LUA: Summer / Winter from timeofday or other...
sincze
Domoticz version: 2024.4
Re: LUA: Summer / Winter from timeofday or other...
Post by sincze »
The wiki is always available for help :D
https://www.domoticz.com/wiki/User_variables
It has a nice description on how to fill user variables that you can use in domoticz.
And it uses this nice function:
function WhichSeason()
     local tNow = os.date("*t")
     local dayofyear = tNow.yday
     local season
     if (dayofyear >= 79) and (dayofyear < 172) then season = "Spring"
     elseif (dayofyear >= 172) and (dayofyear < 266) then season = "Summer"
     elseif (dayofyear >= 266) and (dayofyear < 355) then season = "Autumn"
     else season = "Winter"
     return season
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Derik
Post by Derik »
jvdz wrote:
Derik wrote:The option from Jos, is without any hard to get stuff...... I got him working in a few minutes....
Without cron is better for my backup...
Did you see my post above your's since we posted around the same time?
Jos
Yes i am happy with your code works perfect....
Jan Jansen
Domoticz version: Stable
Post by Jan Jansen »
Today I made ​​a beginning with user variables and LUA.
Knipsel 1.PNG (73.06 KiB) Viewed 5101 times
I would like to connect a switch to the user variable dark but I did not succeed, using blockly.
Knipsel 2.PNG (21.07 KiB) Viewed 5101 times
I hope somebody can help.
I can not write LUA programs, I only use blockly. But today, and foor the first time, I managed to copy a program from the WIKI into Domoticz.
Thanks in advance.
Martijn85
Post by Martijn85 »
Thanks for the script @jvdz I have changed it a little so there`s only one selector switch.
This is the (changed) LUA script:
-- script_time_season.lua
-- The change of state is a fixed date:
-- Lente: 21 maart t/m 20 juni
-- Zomer: 21 juni t/m 20 september
-- Herfst: 21 september t/m 20 december
-- Winter: 21 december t/m 20 maart
time = os.date("*t")
-- check once a minute for the season to change
if (time.month == 12 and time.day >= 21)
or (time.month == 1)
or (time.month == 2)
or (time.month == 3 and time.day < 21) then
   Seizoen = 'Winter'
elseif (time.month == 3)
or (time.month == 4)
or (time.month == 5)
or (time.month == 6 and time.day < 21) then
   Seizoen = 'Voorjaar'
elseif (time.month == 6)
or (time.month == 7)
or (time.month == 8)
or (time.month == 9 and time.day < 21) then
   Seizoen = 'Zomer'
elseif (time.month == 9)
or (time.month == 10)
or (time.month == 11)
or (time.month == 12 and time.day < 21) then
   Seizoen = 'Herfst'
   print('Something wrong in the season logic :)')
if Seizoen == 'Voorjaar' then
   commandArray['Seizoen'] = 'Set Level: 10'
elseif Seizoen == 'Zomer' then
   commandArray['Seizoen'] = 'Set Level: 20'
elseif Seizoen == 'Herfst' then
   commandArray['Seizoen'] = 'Set Level: 30'
elseif Seizoen == 'Winter' then
   commandArray['Seizoen'] = 'Set Level: 40'
   print('Het seizoen is veranderd, het is nu '..Seizoen)
mikeoo
Post by mikeoo »
Martijn85 wrote:Thanks for the script @jvdz I have changed it a little so there`s only one selector switch.
   Seizoen = 'Winter'
   Seizoen = 'Zomer'
   Seizoen = 'Herfst'
Nice one thanks for the script. Only the Print commands are not working because the IF is always true for 1 of the 4 so it will never gets to the else.
Your seasons picture (switch) is not correct . Lente needs to be Zomer :D
Tweaked your scripts a bit and added colors to the print commands.Only the PRINT command is now logged every minute. Still looking for a way to adjust it to only once.
   Seizoen = 'Winter'
   Seizoen = 'Lente'
   Seizoen = 'Zomer'
   Seizoen = 'Herfst'
   print('<font color="red">Logica van de seizoenen kloppen niet!!!</font>')
if Seizoen == 'Lente' then
   print('<font color="blue">Seizoen aangepast naar Lente</font>')
   print('<font color="blue">Seizoen aangepast naar Zomer</font>')
   print('<font color="blue">Seizoen aangepast naar Herfst</font>')
   print('<font color="blue">Seizoen aangepast naar Winter</font>')
	print('<font color="blue">Geen actie nodig voor het aanpassen van de seizoenen</font>')
Martijn85
Post by Martijn85 »
Thanks for the update/tweak!
mikeoo wrote:Only the PRINT command is now logged every minute. Still looking for a way to adjust it to only once.
That would be nice indeed! For now i have added this:
-- check every 720 minutes for the season to change
if((time.min % 720)==0) then
Now it's running every 12 hours, not every minute.
The complete script:
   Seizoen = 'Winter'
   Seizoen = 'Lente'
   Seizoen = 'Zomer'
   Seizoen = 'Herfst'
mlamie
Domoticz version: 3.5877
Post by mlamie »
Thanks for the nice lua script. Now I have to find a good use case ;)
Raspberry Pi 3, RaZberry, RFXtrx433
Various Z-Wave devices, KlikAanKlikUit devices, ESP8266 NodeMCU, Sonoff POW and a Essent E-thermostaat
IP camera: Dahua 4MP IPC-HDBW4421R-AS, Vivotek FD8134V
Derik
Post by Derik »
mlamie wrote:Thanks for the nice lua script. Now I have to find a good use case ;)
Same switch for other stuff in winter and summer
lights longer or shorter
etc
Jan Jansen
Martijn85 wrote:Thanks for the update/tweak!
   Seizoen = 'Winter'
   Seizoen = 'Lente'
   Seizoen = 'Zomer'
   Seizoen = 'Herfst'
I tried the customized script but the relevant selector is updated every hour . I don't know what's wrong.
jvdz
Domoticz version: 4.107
Post by jvdz »
Jan Jansen wrote: I tried the customized script but the relevant selector is updated every hour . I don't know what's wrong.
Makes sense i think, as the variable time.min will contain a value between 0 and 59 so the below statement is true when it is 0:
if ((time.min % 720) == 0) then
Right?
Jos
Jan Jansen
I only see that it does not work as desired. Lua is still a challenge for me. This certainly applies to the variable time.
jvdz
Post by jvdz »
Without testing I guess that statement should be
if (((time.hour*60+time.min) % 720) == 0) then
Jos
Jan Jansen
@ Jos
Your statement is ok.
zicht
Domoticz version: 2023.1+
Post by zicht »
Jan Jansen wrote:Today I made ​​a beginning with user variables and LUA.
Thanks in advance.
Hi !
Since you do not know lua :
I dont use blocky, but i see you have a string variable ?
Are you i Blockey also using string compaire and not boolean values ?
mixing things can mess things up.
Try using some text like "ok" and "nok" instead of true an false just to test --> but on both so in the user var and in the blocky both the same of course.
niki_lauda
Post by niki_lauda »
   Seizoen = 'Winter'
   Seizoen = 'Lente'
   Seizoen = 'Zomer'
   Seizoen = 'Herfst'
How do I get, in lua, the content 'Seizoen'. One thing what I would like to do is not to set the level to 20 when its already set to 20.
jvdz
Post by jvdz »
Just add an and relation to the If like: (untested)
if Seizoen == 'Lente' and otherdevices['Seizoen'] ~= 10 then
 elseif Seizoen == 'Zomer'  and otherdevices['Seizoen'] ~= 20 then
elseif Seizoen == 'Herfst'  and otherdevices['Seizoen'] ~= 30 then
elseif Seizoen == 'Winter' and otherdevices['Seizoen'] ~= 40  then
Could be that you need to test for otherdevices_svalues['Seizoen'] to get the current value and I can't check that now.
Jos
niki_lauda
jvdz wrote:Just add an and relation to the If like: (untested)
Jos
Tested. Doesn't work.
elseif Seizoen == 'Zomer' and otherdevices['Seizoen'] ~=20  then
   print('<font color="red"> de zomer is begonnen!!!</font>')
swiches every minute 2017-06-26 20:14:06.915 LUA: Open
2017-06-26 20:14:07.292 LUA: de zomer is begonnen!!!
2017-06-26 20:14:07.296 EventSystem: Script event triggered: seizoen
niki_lauda
Found it!
elseif Seizoen == 'Zomer' and otherdevices['Seizoen'] ~= 'Zomer' then
jvdz
Post by jvdz »
Good you sorted it. This is why I mentioned it could also be otherdevices_svalues['Seizoen'] which I believe should be set to the level of the Selector switch. I can't test it to verify at the moment.
Jos
Derik
Post by Derik »
Old topic..
Only....
Dear all..
I will try to hav this script [ seizoenen with 4 dummys ] in the intern lua option from Domoticz..
Only that is not working, with this script
Is there perhaps someone that have this working?
Now i do it with a cron, only need to backup this all.
When i got this into the intern it it is much easier...
Perhaps someone can make this work??
En is there anyone that have a script for all the months of a year?
Like to have every month in domoticz, with some dummy
So i can make my dragon happy
in some months he needs more uvb the others:-)
I did try this with google calendar... only i get that option not working..
