Events system thread (questions and feedback)
CopyCatz
Developer
Re: Events system feedback thread
Post by CopyCatz »
I have just implemented temperature, humidity and barometer values for testing (as of v1.841). A light just came on because the humidity in the room was > 0. :lol:
I have no barometer devices, so if someone could test those..
CopyCatz
Developer
Post by CopyCatz »
Jochen wrote:Hi,
i´m currently playing with the new Eventsystem. Until now everything i tried is working fine!
Realy good job.
But i´m also missing some things.
When I want to send a Notification (Prowl), i want to send the current status, like
Subject: Door is open
Message:
Door: Garden
Type: Open
Time: 12:48:55
My Problem is to include var´s to the strings.
Define Variable.
Blockly has the functions to create own Variables. Can you add this?
Thank you.
Good one, will add that at a later time.
capman
Post by capman »
First of all a big applause for everyone who is in this project for the way it is now :D
Now my problem. I want to use the event system to control my blinds. When the temperature outside is greater then inside my blinds must go down.
I use domoticz latest version with windows os. When I program the blinds via the blocks events: If outside temperature is greater or
equal then temperature in the bedroom do blinds bedroom on (down). So this is working good the blinds go down but the event still working
after the execute. So it still send a on command to my blind as long as the temperature outside is greater than in my bedroom.
So my "coco" asun-650 receiver is still clicking. And with large blinds when they closing and the event send again a on command , they stop , until the event send another on command then they go
further closing. I hope you understand my problem here.
Again a big thank you for a great program.
fafe07
Post by fafe07 »
pierre4fun wrote:Hello,
The event can be saved under chrome: it works fine. in all configs :)
THANKS !
Hello Pierre4fun,
I still can't save the event, can you help on this one?
My configuration is:
Raspbian "Wheezy" + Domoticz
Raspberry PI vB
Rfxtrx
Firefox v22
Are there options to activate in the navigator?
__________________________________________________
Update!
It is OK I resolved my problem!
I could not save because the events were not complete.
Thanks again for your support & work!
Yihaaa
Post by Yihaaa »
Today I have played with the event system and made an event just for testing with 2 lamps.
As it was just a test I deleted the event. But now somehow one of the lamps so every now and than switches on?!
Perhaps this is some kind of bug. Perhaps the event is not quite deleted from the memory of Domoticz?
Jochen
Post by Jochen »
I have found an error...
i tried to make a event that should do this:
1) When open the garage between (22:00 and 07:00) turn on the light in the garage and send an notification.
2) When garagedoor is closed (turn off the light)
PS: To test this, the garagedoor is a Switch-Device and the time is set to between 07:00 and 22:00
In the Log i found this Line after testing:
Error: Sun Jul 14 14:07:02 2013 Lua script error: [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to compare nil with number
EDIT:
When i change the event to this:
There is now error in the log an an Message was send, the light turned on
But Nothing will happend when the garage is closing. No error in the log, no message an the light is still on.
I have not failed 1,000 times.
I have successfully discovered 1000 ways to NOT make a light bulb.
*Thomas Edison*
meinetrashbox
Post by meinetrashbox »
hello
it is not possible to insert a value at the marked spot.
I miss the possibility for countdown timer and on / off delay
greetz
wood
CopyCatz
Developer
Post by CopyCatz »
I'm going to disable having multiple if-then blocks after another. It is too complex for the moment, and I think each event should be saved as a single if-then statement. If you want complex rules use the scripts.
CopyCatz
Developer
Post by CopyCatz »
For issues regarding temperature measurements, deleted events still running:
http://www.domoticz.com/wiki/Events#Usi ... nts_system
Consult the wiki page and check that you are on the version it is implemented/fixed in.
CopyCatz
Developer
Post by CopyCatz »
meinetrashbox wrote:hello
The way you are structuring your logic isn't going to work. Look at jochen's examples, that way it should work, but only with one if/then block.
Jochen
Post by Jochen »
CopyCatz wrote:I'm going to disable having multiple if-then blocks after another. It is too complex for the moment, and I think each event should be saved as a single if-then statement. If you want complex rules use the scripts.
It´s not fine but i can life with it!
I save the single if-then parts with different names and everything works great.
Is there any way to implement a function that fired a command after timeout?
Like:
if(Device == On) {
   timeout(function(){}, 1000);
Another Idea:
What you think about an POST-Message like
if(Device == On) {
   post(URL, PARAMETER);
*Thomas Edison*
CopyCatz
Developer
Post by CopyCatz »
Like:
if(Device == On) {
I was thinking about a delay also but this will be very complex;
Time zero:
If lamp is off set lamp on with delay 10 minutes.
Time one minute: lamp is still off
After 10 minutes the lamp is switched on 10 times... I can implement a delay now but it would have to be less than a minute.
Another Idea:
if(Device == On) {
You can do that with the lua scripts, make a nice example and post it here :) If people are smart enough to want to trigger http api's based on an event they are not the target audience for blockly I think.
Jochen
Post by Jochen »
You are right...
in the next days i will try to develope a litte script what can post data to other api´s.
It could take some time. Currently i´m very busy. When i made this script i will post it.
*Thomas Edison*
Jochen
Post by Jochen »
CopyCatz wrote: I was thinking about a delay also but this will be very complex;
Time zero:
And when this events only triggerd by changing his status? Not every minute?
I think the you can add something like:
Device is switched on -> send Off in 10 Minutes (when device is still on)
*Thomas Edison*
tommit01
Domoticz version: multiple
Post by tommit01 »
Party has started too early...
Last two days event system sent me 490 Mails for deleted rule..
As I still use windows, can you please generate a new windows install file?
834 is currently last one for windows systems.
I will travel to this place tomorrow...
Tommit
1 x RPi3
4 x RPI
3 x RPi2
1 x RPI2 + Win 10 IoT (experimental device)
2 x RPI2 Raspbian "Jessie" + Domoticz (for tenants)
2 x RPI OSMC @ 1GHz
1 RPi Zero W + Cam NOIR
1 RPi Zero W + Cam
RFXtrx 433 FW 1015
RFXtrx 433 E FW 1020
CopyCatz
Developer
Post by CopyCatz »
Sorry, I don't build the windows version..
Anyway, just implemented this:
Use the minutes value only with the int value block as shown. The system determines:
- The device to switch, for instance to "On" and schedules that immediately
- Then finds the opposite action, in this case "Off" and schedules that when the number of minutes have passed.
I have no idea of the weird things you can do with this, so please test :) I guess you can also switch stuff off for a minute.
Sorry for the huge pic, retina screen & too lazy to resize each screenshot.
CopyCatz
Developer
Post by CopyCatz »
Random timer also implemented.
Mike Thrussell
Post by Mike Thrussell »
How do you set dimmer values in Blocky / Lua scripts?
CopyCatz
Developer
Post by CopyCatz »
Mike Thrussell wrote:How do you set dimmer values in Blocky / Lua scripts?
"Set Level x" should work but haven't tested it as I have no dimmers...
Orangina_L
Post by Orangina_L »
Thanks it is very nice !
2 small problems :
- translation don't work for condition, ex : you have to put = "Closed" or "Open" even if the software is in French and normally it is "Fermer" or "Ouvrir" (see attached capture.jpg and Capture2.jpg)
- condition don't worl with Scene (or perhaps I missed something ?) : attachement capture.jpg work and attachement capture 3.jpg don't work.
don't work
don't work
"Fermer" ou Ouvrir"
"Fermer" ou Ouvrir"
Closed or Open
Closed or Open
