IM200/IM210 Imaginitronix Temprature Sensor
b_weijenberg
Re: IM200/IM210 Imaginitronix Temprature Sensor
Post by b_weijenberg »
Maybe better to select one of the supported sensors.
Cheap sensors are not always the best, see for example the WS1200 which does not have a checksum and reports sometimes incorrect values.
Other criteria: transmit range, battery life, accuracy, availability
RFX-433, RFX-433EMC, RFX-868
Eloque
Post by Eloque »
I know :)
Wasn't quite looking for the best sensor, more for the cheap ones. I am going to use the http://www.homewizard.nl/smartwares-dra ... kraan.html parts to set the temp and was wanting to use the cheap sensors to get some averages.
Any, relatively, cheap sensor you recommend?
b_weijenberg
Eloque
Post by Eloque »
Alas, sold out.
They are for home use, so small and hid able would be nice.
ThinkPad
Post by ThinkPad »
Have you made any progress on this?
I found this: http://domoticz.com/forum/viewtopic.php ... nix#p31474
And this: http://sourceforge.net/p/domoticz/code/ ... paign=Code
So it seems there is some support for Imagintronix. But i don't know for which device(s).
b_weijenberg
The supported Imagintronix (Opus XT300) sensor is the soil moisture sensor.
http://www.plantcaretools.com/en/websho ... -en-detail
Eloque
Post by Eloque »
Unfortunatly, it was not a succes. I know to little of these thing to figure out the protocol. They are gathering dust now.
roblom
Post by roblom »
The 433mHz transmitter has a written http://www.hh.com SL-TX583 text on it. It seems that the pilight does support it. The have reverse engineered the code, so maybe RFXcom has to put less effort in it to add it to the RFXtrxCOM.
SL-TX583
SL-TX583
Eloque
Post by Eloque »
We can hope. But the RFX developer told me he is quite busy atm.
roblom
Post by roblom »
The payside of succes :-)
Eloque
Post by Eloque »
It's been a while, and I just found the set of sensors in the bottom of a box again. Anyone have any luck with these? Since they seem to be the standard kind that I can get on the various Chinese sites, it seems that have become more common.
Didn't work out of the box with the 248 FirmWare for me though.
AxelvanH
Domoticz version: 2020.01
Post by AxelvanH »
I have bought some of these too, curious to hear if someone was able to connect them to an RFXcom
AxelvanH
Post by AxelvanH »
AxelvanH wrote:I have bought some of these too, curious to hear if someone was able to connect them to an RFXcom
I found the right protocol. Its: TH13 - Alecto WS1700 and compatibles
Just enable Rubicon/Alecto/Banggood
simon_rb
Post by simon_rb »
Anyone get these to work? I have one, enabled all protocols in the end with no success.
