Page 2 of 2
Re: Idiots guide to Raspberry Pi Installation
Posted: Sunday 03 January 2016 0:26
by TheBod
By the way, how do I load the Domoticz screen on the Pi rather than through the pc?
Posted: Sunday 03 January 2016 0:56
by Westcott
jvdz wrote:Westcott wrote:
Thanks, but that also only has Windows setup files.
Just follow the Wiki i linked in one of the previous posts, which also has the info for the RPI image.
Jos
Thanks Jos.
Are you saying that
domoticz-raspberrypi-sdcard-3530.7z 2015-11-01 248.6 MB
is the one to use?
Posted: Sunday 03 January 2016 1:00
by TheBod
That is the one that I used. The image file is 2,078,277,632 bytes
Posted: Sunday 03 January 2016 1:05
by TheBod
Extract the zip file and there is a file in there called "domoticz-raspberrypi-sdcard-3530.img". This is what you need to copy to the SD Card
Posted: Sunday 03 January 2016 1:24
by Westcott
Thanks all!
Bit of a steep learning curve there, I'd never seen a .7z file before.
It's now written to the sd card, which got renamed 'Boot' by Win23DiskImager.
Where did most of the 2Gb image go, I can only see a few Mb-sized files on the sd?
Posted: Sunday 03 January 2016 10:20
by jvdz
TheBod wrote:By the way, how do I load the Domoticz screen on the Pi rather than through the pc?
I am using the RPI just as the server without any GUI type interface.
I connect to the CLI using Putty and am using SAMBA to access the data on the RPI with my Windows computer to allow for easy access to config files.
Jos
Posted: Sunday 03 January 2016 19:44
by NietGiftig
To a second partition (Linux format) on your card that you windows computer cannot see
Posted: Sunday 03 January 2016 22:53
by Micrit431
Checkout my blog about creating a simple zwave home automation network on the PI
www.ComputerTrail.net
Sent from my SM-T530 using Tapatalk
