Page 2 of 6
Re: #2215 Custom Icons uploader Implemented
Posted: Monday 23 March 2015 19:41
by Bikey
I've just uploaded some icons to Domoticz and followed the instrutions in the Wiki.
Works great except if you follow the Wiki you end up with double listing of the new icons.
You must not do the "Editing icon description file" part.
I already thought that to be redundant because it says to add this line in the file:
<filename without extention>;<iconname in interface>;<icon description>
while that was already also in the icons.txt file that you have to upload together in the ZIP-file with the icons.
Also restarting Domoticz is not necessary.
This all for V2.2326 and higher.
Posted: Friday 27 March 2015 18:07
by Kroontje
I've opened this topic today;
http://www.domoticz.com/forum/viewtopic.php?f=31&t=5904 but is locked because of this topic.
I've running the latest beta version of Domoticz and I'm curious if it's possible, through the web interface, to change the icons off the switch types; dimmers, motion sensors, blinds, etc.. Gizmocuz mentioned in the topic start that it will maybe be possible in the feature, already a date?
Posted: Wednesday 01 April 2015 15:54
by Morcegolas
Hi everybody, this is interesting for me, I'm using some text virtual sensors to know the state of my denon receiver, volume and source, and I want to change the icons of them, is it possible to do this or just to ON/OFF switches?
Posted: Wednesday 01 April 2015 15:57
by Morcegolas
gizmocuz wrote:
Currently only supported for On/Off switches (as it is now), and probably later for other types as well
I think I got the answer :/
Posted: Thursday 16 April 2015 15:46
by Wirehead
I've created this for the LG Hombot V3
Please add to the google drive.
- Hombot48_On.png (4.29 KiB) Viewed 14261 times
Posted: Wednesday 06 May 2015 11:52
by EscApe
I have created a few custom icons. Could you please add these to google drive?
- Switch without signaling colors (like red/green) for switches that do not necessarily say anything about the current state of devices/lights. I use this for wall switches that can trigger a scene or dimmer level.
- WAN status icon for anyone who uses their domoticz setup to monitor the WAN connection on the router
- SMS icon. In my case used for a dummy device that triggers a shell script that sends alerts thru sms (using a 3G dongle en gammu-smsd).
Posted: Wednesday 06 May 2015 13:36
by Derik
EscApe wrote:Hi,
Please send them to
[email protected] [ then i have them in the archive ]
Posted: Thursday 28 May 2015 22:38
by jcjames13009
Here are 2 icons I created for my project: Pump & Robot for the pool.
Just sent by mail to
[email protected] as well to be added to the archive
JC
Posted: Friday 05 June 2015 16:52
by Mati24
This is an icon for Philips Hue :
Posted: Saturday 20 June 2015 13:01
by Bikey
Thanks for the Hue icons.
However, when I uploaded this I only got a question mark instead of the Icon. I had to rename the filenames to lower case and change the icons.txt contents accordingly to make this work. Is that a bug?
Furthermore: I can't change the icon for an actual Philips Hue lamp, as this is a "dimmer". It is only possible to assign an icon to a "switch" via the web interface . How did you change the icon for the Hue lamp?
P.s. according to the Wiki you have to change the icon description file in /home/pi/domoticz/www/ however it also works without doing that. Is that old info?
Posted: Saturday 20 June 2015 13:08
by Bikey
I have created these icons for a scene:
- scene48_Off.png (4.12 KiB) Viewed 13895 times
- scene48_On.png (4.3 KiB) Viewed 13895 times
Posted: Monday 29 June 2015 15:39
by 1bigwink
This is rally useful thank you. I see that people have created custom icons for various devices (cameras, motion sensors, door contacts etc) - is it possible to use this. Currently I only get the option for a custom icon for On/Off Switches... is it possible to use these on other items that appear on the switches tab as well?
Thanks,
dk
Posted: Tuesday 30 June 2015 16:35
by cjnicholl
I have made custom icons for Roku & Tivo devices.
Sent by mail to
Posted: Tuesday 30 June 2015 16:39
by cjnicholl
Examples here:
- Tivo48_On.png (3.05 KiB) Viewed 13793 times
- Roku48_On.png (1.74 KiB) Viewed 13793 times
Posted: Tuesday 30 June 2015 17:15
by 1bigwink
cjnicholl wrote:I have made custom icons for Roku & Tivo devices.
Sent by mail to
How are you adding these please? As far as I can see custom icons are only supported on switches, or have I maybe missed something
Posted: Tuesday 30 June 2015 17:27
by cjnicholl
I'm adding them as a device via the System Alive Checker
Posted: Saturday 22 August 2015 10:16
by sylvainsjc
I don't understand what's wrong with my custom icons file ?
impossible to upload it ?? I get message "Icon definition file not found"
domoticz V2.2765
Posted: Saturday 22 August 2015 14:20
by Eduard
sylvainsjc wrote:Hi,
domoticz V2.2765
They seem to be alright, i only made two separate files and tested your icons in v2.2787.
- Schermafbeelding 2015-08-22 om 14.17.04.png (27.69 KiB) Viewed 13617 times
and it worked...
Posted: Saturday 22 August 2015 15:35
by sylvainsjc
yes it works with your 2 zip files but I really don't understand why ???
Does my "SZicons.zip" worked for you ???
Posted: Saturday 22 August 2015 20:23
by Eduard
sylvainsjc wrote:yes it works with your 2 zip files but I really don't understand why ???
No, got the same error. I use it only with one iconsset per zipfile...
