after changed to develop....i have errors at this command sudo python3 -m pip install -r requirements.txt --upgrade
:~/domoticz/plugins/Domoticz-Zigate $ sudo python3 -m pip install -r requirements.txt --upgrade
ERROR: Exception:
File "/usr/local/lib/python3.10/site-packages/pip/_internal/cli/base_command.py", line 173, in _main
status = self.run(options, args)
File "/usr/local/lib/python3.10/site-packages/pip/_internal/cli/req_command.py", line 203, in wrapper
return func(self, options, args)
File "/usr/local/lib/python3.10/site-packages/pip/_internal/commands/install.py", line 266, in run
session = self.get_default_session(options)
File "/usr/local/lib/python3.10/site-packages/pip/_internal/cli/req_command.py", line 74, in get_default_session
self._session = self.enter_context(self._build_session(options))
File "/usr/local/lib/python3.10/site-packages/pip/_internal/cli/req_command.py", line 88, in _build_session
session = PipSession(
File "/usr/local/lib/python3.10/site-packages/pip/_internal/network/session.py", line 289, in __init__
self.headers["User-Agent"] = user_agent()
File "/usr/local/lib/python3.10/site-packages/pip/_internal/network/session.py", line 132, in user_agent
linux_distribution = distro.linux_distribution() # type: ignore
File "/usr/local/lib/python3.10/site-packages/pip/_vendor/distro.py", line 125, in linux_distribution
return _distro.linux_distribution(full_distribution_name)
File "/usr/local/lib/python3.10/site-packages/pip/_vendor/distro.py", line 681, in linux_distribution
self.version(),
File "/usr/local/lib/python3.10/site-packages/pip/_vendor/distro.py", line 741, in version
self.lsb_release_attr('release'),
File "/usr/local/lib/python3.10/site-packages/pip/_vendor/distro.py", line 903, in lsb_release_attr
return self._lsb_release_info.get(attribute, '')
File "/usr/local/lib/python3.10/site-packages/pip/_vendor/distro.py", line 556, in __get__
ret = obj.__dict__[self._fname] = self._f(obj)
File "/usr/local/lib/python3.10/site-packages/pip/_vendor/distro.py", line 1014, in _lsb_release_info
stdout = subprocess.check_output(cmd, stderr=devnull)
File "/usr/local/lib/python3.10/subprocess.py", line 420, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "/usr/local/lib/python3.10/subprocess.py", line 524, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '('lsb_release', '-a')' returned non-zero exit status 1.
File "/usr/local/lib/python3.10/runpy.py", line 196, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/local/lib/python3.10/runpy.py", line 86, in _run_code
exec(code, run_globals)
File "/usr/local/lib/python3.10/site-packages/pip/__main__.py", line 31, in <module>
sys.exit(_main())
File "/usr/local/lib/python3.10/site-packages/pip/_internal/cli/main.py", line 70, in main
return command.main(cmd_args)
File "/usr/local/lib/python3.10/site-packages/pip/_internal/cli/base_command.py", line 98, in main
return self._main(args)
File "/usr/local/lib/python3.10/site-packages/pip/_internal/cli/base_command.py", line 214, in _main
self.handle_pip_version_check(options)
File "/usr/local/lib/python3.10/site-packages/pip/_internal/cli/req_command.py", line 143, in handle_pip_version_check
session = self._build_session(
self.version(),
and plugin doesn t work...
Domoticz on Raspberry Pi 4 with Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy
