnectDirective' on to queue
2019-05-06 17:29:26.459 (Door_1) Processing 'DisconnectedEvent' message
2019-05-06 17:29:26.459 (Door_1) Disconnect event received for '192.168.100.28:6668'.
2019-05-06 17:29:26.459 (Door_1) Pushing 'onDisconnectCallback' on to queue
2019-05-06 17:29:26.459 (Door_1) Processing 'ConnectDirective' message
2019-05-06 17:29:26.459 (Door_1) Transport set to: 'TCP/IP', 192.168.100.28:6668.
2019-05-06 17:29:26.459 (Door_1) Connect directive received, action initiated successfully.
2019-05-06 17:29:26.459 (Door_1) Processing 'onDisconnectCallback' message
2019-05-06 17:29:26.459 (Door_1) Calling message handler 'onDisconnect'.
2019-05-06 17:29:26.459 (Door_1) Disconnected from: 192.168.100.28:6668
2019-05-06 17:29:26.461 (Door_1) Pushing 'onConnectCallback' on to queue
2019-05-06 17:29:26.461 (Door_1) Pushing 'DisconnectedEvent' on to queue
2019-05-06 17:29:26.509 (Door_1) Processing 'onConnectCallback' message
2019-05-06 17:29:26.510 (Door_1) Calling message handler 'onConnect'.
2019-05-06 17:29:26.510 (Door_1) OnConnect Error Status: 111
2019-05-06 17:29:26.510 (Door_1) Pushing 'ConnectDirective' on to queue
2019-05-06 17:29:26.510 (Door_1) Processing 'DisconnectedEvent' message
2019-05-06 17:29:26.510 (Door_1) Disconnect event received for '192.168.100.28:6668'.
2019-05-06 17:29:26.510 (Door_1) Pushing 'onDisconnectCallback' on to queue
2019-05-06 17:29:26.510 (Door_1) Processing 'ConnectDirective' message
2019-05-06 17:29:26.510 (Door_1) Transport set to: 'TCP/IP', 192.168.100.28:6668.
2019-05-06 17:29:26.510 (Door_1) Connect directive received, action initiated successfully.
2019-05-06 17:29:26.510 (Door_1) Processing 'onDisconnectCallback' message
2019-05-06 17:29:26.510 (Door_1) Calling message handler 'onDisconnect'.
2019-05-06 17:29:26.510 (Door_1) Disconnected from: 192.168.100.28:6668
Posted: Monday 06 May 2019 18:11
by sincze
What is the outcome of getdps.py?
As stated in the readme:
A Domoticz plugin to manage Tuya Smart Plug (single and multi socket device) This is a modified plugin from the original by Tixi, The original plugin only supported an On/Off switch. Now meters for Watt, Voltage, Ampere, kWh (calculated) are also created.
The plugin was not tested with a NEO door window sensor. As it is not a powerplug. But indeed interesting enough Maybe to extend the plugin ( if not ready existing of course)
Posted: Monday 06 May 2019 19:00
by mirmil99
Thank you for your interest...
would be nice;)
getdps.py...
osmc@Malina:~/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin$ ./get_dps.py 192.168.100.28 87532803bcddc295e153
A problem occur please retry...
Posted: Monday 06 May 2019 20:17
by jslegers
mirmil99 wrote: Monday 06 May 2019 19:00
would be nice;)
getdps.py...
Hi I have seen this error also maybe stop domoticz or stop the App on the phone if you are using it. And then try it again.
Posted: Monday 06 May 2019 21:12
by sincze
Tnx @jslegers for the tip
Let's wait and find out what happens.
Posted: Tuesday 07 May 2019 8:59
by mirmil99
the app on the phone was already switched off...
domoticz - stop, and...
Posted: Thursday 16 May 2019 14:57
by wvries
mirmil99 wrote: Tuesday 07 May 2019 8:59
Same problem here...
pi@Domoticz-Server:~/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin $ sudo python3 get_dps.py 192.168.0.50 46268374840d8e953390
Plug State Information:
{'devId': '46268374840d8e953390', 'dps': {'25': 1200, '9': 0, '19': 49, '22': 638, '21': 1, '23': 30205, '20': 2304, '1': True, '24': 17250, '18': 36}}
Plug DPS List:
1
{'devId': '46268374840d8e953390', 'dps': {'1': True, '19': 49, '22': 638, '23': 30205, '24': 17250, '9': 0, '20': 2304, '25': 1200, '18': 36, '21': 1}}
Plug DPS List:
1
{'devId': '46268374840d8e953390', 'dps': {'24': 17250, '20': 2304, '19': 49, '18': 36, '21': 1, '22': 638, '9': 0, '1': True, '23': 30205, '25': 1200}}
Plug DPS List:
1
sometimes I get an answer back, most of the time not.
And, the structure seems also not constant (e.g. the True pops up in different locations sometimes)
Running DZ 4.10710
Switching on / Off works fine, no problem there.
Do get errors in the log
2019-05-16 14:56:01.261 Error: (TSP 1) 'onMessage' failed 'KeyError'.
2019-05-16 14:56:01.261 Error: (TSP 1) ----> Line 531 in '/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/plugin.py', function onMessage
2019-05-16 14:56:01.261 Error: (TSP 1) ----> Line 439 in '/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/plugin.py', function onMessage
EDIT:
Solved the error - make sure the right ID's for voltage etc are in the plugin !!!!!
Posted: Thursday 16 May 2019 21:05
by sincze
wvries wrote:mirmil99 wrote: Tuesday 07 May 2019 8:59
Plug DPS List:
1
Plug DPS List:
1
Plug DPS List:
1
Running DZ 4.10710
EDIT:
Tnx for the update
Sent from my ONEPLUS A6003 using Tapatalk
Posted: Saturday 08 June 2019 17:21
by Tugado
recently I upgraded the firmware of one of my Tuya devices (they are all the same device type) and the plugin stopped recieving data back from the device.
This one works fine:
2019-06-08 17:08:55.047 Processing 'onHeartbeatCallback' message
2019-06-08 17:08:55.047 Calling message handler 'onHeartbeat'.
2019-06-08 17:08:55.050 Pushing 'WriteDirective' on to queue
2019-06-08 17:08:55.050 Processing 'WriteDirective' message
2019-06-08 17:08:55.050 Sending 86 bytes of data
2019-06-08 17:08:55.101 Processing 'ReadEvent' message
2019-06-08 17:08:55.101 Received 156 bytes of data
The plug with the firmware upgraded (before the upgrade it was working perfectly):
2019-06-08 17:30:38.133 Calling message handler 'onConnect'.
2019-06-08 17:30:38.133 Connected successfully to: 192.168.1.148:6668
2019-06-08 17:30:38.135 Pushing 'WriteDirective' on to queue
2019-06-08 17:30:38.135 Processing 'WriteDirective' message
2019-06-08 17:30:38.135 Sending 86 bytes of data
2019-06-08 17:30:58.869 Pushing 'DisconnectedEvent' on to queue
2019-06-08 17:30:58.897 Processing 'DisconnectedEvent' message
2019-06-08 17:30:58.897 Disconnect event received for '192.168.1.148:6668'.
2019-06-08 17:30:58.897 Pushing 'onDisconnectCallback' on to queue
2019-06-08 17:30:58.897 Processing 'onDisconnectCallback' message
2019-06-08 17:30:58.897 Calling message handler 'onDisconnect'.
2019-06-08 17:30:58.897 Disconnected from: 192.168.1.148:6668
2019-06-08 17:30:58.869 Error: : Async Read Exception: 104, Connection reset by peer
I tried with the get_dps.py and returned connection error too.
Is there any chance of get it fixed or a firmware downgrade?
Posted: Sunday 09 June 2019 8:49
by sincze
Thx for reporting and warning not to update the firmware. I don't have these things so honestly don't know. Maybe flashing to Tasmota is also an option? Than it will be MQTT compatible.
Posted: Sunday 09 June 2019 10:05
by LouiS22
sincze wrote: Sunday 09 June 2019 8:49
It's not possible to flash tasmota to any of these tuya based door/PIR sensors, due to a coprocessor that essentially handles everything else besides the connection to tuya servers. There's an ongoing project to resolve this, have a look at here:
https://github.com/brandond/esphome-tuya_pir/
Posted: Sunday 09 June 2019 14:55
by sincze
LouiS22 wrote: Sunday 09 June 2019 10:05
It's not possible to flash tasmota to any of the tuya based sensors, due to a coprocessor that essentially handles everything else besides the connection to tuya servers. There's an ongoing project to resolve this, have a look at here:
Tnx @LouiS22 for the correction.
Posted: Sunday 09 June 2019 15:22
by LouiS22
Shelly developers are currently planning to release a door sensor (that'll also have a coprocessor, but hopefully it'll be easier to integrate into any HA.
Posted: Friday 14 June 2019 18:31
by bwbboot
It looks like the new IOS released tuya/smartlife apps prevent DevID & Local Key extraction. Can someone confirm pls?
Posted: Sunday 16 June 2019 10:51
by merlot
Simw time later ...
I have returned the previous smart plug and I've bought a new one, a double one for 16A.
And I'm having the same problems
So, let's start form the begining.
Is a packet like the one below correct to get the devId and localkey?
Is this a packet that belongs to a tuya device that can be used by this plugin?
Thank you very much indeed
merlot wrote: Monday 15 April 2019 19:01
"result": {
"virtual": false,
"dps": {
"22": 626,
"23": 30727,
"1": true,
"24": 17543,
"25": 1190,
"26": 0,
"17": 5,
"18": 0,
"19": 0,
"9": 0,
"20": 0,
"21": 1
"lon": "",
"moduleMap": {
"wifi": {
"upgradeStatus": 3,
"bv": "5.42",
"cdv": "1.0.0",
"pv": "2.2",
"verSw": "1.0.7",
"isOnline": true,
"id": 8256355,
"cadv": ""
"mcu": {
"upgradeStatus": 0,
"cdv": "",
"verSw": "1.0.7",
"isOnline": true,
"id": 8256356,
"cadv": ""
"devAttribute": 3,
"isShare": false,
"lat": "",
"t": 1555161843633,
"success": true,
"status": "ok"
Thank you again
