Python plugin: Xiaomi Mi Robot Vacuum Topic is solved
dagasoft
Re: Python plugin: Xiaomi Mi Robot Vacuum
Post by dagasoft »
axel2906 wrote:]
i make sh file for each room. I take the coordinates from FloleVac (android app). this app do the same as the offical app but when you do clean zone, select the zone that you clean and then long press on cleanup he make a copy of the coordinates into the clipboard. I do it for each room.
Great!!!
I didn't know about that android app. I will check it out.
Lots of thanks Axel!!
axel2906
Domoticz version: V3.8926
Post by axel2906 »
dagasoft wrote: Sunday 13 January 2019 13:59
axel2906 wrote:]
Great!!!
You're welcome ! :D ;)
Now i can ask to my google home : "hey google ! clean the kitchen !" or "hey google ! clean the bedroom"
RPi3 - RfxComm - Milight - OWL160
dagasoft
Post by dagasoft »
dagasoft wrote:
axel2906 wrote:]
Great!!!
Yes!!
That's what I want to do... By the way, are you using scenes for the voice commands?
I ask because I have to pass it through Controlicz and for Google to understand "Clean the kitchen" I suppose that you need an scene with that name. Am I right?
axel2906
Post by axel2906 »
dagasoft wrote: Sunday 13 January 2019 15:24
dagasoft wrote:
axel2906 wrote:]
Great!!!
Yes!!
i use IFTTT for it. I will try it with controlicz. I suppose that you need an scene to do it
axel2906
Post by axel2906 »
axel2906 wrote: Sunday 13 January 2019 16:36
dagasoft wrote:
Great!!!
Yes!!
i doesn't find a way to excute an selector switch with controlicz. i use it only for simple request (temperature or other things like this). I prefer to use IFTTT to do this stuff (for the vacuum)
dagasoft
Post by dagasoft »
dagasoft wrote: Sunday 13 January 2019 15:24 Yes!!
I use a virtual switch to enable/disable vacuum and use a lua script to trigger level this way:
-- Possible state's of Robot Vacuum:  Charging / Paused / Cleaning / Waiting / Back to home / Sleeping
-- Selector witch Robot Vacuum:       Clean(10) / Home(20) / Spot(30) / Pauze(40) / Stop(50) / Find(60)
-- Required to convert State to Stringvalue
if (devicechanged['Aspiradora - Estado']) then
	EstadoAspiradora = tostring(otherdevices_svalues['Aspiradora - Estado'])
	if (EstadoAspiradora == 'Cleaning' and otherdevices['Aspiradora']=='Off') then
		commandArray['Aspiradora'] = 'On'
	else if (EstadoAspiradora == 'Charging' and otherdevices['Aspiradora']=='On') then
		commandArray['Aspiradora'] = 'Off'
else if (devicechanged['Aspiradora']) then
	if otherdevices['Aspiradora'] == 'On' then
		commandArray['Aspiradora - Control'] = 'Set Level 10'
	else if otherdevices['Aspiradora'] == 'Off' then
		commandArray['Aspiradora - Control'] = 'Set Level 20' end
dagasoft
Post by dagasoft »
Edited previous post to add the correct lua script for trigger Vacuum with a virtual switch so you can use it with Google Assistant an Controlicz
Lebo2d9
Domoticz version: L stab
Post by Lebo2d9 »
Is there someone who have python code to move the vacuum cleaner?
The docking station is hidden under a cupboard and I want, when the 1st time my geofence has detected somebody at home, that the vacuum cleaner is moving to the middle of the room and then I do a "find" just to notify to clean the bin
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
dagasoft
Post by dagasoft »
Lebo2d9 wrote:Hi,
I'm using python-miio as Axel said in a previous post. You can use goto command to clean the dust bin. That's the way I use so it doesn't lose house mapping.
You can see more info about commands in https://python-miio.readthedocs.io/en/l ... acuum.html
Lebo2d9
Post by Lebo2d9 »
dagasoft wrote:I'm using python-miio as Axel said in a previous post. You can use goto command to clean the dust bin. That's the way I use so it doesn't lose house mapping.
Hi dagasoft, I have installed the python-miio but I can't launch the mirobot
I get this error
pi@raspberrypi:~ $ mirobo discover
-bash: mirobo: command not found
Kind regards
More to come
Lebo2d9
Post by Lebo2d9 »
Lebo2d9 wrote: Tuesday 22 January 2019 5:43
I get this error
Kind regards
Hi the problem is related to the $PATH, in the folder ~/.local/bin I'me able to run the mirobo command
My $PATH is "/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games"
Kind Regards
More to come
rood
Post by rood »
I am trying for quite a long time to get the plugin to work.
when I execute: mirobo --ip 192.168.2.15 --token 4242xxxxxxxxx start[/i] it works perfectly.
when I start a clean-up in domoticz nothing happens. It looks like if no connection could be made.
in the error logs I see this:
2019-01-27 00:50:49.123 (Stofzuiger) 82 a9 65 78 63 65 70 74 69 6f 6e b6 70 79 74 68 6f 6e 2d 6d ��exception�python-m
2019-01-27 00:50:49.123 (Stofzuiger) 69 69 6f 3a 20 64 65 76 69 63 65 5f 69 64 a3 63 6d 64 a6 73 iio:.device_id�cmd�s
2019-01-27 00:50:49.123 (Stofzuiger) 74 61 74 75 73 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. tatus
2019-01-27 00:50:49.123 (Stofzuiger) Pushing 'onMessageCallback' on to queue
2019-01-27 00:50:49.123 (Stofzuiger) Processing 'onMessageCallback' message
2019-01-27 00:50:49.123 (Stofzuiger) Calling message handler 'onMessage'.
2019-01-27 00:50:49.123 (Stofzuiger) Got: {'exception': 'python-miio: device_id', 'cmd': 'status'}
but it doens't say anything to me. Anyone an idea?
Lebo2d9
Post by Lebo2d9 »
rood wrote:I am trying for quite a long time to get the plugin to work.
Have you added the ipadress and the token of your robot in the miio_server.sh file?
Kind regards Koen
More to come
rood
Post by rood »
Yes I have. After couple of hours of fighting, decided to completly reinstall my PI. It works now!
BUSHA
Domoticz version: 3.8367
Post by BUSHA »
deennoo wrote: Monday 02 October 2017 18:36
kluczus wrote: Monday 02 October 2017 17:09
kluczus wrote: Friday 29 September 2017 13:41 How to check a status of the vacuum ? I installed plugin, everything works just fine. I was trying to define a blockly with notification when vacuum is comming back to home but without luck.
Blocky
if vacuum-status = "Back to home" then ....
is not working
Anyone ?
That just a basic LUA event on a selector switch, nothing hard on this, all is explain on the wiki, and your question isn't Xiaomi Vaccum robot specific
Your best reading is : https://www.domoticz.com/wiki/Events
It's not a selector. I can't find way to send notifications too :(
BUSHA
Post by BUSHA »
RESOLVED.
LUA code for telegram notifications:
token = "YOUR_TELEGRAM_TOKEN"
chatid = CHAT_ID
cleaning = '🧹Уборка начата'
charge = '✅ Уборка завершена. Пылесос вернулся на базу и заряжается'
waiting = '❗Пылесос не смог вернуться на базу'
problem = '❗️У пылесоса проблемы'
status_vacuum = otherdevices_svalues["Mi Robot - Status"]
if ((devicechanged['Mi Robot - Status'])) then
if ((status_vacuum == "Cleaning")) then
    os.execute('curl --data chat_id='..chatid..' --data-urlencode "text='..cleaning..'"  "https://api.telegram.org/bot'..token..'/sendMessage" ')
elseif ((status_vacuum == "Waiting")) then
    os.execute('curl --data chat_id='..chatid..' --data-urlencode "text='..waiting..'"  "https://api.telegram.org/bot'..token..'/sendMessage" ')
elseif ((status_vacuum == "Charging")) then
    os.execute('curl --data chat_id='..chatid..' --data-urlencode "text='..charge..'"  "https://api.telegram.org/bot'..token..'/sendMessage" ')
elseif ((status_vacuum == "In Error")) then
    os.execute('curl --data chat_id='..chatid..' --data-urlencode "text='..problem..'"  "https://api.telegram.org/bot'..token..'/sendMessage" ')
Do not forget to change "Mi Robot - Status" to your status device name.
Darkneo
Post by Darkneo »
Hi there,
I just installed the plugin (hoping that other issues I already solved with python will handle potential issues for this plugin)... Unfortunately it did not... :cry:
I raised an issue on Git for that topic but if someone can help.
Domoticz 4.97
Installed on Synology
After creating the harware, I am having those errors:
2019-03-07 23:22:35.160 Error: (xiaomi-mi-robot-vacuum) failed to load 'plugin.py', Python Path used was '/usr/local/domoticz/var/plugins/xiaomi-mirobot/:/volume1/@appstore/py3k/usr/local/lib/python35.zip:/volume1/@appstore/py3k/usr/local/lib/python3.5/:/volume1/@appstore/py3k/usr/local/lib/python3.5/plat-linux:/volume1/@appstore/py3k/usr/local/lib/python3.5/lib-dynload'.
2019-03-07 23:22:35.247 Error: (Vacuum) Module Import failed, exception: 'ImportError'
2019-03-07 23:22:35.247 Error: (Vacuum) Module Import failed: ' Name: msgpack'
2019-03-07 23:22:35.247 Error: (Vacuum) Error Line details not available.
Missing python packages? Which ones?
Thanks for your help :)
bazyl
Post by bazyl »
I stuck with Roborock V2 configuration on OragnePI2 - latest beta Domoticz V4.10602.
I can ping Roborock from OrangePI.
Followed instruction, but during test i get:
1. SSH Connection with miio_server.py
:/home/domoticz/domoticz/plugins/xiaomi-mirobot# ./miio_server.py 192.168.1.18 TOKEN --host 127.0.0.1 --port 22222
server: Starting server on 127.0.0.1 22222
server: connected ('127.0.0.1', 46868)
server: got socket msg: ['status']
Got error when receiving: timed out
Retrying with incremented id, retries left: 3
Retrying with incremented id, retries left: 2
Retrying with incremented id, retries left: 1
server: vac result {'cmd': 'status', 'exception': 'python-miio: '}
server: send reply ('127.0.0.1', 46868)
server: closed connection ('127.0.0.1', 46868)
2. SSH Connection with ./test.py
:/home/domoticz/domoticz/plugins/xiaomi-mirobot# ./test.py
test: python modules path: ././.env/lib/python3.5/site-packages
test: trying connect to 127.0.0.1:22222
test: sent request to server [status]
test: reading response...
test: got server reply {'cmd': 'status', 'exception': 'python-miio: '}
Any ideas? I tried reinstall plugin few times. No other issues during first part of installation.
Nevermind. My token was changed during flashing firmware from International to China version....
With new token it works perfectly fine! Thanks for great plugin!
rensbr
Post by rensbr »
I used this plugin for quite some time now and it works great. Recentely is installed a new Raspberry pi (and did a clean install of Domoticz and all the plugins). But now the plugin does not want to work.
I followed all the steps, but when I tried to test / start the server:
sudo service miio_server start
I get the following error:
Job for miio_server.service failed because the control process exited with error code.
See "systemctl status miio_server.service" and "journalctl -xe" for details.
When I check 'systemctl' the following appears:
● miio_server.service - LSB: MIIO Server
Loaded: loaded (/etc/init.d/miio_server; generated; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2019-04-28 19:39:35 CEST; 34s ago
Docs: man:systemd-sysv-generator(8)
Process: 25776 ExecStart=/etc/init.d/miio_server start (code=exited, status=1/FAILURE)
Apr 28 19:39:35 raspberrypi systemd[1]: Starting LSB: MIIO Server...
Apr 28 19:39:35 raspberrypi miio_server[25776]: File "/etc/init.d/miio_server", line 14
Apr 28 19:39:35 raspberrypi miio_server[25776]: PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin
Apr 28 19:39:35 raspberrypi miio_server[25776]: ^
Apr 28 19:39:35 raspberrypi miio_server[25776]: SyntaxError: invalid syntax
Apr 28 19:39:35 raspberrypi systemd[1]: miio_server.service: Control process exited, code=exited status=1
Apr 28 19:39:35 raspberrypi systemd[1]: Failed to start LSB: MIIO Server.
Apr 28 19:39:35 raspberrypi systemd[1]: miio_server.service: Unit entered failed state.
Apr 28 19:39:35 raspberrypi systemd[1]: miio_server.service: Failed with result 'exit-code'.
There is an SyntaxError in the file, but on a line that I haven't changed.
The miio_server is below:
#!/home/pi/domoticz/plugins/xiaomi-mirobot/.env/bin/python3
### BEGIN INIT INFO
# Author: mrin
# Provides: miio_server
# Required-Start:
# Required-Stop:
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: MIIO Server
# Description: This daemon will start MIIO Server
### END INIT INFO
NAME="MIIO Server"
SCRIPTNAME=/etc/init.d/miio_server
PIDFILE=/var/run/miio_server.pid
DAEMON_USER=root
DAEMON=/home/pi/domoticz/plugins/xiaomi-mirobot/miio_server.py
DAEMON_ARGS="192.168.0.193 364b546f737678505353374d496e3255"
DAEMON_ARGS="$DAEMON_ARGS --host 127.0.0.1 --port 22222"
I have the following versions:
ython3 is already the newest version (3.5.3-1).
python3-dev is already the newest version (3.5.3-1).
python3-pip is already the newest version (9.0.1-2+rpt2).
libffi-dev is already the newest version (3.2.1-6).
libssl-dev is already the newest version (1.1.0j-1~deb9u1).
Plugin: Last version from Github
Domoticz; Stable 4.9700
The strange thing is, when I test the function with:
sudo ./miio_server.py 192.168.0.193 364b546f737678505353374d496e3255 --host 127.0.0.1 --port 22222
It seems to work:
server: connected ('127.0.0.1', 48294)
server: got socket msg: ['consumable_status']
Unable to discover a device at address 192.168.0.193
server: vac result {'cmd': 'consumable_status', 'exception': 'python-miio: Unable to discover the device 192.168.0.193'}
server: send reply ('127.0.0.1', 48294)
server: vac result {'cmd': 'status', 'exception': 'python-miio: Unable to discover the device 192.168.0.193'}
server: vac result {'cmd': 'status', 'clean_area': 1.64, 'state_code': 8, 'clean_seconds': 0, 'battery': 100, 'error': None, 'fan_level': 77}
Has anybody an idea what is wrong?
Edit: I have found a workout. I used the script provided in: https://www.domoticz.com/forum/viewtopi ... 29#p183929 and now it works again.
KiiB
Domoticz version: Stable
Blocky, ant mirobot state
Post by KiiB »
Hello Guys,
Maybe anyone tried to insert mi robot " State 12: 'In Error' " in blocky script?
I tried doing so in difrent formants and difrent fields, but none of them works.
Maybe someone had better luck?
I would like to write simple script to try restart cleaning again (at least few times) if error apear, and if battery is above 25% and also send push up messege to my phone.
pick up field do not work because "In error" have same state as "charging" or "paused". Thoose all statuses in domoticz are shown as state 0.
Value is shown as "0/In Error" but cant get it working with that syntax.
Thank You :)
