Page 2 of 2
Re: script to load ENTSOE day ahead electricity prices
Posted: Monday 17 April 2023 0:00
by renerene
JanvdW wrote: Wednesday 28 December 2022 23:33 I think that the best solution is to run a script every x hours that selects the optimum timeslots for these scenarios (both for load and unload) and store them in (global user) data, e.g.:
  • 3 or 4 best slots for 1 hour
  • 1 or 2 best slots for 2 hours
  • 1 best slot for 3 hours
Other scripts can select the optimal available time slots to control the devices.
here are some simular routines:
https://domoticz.com/forum/viewtopic.ph ... 72#p302072
2023-04-16 23:47:12.379 Status: dzVents: Info: dzDailyEnergyPrices: the cheapest hour is: 16
2023-04-16 23:47:12.384 Status: dzVents: Info: dzDailyEnergyPrices: the cheapest five hours in a row start on:14
2023-04-16 23:47:12.385 Status: dzVents: Info: dzDailyEnergyPrices: current hour is on place 21 where place 1 is the cheapest from today's 24 hrs
Posted: Monday 17 April 2023 9:48
by willemd
If you are looking for using cheap hours, here is info about a script that does 24 hour charge/discharge planning for a battery system, with the option to include solar production forecast.
viewtopic.php?t=39709
It uses the ENTSOE prices but this time loaded with a python script.
The dzvents script I posted above in this thread indeed has the problem that it crashes if it does not receive the correct number of hours. It happened once that ENTSOE had one hour missing but also sometimes they have their planned maintenance. The source for gas data is less reliable, often in the weekend it does not supply new data. I tried changing the script so it first checks the number of hours available but found that not to be easy in dzvents so I did not post a new version yet. The python program handles it without problems.
Posted: Saturday 09 December 2023 11:11
by willemd
I modified my script that was posted at the start of this post to not load the prices onto historic variables, but post them onto a managed counter. This makes it possible to display them in a graph both in domoticz and in dashticz.
Now I found out from a post by gizmocuz that in the meantime (with release 2023.2) domoticz has new hardware to load dynamic electricity price from various providers. The hardware is called "Enever Dutch Electricity/Gas Price Feed". I have not tried it yet but if you plan to use dynamic prices, you should take a look.
Posted: Tuesday 05 March 2024 18:23
by Wilop91
Hello
I created a new topic because I was inspired about what you achieved in this topic:
viewtopic.php?t=42104
Could sombody give an advice about the "feasability"?
Thanks a lot
Willy
Posted: Saturday 08 June 2024 13:48
by Nateonas
JanvdW wrote: Saturday 15 April 2023 11:02
Alain wrote: Saturday 15 April 2023 5:08 I've tried adding this code to the code above to find the lowest price in the day ahead table, but I get an error saying that I am trying to do arithmetic on a nil value (global variable VarIndexStroom). I'm not completely understanding how to work with putting data in some sort of array (which I can't see) and then working with that. I have always just used user variables and am new to this approach. I hope someone can help me. I would like to identify both the lowest price and the highest price, but more importantly, at which time of day they occur.
This has nothing to do with the global variable. By the way, you can find the variables in the domoticz/scripts/dzVents/data folder.
Your problem has probably to do with the number of items that's available in the dataset. The loop goes outside the available range at some times.
I recognize the problem and have made quite a few changes to my script. Here's my current script for inspiration. Not completely finished yet, but hopefully this will help out.
-- Script to load day-ahead electricity and gas prices into Domoticz historic variables, as a base for further processing.
-- New electricity prices are available every day at 13:00 for the coming 24 hrs. These are base prices. Providers of dynamic electricity contracts will add their surcharges and government taxes to it.
-- API documentation at: https://transparency.entsoe.eu/content/static_content/Static%20content/web%20api/Guide.html
--    1) Register for an account at https://transparency.entsoe.eu/dashboard/show and send an email with subject "Restful API access" and your account email address in the body to [email protected]
--    2) After receipt of their confirmation, go into your account and generate your token.
--    3) Update variables and idx's on the lines below (including EUtoken which you just generated!)
-- Device idx's
local idxStroomP1                   = <idx>
local idxGasP1                      = <idx>
local idxSolar                      = <idx>
local idxCurrentDynamicStroomPrice  = <idx>
local idxDynamicStroomCosts         = <idx>
local idxDynamicSolarRevenue        = <idx>
local idxCurrentDynamicGasPrice     = <idx>
local idxDynamicGasCosts            = <idx>
local idxEnergyCosts                = <idx>
local idxVirtualEnergyCosts         = <idx>
local idxlowPriceIndex1             = <idx>
local idxlowPriceIndex2             = <idx>
local idxlowPriceIndex3             = <idx>
local idxlowPriceIndex4             = <idx>
-- variables for EU market prices gas and electricity
local UrlStart                      = 'https://web-api.tp.entsoe.eu/api?'           -- EU electricity API - launch the EU electricity API get request
local DocType                       = 'A44'                                         -- EU electricity API - day ahead prices document type
local PriceRegion                   = '10YNL----------L'                            -- EU electricity API - region is set to The Netherlands (adapt to your need as per API documentation)
local EUtoken                       = 'f9eb2b55-708b-4464-ae62-6d1185435b44'        -- EU electricity API - API token
local GASUrlStart                   = 'https://api.energyzero.nl/v1/energyprices?'  -- Gas API website
local usageType                     = 2                                             -- Gas
	on = {  timer = {   'at *:45',                                                  -- Get new price arrays. Prices received are in UTC so 1 hour shift needed
        -- Prices are re-loaded every hour, to avoid using old prices when there is one error loading once per day.
		                'at *:55',                                                  -- Determine cheapest hour frames and calculate the costs of the past hour (missing last minutes, added to next hour, except end of day)
		                'at *:59' },                                                -- Store cost/revenue to corresponding devices, update current prices and set switches on/off
		    httpResponses = {   'EUprices',                                         -- must match with the callback passed to the openURL command in the code below
			                    'EZGASprices', } },
	data =  {   StroomHourPrices            = { history = true, maxItems = 48 },
                NrRecordsStroom             = { initial = 24},
                GasDayPrices                = { history = true, maxItems = 24 },
                NrRecordsGas                = { initial = 24},
                PreviousHrCumStroomCosts    = { initial = 0},
                PreviousHrCumStroomNett     = { initial = 0},
                PreviousHrCumSolarRevenue   = { initial = 0},
                PreviousHrCumSolarNett      = { initial = 0},
                PreviousHrCumGasCosts       = { initial = 0},
                PreviousHrCumGasNett        = { initial = 0},
                lowPriceIndex1              = { initial = 0},
                lowPriceIndex2              = { initial = 0},
                lowPriceIndex3              = { initial = 0},
                lowPriceIndex4              = { initial = 0},
                SwitchOnTime1               = { initial = 0},
                SwitchOnTime2               = { initial = 0},
                SwitchOnTime3               = { initial = 0},
                SwitchOnTime4               = { initial = 0},
    logging = { level   = domoticz.LOG_INFO,
		        marker  = 'EU and EZ day ahead prices', },
        -- Variables
        local BTW                           = 21                                            -- BTW percentage
        local DayStroomFixed                = 0                                             -- Fixed daily costs electrcity (excl. BTW)
        local MonthStroomFixed              = -11.52892562                                  -- Fixed monthly costs electricity (excl. BTW)
        local kwhStroom                     = 0.128471074                                   -- Variable costs electricity (per KwH), on top of EU market price (excl. BTW) -> (0,128471074 + 0,003)/1,21
        local DayGasFixed                   = 0                                             -- Fixed daily costs gas (excl. BTW)
        local MonthGasFixed                 = 19.4214876                                    -- Fixed monthly costs gas (excl. BTW)
        local m3Gas                         = 0.531123967                                   -- Variable costs gas (per m3), on top of EU market price (excl. BTW)
        local Time                          = require('Time')
        local ContractEindDatum             = Time('2023-2-28 23:59:59')                    -- Einddatum huidige energiecontract
        if domoticz.time.compare(ContractEindDatum).compare < 0 then                        -- Tarieven na ContractEindDatum bij contractwijziging
	    local StroomHourPrices      = domoticz.data.StroomHourPrices
	    local GasDayPrices          = domoticz.data.GasDayPrices
	    local todayStroom           = domoticz.devices(idxStroomP1).counterToday
	    local todayStroomreturn     = domoticz.devices(idxStroomP1).counterDeliveredToday
	    local todayGas              = domoticz.devices(idxGasP1).counterToday
	    local todaySolar            = domoticz.devices(idxSolar).counterToday
        local NrRecordsStroom       = domoticz.data.NrRecordsStroom
        local VarIndexStroom        = NrRecordsStroom-tonumber(os.date("%H"))        -- last price of day is index 1
        local NrRecordsGas          = domoticz.data.NrRecordsGas
        local VarIndexGas           = NrRecordsGas-tonumber(os.date("%H"))
	    if (item.isTimer) then
 	        if (item.trigger == 'at *:59') then
                if (tonumber(os.date("%H")) == 23) then
                    domoticz.devices(idxDynamicStroomCosts).updateCustomSensor(domoticz.data.PreviousHrCumStroomCosts)
                    domoticz.devices(idxDynamicSolarRevenue).updateCustomSensor(domoticz.data.PreviousHrCumSolarRevenue)
                    domoticz.devices(idxDynamicGasCosts).updateCustomSensor(domoticz.data.PreviousHrCumGasCosts)
                    domoticz.devices(idxEnergyCosts).updateCustomSensor(domoticz.data.PreviousHrCumStroomCosts + domoticz.data.PreviousHrCumGasCosts)
                    domoticz.devices(idxVirtualEnergyCosts).updateCustomSensor(domoticz.data.PreviousHrCumStroomCosts + domoticz.data.PreviousHrCumGasCosts)
        -- copy dynamic price to device holding the current price
	            local CurrentStroomPrice=tonumber(StroomHourPrices.get(VarIndexStroom - 1).data)/1000 + kwhStroom                               -- from EURO/MWh to EURO/kWh + (supplier) price per KwH
                local CurrentStroomPriceBTW = CurrentStroomPrice * (100 + BTW)/100
                domoticz.log('Current Dynamic Stroom price Euro/kWh: ' .. CurrentStroomPriceBTW,domoticz.LOG_INFO)
	            domoticz.devices(idxCurrentDynamicStroomPrice).updateCustomSensor(CurrentStroomPriceBTW)
	            if VarIndexGas < 3  then
	                VarIndexGas = 1
	                VarIndexGas = VarIndexGas - 2        -- -1 (dataset starts at 23:00) -1 (script runs 1 minute before :00)
	            local CurrentGasPrice=tonumber(GasDayPrices.get(VarIndexGas).data) + m3Gas                                                      -- Euro per m3, last price is for 00:00 to 01:00 next day.
	            local CurrentGasPriceBTW = CurrentGasPrice * (100 + BTW)/100
	            domoticz.log('Current Dynamic Gas price Euro/m3: ' .. CurrentGasPriceBTW,domoticz.LOG_INFO)
	            domoticz.devices(idxCurrentDynamicGasPrice).updateCustomSensor(CurrentGasPriceBTW)
                --if tonumber(os.date("%H")) < 9 or tonumber(os.date("%H")) > 19 then
                    --domoticz.notify('VarIndexGas','VarIndexGas: ' .. VarIndexGas .. ' (' .. NrRecordsGas .. ' records)',domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                    --domoticz.notify('Dynamic Gas price','Gas price: ' .. CurrentGasPriceBTW,domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                --end
                if tonumber(os.date("%H")) == NrRecordsStroom-1-domoticz.data.lowPriceIndex1 then                                               -- Set switches with 1 hour frame on
                    --domoticz.notify('Goedkoopste tijdslot','Start goedkoopste tijdslot van 1 uur (index ' .. NrRecordsStroom-1-domoticz.data.lowPriceIndex1 .. ')',domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                    domoticz.log('Zet schakelaars voor laden apparatuur aan (1 uur frame)',domoticz.LOG_INFO)
                    domoticz.data.SwitchOnTime1 = tonumber(os.date("%H"))
                    --domoticz.devices('Name or idx switch').switchOn().checkFirst()
                if tonumber(os.date("%H")) == NrRecordsStroom-1-domoticz.data.lowPriceIndex2 then                                               -- Set switches with 2 hour frame on
                    --domoticz.notify('Goedkoopste tijdslot','Start goedkoopste tijdslot van 2 uur (index ' .. NrRecordsStroom-1-domoticz.data.lowPriceIndex2 .. ')',domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                    domoticz.log('Zet schakelaars voor laden apparatuur aan (2 uurs frame)',domoticz.LOG_INFO)
                    domoticz.data.SwitchOnTime2 = tonumber(os.date("%H"))
                if tonumber(os.date("%H")) == NrRecordsStroom-1-domoticz.data.lowPriceIndex3 then                                               -- Set switches with 3 hour frame on
                    --domoticz.notify('Goedkoopste tijdslot','Start goedkoopste tijdslot van 3 uur (index ' .. NrRecordsStroom-1-domoticz.data.lowPriceIndex3 .. ')',domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                    domoticz.log('Zet schakelaars voor laden apparatuur aan (3 uurs frame)',domoticz.LOG_INFO)
                    domoticz.data.SwitchOnTime3 = tonumber(os.date("%H"))
                if tonumber(os.date("%H")) == NrRecordsStroom-1-domoticz.data.lowPriceIndex4 then                                               -- Set switches with 4 hour frame on
                    --domoticz.notify('Goedkoopste tijdslot','Start goedkoopste tijdslot van 4 uur (index ' .. NrRecordsStroom-1-domoticz.data.lowPriceIndex4 .. ')',domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                    domoticz.log('Zet schakelaars voor laden apparatuur aan (4 uurs frame)',domoticz.LOG_INFO)
                    domoticz.data.SwitchOnTime4 = tonumber(os.date("%H"))
                if tonumber(os.date("%H")) == domoticz.data.SwitchOnTime1 + 1 then                                                              -- Set switches with 1 hour frame off
                    --domoticz.notify('Goedkoopste tijdslot','Eind goedkoopste tijdslot van 1 uur (index ' .. NrRecordsStroom-1-domoticz.data.lowPriceIndex1 + 1 .. ')',domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                    domoticz.log('Zet schakelaars voor laden apparatuur uit (1 uur frame)',domoticz.LOG_INFO)
                    --domoticz.devices('Name or idx switch').switchOff().checkFirst()
                if tonumber(os.date("%H")) == domoticz.data.SwitchOnTime2 + 2 then                                                              -- Set switches with 2 hour frame off
                    --domoticz.notify('Goedkoopste tijdslot','Eind goedkoopste tijdslot van 2 uur (index ' .. NrRecordsStroom-1-domoticz.data.lowPriceIndex2 + 2 .. ')',domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                    domoticz.log('Zet schakelaars voor laden apparatuur uit (2 uurs frame)',domoticz.LOG_INFO)
                if tonumber(os.date("%H")) == domoticz.data.SwitchOnTime3 + 3 then                                                              -- Set switches with 3 hour frame off
                    --domoticz.notify('Goedkoopste tijdslot','Eind goedkoopste tijdslot van 3 uur (index ' .. NrRecordsStroom-1-domoticz.data.lowPriceIndex3 + 3 .. ')',domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                    domoticz.log('Zet schakelaars voor laden apparatuur uit (3 uurs frame)',domoticz.LOG_INFO)
                if tonumber(os.date("%H")) == domoticz.data.SwitchOnTime4 + 4 then                                                              -- Set switches with 4 hour frame off
                    --domoticz.notify('Goedkoopste tijdslot','Eind goedkoopste tijdslot van 4 uur (index ' .. NrRecordsStroom-1-domoticz.data.lowPriceIndex4 + 4 .. ')',domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_TELEGRAM)
                    domoticz.log('Zet schakelaars voor laden apparatuur uit (4 uurs frame)',domoticz.LOG_INFO)
	            if (item.trigger == 'at *:55') then        -- first calculate cumulative daily total and last hour electricity usage
    	            local todayStroomNett=domoticz.devices(idxStroomP1).counterToday-domoticz.devices(idxStroomP1).counterDeliveredToday
    	            local lastHrStroomNett = todayStroomNett - domoticz.data.PreviousHrCumStroomNett
                    local lastHrStroomCosts = lastHrStroomNett * domoticz.devices(idxCurrentDynamicStroomPrice).sensorValue * (100 + BTW)/100   -- then calculate the costs and add to device
    	            local CumStroomCosts = domoticz.utils.round(domoticz.data.PreviousHrCumStroomCosts + lastHrStroomCosts,2)
    	            domoticz.devices(idxDynamicStroomCosts).updateCustomSensor(CumStroomCosts)
        domoticz.log('todayStroomNett: ' .. domoticz.devices(idxStroomP1).counterToday-domoticz.devices(idxStroomP1).counterDeliveredToday,domoticz.LOG_INFO)
        domoticz.log('counterToday: ' .. domoticz.devices(idxStroomP1).counterToday,domoticz.LOG_INFO)
        domoticz.log('counterDeliveredToday: ' .. domoticz.devices(idxStroomP1).counterDeliveredToday,domoticz.LOG_INFO)
        domoticz.log('lastHrStroomNett: ' .. lastHrStroomNett,domoticz.LOG_INFO)
        domoticz.log('lastHrStroomCosts: ' .. lastHrStroomCosts,domoticz.LOG_INFO)
        domoticz.log('CumStroomCosts: ' .. CumStroomCosts,domoticz.LOG_INFO)
    	            if (tonumber(os.date("%H"))==23) then        -- if end of day, reset the cumulative daily totals
    	                domoticz.data.PreviousHrCumStroomCosts = (DayStroomFixed+MonthStroomFixed/31) * (100 + BTW)/100
    	                domoticz.data.PreviousHrCumStroomNett = 0
    	                domoticz.data.PreviousHrCumStroomCosts = CumStroomCosts
    	                domoticz.data.PreviousHrCumStroomNett = todayStroomNett
    	            local todaySolarNett=domoticz.devices(idxSolar).counterToday
    	            local lastHrSolarNett = todaySolarNett - domoticz.data.PreviousHrCumSolarNett
                    local lastHrSolarRevenue = lastHrSolarNett * domoticz.devices(idxCurrentDynamicStroomPrice).sensorValue * (100 + BTW)/100   -- then calculate the costs and add to device
    	            local CumSolarRevenue = domoticz.utils.round(domoticz.data.PreviousHrCumSolarRevenue + lastHrSolarRevenue,2)
    	            domoticz.devices(idxDynamicSolarRevenue).updateCustomSensor(CumSolarRevenue)
        domoticz.log('counterToday Solar: ' .. domoticz.devices(idxSolar).counterToday,domoticz.LOG_INFO)
        domoticz.log('lastHrSolarNett: ' .. lastHrSolarNett,domoticz.LOG_INFO)
        domoticz.log('lastHrSolarRevenue: ' .. lastHrSolarRevenue,domoticz.LOG_INFO)
        domoticz.log('CumSolarRevenue: ' .. CumSolarRevenue,domoticz.LOG_INFO)
    	                domoticz.data.PreviousHrCumSolarRevenue = 0
    	                domoticz.data.PreviousHrCumSolarNett = 0
    	                domoticz.data.PreviousHrCumSolarRevenue = CumSolarRevenue
    	                domoticz.data.PreviousHrCumSolarNett = todaySolarNett
    	            local todayGasNett=domoticz.devices(idxGasP1).counterToday        -- calculate cumulative daily total and last hour gas usage
    	            local lastHrGasNett = todayGasNett - domoticz.data.PreviousHrCumGasNett
    	            local lastHrGasCosts = lastHrGasNett * domoticz.devices(idxCurrentDynamicGasPrice).sensorValue * (100 + BTW)/100            -- then calculate the costs and add to device
    	            local CumGasCosts = domoticz.utils.round(domoticz.data.PreviousHrCumGasCosts + lastHrGasCosts,2)
    	            domoticz.devices(idxDynamicGasCosts).updateCustomSensor(CumGasCosts)
        domoticz.log('counterToday todayGasNett: ' .. domoticz.devices(idxGasP1).counterToday,domoticz.LOG_INFO)
        domoticz.log('lastHrGasNett: ' .. lastHrGasNett,domoticz.LOG_INFO)
        domoticz.log('lastHrGasCosts: ' .. lastHrGasCosts,domoticz.LOG_INFO)
        domoticz.log('CumGasCosts: ' .. CumGasCosts,domoticz.LOG_INFO)
    	                domoticz.data.PreviousHrCumGasCosts = (DayGasFixed+MonthGasFixed/31) * (100 + BTW)/100
    	                domoticz.data.PreviousHrCumGasNett = 0
    	                domoticz.data.PreviousHrCumGasCosts = CumGasCosts
    	                domoticz.data.PreviousHrCumGasNett = todayGasNett
	                local TotalCosts = tonumber(domoticz.utils.round((CumStroomCosts + CumGasCosts),2))
                    local TotalUse = tonumber(domoticz.utils.round((TotalCosts + CumSolarRevenue),2))
    	            domoticz.devices(idxEnergyCosts).updateCustomSensor(TotalCosts)
                    domoticz.devices(idxVirtualEnergyCosts).updateCustomSensor(TotalUse)
        domoticz.log('TotalCosts: ' .. TotalCosts,domoticz.LOG_INFO)
        domoticz.log('TotalUse: ' .. TotalUse,domoticz.LOG_INFO)
        -- Determine cheapest time frames in the next period
            	    local IndexStart, TimeStart, IndexEnd, TimeEnd, min, TimeFrame, currentSum
            	    local NrAvailablePrices = 8        -- # available records: max 10. Or # available records - records in the past - max Timeframe (4)
            	    if NrRecordsStroom - tonumber(os.date("%H")) - 4 - 1 < 10 then
            	        NrAvailablePrices = NrRecordsStroom - tonumber(os.date("%H")) - 4
            	    for TimeFrame = 1, 4 do
            	        min = math.huge        -- starting point for minimum value (infinity)
            	        IndexStart = 0        -- index values for start timeframe with lowest price
            	        IndexEnd = 0        -- index values for end timeframe with lowest price
                		for i = VarIndexStroom - NrAvailablePrices -1, VarIndexStroom - TimeFrame do
                		    currentSum = 0        -- temporary value for calculation lowest prices in time frames
                		    for IndexEnd = i, i + TimeFrame - 1 do
                			    currentSum = currentSum + tonumber(StroomHourPrices.get(IndexEnd).data)
                			if currentSum <= min then
                				min = currentSum
                				IndexEnd = i
                				IndexStart = i + TimeFrame - 1
                        if 24-IndexStart < 0 then
                            TimeStart = 48-IndexStart
                            TimeStart = 24-IndexStart
                        if 24-IndexEnd < 0 then
                            TimeEnd = 48-IndexEnd
                            TimeEnd = 24-IndexEnd
                        domoticz.log('Cheapest ' .. TimeFrame .. ' hour frame ' .. TimeStart .. ':00 uur (' ..tonumber(StroomHourPrices.get(IndexStart).data) .. ') tot  ' .. TimeEnd .. ':59 uur (' ..tonumber(StroomHourPrices.get(IndexEnd).data) .. ')',domoticz.LOG_INFO)
                        if TimeFrame == 1 then
                            domoticz.data.lowPriceIndex1 = IndexStart
                            domoticz.devices(idxlowPriceIndex1).updateCustomSensor(TimeStart)
                        elseif TimeFrame == 2 then
                            domoticz.data.lowPriceIndex2 = IndexStart
                            domoticz.devices(idxlowPriceIndex2).updateCustomSensor(TimeStart)
                        elseif TimeFrame == 3 then
                            domoticz.data.lowPriceIndex3 = IndexStart
                            domoticz.devices(idxlowPriceIndex3).updateCustomSensor(TimeStart)
                        elseif TimeFrame == 4 then
                            domoticz.data.lowPriceIndex4 = IndexStart
                            domoticz.devices(idxlowPriceIndex4).updateCustomSensor(TimeStart)
	            else        -- at *:45: depending on launch hour, get current or tomorrow's data
        	        local PricePeriodStart=os.date("%Y%m%d",os.time()) .. "0000"        -- range 00:00 to 23:00, this will return full day anyway
        	        local PricePeriodEnd=os.date("%Y%m%d", os.time() + 24*60*60) .. "2300"                                                      -- depending on time the script is launched, get current day and/or tomorrow's data
        	        local EUurl=UrlStart .. 'securityToken=' .. EUtoken .. '&documentType=' .. DocType .. '&in_Domain=' .. PriceRegion .. '&out_Domain=' .. PriceRegion .. '&periodStart=' .. PricePeriodStart .. '&periodEnd=' .. PricePeriodEnd
                    domoticz.log("URL : " .. EUurl, domoticz.LOG_INFO)
        			domoticz.openURL({  url         = EUurl,        -- launch url
        				                method      = 'GET',
        				                callback    = 'EUprices', })        -- must match httpResponses above
        -- section to launch the EnergyZero gas prices API get request (UTC timing), run between 00:00 and 01:00
        	        local GasPricePeriodStart=os.date("%Y-%m-%d",os.time()) .. "T00:00:00.000Z"                                                 -- always get current day data. This first price is valid from 01:00 CET
        	        local GASPricePeriodEnd=os.date("%Y-%m-%d", os.time()) .. "T23:59:59.999Z"
        	        local EZurl=GASUrlStart .. 'fromDate=' .. GasPricePeriodStart .. '&tillDate=' .. GASPricePeriodEnd .. '&interval=4&usageType=' .. usageType .. '&inclBtw=false'
                    domoticz.log("URL : " .. EZurl, domoticz.LOG_INFO)
        			domoticz.openURL({  url         = EZurl,        -- launch url
        				                method      = 'GET',
        				                callback    = 'EZGASprices', })        -- must match httpResponses above
		    if (item.isHTTPResponse) then        -- response to openURL (HTTP GET) request was received
		        if (item.trigger=="EUprices") then
    			    if (item.ok) then
    			        if (item.isXML) then        -- should be XML
                            StroomHourPrices.reset()        -- remove historic prices from previous run
                            if #item.xml.Publication_MarketDocument.TimeSeries == 2 then
                                domoticz.data.NrRecordsStroom = 48
                                for TS = 1, 2 do
                                    for id = 1, 24 do
                                        if TS == 1 then
                                            domoticz.log('Stroom marktprijs vandaag vanaf ' .. id-1 .. ':00 uur: ' .. item.xml.Publication_MarketDocument.TimeSeries[TS].Period.Point[id]['price.amount']/1000 .. " (" .. domoticz.utils.round((item.xml.Publication_MarketDocument.TimeSeries[TS].Period.Point[id]['price.amount']/1000 + kwhStroom) * (100 + BTW) / 100,4) .. " incl.)",domoticz.LOG_INFO)
                                            domoticz.log('Stroom marktprijs morgen vanaf ' .. id-1 .. ':00 uur: ' .. item.xml.Publication_MarketDocument.TimeSeries[TS].Period.Point[id]['price.amount']/1000  .. " (" .. domoticz.utils.round((item.xml.Publication_MarketDocument.TimeSeries[TS].Period.Point[id]['price.amount']/1000 + kwhStroom) * (100 + BTW) / 100,4) .. " incl.)",domoticz.LOG_INFO)
                                        StroomHourPrices.add(item.xml.Publication_MarketDocument.TimeSeries[TS].Period.Point[id]['price.amount'])
                                domoticz.data.NrRecordsStroom = 24
                                for id = 1, 24 do
                                    domoticz.log('Stroom marktprijs vanaf ' .. id-1 .. ':00 uur: ' .. item.xml.Publication_MarketDocument.TimeSeries.Period.Point[id]['price.amount']/1000  .. " (" .. domoticz.utils.round((item.xml.Publication_MarketDocument.TimeSeries.Period.Point[id]['price.amount']/1000 + kwhStroom) * (100 + BTW) / 100,4) .. " incl.)",domoticz.LOG_INFO)
                                    StroomHourPrices.add(item.xml.Publication_MarketDocument.TimeSeries.Period.Point[id]['price.amount'])
                            domoticz.log('No XML received', domoticz.LOG_INFO)
    				    domoticz.log('There was a problem handling the request. Item not ok', domoticz.LOG_INFO)
    				    if item.statusCode == 503 then
    				        domoticz.log('Electriciteitsprijzen tijdelijk niet beschikbaar ivm onderhoud. HTTP statuscode: ' .. item.statusCode .. ' - ' .. item.statusText, domoticz.LOG_INFO)
    				        domoticz.log('Foutsituatie. HTTP statuscode: ' .. item.statusCode .. ' - ' .. item.statusText, domoticz.LOG_INFO)
	            else        -- trigger was not EU electricity prices but energyzero gas prices
    	            if (item.ok) then
    			        if (item.isJSON) then        -- should be JSON
    			            GasDayPrices.reset()        -- remove historic prices from previous run
                            domoticz.data.NrRecordsGas = #item.json.Prices
    			            for gasid = 1, domoticz.data.NrRecordsGas do        -- add prices from current day 01:00-02:00 to next day 00:00-01:00 intervals
                                domoticz.log('Gas marktprijs vandaag vanaf: ' .. gasid .. ':00 uur: ' .. item.json.Prices[gasid].price .. " (" .. domoticz.utils.round((item.json.Prices[gasid].price + m3Gas) * (100 + BTW) / 100,4) .. " incl.)",domoticz.LOG_INFO)
                                GasDayPrices.add(item.json.Prices[gasid].price)
                            domoticz.log('No JSON received', domoticz.LOG_INFO)
    				    domoticz.log('There was a problem handling the request. Returned XML item is not ok.', domoticz.LOG_INFO)
    				        domoticz.log('Gasprijzen tijdelijk niet beschikbaar ivm onderhoud. HTTP statuscode: ' .. item.statusCode .. ' - ' .. item.statusText, domoticz.LOG_INFO)
Hi JanvdW, thanks for this script, I like it and want to use it, but unfortunately it lacks sensible comments. Could your please give a global outline of what it is exactly doing? I've been trying to understand the working for about a week now, but I make very little progress. No need to understand it so deep as would be able to write it from scratch, right?
Posted: Saturday 08 June 2024 14:45
by waltervl
Nateonas wrote: Saturday 08 June 2024 13:48 Hi JanvdW, thanks for this script, I like it and want to use it, but unfortunately it lacks sensible comments. Could your please give a global outline of what it is exactly doing? I've been trying to understand the working for about a week now, but I make very little progress. No need to understand it so deep as would be able to write it from scratch, right?
Perhaps check the native enever hardware gateway that does the same without scripting.
Posted: Tuesday 11 June 2024 8:52
by Nateonas
Thanks for the response! I've tried that, but (to my humble opinion) the Enever-plugin is very low on features.
* This dzvents script can be used for non Dutch users,
* it provides both clean spot prices and configurable supplier prices (surcharges, periodic costs and VAT),
* it retrieves the spotprices from entsoe and energyzero. Both do not limit the number of requests (enever does).
* it can calculate:
- the hourly electricity, gas and total energy costs based on near real time usage and delivery.
- solar revenue or savings
- cheap electricity hours, activate switches (like home batteries) and send notifications
Enever-plugin doesn't provide any of these features, so if you want them you need to code them anyway. This dzvents is just not finished yet (as JanvdW wrote himself) and it lacks comments making it really difficult to start improving it...
Posted: Tuesday 11 June 2024 9:58
by waltervl
There are some developments on the beta environment that can do costs calculations natively, so perhaps wait a couple of weeks to arrive this in Stable or be brave and switch to beta.
But still can not do all the things you say the script can do.....
Posted: Thursday 10 October 2024 10:38
by PVerm
Hi Willemd,
I use your script everyday and have to say it worked flawless till start of October '24.
I suspect that from that time the xml-data-pattern has been changed on the Entsoe-site because from now on it is not possible to update anymore. The log shows:
2024-10-06 23:08:07.529 Error: dzVents: Error: (3.1.7) dzDailyEnergyPrices: An error occurred when calling event handler dzDailyEnergyPrices
2024-10-06 23:08:07.529 Error: dzVents: Error: (3.1.7) dzDailyEnergyPrices: ...cripts/dzVents/generated_scripts/dzDailyEnergyPrices.lua:280: attempt to index a nil value (field 'Point')
I don't have any experience with transferring xml to arrays, could you please take a look what is going wrong?
Posted: Thursday 10 October 2024 14:47
by PVerm
Hi WIllemd, sorry to bother you, it looks that the error below is solved, the Domoticz system was now able to retreive new updates this afternoon, also for tomorrow. I cannot find another reason than that the api-Entsoe-site had a hick. I saw on their site that there were some troubles with server-maintenance the past days.
PVerm wrote: Thursday 10 October 2024 10:38 Hi Willemd,
Posted: Thursday 17 October 2024 13:54
by willemd
They are moving the transparency platform to a new website and doing data migration.
The API seems to be working still, not sure how much that is going to change.
They had some emergency outaged as well on Oct 10 and 11.
Posted: Monday 10 February 2025 12:28
by psubiaco
Hi.
A script that fetches data from ENTSO for a selected zone, and showing the day-ahead energy price is very useful.
But, can anybody publish the link to the last version of the script? Perhaps a github repository will be perfect!
Thanks a lot!
Paolo
@willemd @PVerm ...
Posted: Tuesday 11 February 2025 18:55
by willemd
here is my current version. It is still working even though the website has moved. I need to check whether that will continu into the future.
It might have been polluted a bit after I switched to a new smart meter that increased the frequeny of data. I did not adapt all the comments.
Also it calculates costs and puts that on counters. So please remove the part that you do not need.
-- Script to load day-ahead electricity prices into Domoticz historic variables, as a base for further processing.
-- New prices are available every day at 15:00 for the coming 24 hrs.
-- These are base prices. Providers of dynamic electricity contracts will add their surcharges and government taxes to it.
-- To get this data yourself (it is free):
--    2) Send an email with subject "Restful API access" and your account email address in the body
--    3) After receipt of their confirmation, go into your account and generate your token.
--    4) Store the token in a domoticz user variable and note down the idx.
--    5) Adapt the idx on the line below.
-- devices
local idxElectricityP1=1
local idxGasP1=2
local idxCurrentDynamicElPrice=102
local idxDynamicElCosts=103
local idxDynamicElCostsCntr=104  -- counters are just added for testing, work fine as long as costs are positive
local idxCurrentDynamicGasPrice=107
local idxDynamicGasCosts=108
local idxDynamicGasCostsCntr=109 -- counters are just added for testing, work fine as long as costs are positive
-- user variables
local idxEUtoken=12  -- idx of the user variable with the API token
local idxBTWpercentage=13 -- user variable with BTW/VAT percentage
local idxDayElTransport=3 -- user variable for fixed daily transport costs, incl BTW
local idxMonthElFixed=8   -- user variable for fixed monthly costs, incl BTW
local idxDayGasTransport=6 -- user variable for fixed daily transport costs, incl BTW
local idxMonthGasFixed=8   -- user variable for fixed monthly costs, incl BTW
local idxElTax=4          -- user variable for electricity tax, incl BTW
local idxGasTax=7         -- user variable for gas tax, incl BTW
local idxElInkoop=22      -- user variable for purchase costs charge in dynamic electricity contract
		timer = {
		    'at *:45',  -- Timer to get new electricity prices. Adapt timer to your needs. Normally new electricty prices are available after 15:00.
		                -- Timer to get new gas prices. Prices received are in UTC so 1 hour shift needed for me.
		                -- Prices are now re-loaded every hour, to avoid using old prices when there is one error loading once per day.
		    'at *:59',   -- trigger to calculate the costs of the past hour (missing 1 minute, added to next hour, except end of day)
		    'at *.05',   -- repeat the gas cost calculation since now the qty has been received from the P1 meter
		    'at *:01'    -- trigger to copy price from list (24 historic variables) to device with current price
		httpResponses = {
			'EZGASprices',
	data =  {
            ElDayPrices               = { history = true, maxItems = 24 },
            PreviousHrCumElCosts      = { initial = 0},
            PreviousHrCumElNett       = { initial = 0},
            PreviousHrGasPrice         = { initial = 0}
	logging = {
	    local ElDayPrices = domoticz.data.ElDayPrices
	    local todayEl = domoticz.devices(idxElectricityP1).counterToday
	    local todayElreturn = domoticz.devices(idxElectricityP1).counterDeliveredToday
	        if (item.trigger == 'at *:01') then
	            local VarIndex=24-tonumber(os.date("%H")) -- last price of day is index 1
	            local CurrentElPrice=tonumber(ElDayPrices.get(VarIndex).data)/1000 -- from EURO/MWh to EURO/kWh
	            CurrentElPrice=CurrentElPrice * (100 + domoticz.variables(idxBTWpercentage).value)/100 -- add BTW/VAT
	            domoticz.log('Current Dynamic El price EURO/kWh :' .. CurrentElPrice,domoticz.LOG_INFO)
	            domoticz.devices(idxCurrentDynamicElPrice).updateCustomSensor(CurrentElPrice)
	            -- also copy gas prices to current device
	            if tonumber(os.date("%H"))==0 then
	                VarIndex=1
	                VarIndex=24-tonumber(os.date("%H"))+1
	            local CurrentGasPrice=tonumber(GasDayPrices.get(VarIndex).data) -- Euro per m3, last price is for 00:00 to 01:00 next day.
	            CurrentGasPrice=CurrentGasPrice * (100 + domoticz.variables(idxBTWpercentage).value)/100 -- add BTW/VAT
	            domoticz.log('Current Dynamic Gas price :' .. CurrentGasPrice,domoticz.LOG_INFO)
	            domoticz.devices(idxCurrentDynamicGasPrice).updateCustomSensor(CurrentGasPrice)
	            if (tonumber(os.date("%H")) == 0) then
	                domoticz.devices(idxDynamicElCosts).updateCustomSensor(domoticz.data.PreviousHrCumElCosts)
    	            local todayElNett=domoticz.devices(idxElectricityP1).counterToday-domoticz.devices(idxElectricityP1).counterDeliveredToday
    	            domoticz.log('counterToday :' .. domoticz.devices(idxElectricityP1).counterToday,domoticz.LOG_INFO)
    	            domoticz.log('counterDeliveredToday :' .. domoticz.devices(idxElectricityP1).counterDeliveredToday,domoticz.LOG_INFO)
    	            domoticz.log('todayElNett :' .. todayElNett,domoticz.LOG_INFO)
    	            local lastHrElNett = todayElNett - domoticz.data.PreviousHrCumElNett
    	            domoticz.log('lastHrElNett :' .. lastHrElNett,domoticz.LOG_INFO)
    	            local lastHrElCosts = lastHrElNett * domoticz.devices(idxCurrentDynamicElPrice).sensorValue + lastHrElNett * domoticz.variables(idxElTax).value + lastHrElNett * domoticz.variables(idxElInkoop).value  -- tax variable is already including BTW/VAT
    	            domoticz.log('lastHrElCosts :' .. lastHrElCosts,domoticz.LOG_INFO)
    	            local CumElCosts = domoticz.utils.round(domoticz.data.PreviousHrCumElCosts + lastHrElCosts,2)
    	            domoticz.log('CumElCosts :' .. CumElCosts,domoticz.LOG_INFO)
    	            domoticz.devices(idxDynamicElCosts).updateCustomSensor(CumElCosts)
    	            local previousCounter=0
		            local divider=100
		            previousCounter=domoticz.devices(idxDynamicElCostsCntr).counter
		            --domoticz.devices(idxDynamicElCostsCntr).updateCounter(lastHrElCosts*divider + previousCounter*divider)
		            domoticz.devices(idxDynamicElCostsCntr).updateCounter(CumElCosts*divider)
		            domoticz.log('previousCounter :' .. previousCounter,domoticz.LOG_INFO)
		            domoticz.log('newcounter :' .. lastHrElCosts + previousCounter,domoticz.LOG_INFO)
    	                domoticz.data.PreviousHrCumElCosts=domoticz.utils.round(domoticz.variables(idxDayElTransport).value+domoticz.variables(idxMonthElFixed).value/31,2) -- variables are including BTW/VAT
    	                domoticz.data.PreviousHrCumElNett=0
    	                domoticz.data.PreviousHrCumElCosts=CumElCosts
    	                domoticz.data.PreviousHrCumElNett=todayElNett
    	            -- first calculate cumulative daily total and last hour gas usage
    	            domoticz.log('counterToday :' .. domoticz.devices(idxGasP1).counterToday,domoticz.LOG_INFO)
    	            domoticz.log('todayGasNett :' .. todayGasNett,domoticz.LOG_INFO)
    	            domoticz.log('lastHrGasNett :' .. lastHrGasNett,domoticz.LOG_INFO)
    	            local lastHrGasCosts = lastHrGasNett * domoticz.devices(idxCurrentDynamicGasPrice).sensorValue +lastHrGasNett * domoticz.variables(idxGasTax).value -- tax variable is already including BTW/VAT
    	            domoticz.data.PreviousHrGasPrice=domoticz.devices(idxCurrentDynamicGasPrice).sensorValue   -- save this price to use in 6 minutes from now when the gas qty has been updated
    	            domoticz.log('lastHrGasCosts :' .. lastHrGasCosts,domoticz.LOG_INFO)
    	            domoticz.log('CumGasCosts :' .. CumGasCosts,domoticz.LOG_INFO)
    	            previousCounter=0
		            divider=100
		            previousCounter=domoticz.devices(idxDynamicGasCostsCntr).counter
		            --domoticz.devices(idxDynamicGasCostsCntr).updateCounter(lastHrGasCosts*divider + previousCounter*divider)
		            domoticz.devices(idxDynamicGasCostsCntr).updateCounter(CumGasCosts*divider)
		            domoticz.log('newcounter :' .. lastHrGasCosts + previousCounter,domoticz.LOG_INFO)
    	                domoticz.data.PreviousHrCumGasCosts=domoticz.utils.round(domoticz.variables(idxDayGasTransport).value+domoticz.variables(idxMonthGasFixed).value/31,2)  -- variables are including BTW/VAT
    	                domoticz.data.PreviousHrCumGasNett=0
    	                domoticz.data.PreviousHrCumGasCosts=CumGasCosts
    	                domoticz.data.PreviousHrCumGasNett=todayGasNett
	                if (item.trigger == 'at *.05') then  -- an extra trigger to repeat the update of the gas costs, since the gas qty is only received a few minutes after the hour
        	            local lastHrGasCosts = lastHrGasNett * domoticz.data.PreviousHrGasPrice +lastHrGasNett * domoticz.variables(idxGasTax).value -- tax variable is already including BTW/VAT
    		            local divider=100
            	        -- section to launch the EU electricity API get request
            	        local UrlStart='https://web-api.tp.entsoe.eu/api?'  -- the API website
            	        local EUtoken=domoticz.variables(idxEUtoken)        -- user variable with API token
            	        local DocType='A44'                                 -- day ahead prices document type
            	        local PriceRegion='10YNL----------L'                -- region is set to The Netherlands (adapt to your need as per API documentation)
            	        -- depending on launch hour, get current or tomorrow's data
            	        local dayahead=0
            	        if tonumber(os.date("%H"))>=23 then                 -- day ahead available after 15:00, otherwise retrieve current day, depending on the time this script is launched
            	            dayahead=24*60*60  -- seconds for full day ahead
            	        local PricePeriodStart=os.date("%Y%m%d",os.time()+ dayahead) .. "0000"  -- range 00:00 to 23:00, this will return full day anyway
            	        local PricePeriodEnd=os.date("%Y%m%d", os.time()+ dayahead) .. "2200"    -- depending on time the script is launched, get current day or tomorrow's data
            	        -- compose the full URL
            	        local EUurl=UrlStart .. 'securityToken=' .. EUtoken.value .. '&documentType=' .. DocType .. '&in_Domain=' .. PriceRegion .. '&out_Domain=' .. PriceRegion .. '&periodStart=' .. PricePeriodStart .. '&periodEnd=' .. PricePeriodEnd
            	        -- launch the URL
            			domoticz.openURL({
            				url = EUurl,
            				method = 'GET',
            				callback = 'EUprices', -- must match httpResponses above
            	        local GASUrlStart='https://api.energyzero.nl/v1/energyprices?'  -- the API website
            	        local usageType=2  -- GAS
            	        local GasPricePeriodStart=os.date("%Y-%m-%d",os.time()) .. "T00:00:00.000Z"  -- this first price is valid from 01:00 CET
            	        -- launch the URL
            			domoticz.openURL({
            				url = EZurl,
            				method = 'GET',
            				callback = 'EZGASprices', -- must match httpResponses above
    			    if (item.ok) then
    			            domoticz.log('start dumptable', domoticz.LOG_INFO)
    			            domoticz.utils.dumpTable(item.xml)  -- dumpTable can be used for debugging
    			            domoticz.log('end dumptable', domoticz.LOG_INFO)
    			            ElDayPrices.reset()  -- remove historic prices from previous run
    			            for id = 1, 24 do
                                domoticz.log('adding EL price : ' .. item.xml.Publication_MarketDocument.TimeSeries.Period.Point[id]['price.amount'],domoticz.LOG_INFO)
                                ElDayPrices.add(item.xml.Publication_MarketDocument.TimeSeries.Period.Point[id]['price.amount'])
                                local priceHour=(id-1)
                                if priceHour<10 then
                                    priceHourStr="0" .. priceHour
                                    priceHourStr=priceHour
                                local priceDate=os.date("%Y-%m-%d",os.time()) .. " " .. priceHourStr .. ":00:00"
                                domoticz.log('priceDate ' .. priceDate .. " price " .. item.xml.Publication_MarketDocument.TimeSeries.Period.Point[id]['price.amount'] , domoticz.LOG_INFO)
                                --domoticz.devices(177).updateHistory('
    				    domoticz.log(item, domoticz.LOG_INFO)
	                -- trigger was not eu electricity prices but energyzero gas prices
                    domoticz.log('start gasprices', domoticz.LOG_INFO)
    	            if (item.ok) then
    	                domoticz.log('gasprices ok', domoticz.LOG_INFO)
    			            domoticz.utils.dumpTable(item.json)  -- dumpTable can be used for debugging
    			            for gasid = 1, 24 do
    			                -- this adds prices from current day 01:00-02:00 to next day 00:00-01:00 intervals
                                domoticz.log('adding GAS price : ' .. item.json.Prices[gasid].price,domoticz.LOG_INFO)
Posted: Sunday 23 March 2025 7:47
by Alain
Has anybody given thought to the fact that as of June this year, the prices will be quarterly instead of hourly? The script will need to be changed.
Posted: Monday 24 March 2025 10:28
by gizmocuz
Yep, and not only scripts like these need to be changed
Posted: Thursday 30 October 2025 11:04
by willemd
I have adapted my script to load day-ahead dynamic prices onto managed counters (can be displayed in dashticz with todaytomorrow filter). It now handles 15-minute prices correctly. It also takes into account that sometimes pricepoints are missing and will then still handle the remaining available points correctly.
I also found that requesting and processing two days at the same time, with two separate http responses, did often crash Domoticz, so now it makes those requests with 3 minutes in between. Sometimes it still crashes Domoticz after processing the final price (but less often) I have no idea why. Below is a small first part of the error log.
2025-10-30 12:03:42.072  dzVents: EU future EL prices: position 96 priceDate 2025-10-30 23:45:00 priceHourStr 23 priceQtrStr45price 5700
2025-10-30 12:03:42.408  Error: Domoticz(pid:6817, tid:6818('SQLHelper')) received fatal signal 6 (Aborted)
2025-10-30 12:03:42.408  Error: siginfo address=0x1aa1, address=0x766efaa4
2025-10-30 12:03:47.594  Error: Did not find stack frame for thread (LWP 6818)), printing full gdb output:
2025-10-30 12:03:47.594  Error: > gdb: warning: Couldn't determine a path for the index cache directory.
2025-10-30 12:03:47.594  Error: > [New LWP 6818]
Anyway, much more reliable and correct. Here it is.
-- Script to load day-ahead electricity prices onto a managed counters.
-- The script loads prices excluding tax and including tax onto two managed counters and also uses a managed counter to indicate
-- the current hour, so that can be used in a graph to highlight that hour.
-- New prices are available every day at 15:00, sometimes earlier, for the coming 24 hrs.
-- The script takes the base prices and adds tax and fees to it, retrieved from user variables.
-- devices
local idxDynamicELPrices=177 -- excluding tax
local idxDynamicELPricesIncl=184 -- including tax
local idxCurrentHourIndicator=179 -- for use in Dashticz graph, indicating current hour
-- user variables
local idxElInkoop=22   -- usr variable for purchase fee per kWh on dynamic contract
		timer = {
		    'at *:03',  -- Timer to get new electricity prices. Adapt timer to your needs. Normally new electricty prices are available after 15:00.
		    'at *:06'   -- get first day at 03 and second day, if available, at 06
		httpResponses = {
			'ELday1prices', -- must match with the callback passed to the openURL command in the code below
			'ELday2prices', -- must match with the callback passed to the openURL command in the code below
	logging = {
		marker = 'EU future EL prices',
	        domoticz.log("item trigger "..item.trigger,domoticz.LOG_INFO)
	        if item.trigger=='at *:03' then
    	        --get data current day first
    	        local dayahead=0
    	        local PricePeriodStart=os.date("%Y%m%d",os.time() + dayahead) .. "0000"  -- range 00:00 to 23:00, this will return full day anyway
    	        local PricePeriodEnd=os.date("%Y%m%d", os.time() + dayahead) .. "2200"
    	        -- launch the URL
    			domoticz.openURL({
    				url = EUurl,
    				method = 'GET',
    				callback = 'ELday1prices', -- must match httpResponses above
		    if item.trigger=='at *:06' then
    			if Time().hour>=13 then
    			    -- get the data for the second day
        			local dayahead=24*60*60
        	        -- launch the URL
        			domoticz.openURL({
        				url = EUurl,
        				method = 'GET',
        				callback = 'ELday2prices', -- must match httpResponses above
			local PreviousHourDateTime=os.date("%Y-%m-%d %H:00:00",os.time() - 60*60)
			--domoticz.log("previous datetime " .. PreviousHourDateTime,domoticz.LOG_INFO)
			local NextHourDateTime=os.date("%Y-%m-%d %H:00:00",os.time() + 60*60)
			--domoticz.log("next datetime " .. NextHourDateTime,domoticz.LOG_INFO)
			domoticz.devices(idxCurrentHourIndicator).updateHistory(PreviousHourDateTime,"0;0")
			domoticz.devices(idxCurrentHourIndicator).updateHistory(NextHourDateTime,"0;0")
		        local CurrentHr=os.date("%H",os.time())
		        local CurrentDateTime=os.date("%Y-%m-%d %H:00:00",os.time())
		        if (item.trigger=="ELday1prices") or (item.trigger=="ELday2prices") then
    			    if (item.ok) then
    			            local responseKey=""
    			            for key, value in pairs (item.xml) do
    			                responseKey=key
    			            if responseKey == "Publication_MarketDocument" then
    			                local priceHourStr=""
    			                local priceQtrStr=""
    			                local priceDate=""
    			                local priceAmount=0
    			                local inclAmount=0
    			                local sValueStr=""
    			                local inclSValueStr=""
    			                local position=nil
    			                for key, value in pairs (item.xml.Publication_MarketDocument.TimeSeries.Period.Point) do
    			                    for subkey,subvalue in pairs (value) do
    			                        if subkey=="position" then
    			                            position=subvalue
    			                            priceAmount=domoticz.utils.round(subvalue*100,0)
    			                    if math.tointeger(position)<=96 then
                                        local priceHour=math.floor((position-1)/4)
                                        local priceQtr=(position-1)%4
                                        if priceQtr==0 then
                                            priceQtrStr="00"
                                            if priceQtr==1 then
                                                priceQtrStr="15"
                                                if priceQtr==2 then
                                                    priceQtrStr="30"
                                                    priceQtrStr="45"
                                        if (item.trigger=="ELday1prices") then
                                            priceDate=os.date("%Y-%m-%d",os.time()) .. " " .. priceHourStr .. ":" .. priceQtrStr .. ":00"
                                            priceDate=os.date("%Y-%m-%d",os.time() + 24*60*60) .. " " .. priceHourStr .. ":" .. priceQtrStr .. ":00"
                                        domoticz.log('position '..position..' priceDate ' .. priceDate..' priceHourStr '..priceHourStr..' priceQtrStr'..priceQtrStr.."price "..priceAmount, domoticz.LOG_INFO)
                                        inclAmount=domoticz.utils.round(priceAmount*(1+domoticz.variables(idxBTWpercentage).value/100)+domoticz.variables(idxElTax).value*100000+domoticz.variables(idxElInkoop).value*100000,0)
                                        sValueStr="0;" .. priceAmount
                                        inclSValueStr="0;"..inclAmount
                                        domoticz.devices(idxDynamicELPrices).updateHistory(priceDate,sValueStr)
                                        domoticz.devices(idxDynamicELPricesIncl).updateHistory(priceDate,inclSValueStr)
                                            if tostring(CurrentHr)==tostring(priceHourStr) then
                                                domoticz.devices(idxCurrentHourIndicator).updateHistory(CurrentDateTime,sValueStr)
                                                domoticz.devices(idxCurrentHourIndicator).updateCounter(priceAmount)
                                                domoticz.devices(idxDynamicELPrices).updateCounter(priceAmount)
                                                domoticz.devices(idxDynamicELPricesIncl).updateCounter(inclAmount)
                                domoticz.log("No price data received from trigger " .. item.trigger .. " key " .. responseKey, domoticz.LOG_INFO)
