15326 - [WebServer] Depricated RType Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- EdwinK
- Domoticz version: BETA
Re: 15326 - [WebServer] Depricated RType
Didn't think of that one. I have the Machinon theme in use. Trying to switch to default one now.
Edit: It did fix the camera thing, but the devices error still come up. So i guess I need to look further into this.
Ok thanks for the answer.kiddigital wrote: Monday 05 June 2023 7:06 No mistake, matter of cleaning up old inconsistencies.
Should be easy to fix. Maybe ask the either the author to fix it for you or do it yourself.
Look for the API calls that do not start with `type=command`.
Example `type=devices` should become `type=command¶m=getdevices`
Hum many troubles for not a lot...
I revert to a backup but I'm facing something weird. I do not have all the switches in the "switch" tab... the list is short whereas they are all in the device list.
getting crazy after this update... lesson learnt : stop beta !
Is there a way to update to a specific version of domotics? for instance I'm in build 15178, how do I do to go to build 15191 for instance?
- kiddigital
The following RTypes have been migrated to their appropriate Command alternatives
A small set of the RTypes still work as they are mapped to their new Commands:
When ever an RType API call is received, a message will appear in the log.
// Migrated RTypes to regular commands
RegisterCommandCode("getusers", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetUsers(session, req, root); });
RegisterCommandCode("getsettings", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetSettings(session, req, root); });
RegisterCommandCode("getdevices", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetDevices(session, req, root); });
RegisterCommandCode("gethardware", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetHardware(session, req, root); });
RegisterCommandCode("events", [this](auto&& session, auto&& req, auto&& root) { Cmd_Events(session, req, root); });
RegisterCommandCode("getnotifications", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetNotifications(session, req, root); });
RegisterCommandCode("createvirtualsensor", [this](auto&& session, auto&& req, auto&& root) { Cmd_CreateMappedSensor(session, req, root); });
RegisterCommandCode("createdevice", [this](auto&& session, auto&& req, auto&& root) { Cmd_CreateDevice(session, req, root); });
RegisterCommandCode("getscenelog", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetSceneLog(session, req, root); });
RegisterCommandCode("getscenes", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetScenes(session, req, root); });
RegisterCommandCode("addscene", [this](auto&& session, auto&& req, auto&& root) { Cmd_AddScene(session, req, root); });
RegisterCommandCode("deletescene", [this](auto&& session, auto&& req, auto&& root) { Cmd_DeleteScene(session, req, root); });
RegisterCommandCode("updatescene", [this](auto&& session, auto&& req, auto&& root) { Cmd_UpdateScene(session, req, root); });
RegisterCommandCode("getmobiles", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetMobiles(session, req, root); });
RegisterCommandCode("getcameras", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetCameras(session, req, root); });
RegisterCommandCode("getcameras_user", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetCamerasUser(session, req, root); });
RegisterCommandCode("getschedules", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetSchedules(session, req, root); });
RegisterCommandCode("gettimers", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetTimers(session, req, root); });
RegisterCommandCode("getscenetimers", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetSceneTimers(session, req, root); });
RegisterCommandCode("getsetpointtimers", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetSetpointTimers(session, req, root); });
RegisterCommandCode("getplans", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetPlans(session, req, root); });
RegisterCommandCode("getfloorplans", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetFloorPlans(session, req, root); });
RegisterCommandCode("getlightlog", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetLightLog(session, req, root); });
RegisterCommandCode("gettextlog", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetTextLog(session, req, root); });
RegisterCommandCode("gettransfers", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetTransfers(session, req, root); });
RegisterCommandCode("dotransferdevice", [this](auto&& session, auto&& req, auto&& root) { Cmd_DoTransferDevice(session, req, root); });
RegisterCommandCode("createrflinkdevice", [this](auto&& session, auto&& req, auto&& root) { Cmd_CreateRFLinkDevice(session, req, root); });
RegisterCommandCode("createevohomesensor", [this](auto&& session, auto&& req, auto&& root) { Cmd_CreateEvohomeSensor(session, req, root); });
RegisterCommandCode("bindevohome", [this](auto&& session, auto&& req, auto&& root) { Cmd_BindEvohome(session, req, root); });
RegisterCommandCode("custom_light_icons", [this](auto&& session, auto&& req, auto&& root) { Cmd_CustomLightIcons(session, req, root); });
RegisterCommandCode("deletedevice", [this](auto&& session, auto&& req, auto&& root) { Cmd_DeleteDevice(session, req, root); });
RegisterCommandCode("getshareduserdevices", [this](auto&& session, auto&& req, auto&& root) { Cmd_GetSharedUserDevices(session, req, root); });
RegisterCommandCode("setshareduserdevices", [this](auto&& session, auto&& req, auto&& root) { Cmd_SetSharedUserDevices(session, req, root); });
RegisterCommandCode("graph", [this](auto&& session, auto&& req, auto&& root) { Cmd_HandleGraph(session, req, root); });
RegisterCommandCode("setused", [this](auto&& session, auto&& req, auto&& root) { Cmd_SetUsed(session, req, root); });
if (rtype.compare("settings") == 0)
altrtype = "getsettings";
else if (rtype.compare("users") == 0)
altrtype = "getusers";
else if (rtype.compare("devices") == 0)
altrtype = "getdevices";
else if (rtype.compare("hardware") == 0)
altrtype = "gethardware";
else if (rtype.compare("events") == 0)
altrtype = "events";
else if (rtype.compare("notifications") == 0)
altrtype = "getnotifications";
else if (rtype.compare("createdevice") == 0)
altrtype = "createdevice";
Would it be possible to know to which version of domoticz this relate to. This is required to provide backward compatibility of the pluginsgizmocuz wrote: Friday 02 June 2023 14:04 For external API queries, RType queries have been replaced by normal queries.
We might need to update the wiki for these left overs.
The user interface commands (web gui) have been modified
Maybe a crazy idea there, but would it be somehow possible to capture and "translate" those former API calls to the new format ?
A kind of proxy somehow
- Domoticz version: 2025.1
Warning added in the wiki: https://www.domoticz.com/wiki/Domoticz_ ... d_newer.29
- jvdz
- Domoticz version: 4.107
This will be a challenge for standalone applications like DTGBOT to maintain backwards compatibility for current production systems while also implementing support for the current Beta's.
As I see it most important calls will work and only give deprecation warnings in the log.jvdz wrote: Monday 05 June 2023 16:10 This will be a challenge for standalone applications like DTGBOT to maintain backwards compatibility for current production systems while also implementing support for the current Beta's.![]()
- kiddigital
True, goal is to keep this period as short as possible meaning a new Stable is due soon. And looking into keeping some of the most important changed calls to 'translate' them internally. Some are already but maybe that small list gets extended.jvdz wrote: Monday 05 June 2023 16:10 This will be a challenge for standalone applications like DTGBOT to maintain backwards compatibility for current production systems while also implementing support for the current Beta's.![]()
- jvdz
Keeping the period short isn't the issue here as there is no cutoff for me implementing the change in DTGBOT.
I need to support both since Domoticz internals doesn't and we honestly may not expect every user of domoticz upgrade at once.
I guess the design/change choice was made so I will go for the approach of retrieving the Revision first and depending on that either use the OLD or NEW format.
- jvdz
As I see it this statement doesn't buy me anything as it doesn't support the version I use in DTGBOT.waltervl wrote: Monday 05 June 2023 16:36 As I see it most important calls will work and only give deprecation warnings in the log.
... and the warning means it really will be remove at some point of time ...right? When?
- kiddigital
Which ones do you look for?jvdz wrote:As I see it this statement doesn't buy me anything as it doesn't support the once I use in DTGBOT.waltervl wrote: Monday 05 June 2023 16:36 As I see it most important calls will work and only give deprecation warnings in the log.
And yes, eventually (6-18 months?) the backward compatibility support will go away.
We can’t keep supporting Users that do not want to upgrade for ever. Same goes for DTGBOT users. They can also choose to stay on an older version compatible with their older domoticz version.
- jvdz
In my case it is type=devices/scenes/plans .
Understand how it works, hence my rhetorical question/comment.kiddigital wrote: Monday 05 June 2023 17:49 And yes, eventually (6-18 months?) the backward compatibility support will go away.
So please don't worry about it, I know now what the issue is and my only approach is to maintain backwards compatibility for a longer period so will do as I mentioned and using the appropriate format based on the returned revision from the "/json.htm?type=command¶m=getversion" restcall.
Tnx
- EdwinK
Don't understand much of this. Hope I'll have more time to look at this later this week. Or maybe next. For now I will have to life with the messages in the status log.
Lokonli
Are you using Dashticz?
Dashticz still is using the outdated API at some places causing the log massages in Domoticz.
I'm preparing a fix.
Revert to a version still compatible and will stop update afterthat as I have too many things relying on those calls, and more important some that I'm not able to update myself...
Bye bye domoticz upgrade then
- EdwinK
Yes, using Dashticz.Lokonli wrote: Monday 05 June 2023 23:03 Are you using Dashticz?
- jvdz
Isn't dzVents causing these messages too as I see some 28 references that needs changing in the current github source of which 12 seem to be in the core code?:
\domoticz\dzVents\runtime\device-adapters\evohome_device.lua
43,7: "/json.htm?type=setused&idx=" .. device.id ..
\domoticz\dzVents\runtime\device-adapters\generic_device.lua
153,6: '/json.htm?type=setused&used=true&name=' ..
172,8: '/json.htm?type=setused&used=true&protected=true' ..
179,8: '/json.htm?type=setused&used=true&protected=false' ..
\domoticz\dzVents\runtime\device-adapters\group_device.lua
56,8: '/json.htm?type=updatescene&scenetype=1' ..
64,54: local url = domoticz.settings['Domoticz url'] .. '/json.htm?type=updatescene&scenetype=1' ..
72,54: local url = domoticz.settings['Domoticz url'] .. '/json.htm?type=updatescene&scenetype=1&protected=true' ..
80,54: local url = domoticz.settings['Domoticz url'] .. '/json.htm?type=updatescene&scenetype=1&protected=false' ..
\domoticz\dzVents\runtime\device-adapters\scene_device.lua
51,54: local url = domoticz.settings['Domoticz url'] .. '/json.htm?type=updatescene&scenetype=0' ..
59,54: local url = domoticz.settings['Domoticz url'] .. '/json.htm?type=updatescene&scenetype=0' ..
67,54: local url = domoticz.settings['Domoticz url'] .. '/json.htm?type=updatescene&scenetype=0&protected=true' ..
75,54: local url = domoticz.settings['Domoticz url'] .. '/json.htm?type=updatescene&scenetype=0&protected=false' ..
\domoticz\dzVents\runtime\integration-tests\descriptionScript.lua
16,49: local url = dz.settings['Domoticz url'] .. "/json.htm?type=scenes"
\domoticz\dzVents\runtime\integration-tests\domoticzTestTools.lua
285,27: -- http://localhost:8080/json.htm?type=hardware
338,26: --http://localhost:8080/json.htm?type=setused&idx=1&name=vdSwitch&description=des&strparam1=&strparam2=&protected=false&switchtype=0&customimage=0&used=true&addjvalue=0&addjvalue2=0&options=
\domoticz\dzVents\runtime\integration-tests\IconScript.lua
12,49: local url = dz.settings['Domoticz url'] .. '/json.htm?type=devices&rid=' .. item.id
\domoticz\dzVents\runtime\tests\testDevice.lua
672,41: assert.is_same('http://127.0.0.1:8080/json.htm?type=setused&used=true&protected=false&idx=1', res)
688,41: assert.is_same('http://127.0.0.1:8080/json.htm?type=setused&used=true&protected=false&idx=1', res)
722,41: assert.is_same('http://127.0.0.1:8080/json.htm?type=setused&used=true&name=myDevice&description=Description+1&idx=1&switchtype=2&customimage=24', res)
805,41: assert.is_same('http://127.0.0.1:8080/json.htm?type=setused&idx=1&setpoint=&state=Off&mode=Permanent&used=true', res)
1551,42: assert.is_same('http://127.0.0.1:8080/json.htm?type=updatescene&scenetype=0&protected=false&idx=1&name=myScene&description=Description+1', res)
1554,42: assert.is_same('http://127.0.0.1:8080/json.htm?type=updatescene&scenetype=0&protected=true&idx=1&name=myScene&description=Description+1', res)
1557,42: assert.is_same('http://127.0.0.1:8080/json.htm?type=updatescene&scenetype=0&idx=1&name=a&description=Description+1', res)
1560,42: assert.is_same('http://127.0.0.1:8080/json.htm?type=updatescene&scenetype=0&idx=1&name=myScene&description=groupie', res)
1622,42: assert.is_same('http://127.0.0.1:8080/json.htm?type=updatescene&scenetype=1&protected=false&idx=1&name=myGroup&description=Description+1', res)
1625,42: assert.is_same('http://127.0.0.1:8080/json.htm?type=updatescene&scenetype=1&protected=true&idx=1&name=myGroup&description=Description+1', res)
1628,42: assert.is_same('http://127.0.0.1:8080/json.htm?type=updatescene&scenetype=1&idx=1&name=a&description=Description+1', res)
1631,42: assert.is_same('http://127.0.0.1:8080/json.htm?type=updatescene&scenetype=1&idx=1&name=myGroup&description=groupie', res)
- EdwinK
Will do
Unfortunately, it still gives the same error.
