Time based Lua script
cjnicholl
Domoticz version: 2564
Re: Time based Lua script
Post by cjnicholl »
I'm guessing it's machine based but how many scripts is it possible to have running at any one time?
stef62376
Post by stef62376 »
Actually you should add and (time.hour > 12) to the elseif statement for evening, otherwise it switches to evening again after midnight:
time = os.date("*t")
if (timeofday['Daytime']) and (time.hour < 12) then
        commandArray['Variable:Time-Variable']='Morning'
        print("Time set to Morning")
elseif (timeofday['Daytime']) and (time.hour >= 12) then
        commandArray['Variable:Time-Variable']='Afternoon'
        print("Time set to Afternoon")
elseif (timeofday['Nighttime']) and (time.hour < 23) and (time.hour > 12) then
        commandArray['Variable:Time-Variable']='Evening'
        print("Time set to Evening")
elseif (timeofday['Nighttime']) then
        commandArray['Variable:Time-Variable']='Night'
        print("Time set to Night")
D'rMorris
Post by D'rMorris »
Absolutely true, my bad :).
Danny94
Post by Danny94 »
When the variable is allready set to the current time of the day, it does not have to do it, and print a log again every minute.
Maybe add this to each IF?
to
if (timeofday['Daytime']) and (time.hour < 12) and uservariables["Time-Variable"] ~= "Morning" then
3x Hue Lux, 1x Hue Ambiance, 1x Hue rgbwstrip, 1x Hue Iris, 4x KiKa, KiKa doorbell
Raspberry Pi 3, RFXtrx433 USB
lukbe
Domoticz version: 3.8153
Post by lukbe »
Hello, is possible write in LUA script which will be executed for example every 30? I know that 1 minute is not problem, howewer i would like do script in lua which will be called every 30 or 20 seconds. Thank you
