Latest update crashes domoticz
gerard1
Re: Latest update crashes domoticz
I have done a restore, got Domoticz running again. (back to 14338)
However, many errors in the log file. Had to repair the Database.
Now everything is running as it should.
- Dnpwwo
This seems to have been a Linux only issue, I've pushed a fix that should fix at least some of the issues (maybe all).
Thanks @heggink, given I already had a copy of your test plugin I was able to reproduce the crash.
gerard1
I have tried to update to Versie #14343
Did not work, same issue as before.
Had to rollback to Version # 14338 again.
ferrosk
- Domoticz version: 2026.2
The fix is included in build #14344, you have to test with this version.gerard1 wrote: Thursday 26 May 2022 13:59 I have tried to update to Versie #14343
Domoticz 2026.2 on Odroid M1 and Armbian
MySensors (RFM69 Serial GW): bunch of DIY sensors/devices
Zwave (Z-Wave.me RaZberry board): Danfoss devices
Zigbee (Sonoff Dongle Plus): IKEA, Tesla devices
Huntback
- Domoticz version: 2024.2
Same here, did update to b14343 but crashed also.
Removed plugin again.
btw b14344 is not available, b14343 is latest to pull.
Synology - DS918+
RFXCOM - RFXtrx433XL (LAN)
Oregon - Weatherstation
Some KAKU, Impuls, TFA, etc.
ferrosk
If you do not update by compiling from sources but use updatebeta script method, you have to wait next day for new beta build #14344 (or newer)
(see https://domoticz.com/forum/viewtopic.php?t=36966)
- heggink
- Domoticz version: 12451
Fix working for me after compiling from source. Thanks!!Dnpwwo wrote:Hi,
Sent from my SM-G980F using Tapatalk
P1 meter & solar panel
gerard1
Eveything is working again. Have done a source update.
Takes some time, but it worked. ( version: 14344)
DoMoAD
- Domoticz version: BETA
With the build from today 14348 the problem is gone. deConz plugin is working again and no crash on startup.
Thank you very much
Thank you very much
Huntback
Domoticz (Latest) on Docker/Synology:
After auto-update (Portainer) from 2022.1-build:14341 to 2022.1-build:14348 Domoticz is (with the Python plugin) not crashing and stable again
Thanks for resolving the issue.
Synology - DS918+
