Is there a really good looking theme out there?
BarryT
Domoticz version: 2024.3
Re: Is there a really good looking theme out there?
Post by BarryT »
rron wrote: Friday 12 April 2024 16:27 I’m looking for a dashboard for my solar panel, P1 and my electic car. I want a easy overview where you can you can see the status of your energy management wich can be expanded with a battery. The home assistent is a good example.
If it has a graphic design the rest of the family can understand it also that is a plus.
Ps victron is next level energy
Is the Energy Dashboard something you mean, in the latest beta of Domoticz?
Still have to add our car imo, but thats not the case in here... ;)
nfuse
Post by nfuse »
i love dashticz but it has a little of a learning curve but once you own it nothing beats it.
i hope the devs will add the new energy dashboard soon because i like it very much but an iframe is not the most ideal solution.
docker with sonos http api / mosquitto / zigbee2mqtt assistant / portainer / dashticz / nodeJS on windows with Zigbee2Mqtt, and some flask builds of my own
There is now the nightglass theme viewtopic.php?t=44563 and the new build in dynamic dashboard almost does the same as dashticz without a learning curve. https://wiki.domoticz.com/DynamicDashboard
Ragdag
Post by Ragdag »
Am I allowed to plug the newly improved Machinon :D
viewtopic.php?t=45132
With full support of the new Dynamic Dashboard, and loads of other features like an Custom icon installer that comes with over 250+ icons
JayDotR
Post by JayDotR »
waltervl wrote: Tuesday 11 August 2026 20:15 There is now the nightglass theme viewtopic.php?t=44563 and the new build in dynamic dashboard almost does the same as dashticz without a learning curve. https://wiki.domoticz.com/DynamicDashboard
+1 :D
Domoticz Beta on raspberry3b, and raspberry4(b) on Rasbian Trixie / Python 3.13 / 64 bit
Using: PiHole, SolarEdge Modbus, Sainlogic / Weather Underground, MQTT, Fritzbox, P1 Meter(s), dzvents Scripting
https://www.github.com/janreimen/
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
Dashticz has been redesigned and is now much easier in configuring a dashboard
The blocks can be placed on every location and size with a mouse click.
Also adding a functionality can be done via a wizard menu as also adding your devices
For all the new features you can checkout the new beta
