Page 2 of 2
Re: Let’s Encrypt HTTPS certificates
Posted: Tuesday 12 January 2016 9:27
by rverbruggen
nayr wrote:ah, I see.. well I dont trust domoticz that much, I'd rather expose nginx as its powering some massive sites and sure to be on top of security.
I dont think you'll get an A+ rating using only the built in HTTPS without modifying the built in webserver code to harden it, I dont see any configuration options for chiper suits or anything.. Going to have to drop all the old weak crypto out of the client options.
Same thing goes for me!
But I hope that I can help making Domoticz better for the more average users in the future (if Domoticz will become an widely used product).
On top of that I think that it will be easier to change it now while there is a lot programming going on and hopefully the changes can be made without to much trouble, then when we have to change it when it is a full blown solution and changes get harder and harder.
Posted: Tuesday 12 January 2016 9:47
by nayr
im all for native https, and it should be the easy option.. but its not the only one, and if you want A+ level security out of it then you may be asking too much.
documentation imo should cover both possibilities, I just saw a pull request for myDomoticz that will finally allow us to run multiple domoticz sites behind a proxy, mixed with other sites all behind a single IP/Port/Certificate..
for example: https://yoursite.com/domoticz/
now you can buy a secure cert for https://yoursite.com, and put something else entirely here, then just proxy /domoticz/ to your domoticz (even using https between proxy and domo if you want)
Posted: Friday 15 January 2016 22:27
by mrcage
I think you should create a server and a client certificate to make the connection to domoticz.
You can easily create a certificate pair by using putty key generator.
Not sure if you can require this by connecting to domoticz though.
Posted: Friday 15 January 2016 22:55
by nayr
mrcage wrote:I think you should create a server and a client certificate to make the connection to domoticz.
Actually you can, I just finished up documentation and getting SSO support committed to the core.. see: viewtopic.php?f=21&t=9799
Its just more of an advanced configuration, I cannot see any easy way to simplify for the masses beyond documenting it well.. would be a huge undertaking to implement a built in key manager correctly and securely.. there is a good reason advanced authentication mechanisms are usually offloaded to external programs.
Posted: Wednesday 13 April 2016 22:19
by MarcelMAH
Let's encrypt is now out of beta... I would really like Domoticz to support this native (even on Windows).
Posted: Tuesday 21 June 2016 22:20
by irrbloss
bizziebis wrote:I'm going to try it later today. You need a client to generate the certificate from your system. You don't create it from their website as far as I know.
It will at least save me from importing certificates to every device to ge domoticz secure :)
edit: Got it up and running, not so difficult ;)
I followed this website: https://coolaj86.com/articles/lets-encr ... pberry-pi/
Then I created the server_cert.pem with the following content:
-privkey.pem
-cert.pem
-chain.pem
Where did you put those files?
Posted: Tuesday 10 January 2017 17:29
by Calzor Suzay
With this method are you able to setup public and private keys for devices (such as iPhone, PC etc.)?
Or is NGINX the preferred method for this, it's just that at the NGINX wiki page https://www.domoticz.com/wiki/Secure_Nginx_Proxy_Setup at the top it says "Please note! Domoticz now has native HTTPS / SSL support since Version 2.2563 (June 14th 2015)"
Re: RE: Re: Let’s Encrypt HTTPS certificates
Posted: Thursday 12 January 2017 23:02
by jake
Calzor Suzay wrote:With this method are you able to setup public and private keys for devices (such as iPhone, PC etc.)?
I never understood those lines in the Wiki as well. If I use the 443 port and forward that in my router, how much more safe is this, compared to the standard http? What is the actual risk with hacking when I use the login page and the password has sufficient quality, together with the https?
Using the https always gives me a read 'failed update browser cache' on my pc at work.
Posted: Saturday 08 December 2018 10:37
by mrelfire
I am looking for the same wiki for windows but no way to find it , any suggestions please ?
