Page 2 of 2
Re: Grayed-out UI item in Utility Sensors
Posted: Monday 25 January 2021 17:43
by philchillbill
@waaren, That fixed it for me too - many thanks !
The original post in
viewtopic.php?p=128783#p128783 is then also incomplete regarding the hardware id because that's the tutorial I followed a few years ago to create that water meter.
Posted: Monday 25 January 2021 19:39
by waaren
MikeyMan wrote: Monday 25 January 2021 15:35
Is that a reserved hardware ID? The internal one?
I don't know if it is reserved but it is in all my domoticz systems. Preferable I would connect the loose deviceid(s) with a dummy hardware but I could not tell from your list of hardware if you have such a hardware and connect it to internal is also OK.
Posted: Monday 25 January 2021 19:56
by waaren
philchillbill wrote: Monday 25 January 2021 17:43
There was indeed room for confusion in that post and it advises to use API calls where it can be done much easier from within the GUI.
by creating a dummy hardware from the hardware tab and use the button on that newly created hardware to create a new virtual device of type counter.
Posted: Monday 19 April 2021 12:28
by sammyke007
I've ran into the same "problem" today after updating to 2021.1. Fixing it with the sqlite3 commands did the magic. Tnx @waaren!
Posted: Monday 19 April 2021 13:51
by Bochelork
I've grayed out items with a lot of sensors. The reason is that the hardware is disabled, because I do not use the hardware plugins anymore. Data comes from scripts. E.g. Wunderground comes from my own script. I kept the sensors, but hardware is disabled. Updates are done with domoticz api or mqtt/in from scripts. Is there a way to show the sensors from disabled hardware NOT grayed out?
Posted: Monday 19 April 2021 14:40
by waaren
Bochelork wrote: Monday 19 April 2021 13:51
No.
What you could do is define a "Dummy (Does nothing, use for virtual switches only)" hardware and connect the devices updated via JSON / MQTT using sqlite or similar to this 'hardware' using the following commands.
cd <domoticz dir>
sudo sqlite3 domoticz.db "UPDATE DeviceStatus SET HardwareID = (SELECT ID from Hardware WHERE Type = 15 ORDER BY ID DESC LIMIT 1) WHERE HARDWAREID IN (SELECT ID FROM Hardware WHERE Enabled = 0)"
Posted: Monday 19 April 2021 14:50
by Bochelork
Thanks, that worked! (typo Enabed ->Enabled)
Posted: Friday 30 April 2021 21:52
by Pantagruel
Thanks @waaren, The sqlite3 routine did the trick - Thanks !
As mentioned before, I too created an RFXMeter some years ago according to: viewtopic.php?p=128783#p128783.
The update to 2021.1 resulted in a grayed out UI item.
Again thanks for the fix!
Posted: Monday 13 September 2021 17:43
by MadMedic
Used this helpfull guide too, with the appropiate idx's, worked like a charm.
was the watermeter sensor here, too. *Coincidence ?
Thnx anyway, guys !
Posted: Monday 13 September 2021 18:01
by waltervl
MadMedic wrote: Monday 13 September 2021 17:43
Thnx anyway, guys !
Not a coincidence, the manual on the website
https://ehoco.nl/watermeter-uitlezen-in ... on-script/ and the same forumtopic
viewtopic.php?p=128783#p128783 is incorrect, resulting in this issue.
