Page 2 of 2
Re: Zwavejs-UI working in Control panel, but NOT in Domoticz with auto discovery
Posted: Monday 29 January 2024 14:31
by pgas37
I checked the menu/setup many times, no new devices from hardware "MQTT Auto disc Client Gateway with LAN interface"
No errors in the log concerning the problem ofcourse ohter because of missing devices (dzvents scripts
Posted: Monday 29 January 2024 14:42
Well then we have to wait if your folder homeassistant is filled with config devices. No Config devices, No devices in Domoticz.
See for an example the wiki page
https://www.domoticz.com/wiki/MQTT_AD_R ... ms#Example
Posted: Monday 29 January 2024 16:29
by pgas37
i wait already two days, no devices.
tomorrow i will do a portforwarding for port1883 in the router on location. Then i have here at home realtime mqtt data to share
Posted: Monday 29 January 2024 19:33
I meant waiting for your confirmation:-)
And if no data then check your Zwave-JS-UI settings. For that you also need remote access.
Posted: Tuesday 30 January 2024 11:24
by pgas37
back again,
this show the hardware setup and mqtt-output. Checked the zwavejs setting against an other setup which is running on my home-location. Apart from authority key-numbers no difference i can see
Posted: Tuesday 30 January 2024 13:21
There is something wrong in your Zwave-js-UI configuration or connection with MQTT server (from Zwave-JS-UI). The homeassistant folder in mqtt-explorer is empty. Check again the actions mentioned here
https://www.domoticz.com/wiki/Zwave-JS- ... r_Domoticz
perhaps try: To add all devices at once, press "Save" in Zwave JS UI preferences. This will generate status messages for all devices
Posted: Tuesday 30 January 2024 15:06
by pgas37
Succes comes at the end
Its working.
thanks a lot
Paul
Posted: Tuesday 30 January 2024 19:37
Good, but it would help us all to understand what the solution was. Can you share that?
Posted: Tuesday 30 January 2024 22:01
by pgas37
As you advised “check the actions mentioned “
https://www.domoticz.com/wiki/Zwave-JS- ... r_Domoticz“.
In section “Home assistant” the switches MQTT-discovery and Retained discovery were not activated. Why not?
As you probably know, there is also a home automation system called "home assistant" see link
https://www.home-assistant.io/. The name of the section "home assistant "put me on the wrong track. I thought that has nothing to do with "domoticz", but with "home-assistant". I left that section for what it was. Incorrect in other words. A different name of the section would have been better (for me).
Posted: Tuesday 30 January 2024 22:12
Thanks, I indeed suspected that those features were missing. For your information, the MQTT Auto Discover protocol Domoticz is using to communicate with Zwave-JS-UI is first created for/by Home Assistant.
