Ikea lamp does work work correctly
manjh
Re: Ikea lamp does work work correctly
Post by manjh »
pipiche wrote: Wednesday 11 January 2023 11:50 I never took much attention to the slider inside the Color widget, may be there is a different beaviour on the way Domoticz is sending the information to the plugin , may be it has changed .
I'll setup a test environment and check that
Didn't you set any parameter to get a smooth move of the level control ?
You can eventually enable debugCommand ( in the debug parameters) this will increase the level of debug when doing commands from Domoticz, and you might check if they are different
Are these parameters documented?
Hans
manjh
Post by manjh »
I looked into the parameters, set the first to 255, all others to 1. Did not make a difference.
Then modified the debug settings, set the : "widget" on.
Now when I modify the level and color of the lamp, I see this on the Domoticz console:
2023-01-16 15:10:46.464 Status: setcolbrightnessvalue: ID: 1249, bri: 50, color: '{m: 2, RGB: 000000, CWWW: 06f9, CT: 249}'
Looks good, I can see brightness level and color temp.
When I set that same light to switch based on timed event, I see this:
2023-01-16 15:12:01.516 ZigbeeConbee: UpdateDevice - (lampje openhaard 1) 1:3
2023-01-16 15:12:01.272 Status: Schedule item started! Name: lampje openhaard 1, Type: On Time, DevID: 4681, Time: 2023-01-16 15:12:01
2023-01-16 15:12:06.526 ZigbeeConbee: UpdateDevice - (lampje openhaard 1) 1:13
No specific setting for brightness and color temp. Does this make any sense?
Hans
manjh
Post by manjh »
Hmmm... more info. I feel we're getting closer to the root.
I have two Ikea lamps in a lamp fixture with 2 sockets. Each of the lamps are in Domoticz as individual device. When I control them using timed events on the widget, they donot behave correctly: on/off and color work fine, brightness does not.
But now I have both lamps in a group, so I can control them in synch. When I define a timer on the group widget, everything works OK!!!
So it looks like the individual lamp widget is at fault, the group widget works OK.
Does this help?
Hans
manjh
Post by manjh »
I ran some more tests, and observed a full cycle on timed events.
I can now confirm this is working: as long as a lamp is in a group, even as a single lamp in that group, all timers and scene actions work properly on that group.
Timers and scene actions on the individual lamp widget work partly: color and on/off are working OK, brightness level does not.
So for now, things work. I would suggest either to fix the problem, or to document it as a peculiarity. I'm available for testing fixes.
Hans
manjh
Post by manjh »
What is the current status?
Everything works OK for me thanks to that work-around using a lamp as group, but obviously for the long run it would be more elegant if it works on its own...
Hans
