[REQUEST] Plugin for Tuya
merlot
Re: [REQUEST] Plugin for Tuya
Post by merlot »
The point is that if I use packet capture with its app I can see the packets that I guess are the ones expected
  "result": {
    "devId": "51817282840d8e5f63cd",
    "dpMaxTime": 1555161839644,
    "virtual": false,
    "productId": "0fHWRe8ULjtmnBNd",
    "dps": {
      "22": 626,
      "23": 30727,
      "1": true,
      "24": 17543,
      "25": 1190,
      "26": 0,
      "17": 5,
      "18": 0,
      "19": 0,
      "9": 0,
      "20": 0,
      "21": 1
    "activeTime": 1555161828,
    "ip": "89.141.147.40",
    "lon": "",
    "moduleMap": {
      "wifi": {
        "upgradeStatus": 3,
        "bv": "5.42",
        "cdv": "1.0.0",
        "pv": "2.2",
        "verSw": "1.0.7",
        "isOnline": true,
        "id": 8256355,
        "cadv": ""
      "mcu": {
        "upgradeStatus": 0,
        "cdv": "",
        "verSw": "1.0.7",
        "isOnline": true,
        "id": 8256356,
        "cadv": ""
    "uuid": "51817282840d8e5f63cd",
    "mac": "84:0d:8e:5f:63:cd",
    "devAttribute": 3,
    "name": "Smart Socket-10A",
    "isShare": false,
    "timezoneId": "Europe/Madrid",
    "iconUrl": "https://images.tuyaeu.com/smart/icon/15324342875tjvmpp9uw8_0.png",
    "lat": "",
    "runtimeEnv": "prod",
    "localKey": "1a9ae1ca27591e4a"
  "t": 1555161843633,
  "success": true,
  "status": "ok"
Is this packet as expected?
Thank you again
Enviado desde mi Redmi Note 4 mediante Tapatalk
sincze
Domoticz version: 2024.4
Post by sincze »
That look excellent indeed. But with the provided py script for testing it is not working?? Right?
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
merlot
Post by merlot »
sincze wrote:That look excellent indeed. But with the provided py script for testing it is not working?? Right?
Yes, it's not working.
I'm using the IP, device ID and localkey you can see in the packet shown.
Have you got any suggestion?
Thank's a lot
merlot
Post by merlot »
Following my research to try to find out why it's not working in my device, I have activated the Debug=1 and uncommented the Degug level setting in pytuya script.
And I don't understand this difference.
From the Packet Capture of the Smart Life the POST packet payload is:
"postData" = "{"devId":"51817282840d8e5f63cd"}"
However in the debug output of get_dps_py, I can see
DEBUG:pytuya:json_payload=b'{"devId":"51817282840d8e5f63cd","gwId":"51817282840d8e5f63cd"}'
Moreover, the POST in the packet capture seems to be using the URL api.json with several options
[truncated]POST /api.json?appVersion=3.9.1&appRnVersion=5.12&channel=oem&sign=252e265bb7106e66e692cf4766287707d906c691ebe5a971edc62acd4dc1a933&deviceId=bdc1041d291a540b18114de6f5acd3dcb0580c0a6881&platform=Redmi%20Note%204&sid=eu155509I38
But I'm not able to see which URL is using pytuya.
Finally, is the localkey not requiered in the get_dps.py?
Thank you very much
sincze
Post by sincze »
merlot wrote: Saturday 20 April 2019 12:43 Hi,
Thank you very much
To discover the url use the app via a fiddler proxy :)
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
mirmil99
Post by mirmil99 »
Hello
unfortunately, but Neo DS01W (door/window sensor) does not work;( , no changes in the virtual switch... Of course, everything is properly installed.
2019-05-06 16:50:45.221 Status: (Door_1) Started.
2019-05-06 16:50:45.630 Status: (Door_1) Entering work loop.
2019-05-06 16:50:45.631 Status: (Door_1) Initialized version 1.0.0, author 'tixi_sincze'
(Door_1) Pushing 'onHeartbeatCallback' on to queue
2019-05-06 17:22:25.756 (Door_1) Processing 'onHeartbeatCallback' message
2019-05-06 17:22:25.756 (Door_1) Calling message handler 'onHeartbeat'.
2019-05-06 17:22:25.757 (Door_1) Pushing 'ConnectDirective' on to queue
2019-05-06 17:22:25.757 (Door_1) Processing 'ConnectDirective' message
2019-05-06 17:22:25.757 (Door_1) Transport set to: 'TCP/IP', 192.168.100.28:6668.
2019-05-06 17:22:25.757 (Door_1) Connect directive received, action initiated successfully.
2019-05-06 17:22:26.638 EventSystem: Event triggered: ..................................
2019-05-06 17:22:28.891 (Door_1) Pushing 'onConnectCallback' on to queue
2019-05-06 17:22:28.891 (Door_1) Pushing 'DisconnectedEvent' on to queue
2019-05-06 17:22:28.914 (Door_1) Processing 'onConnectCallback' message
2019-05-06 17:22:28.914 (Door_1) Calling message handler 'onConnect'.
2019-05-06 17:22:28.915 (Door_1) OnConnect Error Status: 113
2019-05-06 17:22:28.915 (Door_1) Processing 'DisconnectedEvent' message
2019-05-06 17:22:28.915 (Door_1) Disconnect event received for '192.168.100.28:6668'.
2019-05-06 17:22:28.915 (Door_1) Pushing 'onDisconnectCallback' on to queue
2019-05-06 17:22:28.915 (Door_1) Processing 'onDisconnectCallback' message
2019-05-06 17:22:28.915 (Door_1) Calling message handler 'onDisconnect'.
2019-05-06 17:23:28.914 (Door_1) Disconnected from: 192.168.100.28:6668
2019-05-06 17:29:26.205 (Door_1) Connect directive received, action initiated successfully.
2019-05-06 17:29:26.205 (Door_1) Processing 'onDisconnectCallback' message
2019-05-06 17:29:26.205 (Door_1) Calling message handler 'onDisconnect'.
2019-05-06 17:29:26.205 (Door_1) Disconnected from: 192.168.100.28:6668
2019-05-06 17:29:26.207 (Door_1) Pushing 'onConnectCallback' on to queue
2019-05-06 17:29:26.207 (Door_1) Pushing 'DisconnectedEvent' on to queue
2019-05-06 17:29:26.255 (Door_1) Processing 'onConnectCallback' message
2019-05-06 17:29:26.255 (Door_1) Calling message handler 'onConnect'.
2019-05-06 17:29:26.255 (Door_1) OnConnect Error Status: 111
2019-05-06 17:29:26.256 (Door_1) Pushing 'ConnectDirective' on to queue
2019-05-06 17:29:26.256 (Door_1) Processing 'DisconnectedEvent' message
2019-05-06 17:29:26.256 (Door_1) Disconnect event received for '192.168.100.28:6668'.
2019-05-06 17:29:26.256 (Door_1) Pushing 'onDisconnectCallback' on to queue
2019-05-06 17:29:26.256 (Door_1) Processing 'ConnectDirective' message
2019-05-06 17:29:26.256 (Door_1) Transport set to: 'TCP/IP', 192.168.100.28:6668.
2019-05-06 17:29:26.256 (Door_1) Connect directive received, action initiated successfully.
2019-05-06 17:29:26.256 (Door_1) Processing 'onDisconnectCallback' message
2019-05-06 17:29:26.256 (Door_1) Calling message handler 'onDisconnect'.
2019-05-06 17:29:26.256 (Door_1) Disconnected from: 192.168.100.28:6668
2019-05-06 17:29:26.261 (Door_1) Pushing 'onConnectCallback' on to queue
2019-05-06 17:29:26.261 (Door_1) Pushing 'DisconnectedEvent' on to queue
2019-05-06 17:29:26.306 (Door_1) Processing 'onConnectCallback' message
2019-05-06 17:29:26.306 (Door_1) Calling message handler 'onConnect'.
2019-05-06 17:29:26.306 (Door_1) OnConnect Error Status: 111
2019-05-06 17:29:26.306 (Door_1) Pushing 'ConnectDirective' on to queue
2019-05-06 17:29:26.306 (Door_1) Processing 'DisconnectedEvent' message
2019-05-06 17:29:26.306 (Door_1) Disconnect event received for '192.168.100.28:6668'.
2019-05-06 17:29:26.306 (Door_1) Pushing 'onDisconnectCallback' on to queue
2019-05-06 17:29:26.306 (Door_1) Processing 'ConnectDirective' message
2019-05-06 17:29:26.306 (Door_1) Transport set to: 'TCP/IP', 192.168.100.28:6668.
2019-05-06 17:29:26.307 (Door_1) Connect directive received, action initiated successfully.
2019-05-06 17:29:26.307 (Door_1) Processing 'onDisconnectCallback' message
2019-05-06 17:29:26.307 (Door_1) Calling message handler 'onDisconnect'.
2019-05-06 17:29:26.307 (Door_1) Disconnected from: 192.168.100.28:6668
2019-05-06 17:29:26.311 (Door_1) Pushing 'onConnectCallback' on to queue
2019-05-06 17:29:26.311 (Door_1) Pushing 'DisconnectedEvent' on to queue
2019-05-06 17:29:26.357 (Door_1) Processing 'onConnectCallback' message
2019-05-06 17:29:26.357 (Door_1) Calling message handler 'onConnect'.
2019-05-06 17:29:26.357 (Door_1) OnConnect Error Status: 111
2019-05-06 17:29:26.357 (Door_1) Pushing 'ConnectDirective' on to queue
2019-05-06 17:29:26.357 (Door_1) Processing 'DisconnectedEvent' message
2019-05-06 17:29:26.357 (Door_1) Disconnect event received for '192.168.100.28:6668'.
2019-05-06 17:29:26.357 (Door_1) Pushing 'onDisconnectCallback' on to queue
2019-05-06 17:29:26.358 (Door_1) Processing 'ConnectDirective' message
2019-05-06 17:29:26.358 (Door_1) Transport set to: 'TCP/IP', 192.168.100.28:6668.
2019-05-06 17:29:26.358 (Door_1) Connect directive received, action initiated successfully.
2019-05-06 17:29:26.358 (Door_1) Processing 'onDisconnectCallback' message
2019-05-06 17:29:26.358 (Door_1) Calling message handler 'onDisconnect'.
2019-05-06 17:29:26.358 (Door_1) Disconnected from: 192.168.100.28:6668
2019-05-06 17:29:26.361 (Door_1) Pushing 'onConnectCallback' on to queue
2019-05-06 17:29:26.361 (Door_1) Pushing 'DisconnectedEvent' on to queue
2019-05-06 17:29:26.408 (Door_1) Processing 'onConnectCallback' message
2019-05-06 17:29:26.408 (Door_1) Calling message handler 'onConnect'.
2019-05-06 17:29:26.408 (Door_1) OnConnect Error Status: 111
2019-05-06 17:29:26.408 (Door_1) Pushing 'ConnectDirective' on to queue
2019-05-06 17:29:26.408 (Door_1) Processing 'DisconnectedEvent' message
2019-05-06 17:29:26.408 (Door_1) Disconnect event received for '192.168.100.28:6668'.
2019-05-06 17:29:26.408 (Door_1) Pushing 'onDisconnectCallback' on to queue
2019-05-06 17:29:26.408 (Door_1) Processing 'ConnectDirective' message
2019-05-06 17:29:26.408 (Door_1) Transport set to: 'TCP/IP', 192.168.100.28:6668.
2019-05-06 17:29:26.409 (Door_1) Connect directive received, action initiated successfully.
2019-05-06 17:29:26.409 (Door_1) Processing 'onDisconnectCallback' message
2019-05-06 17:29:26.409 (Door_1) Calling message handler 'onDisconnect'.
2019-05-06 17:29:26.409 (Door_1) Disconnected from: 192.168.100.28:6668
2019-05-06 17:29:26.410 (Door_1) Pushing 'onConnectCallback' on to queue
2019-05-06 17:29:26.410 (Door_1) Pushing 'DisconnectedEvent' on to queue
2019-05-06 17:29:26.459 (Door_1) Processing 'onConnectCallback' message
2019-05-06 17:29:26.459 (Door_1) Calling message handler 'onConnect'.
2019-05-06 17:29:26.459 (Door_1) OnConnect Error Status: 111
2019-05-06 17:29:26.459 (Door_1) Pushing 'ConnectDirective' on to queue
2019-05-06 17:29:26.459 (Door_1) Processing 'DisconnectedEvent' message
2019-05-06 17:29:26.459 (Door_1) Disconnect event received for '192.168.100.28:6668'.
2019-05-06 17:29:26.459 (Door_1) Pushing 'onDisconnectCallback' on to queue
2019-05-06 17:29:26.459 (Door_1) Processing 'ConnectDirective' message
2019-05-06 17:29:26.459 (Door_1) Transport set to: 'TCP/IP', 192.168.100.28:6668.
2019-05-06 17:29:26.459 (Door_1) Connect directive received, action initiated successfully.
2019-05-06 17:29:26.459 (Door_1) Processing 'onDisconnectCallback' message
2019-05-06 17:29:26.459 (Door_1) Calling message handler 'onDisconnect'.
2019-05-06 17:29:26.459 (Door_1) Disconnected from: 192.168.100.28:6668
2019-05-06 17:29:26.461 (Door_1) Pushing 'onConnectCallback' on to queue
2019-05-06 17:29:26.461 (Door_1) Pushing 'DisconnectedEvent' on to queue
2019-05-06 17:29:26.509 (Door_1) Processing 'onConnectCallback' message
2019-05-06 17:29:26.510 (Door_1) Calling message handler 'onConnect'.
2019-05-06 17:29:26.510 (Door_1) OnConnect Error Status: 111
2019-05-06 17:29:26.510 (Door_1) Pushing 'ConnectDirective' on to queue
2019-05-06 17:29:26.510 (Door_1) Processing 'DisconnectedEvent' message
2019-05-06 17:29:26.510 (Door_1) Disconnect event received for '192.168.100.28:6668'.
2019-05-06 17:29:26.510 (Door_1) Pushing 'onDisconnectCallback' on to queue
2019-05-06 17:29:26.510 (Door_1) Processing 'ConnectDirective' message
2019-05-06 17:29:26.510 (Door_1) Transport set to: 'TCP/IP', 192.168.100.28:6668.
2019-05-06 17:29:26.510 (Door_1) Connect directive received, action initiated successfully.
2019-05-06 17:29:26.510 (Door_1) Processing 'onDisconnectCallback' message
2019-05-06 17:29:26.510 (Door_1) Calling message handler 'onDisconnect'.
2019-05-06 17:29:26.510 (Door_1) Disconnected from: 192.168.100.28:6668
sincze
Post by sincze »
What is the outcome of getdps.py?
As stated in the readme:
A Domoticz plugin to manage Tuya Smart Plug (single and multi socket device) This is a modified plugin from the original by Tixi, The original plugin only supported an On/Off switch. Now meters for Watt, Voltage, Ampere, kWh (calculated) are also created.
The plugin was not tested with a NEO door window sensor. As it is not a powerplug. But indeed interesting enough Maybe to extend the plugin ( if not ready existing of course) :)
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
mirmil99
Post by mirmil99 »
Thank you for your interest...
would be nice;)
getdps.py...
osmc@Malina:~/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin$ ./get_dps.py 192.168.100.28 87532803bcddc295e153
A problem occur please retry...
jslegers
Domoticz version: 2025.2
Post by jslegers »
mirmil99 wrote: Monday 06 May 2019 19:00 Thank you for your interest...
would be nice;)
getdps.py...
Hi I have seen this error also maybe stop domoticz or stop the App on the phone if you are using it. And then try it again.
sincze
Post by sincze »
Tnx @jslegers for the tip
Let's wait and find out what happens.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
mirmil99
Post by mirmil99 »
the app on the phone was already switched off...
domoticz - stop, and...
wvries
Domoticz version: latest B
Post by wvries »
mirmil99 wrote: Tuesday 07 May 2019 8:59 the app on the phone was already switched off...
Same problem here...
pi@Domoticz-Server:~/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin $ sudo python3 get_dps.py 192.168.0.50 46268374840d8e953390
Plug State Information:
{'devId': '46268374840d8e953390', 'dps': {'25': 1200, '9': 0, '19': 49, '22': 638, '21': 1, '23': 30205, '20': 2304, '1': True, '24': 17250, '18': 36}}
Plug DPS List:
1
{'devId': '46268374840d8e953390', 'dps': {'1': True, '19': 49, '22': 638, '23': 30205, '24': 17250, '9': 0, '20': 2304, '25': 1200, '18': 36, '21': 1}}
Plug DPS List:
1
{'devId': '46268374840d8e953390', 'dps': {'24': 17250, '20': 2304, '19': 49, '18': 36, '21': 1, '22': 638, '9': 0, '1': True, '23': 30205, '25': 1200}}
Plug DPS List:
1
sometimes I get an answer back, most of the time not.
And, the structure seems also not constant (e.g. the True pops up in different locations sometimes)
Running DZ 4.10710
Switching on / Off works fine, no problem there.
Do get errors in the log
2019-05-16 14:56:01.261 Error: (TSP 1) 'onMessage' failed 'KeyError'.
2019-05-16 14:56:01.261 Error: (TSP 1) ----> Line 531 in '/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/plugin.py', function onMessage
2019-05-16 14:56:01.261 Error: (TSP 1) ----> Line 439 in '/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/plugin.py', function onMessage
EDIT:
Solved the error - make sure the right ID's for voltage etc are in the plugin !!!!!
sincze
Post by sincze »
Plug DPS List:
1
Plug DPS List:
1
Plug DPS List:
1
Running DZ 4.10710
EDIT:
Tnx for the update
Sent from my ONEPLUS A6003 using Tapatalk
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Tugado
Domoticz version: 4.10717
Post by Tugado »
recently I upgraded the firmware of one of my Tuya devices (they are all the same device type) and the plugin stopped recieving data back from the device.
This one works fine:
2019-06-08 17:08:55.047  Processing 'onHeartbeatCallback' message
2019-06-08 17:08:55.047  Calling message handler 'onHeartbeat'.
2019-06-08 17:08:55.050  Pushing 'WriteDirective' on to queue
2019-06-08 17:08:55.050  Processing 'WriteDirective' message
2019-06-08 17:08:55.050  Sending 86 bytes of data
2019-06-08 17:08:55.101  Processing 'ReadEvent' message
2019-06-08 17:08:55.101  Received 156 bytes of data
The plug with the firmware upgraded (before the upgrade it was working perfectly):
2019-06-08 17:30:38.133  Calling message handler 'onConnect'.
2019-06-08 17:30:38.133  Connected successfully to: 192.168.1.148:6668
2019-06-08 17:30:38.135  Pushing 'WriteDirective' on to queue
2019-06-08 17:30:38.135  Processing 'WriteDirective' message
2019-06-08 17:30:38.135  Sending 86 bytes of data
2019-06-08 17:30:58.869  Pushing 'DisconnectedEvent' on to queue
2019-06-08 17:30:58.897  Processing 'DisconnectedEvent' message
2019-06-08 17:30:58.897  Disconnect event received for '192.168.1.148:6668'.
2019-06-08 17:30:58.897  Pushing 'onDisconnectCallback' on to queue
2019-06-08 17:30:58.897  Processing 'onDisconnectCallback' message
2019-06-08 17:30:58.897  Calling message handler 'onDisconnect'.
2019-06-08 17:30:58.897  Disconnected from: 192.168.1.148:6668
2019-06-08 17:30:58.869 Error: : Async Read Exception: 104, Connection reset by peer
I tried with the get_dps.py and returned connection error too.
Is there any chance of get it fixed or a firmware downgrade?
sincze
Post by sincze »
Thx for reporting and warning not to update the firmware. I don't have these things so honestly don't know. Maybe flashing to Tasmota is also an option? Than it will be MQTT compatible.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
LouiS22
Post by LouiS22 »
sincze wrote: Sunday 09 June 2019 8:49 Thx for reporting and warning not to update the firmware. I don't have these things so honestly don't know. Maybe flashing to Tasmota is also an option? Than it will be MQTT compatible.
It's not possible to flash tasmota to any of these tuya based door/PIR sensors, due to a coprocessor that essentially handles everything else besides the connection to tuya servers. There's an ongoing project to resolve this, have a look at here: https://github.com/brandond/esphome-tuya_pir/
sincze
Post by sincze »
LouiS22 wrote: Sunday 09 June 2019 10:05
It's not possible to flash tasmota to any of the tuya based sensors, due to a coprocessor that essentially handles everything else besides the connection to tuya servers. There's an ongoing project to resolve this, have a look at here: https://github.com/brandond/esphome-tuya_pir/
Tnx @LouiS22 for the correction.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
LouiS22
Post by LouiS22 »
Shelly developers are currently planning to release a door sensor (that'll also have a coprocessor, but hopefully it'll be easier to integrate into any HA.
bwbboot
Domoticz version: Latest
Post by bwbboot »
It looks like the new IOS released tuya/smartlife apps prevent DevID & Local Key extraction. Can someone confirm pls?
merlot
Post by merlot »
Simw time later ...
I have returned the previous smart plug and I've bought a new one, a double one for 16A.
And I'm having the same problems :(
So, let's start form the begining.
Is a packet like the one below correct to get the devId and localkey?
Is this a packet that belongs to a tuya device that can be used by this plugin?
Thank you very much indeed
merlot wrote: Monday 15 April 2019 19:01 The point is that if I use packet capture with its app I can see the packets that I guess are the ones expected
  "result": {
    "virtual": false,
    "dps": {
      "22": 626,
      "23": 30727,
      "1": true,
      "24": 17543,
      "25": 1190,
      "26": 0,
      "17": 5,
      "18": 0,
      "19": 0,
      "9": 0,
      "20": 0,
      "21": 1
    "lon": "",
    "moduleMap": {
      "wifi": {
        "upgradeStatus": 3,
        "bv": "5.42",
        "cdv": "1.0.0",
        "pv": "2.2",
        "verSw": "1.0.7",
        "isOnline": true,
        "id": 8256355,
        "cadv": ""
      "mcu": {
        "upgradeStatus": 0,
        "cdv": "",
        "verSw": "1.0.7",
        "isOnline": true,
        "id": 8256356,
        "cadv": ""
    "devAttribute": 3,
    "isShare": false,
    "lat": "",
  "t": 1555161843633,
  "success": true,
  "status": "ok"
Thank you again
