How to retrieve ENTSOE electrical consumption of France?
willemd
Domoticz version: 2024.1
Re: How to retrieve ENTSOE electrical consumption of France?
Post by willemd »
I just remembered where I have another script with variable number of data points.
I use this:
    				    local response=item.json.result
				        for datehour,value in pairs(response) do
				            domoticz.log("solar forecast date "..domoticz.utils.stringSplit(datehour)[1].." hour "..domoticz.utils.stringSplit(domoticz.utils.stringSplit(datehour)[2],":")[1].." value "..value,domoticz.LOG_INFO)
				            local previousHour=domoticz.utils.stringSplit(domoticz.utils.stringSplit(datehour)[2],":")[1]-1
				            if previousHour<10 then
				                previousHour="0"..tostring(previousHour)
				                previousHour=tostring(previousHour)
				            domoticz.log("previousHour "..previousHour)
				            if value>0 then
				                sensorDateHour=domoticz.utils.stringSplit(datehour)[1].." "..domoticz.utils.stringSplit(domoticz.utils.stringSplit(datehour)[2],":")[1]..":00:00"
				                sValueStr="0;"..value
				                domoticz.log("sensorDateHour "..sensorDateHour.." sValueStr "..sValueStr,domoticz.LOG_INFO)
				                domoticz.devices(idxSolarForecastCounter).updateHistory(sensorDateHour,sValueStr)
				                if sensorDateHour==currentHR then
				                    domoticz.devices(idxSolarForecastCounter).updateCounter(value)
Wilop91
Domoticz version: 2024.4
Post by Wilop91 »
Hello willemd
Thanks for you reply.
I will have a look into later - for the time being I'm trying to adapt your script to retrieve the data for 2 or 3 production types for which I'm sure there are 24 values. This will take some time because of my limited skills....
Btw I have some very basic questions:
- I understand for each production type I need to create a "device". But do I need to create also a "hardware"?
- If I have 3 devices (representing 3 production types) how to I display them in a single log (i.e. with 3 curves)?
In advance thanks a lot for you valuable help.
BR
Willy
willemd
Post by willemd »
You can use either an existing or create a new hardware setup of the type "dummy (does Nothing, used for virtual switches only)." and then create your devices linked to that hardware.
To display 3 devices in one graph you will have to use dashticz.
Wilop91
Post by Wilop91 »
Hello willemd
Thanks for your reply
I could create the devices for each production type creating a hardware as "dummy" and each device as "counter"
But in your script you have also a device called idxCurrentHourIndicator.
How did you create this device?
PS: for the time being I want to run the script which only gets the XML data (i.e. processing of the responseKey is empty)
BR
Willy
Jan Jansen
Domoticz version: Stable
Post by Jan Jansen »
willemd wrote: Wednesday 06 March 2024 10:58 Here is my latest dzvents script to load the prices onto a managed counter for later display in domoticz and dashticz.
@willemd,
Thanks for sharing the script I was looking for! However, I am amazed at the script's output. I created a user variable VAT (integer 21) and a user variable energy tax (string 13.2).
I know the option to set a divisor. But I don't understand the result of the 2 counters on the right?
Thanks in advance.
willemd
Post by willemd »
You need to adapt the counter divider on the managed counter to 100000.
The first counter is excluding tax (red line below), the second is including tax(blue line below). Both show the full list of available prices.
The third counter only shows the tariff of the current hour and is used as a sort of arrow in a dashtic graph to highlight the current hour, see the yellow line below in the graph.
Here is also the graph definition
blocks['graph_ElPrice'] = {
    title: 'Dynamic El Price',
    width:12,
    height: '260px',
    graph: 'line',
    steppedLine: ['before','before','before'],
    buttonsText: ['last hours','today',''],
    devices: [177,179,184],
    beginAtZero: true,
    customHeader: 'devices[184].Data+" incl taxes"',
    range: 'today',
    legend: false
Screenshot 2024-03-08 192406.png (188.11 KiB) Viewed 403 times
Wilop91
Post by Wilop91 »
I could complete my script after having solved a Domoticz crash:
https://www.domoticz.com/forum/viewtopic.php?t=42176
