Re: zigate tuya siren
Posted: Sunday 31 January 2021 11:39
For the temperature/humidity, please provide logs, I need more less 15 minutes of logs , without I cannot really help.
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
my log:pipiche wrote: Sunday 31 January 2021 11:39 For the temperature/humidity, please provide logs, I need more less 15 minutes of logs , without I cannot really help.
looks not very usefull. Can you do the followingmarktn wrote: Sunday 31 January 2021 17:02 my log:
https://www.dropbox.com/s/knj40mxxiqxac ... e.txt?dl=0
git pullI have the similar behaviourThis is very strange, wometimes the speaker has a soft "tik" when it is not in use.
Sorry for my late response. I am in the middle of a home improvement. Of course some extra wire for domoticapipiche wrote: Sunday 31 January 2021 18:09looks not very usefull. Can you do the followingmarktn wrote: Sunday 31 January 2021 17:02 my log:
1/ update to latest version2/ enable debugTuya ( from the Web Admin Tool -> Debug menu (advanced)Code: Select all
git pull
3/ leave it for while
then drop me the :
* log
* export.json
redo paring done!pipiche wrote: Saturday 13 February 2021 19:00 From what I saw in th export(1).json , it looks like the pairing was not done correctly.
Can you try to remove all devices in Domoticz, and then redo the pairing ? And then sending the expor.json of Plugin devices RAW (json)
pipiche wrote: Saturday 13 February 2021 21:25 ANy issue in the log ? There is something no happening during the pairing process .
Can you get the latest beta ( 4.12.126 ) and then do once more removing the devices and redo the pairing ?
2021-02-16 18:54:59.842 Status: (Zigate) [ MainThread] 26 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-16.txt
2021-02-16 18:54:59.881 Status: (Zigate) [ MainThread] Transport mode: USB
2021-02-16 18:54:59.881 Status: (Zigate) ZiGate plugin start with limited capabilities due to Domoticz version below 2020.2 (Build 12741)
2021-02-16 18:54:59.882 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0
2021-02-16 18:54:59.887 Status: (Zigate) [ZiGateWriter_16] ZigateTransport: writer_thread Thread start.
2021-02-16 18:54:59.887 Status: (Zigate) [ZiGateForwarder_16] ZigateTransport: thread_processing_and_sending Thread start.
2021-02-16 18:54:59.888 Status: (Zigate) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2021-02-16 18:55:09.577 Status: (Zigate) [ZiGateForwarder_16] ZiGate Classic
2021-02-16 18:55:09.577 Status: (Zigate) [ZiGateForwarder_16] Installer Version Number: 031c
2021-02-16 18:55:18.623 Status: (Zigate) [ZiGateForwarder_16] Zigate addresses ieee: 00158d0001ee040a , short addr: 0000
2021-02-16 18:55:18.623 Status: (Zigate) [ZiGateForwarder_16] Network state UP, PANID: 4f3e extPANID: 0x2fe14f25179533d9 Channel: 11
2021-02-16 18:55:23.414 Status: (Zigate) [ MainThread] Request Disabling Accepting new Hardware
2021-02-16 18:55:25.026 Status: (Zigate) [ZiGateForwarder_16] Accepting new Hardware: Disable
2021-02-16 18:55:25.530 Status: (Zigate) [ZiGateForwarder_16] Number of devices recently active in Zigate = 16
2021-02-16 18:55:25.530 Status: (Zigate) [ZiGateForwarder_16] [00] DevID = 00 Network addr = c2bb IEEE = 00158d0003cc6bae LQI = 149 Power = 00 Model = lumi.sensor_ht ( Sensor badkamer )
2021-02-16 18:55:25.530 Status: (Zigate) [ZiGateForwarder_16] [01] DevID = 01 Network addr = 746c IEEE = 00158d00036b5243 LQI = 096 Power = 00 Model = lumi.weather ( 3D printer )
2021-02-16 18:55:25.530 Status: (Zigate) [ZiGateForwarder_16] [02] DevID = 02 Network addr = 2172 IEEE = 00158d00045c2862 LQI = 073 Power = 00 Model = lumi.sensor_magnet.aq2 ( Deursensor schuifdeur )
2021-02-16 18:55:25.530 Status: (Zigate) [ZiGateForwarder_16] [03] DevID = 03 Network addr = 3478 IEEE = 00158d0005225f00 LQI = 095 Power = 00 Model = lumi.sensor_magnet.aq2 ( Deursensor voordeur )
2021-02-16 18:55:25.531 Status: (Zigate) [ZiGateForwarder_16] [04] DevID = 04 Network addr = 907a IEEE = 00158d00056e67a4 LQI = 072 Power = 00 Model = lumi.sensor_smoke ( Rookmelder zolder )
2021-02-16 18:55:25.531 Status: (Zigate) [ZiGateForwarder_16] [05] DevID = 06 Network addr = 5554 IEEE = 00158d000490afab LQI = 072 Power = 00 Model = lumi.sensor_smoke ( rookmelder kantoor )
2021-02-16 18:55:25.531 Status: (Zigate) [ZiGateForwarder_16] [06] DevID = 07 Network addr = c52b IEEE = 00158d000572a925 LQI = 078 Power = 00 Model = lumi.sensor_smoke ( Rookmelder wasmachine )
2021-02-16 18:55:25.531 Status: (Zigate) [ZiGateForwarder_16] [07] DevID = 08 Network addr = 5f8f IEEE = 00158d0005884092 LQI = 149 Power = 00 Model = lumi.sensor_smoke ( Rookmelder hal )
2021-02-16 18:55:25.531 Status: (Zigate) [ZiGateForwarder_16] [08] DevID = 28 Network addr = 8b16 IEEE = 000d6ffffe485188 LQI = 069 Power = 01 Model = TRADFRI bulb E27 WS opal 980lm ( Woonkamer bankstel )
2021-02-16 18:55:25.531 Status: (Zigate) [ZiGateForwarder_16] [09] DevID = 29 Network addr = f1f1 IEEE = 680ae2fffe413429 LQI = 157 Power = 01 Model = TRADFRI control outlet ( TV boven schakelaar )
2021-02-16 18:55:25.531 Status: (Zigate) [ZiGateForwarder_16] [10] DevID = 2a Network addr = d4ad IEEE = 00158d000444ee2f LQI = 117 Power = 01 Model = lumi.relay.c2acn01 ( Voortuin relay )
2021-02-16 18:55:25.532 Status: (Zigate) [ZiGateForwarder_16] [11] DevID = 2b Network addr = f295 IEEE = ec1bbdfffeb8ab2a LQI = 081 Power = 01 Model = TRADFRI bulb E27 WW clear 250lm ( )
2021-02-16 18:55:25.532 Status: (Zigate) [ZiGateForwarder_16] [12] DevID = 2c Network addr = 9ab3 IEEE = ec1bbdfffe468a93 LQI = 150 Power = 01 Model = TRADFRI bulb GU10 WS 400lm ( Woonkamer salontafel_2 )
2021-02-16 18:55:25.532 Status: (Zigate) [ZiGateForwarder_16] [13] DevID = 2d Network addr = 7f15 IEEE = ec1bbdfffe986a27 LQI = 151 Power = 01 Model = TRADFRI bulb GU10 WS 400lm ( Woonkamer salontafel_1 )
2021-02-16 18:55:25.532 Status: (Zigate) [ZiGateForwarder_16] [14] DevID = 2e Network addr = 3764 IEEE = 00158d0003f05121 LQI = 104 Power = 01 Model = lumi.relay.c2acn01 ( Badkamer relay )
2021-02-16 18:55:25.532 Status: (Zigate) [ZiGateForwarder_16] [15] DevID = 2f Network addr = 5a7a IEEE = 680ae2fffe373006 LQI = 128 Power = 01 Model = TRADFRI bulb GU10 WS 400lm ( Woonkamer salontafel_3 )
2021-02-16 18:55:28.435 Status: (Zigate) [ MainThread] Zigate set to Certification : CE
2021-02-16 18:55:28.435 Status: (Zigate) [ MainThread] Start Group Management
2021-02-16 18:55:28.459 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c2 FileVersion: 23028631 Size: 179390 Bytes Filename: 159701-2.1-TRADFRI-wireless-dimmer-2.3.028.ota.ota.signed
2021-02-16 18:55:28.477 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2203 FileVersion: 23007631 Size: 207870 Bytes Filename: 100355342-2.1-TRADFRI-bulb-ws-gu10-2.3.007.ota.ota.signed
2021-02-16 18:55:28.492 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2801 FileVersion: 13009572 Size: 178366 Bytes Filename: 10035515-TRADFRI-bulb-cws-1.3.009.ota.ota.signed
2021-02-16 18:55:28.507 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4201 FileVersion: 12217572 Size: 173246 Bytes Filename: 159698-TRADFRI-driver-lp-1.2.217.ota.ota.signed
2021-02-16 18:55:28.522 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4202 FileVersion: 12217572 Size: 173246 Bytes Filename: 159697-TRADFRI-driver-hp-1.2.217.ota.ota.signed
2021-02-16 18:55:28.540 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4203 FileVersion: 20022623 Size: 208830 Bytes Filename: 191100-4.1-TRADFRI-sy5882-driver-ws-2.0.022.ota.ota.signed
2021-02-16 18:55:28.555 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11ca FileVersion: 21024631 Size: 180926 Bytes Filename: 10043101-3.1-TRADFRI-dimmer-2.1.024.ota.ota.signed
2021-02-16 18:55:28.571 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c8 FileVersion: 20022623 Size: 186814 Bytes Filename: 10039874-1.0-TRADFRI-motion-sensor-2-2.0.022.ota.ota.signed
2021-02-16 18:55:28.589 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4206 FileVersion: 21022631 Size: 208254 Bytes Filename: 10047227-1.2-TRADFRI-cv-cct-unified-2.1.022.ota.ota.signed
2021-02-16 18:55:28.606 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2201 FileVersion: 23007631 Size: 208126 Bytes Filename: 10035514-2.1-TRADFRI-bulb-ws-2.3.007.ota.ota.signed
2021-02-16 18:55:28.622 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4101 FileVersion: 12245572 Size: 181118 Bytes Filename: 159495-TRADFRI-transformer-1.2.245.ota.ota.signed
2021-02-16 18:55:28.638 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x1187 FileVersion: 22009631 Size: 186942 Bytes Filename: 10037585-5.1-TRADFRI-connected-blind-2.2.009.ota.ota.signed
2021-02-16 18:55:28.654 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c1 FileVersion: 23014631 Size: 182590 Bytes Filename: 159699-5.1-TRADFRI-remote-control-2.3.014.ota.ota.signed
2021-02-16 18:55:28.670 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x1102 FileVersion: 22005631 Size: 189822 Bytes Filename: 10037603-3.1-TRADFRI-signal-repeater-2.2.005.ota.ota.signed
2021-02-16 18:55:28.685 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2101 FileVersion: 12214572 Size: 168318 Bytes Filename: 159696-TRADFRI-bulb-w-1000lm-1.2.214.ota.ota.signed
2021-02-16 18:55:28.698 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c4 FileVersion: 12214572 Size: 157822 Bytes Filename: 159700-TRADFRI-motion-sensor-1.2.214.ota.ota.signed
2021-02-16 18:55:28.714 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x11c5 FileVersion: 22010631 Size: 179838 Bytes Filename: 10005778-10.1-TRADFRI-onoff-shortcut-control-2.2.010.ota.ota.signed
2021-02-16 18:55:28.729 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x0002 FileVersion: 165801bc Size: 166270 Bytes Filename: 190579-ncp572b444.ebl.ota.ota.signed
2021-02-16 18:55:28.747 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4204 FileVersion: 20023623 Size: 209086 Bytes Filename: 10038562-2.1-TRADFRI-sy5882-bulb-ws-2.0.023.ota.ota.signed
2021-02-16 18:55:28.765 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x1101 FileVersion: 20024623 Size: 202110 Bytes Filename: 10005777-6.1-TRADFRI-control-outlet-2.0.024.ota.ota.signed
2021-02-16 18:55:28.783 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4103 FileVersion: 21022631 Size: 202878 Bytes Filename: 10046695-1.1-TRADFRI-light-unified-w-2.1.022.ota.ota.signed
2021-02-16 18:55:28.801 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x2202 FileVersion: 23007631 Size: 208702 Bytes Filename: 159695-2.1-TRADFRI-bulb-ws-1000lm-2.3.007.ota.ota.signed
2021-02-16 18:55:33.943 Status: (Zigate) [ MainThread] Available Firmware - ManufCode: 117c ImageType: 0x4205 FileVersion: 21022631 Size: 208254 Bytes Filename: 10040611-3.2-TRADFRI-sy5882-unified-2.1.022.ota.ota.signed
2021-02-16 18:55:33.948 Status: (Zigate) [ MainThread] Start Web Server connection
2021-02-16 18:55:33.968 Status: (Zigate) [ MainThread] Web backend for Web User Interface started on port: 9440
2021-02-16 18:55:33.968 Status: (Zigate) [ MainThread] Plugin with Zigate firmware 031c correctly initialized
2021-02-16 18:55:34.253 Status: (Zigate) [ZiGateForwarder_16] TxPower Attenuation : 0 dBm
2021-02-16 18:55:34.094 Error: (Zigate) decode8000 - command miss-match 0806 vs. 0018
2021-02-16 18:55:34.171 Error: (Zigate) decode8000 - command miss-match 0019 vs. 0806
2021-02-16 18:55:34.304 Error: (Zigate) decode8000 - cannot get isqn for MsgType 0019
2021-02-16 18:55:38.747 Status: (Zigate) [ MainThread] There is a newer plugin version available on gitHub
2021-02-16 18:55:38.747 Status: (Zigate) [ MainThread] There is a newer Zigate Firmware version available
2021-02-16 18:55:49.180 Status: Notification: Bewatering achter Haag Uitgeschakeld
2021-02-16 18:55:49.193 Status: Notification: Bewatering achter planten Uitgeschakeld
2021-02-16 18:56:02.423 Status: Notification sent (Email)
2021-02-16 18:56:03.532 Status: New sensors allowed for 5 minutes...
2021-02-16 18:56:15.682 Status: Afzuiging badkamer gaat aan
2021-02-16 18:56:20.250 Error: (Zigate) No transport, write directive to '192.168.1.41:59371' ignored.
2021-02-16 18:56:20.310 Error: (Zigate) No transport, write directive to '192.168.1.41:59372' ignored.
2021-02-16 18:57:02.394 Status: Notification sent (Email)
2021-02-16 18:57:08.320 Status: Notification sent (Email)
2021-02-16 19:00:01.831 Status: Schedule item started! Name: Minke Aquarium, Type: On Time, DevID: 4342, Time: 2021-02-16 19:00:01
2021-02-16 19:05:42.558 Status: Notification: De bel
2021-02-16 19:22:48.375 Status: New sensors allowed for 5 minutes...
2021-02-16 19:23:06.061 Status: (Zigate) [ MainThread] Request Accepting new Hardware for ever
2021-02-16 19:23:06.671 Status: (Zigate) [ZiGateForwarder_16] Accepting new Hardware: On
2021-02-16 19:23:11.155 Error: (Zigate) DeviceExist - Found some inconsistency Inputs: b03b 5c0272fffecea9d6 instead of None
2021-02-16 19:23:12.036 Status: (Zigate) [ZiGateForwarder_16] (b03b/5c0272fffecea9d6) send a Leave indication and will be outside of the network. LQI: 0
2021-02-16 19:23:31.704 Error: (Zigate) DeviceExist - Found some inconsistency Inputs: b986 5c0272fffecea9d6 instead of None
2021-02-16 19:23:32.358 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Active Endpoint Response Ep: 01 LQI: 99
2021-02-16 19:23:32.360 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Request Simple Descriptor for Ep: 01
2021-02-16 19:23:33.621 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Simple Descriptor Response EP: 0x01 LQI: 90
2021-02-16 19:23:33.621 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 ProfileID 0104
2021-02-16 19:23:33.621 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 ZDeviceID 0051
2021-02-16 19:23:33.621 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Application Version 0001
2021-02-16 19:23:33.622 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Cluster IN Count: 04
2021-02-16 19:23:33.622 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Cluster In 1: 0000 (Basic)
2021-02-16 19:23:33.622 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Cluster In 2: 0004 (Groups)
2021-02-16 19:23:33.622 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Cluster In 3: 0005 (Scenes)
2021-02-16 19:23:33.622 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Cluster In 4: ef00
2021-02-16 19:23:33.622 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Cluster OUT Count: 02
2021-02-16 19:23:33.622 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-02-16 19:23:33.623 Status: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: b986 Cluster Out 2: 000a (Time)
2021-02-16 19:23:33.826 Status: (Zigate) [0] NEW OBJECT: b986 Model Name: TS0601-sirene
2021-02-16 19:23:38.163 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01) 0:7.85;8115.0
2021-02-16 19:23:38.505 (Zigate) [ZiGateForwarder_16] ReadCluster - 0000 b986/01 attribute Tuya/Zemismat - fffe: 0x00
2021-02-16 19:23:56.823 Status: EventSystem: reset all device statuses...
2021-02-16 19:23:59.287 Status: EventSystem: reset all device statuses...
2021-02-16 19:24:01.858 Status: EventSystem: reset all device statuses...
2021-02-16 19:24:02.394 Status: Notification sent (Email)
2021-02-16 19:24:04.820 Status: EventSystem: reset all device statuses...
2021-02-16 19:24:08.750 Status: EventSystem: reset all device statuses...
2021-02-16 19:24:13.440 Status: EventSystem: reset all device statuses...
2021-02-16 19:24:16.748 (Zigate) UpdateDevice - ($PIR-ligt sterkte) 0:0
2021-02-16 19:24:29.958 Error: (Zigate) No transport, write directive to '192.168.1.41:61151' ignored.
2021-02-16 19:25:02.593 Status: Notification sent (Email)
2021-02-16 19:25:04.325 (Weer) Temp + Humidity + Baro (Tempratuur buiten (online))
2021-02-16 19:25:04.343 (Weer) Wind (Wind (online))
2021-02-16 19:25:04.353 (Weer) General/Visibility (Zichtbaarheid (online))
2021-02-16 19:25:04.361 (Weer) General/Percentage (Wolken (online))
2021-02-16 19:25:50.322 (Zigate) UpdateDevice - ( PIR-voordeur) 1:On
2021-02-16 19:27:02.879 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.9;73.7;3
2021-02-16 19:27:02.889 (Zigate) UpdateDevice - ( Badkamer vocht) 73.7:3
2021-02-16 19:27:02.902 EventSystem: Event triggered: Badkamer afzuiging_2
2021-02-16 19:27:02.903 Status: Afzuiging badkamer gaat uit
2021-02-16 19:29:01.369 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Power-00158d000444ee2f-01) 7.93:7.934482097625732
2021-02-16 19:29:01.379 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01) 0:7.93;8115.94
2021-02-16 19:30:01.082 (Zigate) Zigate receive message processing time Max: 122 ms with an of average: 6 ms
2021-02-16 19:33:28.963 (Zigate) UpdateDevice - ( Zigate temp) 0:19.7;47.0;1;1003.1;3
2021-02-16 19:33:28.974 (Zigate) UpdateDevice - (3D printer vocht) 47.0:1
2021-02-16 19:33:29.000 (Zigate) UpdateDevice - ( Zigate temp) 0:19.7;47.0;1;1003.0;3
2021-02-16 19:33:29.020 (Zigate) UpdateDevice - (Zigate - lumi.weather_Baro-00158d00036b5243-01) 0:1003.0;3
2021-02-16 19:34:39.438 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Power-00158d000444ee2f-01) 7.84:7.83547306060791
2021-02-16 19:34:39.448 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01) 0:7.84;8116.56
2021-02-16 19:35:00.426 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.8;73.7;3
2021-02-16 19:35:00.431 (Zigate) UpdateDevice - (Badkamer temperatuur) 19.8:19.8
2021-02-16 19:35:00.442 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.8;67.6;1
2021-02-16 19:35:00.447 (Zigate) UpdateDevice - ( Badkamer vocht) 67.6:1
2021-02-16 19:35:00.453 EventSystem: Event triggered: Badkamer afzuiging_2
2021-02-16 19:35:04.431 (Weer) Temp + Humidity + Baro (Tempratuur buiten (online))
2021-02-16 19:35:04.445 (Weer) Wind (Wind (online))
2021-02-16 19:35:04.453 (Weer) General/Visibility (Zichtbaarheid (online))
2021-02-16 19:35:04.461 (Weer) General/Percentage (Wolken (online))
2021-02-16 19:36:11.475 (Zigate) UpdateDevice - ($PIR-ligt sterkte) 0:0
2021-02-16 19:36:11.491 (Zigate) UpdateDevice - ( PIR-voordeur) 0:Off
2021-02-16 19:37:02.941 (Zigate) UpdateDevice - (Badkamerventilatie) 0:Off
2021-02-16 19:40:52.404 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.7;67.6;1
2021-02-16 19:40:52.414 (Zigate) UpdateDevice - (Badkamer temperatuur) 19.7:19.7
2021-02-16 19:40:52.433 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.7;74.2;3
2021-02-16 19:40:52.443 (Zigate) UpdateDevice - ( Badkamer vocht) 74.2:3
2021-02-16 19:41:06.472 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Power-00158d000444ee2f-01) 7.89:7.894878387451172
2021-02-16 19:41:06.482 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01) 0:7.89;8117.5
2021-02-16 19:45:04.561 (Weer) Temp + Humidity + Baro (Tempratuur buiten (online))
2021-02-16 19:45:04.575 (Weer) Wind (Wind (online))
2021-02-16 19:45:04.584 (Weer) General/Visibility (Zichtbaarheid (online))
2021-02-16 19:45:04.591 (Weer) General/Percentage (Wolken (online))
2021-02-16 19:46:06.504 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Power-00158d000444ee2f-01) 7.81:7.810821533203125
2021-02-16 19:46:06.514 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01) 0:7.81;8118.12
2021-02-16 19:46:39.296 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.6;74.2;3
2021-02-16 19:46:39.307 (Zigate) UpdateDevice - (Badkamer temperatuur) 19.6:19.6
2021-02-16 19:46:39.327 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.6;80.2;3
2021-02-16 19:46:39.336 (Zigate) UpdateDevice - ( Badkamer vocht) 80.2:3
2021-02-16 19:46:39.349 EventSystem: Event triggered: Badkamer afzuiging_1
2021-02-16 19:46:39.397 (Zigate) UpdateDevice - (Badkamerventilatie) 1:On
2021-02-16 19:46:39.350 Status: Afzuiging badkamer gaat aan
2021-02-16 19:48:25.545 (Zigate) UpdateDevice - ( Deur_woonkamer) 0:Closed
2021-02-16 19:49:20.284 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.6;74.1;3
2021-02-16 19:49:20.294 (Zigate) UpdateDevice - ( Badkamer vocht) 74.1:3
2021-02-16 19:49:20.307 EventSystem: Event triggered: Badkamer afzuiging_2
2021-02-16 19:49:20.308 Status: Afzuiging badkamer gaat uit
2021-02-16 19:51:47.565 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Power-00158d000444ee2f-01) 7.91:7.913871765136719
2021-02-16 19:51:47.575 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01) 0:7.91;8118.75
2021-02-16 19:52:06.300 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.6;68.0;1
2021-02-16 19:52:06.311 (Zigate) UpdateDevice - ( Badkamer vocht) 68.0:1
2021-02-16 19:52:06.324 EventSystem: Event triggered: Badkamer afzuiging_2
2021-02-16 19:53:03.065 (Zigate) UpdateDevice - ( Deur_woonkamer) 1:Open
2021-02-16 19:53:15.662 (Zigate) UpdateDevice - ( Deur_woonkamer) 0:Closed
2021-02-16 19:55:04.640 (Weer) Temp + Humidity + Baro (Tempratuur buiten (online))
2021-02-16 19:55:04.655 (Weer) Wind (Wind (online))
2021-02-16 19:55:04.663 (Weer) General/Visibility (Zichtbaarheid (online))
2021-02-16 19:55:04.671 (Weer) General/Percentage (Wolken (online))
2021-02-16 19:56:10.777 (Zigate) UpdateDevice - (Deur_schuifdeur) 0:Closed
2021-02-16 19:58:10.719 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Power-00158d000444ee2f-01) 7.88:7.8803300857543945
2021-02-16 19:58:10.730 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01) 0:7.88;8119.69
2021-02-16 19:59:20.364 (Zigate) UpdateDevice - (Badkamerventilatie) 0:Off
2021-02-16 19:59:58.851 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.5;68.0;1
2021-02-16 19:59:58.862 (Zigate) UpdateDevice - (Badkamer temperatuur) 19.5:19.5
2021-02-16 19:59:58.884 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.5;62.0;1
2021-02-16 19:59:58.894 (Zigate) UpdateDevice - ( Badkamer vocht) 62.0:1
2021-02-16 20:04:19.826 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Power-00158d000444ee2f-01) 7.94:7.944180965423584
2021-02-16 20:04:19.836 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01) 0:7.94;8120.31
2021-02-16 20:04:55.508 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.5;66.8;1
2021-02-16 20:04:55.518 (Zigate) UpdateDevice - ( Badkamer vocht) 66.8:1
2021-02-16 20:05:04.719 (Weer) Temp + Humidity + Baro (Tempratuur buiten (online))
2021-02-16 20:05:04.733 (Weer) Wind (Wind (online))
2021-02-16 20:05:04.742 (Weer) General/Visibility (Zichtbaarheid (online))
2021-02-16 20:05:04.749 (Weer) General/Percentage (Wolken (online))
2021-02-16 20:05:14.789 (Zigate) UpdateDevice - ( Deur_woonkamer) 1:Open
2021-02-16 20:05:20.324 (Zigate) UpdateDevice - ( Deur_woonkamer) 0:Closed
2021-02-16 20:05:22.029 (Zigate) UpdateDevice - ( Deur_voordeur) 1:Open
2021-02-16 20:05:22.433 (Zigate) UpdateDevice - ($PIR-ligt sterkte) 0:0
2021-02-16 20:05:22.452 (Zigate) UpdateDevice - ( PIR-voordeur) 1:On
2021-02-16 20:05:26.316 (Zigate) UpdateDevice - ( Deur_voordeur) 0:Closed
2021-02-16 20:06:24.633 (Zigate) UpdateDevice - ( Deur_woonkamer) 1:Open
2021-02-16 20:07:26.986 (Zigate) UpdateDevice - (Zigate - lumi.sensor_ht_Temp+Hum-00158d0003cc6bae-01) 0:19.5;68.2;1
2021-02-16 20:07:26.996 (Zigate) UpdateDevice - ( Badkamer vocht) 68.2:1
2021-02-16 20:07:43.938 (Zigate) UpdateDevice - ( Deur_woonkamer) 0:Closed
2021-02-16 20:10:16.862 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Power-00158d000444ee2f-01) 7.94:7.936502456665039
2021-02-16 20:10:16.872 (Zigate) UpdateDevice - (Zigate - lumi.relay.c2acn01_Meter-00158d000444ee2f-01) 0:7.94;8121.25
2021-02-16 20:10:46.164 (Zigate) UpdateDevice - ($PIR-ligt sterkte) 0:0
2021-02-16 20:10:46.183 (Zigate) UpdateDevice - ( PIR-voordeur) 1:On
2021-02-16 20:15:01.132 (Zigate) Zigate receive message processing time Max: 128 ms with an of average: 6 ms
2021-02-16 20:15:04.837 (Weer) Temp + Humidity + Baro (Tempratuur buiten (online))
2021-02-16 20:15:04.852 (Weer) Wind (Wind (online))
2021-02-16 20:15:04.861 (Weer) General/Visibility (Zichtbaarheid (online))
2021-02-16 20:15:04.868 (Weer) General/Percentage (Wolken (online)) I made a update to a newer version (beta branch), in this thread.The problem with the Hue gu10
2021-06-24 20:25:10.680 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:49255' ignored.
2021-06-24 20:25:10.680 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:49257' ignored.
2021-06-24 20:30:11.589 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:49550' ignored.
2021-06-24 20:30:11.589 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:49549' ignored.
2021-06-24 21:12:04.792 Error: Zigate: (Zigate) DeviceExist - Found some inconsistency Inputs: 2dac 00158d0004631f4e instead of None
2021-06-24 21:12:53.398 Error: dzVents: Error: (3.1.7) Discarding device. No last update info found: {["changed"]=true, ["data"]={["hardwareType"]="Zigate plugin", ["protected"]=false, ["customImage"]=0, ["usedByCamera"]=false, ["hardwareID"]=7908956, ["unit"]=40, ["hardwareName"]="Zigate", ["Image"]="Light", ["icon"]="motion", ["hardwareTypeValue"]=94, ["maxDimLevel"]=100, ["levelVal"]=0, ["_state"]="On", ["_nValue"]=1}, ["description"]="", ["image"]="", ["switchType"]="Motion Sensor", ["subType"]="Switch", ["switchTypeValue"]=8, ["batteryLevel"]=1700434296, ["protected"]=false, ["baseType"]="device", ["deviceID"]="", ["lastLevel"]=255, ["lastUpdate"]="", ["id"]=4962, ["rawData"]={"On"}, ["timedOut"]=true, ["signalLevel"]=2686588, ["iconNumber"]=200, ["name"]="Zigate - lumi.sensor_motion_Motion-00158d0004631f4e-01", ["deviceType"]="Light/Switch"}
2021-06-24 21:18:46.979 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:57597' ignored.
2021-06-24 21:18:47.033 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:57599' ignored.
2021-06-24 21:20:50.889 Error: Slave Synolgy: Can not connect to: 192.168.1.59:6144 (Connection refused)
2021-06-24 21:29:48.332 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:62174' ignored.
2021-06-24 21:33:03.292 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:62176' ignored.
2021-06-25 19:13:27.111 Error: dzVents: Error: (3.1.7) Discarding device. No last update info found: {["baseType"]="device", ["timedOut"]=true, ["lastLevel"]=255, ["iconNumber"]=104, ["description"]="", ["lastUpdate"]="", ["switchTypeValue"]=7, ["protected"]=false, ["switchType"]="Dimmer", ["changed"]=true, ["data"]={["customImage"]=0, ["usedByCamera"]=false, ["icon"]="dimmer", ["hardwareType"]="Zigate plugin", ["hardwareID"]=7908956, ["Image"]="Light", ["hardwareName"]="Zigate", ["levelVal"]=1, ["unit"]=41, ["_state"]="On", ["_nValue"]=1, ["color"]="{"b":0,"cw":42,"g":0,"m":2,"r":0,"t":213,"ww":213}", ["maxDimLevel"]=100, ["hardwareTypeValue"]=94, ["protected"]=false}, ["subType"]="RGBWW", ["rawData"]={"1"}, ["batteryLevel"]=1814015136, ["signalLevel"]=2686588, ["name"]="Zigate - hal", ["image"]="", ["deviceID"]="", ["deviceType"]="Color Switch", ["id"]=4963} Code: Select all
e4d3
804b50fffe048336
TS0601-sirene
Zigate - TS0601-sirene_Temp+Hum-804b50fffe048336-01
Zigate - TS0601-sirene_Temp-804b50fffe048336-01
Zigate - TS0601-sirene_Humi-804b50fffe048336-01
Zigate - TS0601-sirene_TuyaSiren-804b50fffe048336-01
Zigate - TS0601-sirene_TuyaSirenHumi-804b50fffe048336-01
Zigate - TS0601-sirene_TuyaSirenTemp-804b50fffe048336-01
RFD
Battery
207
inDB
Live
ebd2
5c0272fffecea9d6
TS0601-sirene
Zigate - TS0601-sirene_Temp+Hum-5c0272fffecea9d6-01
Zigate - TS0601-sirene_Temp-5c0272fffecea9d6-01
Zigate - TS0601-sirene_Humi-5c0272fffecea9d6-01
Zigate - TS0601-sirene_TuyaSiren-5c0272fffecea9d6-01
Zigate - TS0601-sirene_TuyaSirenHumi-5c0272fffecea9d6-01
Zigate - TS0601-sirene_TuyaSirenTemp-5c0272fffecea9d6-01
