15326 - [WebServer] Depricated RType Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
EdwinK
Re: 15326 - [WebServer] Depricated RType
Post by EdwinK »
Didn't think of that one. I have the Machinon theme in use. Trying to switch to default one now.
Edit: It did fix the camera thing, but the devices error still come up. So i guess I need to look further into this.
Loky31
Post by Loky31 »
kiddigital wrote: Monday 05 June 2023 7:06 No mistake, matter of cleaning up old inconsistencies.
Should be easy to fix. Maybe ask the either the author to fix it for you or do it yourself.
Look for the API calls that do not start with `type=command`.
Example `type=devices` should become `type=command&param=getdevices`
Ok thanks for the answer.
Hum many troubles for not a lot...
I revert to a backup but I'm facing something weird. I do not have all the switches in the "switch" tab... the list is short whereas they are all in the device list.
getting crazy after this update... lesson learnt : stop beta !
Is there a way to update to a specific version of domotics? for instance I'm in build 15178, how do I do to go to build 15191 for instance?
kiddigital
Post by kiddigital »
The following RTypes have been migrated to their appropriate Command alternatives
			// Migrated RTypes to regular commands
			RegisterCommandCode("getusers", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetUsers(session, req, root); });
			RegisterCommandCode("getsettings", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetSettings(session, req, root); });
			RegisterCommandCode("getdevices", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetDevices(session, req, root); });
			RegisterCommandCode("gethardware", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetHardware(session, req, root); });
			RegisterCommandCode("events", [this](auto&& session, auto&& req, auto&& root) { Cmd_Events(session, req, root); });
			RegisterCommandCode("getnotifications", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetNotifications(session, req, root); });
			RegisterCommandCode("createvirtualsensor", [this](auto&& session, auto&& req, auto&& root) { Cmd_CreateMappedSensor(session, req, root); });
			RegisterCommandCode("createdevice", [this](auto&& session, auto&& req, auto&& root) { Cmd_CreateDevice(session, req, root); });
			RegisterCommandCode("getscenelog", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetSceneLog(session, req, root); });
			RegisterCommandCode("getscenes", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetScenes(session, req, root); });
			RegisterCommandCode("addscene", [this](auto&& session, auto&& req, auto&& root) { Cmd_AddScene(session, req, root); });
			RegisterCommandCode("deletescene", [this](auto&& session, auto&& req, auto&& root) { Cmd_DeleteScene(session, req, root); });
			RegisterCommandCode("updatescene", [this](auto&& session, auto&& req, auto&& root) { Cmd_UpdateScene(session, req, root); });
			RegisterCommandCode("getmobiles", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetMobiles(session, req, root); });
			RegisterCommandCode("getcameras", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetCameras(session, req, root); });
			RegisterCommandCode("getcameras_user", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetCamerasUser(session, req, root); });
			RegisterCommandCode("getschedules", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetSchedules(session, req, root); });
			RegisterCommandCode("gettimers", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetTimers(session, req, root); });
			RegisterCommandCode("getscenetimers", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetSceneTimers(session, req, root); });
			RegisterCommandCode("getsetpointtimers", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetSetpointTimers(session, req, root); });
			RegisterCommandCode("getplans", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetPlans(session, req, root); });
			RegisterCommandCode("getfloorplans", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetFloorPlans(session, req, root); });
			RegisterCommandCode("getlightlog", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetLightLog(session, req, root); });
			RegisterCommandCode("gettextlog", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetTextLog(session, req, root); });
			RegisterCommandCode("gettransfers", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetTransfers(session, req, root); });
			RegisterCommandCode("dotransferdevice", [this](auto&& session, auto&& req, auto&& root) { Cmd_DoTransferDevice(session, req, root); });
			RegisterCommandCode("createrflinkdevice", [this](auto&& session, auto&& req, auto&& root) { Cmd_CreateRFLinkDevice(session, req, root); });
			RegisterCommandCode("createevohomesensor", [this](auto&& session, auto&& req, auto&& root) { Cmd_CreateEvohomeSensor(session, req, root); });
			RegisterCommandCode("bindevohome", [this](auto&& session, auto&& req, auto&& root) { Cmd_BindEvohome(session, req, root); });
			RegisterCommandCode("custom_light_icons", [this](auto&& session, auto&& req, auto&& root) { Cmd_CustomLightIcons(session, req, root); });
			RegisterCommandCode("deletedevice", [this](auto&& session, auto&& req, auto&& root) { Cmd_DeleteDevice(session, req, root); });
			RegisterCommandCode("getshareduserdevices", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetSharedUserDevices(session, req, root); });
			RegisterCommandCode("setshareduserdevices", [this](auto&& session, auto&& req, auto&& root) { Cmd_SetSharedUserDevices(session, req, root); });
			RegisterCommandCode("graph", [this](auto&& session, auto&& req, auto&& root) { Cmd_HandleGraph(session, req, root); });
			RegisterCommandCode("setused", [this](auto&& session, auto&& req, auto&& root) { Cmd_SetUsed(session, req, root); });
A small set of the RTypes still work as they are mapped to their new Commands:
				if (rtype.compare("settings") == 0)
					altrtype = "getsettings";
				else if (rtype.compare("users") == 0)
					altrtype = "getusers";
				else if (rtype.compare("devices") == 0)
					altrtype = "getdevices";
				else if (rtype.compare("hardware") == 0)
					altrtype = "gethardware";
				else if (rtype.compare("events") == 0)
					altrtype = "events";
				else if (rtype.compare("notifications") == 0)
					altrtype = "getnotifications";
				else if (rtype.compare("createdevice") == 0)
					altrtype = "createdevice";
When ever an RType API call is received, a message will appear in the log.
pipiche
Post by pipiche »
gizmocuz wrote: Friday 02 June 2023 14:04 For external API queries, RType queries have been replaced by normal queries.
We might need to update the wiki for these left overs.
The user interface commands (web gui) have been modified
Would it be possible to know to which version of domoticz this relate to. This is required to provide backward compatibility of the plugins
Loky31
Post by Loky31 »
Maybe a crazy idea there, but would it be somehow possible to capture and "translate" those former API calls to the new format ?
A kind of proxy somehow :)
Domoticz version: 2025.1
jvdz
Domoticz version: 4.107
Post by jvdz »
This will be a challenge for standalone applications like DTGBOT to maintain backwards compatibility for current production systems while also implementing support for the current Beta's. :shock:
jvdz wrote: Monday 05 June 2023 16:10 This will be a challenge for standalone applications like DTGBOT to maintain backwards compatibility for current production systems while also implementing support for the current Beta's. :shock:
As I see it most important calls will work and only give deprecation warnings in the log.
kiddigital
True, goal is to keep this period as short as possible meaning a new Stable is due soon. And looking into keeping some of the most important changed calls to 'translate' them internally. Some are already but maybe that small list gets extended.
jvdz
Post by jvdz »
Keeping the period short isn't the issue here as there is no cutoff for me implementing the change in DTGBOT.
I need to support both since Domoticz internals doesn't and we honestly may not expect every user of domoticz upgrade at once.
I guess the design/change choice was made so I will go for the approach of retrieving the Revision first and depending on that either use the OLD or NEW format.
jvdz
Post by jvdz »
waltervl wrote: Monday 05 June 2023 16:36 As I see it most important calls will work and only give deprecation warnings in the log.
As I see it this statement doesn't buy me anything as it doesn't support the version I use in DTGBOT. ;)
... and the warning means it really will be remove at some point of time ...right? When?
kiddigital
As I see it this statement doesn't buy me anything as it doesn't support the once I use in DTGBOT. ;)
Which ones do you look for?
And yes, eventually (6-18 months?) the backward compatibility support will go away.
We can’t keep supporting Users that do not want to upgrade for ever. Same goes for DTGBOT users. They can also choose to stay on an older version compatible with their older domoticz version.
jvdz
Post by jvdz »
kiddigital wrote: Monday 05 June 2023 17:49 Which ones do you look for?
In my case it is type=devices/scenes/plans .
kiddigital wrote: Monday 05 June 2023 17:49 And yes, eventually (6-18 months?) the backward compatibility support will go away.
Understand how it works, hence my rhetorical question/comment. :)
So please don't worry about it, I know now what the issue is and my only approach is to maintain backwards compatibility for a longer period so will do as I mentioned and using the appropriate format based on the returned revision from the "/json.htm?type=command&param=getversion" restcall.
Tnx
EdwinK
Post by EdwinK »
Don't understand much of this. Hope I'll have more time to look at this later this week. Or maybe next. For now I will have to life with the messages in the status log.
Lokonli
Post by Lokonli »
Are you using Dashticz?
Dashticz still is using the outdated API at some places causing the log massages in Domoticz.
I'm preparing a fix.
Loky31
Post by Loky31 »
Revert to a version still compatible and will stop update afterthat as I have too many things relying on those calls, and more important some that I'm not able to update myself...
Bye bye domoticz upgrade then ;)
EdwinK
Post by EdwinK »
Lokonli wrote: Monday 05 June 2023 23:03 Are you using Dashticz?
Yes, using Dashticz. :) Waiting for a fix then ;)
jvdz
Post by jvdz »
Isn't dzVents causing these messages too as I see some 28 references that needs changing in the current github source of which 12 seem to be in the core code?:
\domoticz\dzVents\runtime\device-adapters\evohome_device.lua
  43,7: 					"/json.htm?type=setused&idx=" .. device.id ..
\domoticz\dzVents\runtime\device-adapters\generic_device.lua
  153,6: 				'/json.htm?type=setused&used=true&name=' ..
  172,8: 						'/json.htm?type=setused&used=true&protected=true' ..
  179,8: 						'/json.htm?type=setused&used=true&protected=false' ..
\domoticz\dzVents\runtime\device-adapters\group_device.lua
  56,8: 						'/json.htm?type=updatescene&scenetype=1' ..
  64,54: 			local url = domoticz.settings['Domoticz url'] .. '/json.htm?type=updatescene&scenetype=1' ..
  72,54: 			local url = domoticz.settings['Domoticz url'] .. '/json.htm?type=updatescene&scenetype=1&protected=true' ..
  80,54: 			local url = domoticz.settings['Domoticz url'] .. '/json.htm?type=updatescene&scenetype=1&protected=false' ..
\domoticz\dzVents\runtime\device-adapters\scene_device.lua
  51,54: 			local url = domoticz.settings['Domoticz url'] .. '/json.htm?type=updatescene&scenetype=0' ..
  59,54: 			local url = domoticz.settings['Domoticz url'] .. '/json.htm?type=updatescene&scenetype=0' ..
  67,54: 			local url = domoticz.settings['Domoticz url'] .. '/json.htm?type=updatescene&scenetype=0&protected=true' ..
  75,54: 			local url = domoticz.settings['Domoticz url'] .. '/json.htm?type=updatescene&scenetype=0&protected=false' ..
\domoticz\dzVents\runtime\integration-tests\descriptionScript.lua
  16,49: 			local url = dz.settings['Domoticz url'] ..  "/json.htm?type=scenes"
\domoticz\dzVents\runtime\integration-tests\domoticzTestTools.lua
  285,27: 		-- http://localhost:8080/json.htm?type=hardware
  338,26: 		--http://localhost:8080/json.htm?type=setused&idx=1&name=vdSwitch&description=des&strparam1=&strparam2=&protected=false&switchtype=0&customimage=0&used=true&addjvalue=0&addjvalue2=0&options=
\domoticz\dzVents\runtime\integration-tests\IconScript.lua
  12,49: 			local url = dz.settings['Domoticz url'] ..  '/json.htm?type=devices&rid=' .. item.id
\domoticz\dzVents\runtime\tests\testDevice.lua
  672,41: 			assert.is_same('http://127.0.0.1:8080/json.htm?type=setused&used=true&protected=false&idx=1', res)
  688,41: 			assert.is_same('http://127.0.0.1:8080/json.htm?type=setused&used=true&protected=false&idx=1', res)
  722,41: 			assert.is_same('http://127.0.0.1:8080/json.htm?type=setused&used=true&name=myDevice&description=Description+1&idx=1&switchtype=2&customimage=24', res)
  805,41: 			assert.is_same('http://127.0.0.1:8080/json.htm?type=setused&idx=1&setpoint=&state=Off&mode=Permanent&used=true', res)
  1551,42: 				assert.is_same('http://127.0.0.1:8080/json.htm?type=updatescene&scenetype=0&protected=false&idx=1&name=myScene&description=Description+1', res)
  1554,42: 				assert.is_same('http://127.0.0.1:8080/json.htm?type=updatescene&scenetype=0&protected=true&idx=1&name=myScene&description=Description+1', res)
  1557,42: 				assert.is_same('http://127.0.0.1:8080/json.htm?type=updatescene&scenetype=0&idx=1&name=a&description=Description+1', res)
  1560,42: 				assert.is_same('http://127.0.0.1:8080/json.htm?type=updatescene&scenetype=0&idx=1&name=myScene&description=groupie', res)
  1622,42: 				assert.is_same('http://127.0.0.1:8080/json.htm?type=updatescene&scenetype=1&protected=false&idx=1&name=myGroup&description=Description+1', res)
  1625,42: 				assert.is_same('http://127.0.0.1:8080/json.htm?type=updatescene&scenetype=1&protected=true&idx=1&name=myGroup&description=Description+1', res)
  1628,42: 				assert.is_same('http://127.0.0.1:8080/json.htm?type=updatescene&scenetype=1&idx=1&name=a&description=Description+1', res)
  1631,42: 				assert.is_same('http://127.0.0.1:8080/json.htm?type=updatescene&scenetype=1&idx=1&name=myGroup&description=groupie', res)
Lokonli
Post by Lokonli »
EdwinK wrote: Tuesday 06 June 2023 8:30
Can you test Dashticz 3.10.5 beta?
EdwinK
Post by EdwinK »
Will do ;)
Unfortunately, it still gives the same error.
