IM200/IM210 Imaginitronix Temprature Sensor
b_weijenberg
- Target OS: -
Re: IM200/IM210 Imaginitronix Temprature Sensor
Maybe better to select one of the supported sensors.
Cheap sensors are not always the best, see for example the WS1200 which does not have a checksum and reports sometimes incorrect values.
Other criteria: transmit range, battery life, accuracy, availability
RFX-433, RFX-433EMC, RFX-868
Eloque
I know
Wasn't quite looking for the best sensor, more for the cheap ones. I am going to use the http://www.homewizard.nl/smartwares-dra ... kraan.html parts to set the temp and was wanting to use the cheap sensors to get some averages.
Any, relatively, cheap sensor you recommend?
b_weijenberg
- Target OS: -
Eloque
Alas, sold out.
They are for home use, so small and hid able would be nice.
ThinkPad
Have you made any progress on this?
I found this: http://domoticz.com/forum/viewtopic.php ... nix#p31474
And this: http://sourceforge.net/p/domoticz/code/ ... paign=Code
So it seems there is some support for Imagintronix. But i don't know for which device(s).
b_weijenberg
- Target OS: -
The supported Imagintronix (Opus XT300) sensor is the soil moisture sensor.
http://www.plantcaretools.com/en/websho ... -en-detail
Eloque
Unfortunatly, it was not a succes. I know to little of these thing to figure out the protocol. They are gathering dust now.
roblom
The 433mHz transmitter has a written http://www.hh.com SL-TX583 text on it. It seems that the pilight does support it. The have reverse engineered the code, so maybe RFXcom has to put less effort in it to add it to the RFXtrxCOM.
- SL-TX583
- SL-TX583.jpg (149.37 KiB) Viewed 3042 times
Eloque
We can hope. But the RFX developer told me he is quite busy atm.
roblom
The payside of succes
Eloque
It's been a while, and I just found the set of sensors in the bottom of a box again. Anyone have any luck with these? Since they seem to be the standard kind that I can get on the various Chinese sites, it seems that have become more common.
Didn't work out of the box with the 248 FirmWare for me though.
AxelvanH
- Domoticz version: 2020.01
I have bought some of these too, curious to hear if someone was able to connect them to an RFXcom
AxelvanH
AxelvanH wrote:I have bought some of these too, curious to hear if someone was able to connect them to an RFXcom
I found the right protocol. Its: TH13 - Alecto WS1700 and compatibles
Just enable Rubicon/Alecto/Banggood
simon_rb
- Target OS: -
Anyone get these to work? I have one, enabled all protocols in the end with no success.
