Latest update crashes domoticz
gerard1
Re: Latest update crashes domoticz
Post by gerard1 »
I have done a restore, got Domoticz running again. (back to 14338)
However, many errors in the log file. Had to repair the Database.
Now everything is running as it should.
Dnpwwo
Post by Dnpwwo »
This seems to have been a Linux only issue, I've pushed a fix that should fix at least some of the issues (maybe all).
Thanks @heggink, given I already had a copy of your test plugin I was able to reproduce the crash.
gerard1
Post by gerard1 »
I have tried to update to Versie #14343
Did not work, same issue as before.
Had to rollback to Version # 14338 again.
ferrosk
Domoticz version: 2023.2
Post by ferrosk »
gerard1 wrote: Thursday 26 May 2022 13:59 I have tried to update to Versie #14343
The fix is included in build #14344, you have to test with this version.
Domoticz 2023.2 on Odroid M1 and Armbian
MySensors (RFM69 Serial GW): bunch of DIY sensors/devices
Zwave (Z-Wave.me RaZberry board): Danfoss devices
Zigbee (Sonoff Dongle Plus): IKEA, Tesla devices
Huntback
Domoticz version: 2024.2
Post by Huntback »
Same here, did update to b14343 but crashed also.
Removed plugin again.
btw b14344 is not available, b14343 is latest to pull.
Synology - DS411+II
Synology - DS918+
RFXCOM - RFXtrx433XL (LAN)
Oregon - Weatherstation
Some KAKU, Impuls, TFA, etc.
ferrosk
Post by ferrosk »
If you do not update by compiling from sources but use updatebeta script method, you have to wait next day for new beta build #14344 (or newer)
(see https://domoticz.com/forum/viewtopic.php?t=36966)
heggink
Domoticz version: 12451
Post by heggink »
Dnpwwo wrote:Hi,
Fix working for me after compiling from source. Thanks!!
DASHTICZ 🙃
P1 meter & solar panel
gerard1
Post by gerard1 »
Eveything is working again. Have done a source update.
Takes some time, but it worked. ( version: 14344)
DoMoAD
Post by DoMoAD »
With the build from today 14348 the problem is gone. deConz plugin is working again and no crash on startup.
Thank you very much
Huntback
Post by Huntback »
Domoticz (Latest) on Docker/Synology:
After auto-update (Portainer) from 2022.1-build:14341 to 2022.1-build:14348 Domoticz is (with the Python plugin) not crashing and stable again :D
Thanks for resolving the issue.
Synology - DS411+II
Synology - DS918+
