Page 2 of 2
Re: QUBINO ZMNHJD1 not compatible with Domoticz ?
Posted: Sunday 27 December 2015 19:11
by lolomin
Wirby wrote:I had the same issue, so I deleted the node manually. Then I turned off the power of the heater, launched inclusion in Domoticz and turned the power on to benefit from the auto-include mode. After that, exclusion worked.
Ok, will try this, I've just plugged electrically the second and third module on others heaters but no way : same problem as for the first one, node included successfully but then marked as dead ...
Thanks.
Laurent
Posted: Sunday 27 December 2015 19:34
by lolomin
Ok, so I've just done the above procedure provided by Wirby and can confirm that this resolves my problem of dead node for my first module, so maybe it should advised to do an auto inclusion rather than a manual one with this module.
With auto inclusion, I can confirm that there are 4 detected devices all with "On, Level 255%" type under devices in domoticz tab with IDs going from 00 to 03.
Which one is the good dimmer that control the 6 states (I would bet on the ID01) ? and which 3 ones are the one that are the switch I1/I2/I3 (not cabled on my case) ?
Wirby, could you please check your ID's and tell which one is the real Dimmer which control the 6 states of the heater please ? So if another guy is searching for the information, he will be able to find the complete procedure to add the module to domoticz with this thread
Thanks again Wirby for your help and time !
Regards,
Laurent
Posted: Sunday 27 December 2015 19:44
by Wirby
In my system, the dimmer's ID is 0000A01.
Posted: Sunday 27 December 2015 20:35
by lolomin
Wirby wrote:In my system, the dimmer's ID is 0000A01.
Yes I confirm also that ID for dimmer is ending with 01 : exemple 0001701, 0001801, 0001901
Posted: Sunday 27 December 2015 23:16
by lolomin
Another question : are the 3 other devices detected by Domoticz are working for you please ? For me these 3 devices are detected as Dimmer also and if I configure it as On/off switch I have an error to send the command, as a dimmer it seems to be useable but no action/effect seems to occur !?
Posted: Sunday 27 March 2016 12:12
by Emmanuel
I have configured 8 Qubino ZMNHJD1 modules in Domoticz (Raspberry + Aeotec ZStick Gen5) to pilot my heaters.
I added the Qubino ZMNHJD1 configuration in the xml file as described above in this post thread.
I discovered that the "node inclusion" from Domoticz seems to be the best method to add new modules in Domoticz.
Sometimes, the Qubino module was added as "Unknown" in Domoticz, or was added correctly and then could not be reached any more (red icon in the node list under the Stick hardware : communication problem?). I tried to exclude these "failed" modules either from the exclude function in Domoticz or manually with the Zwave stick but it did not always work. So I deleted the devices and nodes directly in Domoticz.
When you add a new node, 4 devices are created in Domoticz. The first one is the dimmer and can be used to create a Switch.
The 3 other devices (sensors) are displayed as "On, Set level: 255%" or "Off". These refer to the input switches (I1, I2 and I3) I believe. I suspect the Qubino default configuration is not always the same, therefore the "On" or "Off" data values.
I created a Switch for each Qubino module (8 switches). I also added a virtual Hardware with three Switches ("ArrĂȘt", "Hors Gel" and "Confort"). I created Event scripts to capture on/off events from the virtual switches. Those scripts set the levels of the real Qubino modules to "5%", "15%" and "70%".
I need to configure also the "Eco", "Confort-1" and "Confort-2" modes.
I added an Everspring ST814 temperature and humidity detector. It works fine. It seems to be in sleep mode. I managed to change the values for "Auto report time", "auto report temperature" and "auto report humidity" but did not understand exactly when those values were actually updated in the detector (as it is displayed in sleep mode in Domoticz).
I will try in the future to create more complex scripts to manage day/night temperature depending on the areas (bedrooms, main rooms...).
Also I would like to link the heater mode to the reported temperature from the Everspring detector.
Emmanuel
