update zwave-js-ui Topic is solved
teo1966
Domoticz version: 2025.1
Re: update zwave-js-ui
Post by teo1966 »
I'd love to change everything, but I'm dreading the data I have from 2017 onward and all the devices that don't allow the conversion to work properly. I'd be disappointed if this data were lost.
I currently have a Pi 3B with an 8Gig USB flash drive connected, and the 8Gig is getting a bit cramped.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
gizmocuz
Post by gizmocuz »
So best you find some time, make a backup of the SD card, or even put the card away (make a backup of the zwavejs-ui configuration/data) and export the Domoticz database (backup function in Settings)
Start fresh on a Pi 5, with 32GB sd card, and do everything with docker compose
Getting Mosquitto up and running might be the most challenging, but the rest should be straight forward
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
I'm trying to update ZwaveJS from 11.12 to the lastest, but it is now giving an error when i try to update
unable to get image 'zwavejs/zwave-js-ui:latest': Error response from daemon: client version 1.53 is too new. Maximum supported API version is 1.41
Is this ZwaveJS related or my OS
Running on Debian12
madpatrick
madpatrick wrote: Sunday 08 March 2026 16:28 Hi,
Running on Debian12
Solved it by updating the following packages
 apt install docker-ce docker-ce-cli containerd.io docker-buildx-plugin docker-compose-plugin
