Watermeter through GPIO and TCRT5000
sincze
Domoticz version: 2024.4
Re: Watermeter through GPIO and TCRT5000
Post by sincze »
joostnl wrote:Can someone write me a step guide to install, Isrcounter.
My script for water is working only i want to make it more accurate
It was a bit hidden I have to agree :D
viewtopic.php?f=32&t=3151&start=60#p112272
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
heggink
Domoticz version: 12451
Post by heggink »
I attached the tcrt through espeasy to domoticz. I experience a weird consistenr ~6% higher reading in domoticz than the real consumption. Consistent enough to make me wonder if it's really the reflection meter edge that could cause it. Any thoughts?
H
P1 meter & solar panel
sincze
Post by sincze »
heggink wrote:I attached the tcrt through espeasy to domoticz. I experience a weird consistenr ~6% higher reading in domoticz than the real consumption. Consistent enough to make me wonder if it's really the reflection meter edge that could cause it. Any thoughts?
H
Did you connect directly to EspEasy or also used a resistor (pull down).
I know that having this sensor exposed to external light (lightning) will increase the usage as well.
So I covered mine. I am not using the Espeasy though and have been running the tcrt5000 for 2 years now.
It works like a Swiss clock. :D
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
heggink
Post by heggink »
Turned out that the esp module was faulty and generated lots of bogus counts. Probably a broken lead somewhere which was really difficult to track down.
pvangorp
Domoticz version: Latest B
Post by pvangorp »
print('> Monitoring water consumption')
-- Water usage
-- Retrieve value from water meter device:
sWaterUsage = otherdevices_svalues['Water']
-- To have a better readable format, divide number by 1000:
sWaterUsagePrint = tonumber(sWaterUsage / 1000);
-- calculation is done with the unmodified water value
sWaterUsage = tonumber(sWaterUsage);
print(">> Utilities: Water usage until now is " .. sWaterUsagePrint .. " ");
if (devicechanged['GPIO_WATER'] == 'Close')
then
sWaterUsageTot = (sWaterUsage + 1)
print(">> Utilities: Water usage is now " .. sWaterUsageTot .. " ");
commandArray['UpdateDevice'] = '164|0|'..sWaterUsageTot..''
I changed the code in red. This function is designed for it. When using a test and production environment you don't need to update the IP address.
