Time based Lua script
cjnicholl
- Domoticz version: 2564
Re: Time based Lua script
I'm guessing it's machine based but how many scripts is it possible to have running at any one time?
- stef62376
Actually you should add and (time.hour > 12) to the elseif statement for evening, otherwise it switches to evening again after midnight:
time = os.date("*t")
if (timeofday['Daytime']) and (time.hour < 12) then
commandArray['Variable:Time-Variable']='Morning'
print("Time set to Morning")
elseif (timeofday['Daytime']) and (time.hour >= 12) then
commandArray['Variable:Time-Variable']='Afternoon'
print("Time set to Afternoon")
elseif (timeofday['Nighttime']) and (time.hour < 23) and (time.hour > 12) then
commandArray['Variable:Time-Variable']='Evening'
print("Time set to Evening")
elseif (timeofday['Nighttime']) then
commandArray['Variable:Time-Variable']='Night'
print("Time set to Night")
D'rMorris
Absolutely true, my bad
Danny94
When the variable is allready set to the current time of the day, it does not have to do it, and print a log again every minute.
Maybe add this to each IF?
to
if (timeofday['Daytime']) and (time.hour < 12) thenCode: Select all
if (timeofday['Daytime']) and (time.hour < 12) and uservariables["Time-Variable"] ~= "Morning" then3x Hue Lux, 1x Hue Ambiance, 1x Hue rgbwstrip, 1x Hue Iris, 4x KiKa, KiKa doorbell
Raspberry Pi 3, RFXtrx433 USB
lukbe
- Domoticz version: 3.8153
Hello, is possible write in LUA script which will be executed for example every 30? I know that 1 minute is not problem, howewer i would like do script in lua which will be called every 30 or 20 seconds. Thank you
