Page 2 of 2
Re: Dashticz + Fully Kiosk Browser refresh settings
Posted: Saturday 15 May 2021 20:47
by Lokonli
jacobsentertainment wrote: Saturday 15 May 2021 19:52
Lokonli wrote: Monday 19 April 2021 15:32
You can also set it to 0.
I reboot my tablet every night.
I have done the same thing setting it to 0. It's a quick solution for keeping the screen in full screen mode but comes with other disadvantages, calendar and weather things are not updated any-more. Would be nice for the next update, if full mode is switched that it stays in full mode after refresh...
Unfortunately that's not possible for a normal browser window.
Fully Kiosk will stay full screen.
The new weather module (3.8.2 beta) will update by the way. Also calendar info is refreshed automatically, unless the refresh parameter is 0 or false.
Posted: Saturday 15 May 2021 21:17
by madpatrick
Lokonli wrote: Saturday 15 May 2021 20:47
Is this also applicable for Buienradar ?
It looks this only refresh after a reload
Posted: Saturday 15 May 2021 21:30
by jacobsentertainment
Now I'm confused, are we talking about the same thing here? I'm aiming at an dashticz without the normal browser tabs and address bar etc, the view you get when you hit the button top right corner near the settings.
But once the dashticz page refreshes the screen goes back to normal browser size.
We can avoid that with setting refresh to 0, so far I have replaced the OWM by weather widgets what was mentioned by HansieNL this does work in my browser and is refreshing. For the rest I have to refresh the dashticz manually, ill have a look tomorrow if the calendar is updated over night.
Posted: Saturday 15 May 2021 22:16
by Lokonli
jacobsentertainment wrote: Saturday 15 May 2021 21:30
Yes, we are talking about the same.
Chrome and Safari normally don't start full screen. Dashticz refresh is a kind of reload. It's not possible to reload a URL full screen without user interaction (security limitation of Chrome/Safari)
As an alternative:
On Android install for instance Fully Kiosk Browser.
Or add the URL to the start screen. (this works on Android and iOS). Then the App will start full screen, and will stay full screen, also after refresh.
Posted: Saturday 15 May 2021 22:19
Lokonli wrote: Saturday 15 May 2021 22:16
As an alternative:
That's some nice info you share there
Thanks!!
Posted: Thursday 10 June 2021 10:37
by riko
sammyke007 wrote: Monday 19 April 2021 12:47
The screen comes on when it detects motion with the build in front camera,
or when my front door opens using the http command. It's all working really nice.
Can you tell me a bit more about this feature? I've tried to Google it but I cannot find it.
I am using Dashticz on a Samsung Tab with the Fully Kiosk browser. I would like the screen to turn on when my front door camera detects motion (this is already a Domoticz device). So this means when a Device is 'On', the screen of the tablet should turn on.
Posted: Thursday 10 June 2021 12:13
by sammyke007
riko wrote: Thursday 10 June 2021 10:37
I use the following DZvents script:
devices = {
'Voordeur'
execute = function(domoticz, switch)
if (switch.state == 'Open') then
domoticz.openURL('http://192.168.1.AAAAAAA:2323/?cmd=screenOn&password=BBBBBBBB')
Replace 'Voordeur' with the Domoticz device name of your front door sensor
Replace AAAAAA with your Samsung tabs IP address (use a fixed IP or use DHCP reservation)
Replace BBBBBB with your FullyRemoteKiosk password
Try using the URL (
http://192.168.1.AAAAAAA:2323/?cmd=scre ... d=BBBBBBBB) in a browser in your network first, to test it.
Posted: Thursday 10 June 2021 15:36
by riko
Thanks, I'll try it out soon
