Help needed with script  [Solved]
Re: Help needed with script
Fredom wrote: Wednesday 18 November 2020 20:37 The notifications always come when a door opens, even when the phone is at home.
Maybe I misunderstand your question but the script I posted already does this. It will only send a message when atHome is not true.
Fredom
Domoticz version: 2025.1
Post by Fredom »
waaren wrote: Wednesday 18 November 2020 21:48
Hi Waaren,
Thanks for your quick response
I am now using your latest script I have only changed the switch names.
The script works perfectly, only the notifications also come when Thuis is on.
This shouldn't be.
I have also tried a few things myself, but I can't figure it out (yet).
--(dzVents)--
--Door open  and 'Thuis' is On then no telegram
--Door open  and 'Thuis' is Off then send telegram with name of the door and door is open
--Thuis is Dummy switch that is on when smartphone is at home
--WCD On if 'Thuis'is Off and door state is Alarm, and switch Off when door state is Normal
--Door is an Kerui D026
--Telegram is activated
local doors =
    'Voordeur',
    'Garagedeur',
    'Schuifdeur',
    'Testdeur',  --for testing
local allDevices = doors -- copy the doors table to table allDevices
table.insert(allDevices, 'Thuis') -- this will add this deviceName to the table allDevices
return
    on =
        devices = allDevices,
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'deur',
    execute = function(dz)
        local delay = 300 -- set to amount of seconds the light should stay on
        local allDoorsClosed = true
        local Thuis = dz.devices('Thuis') --atHome
        local wcd = dz.devices('WCD') --Light switch
        local atHome = Thuis.active
        dz.log('state of WCD is ' .. wcd.state , dz.LOG_DEBUG)
        dz.log('state of Thuis is ' .. dz.devices('Thuis').state .. '; atHome is ' .. tostring(atHome), dz.LOG_DEBUG)
        if atHome then
            wcd.switchOff().checkFirst() -- phone is atHome so we can switchOff the wcd if it's on.
            for _, doorName in ipairs(doors) do
                local door = dz.devices(doorName)
                dz.log('state of ' .. doorName .. ' is ' .. door.state .. ' (' .. ( ( door.active and 'active' ) or 'not active' ) .. ')', dz.LOG_DEBUG)
                if door.state == 'Open' or door.state == 'Alarm' then -- a door is open
                    allDoorsClosed = false
                    wcd.cancelQueuedCommands()
                    wcd.switchOn()
                    wcd.switchOff().afterSec(delay)
                    dz.log('wcd activated for ' .. delay .. ' seconds because ' .. doorName .. ' is open.' , dz.LOG_DEBUG)
                    dz.notify('Devices', 'Device ' .. doorName .. ' staat open ')
                    break -- no need to look at the other doors if one is open.
            if allDoorsClosed then
                wcd.switchOff().checkFirst() -- All doors are closed so we can switchOff the wcd when it is on
In below text you can see dat it is sending an message when atHome is active
2020-11-18 20:28:45.951 Status: Notification: Testdeur geopend
2020-11-18 20:28:46.099 Status: dzVents: Info: Handling events for: "Testdeur", value: "Alarm"
2020-11-18 20:28:46.099 Status: dzVents: Info: deur: ------ Start internal script: Deur open melding telegram: Device: "Testdeur (RFX)", Index: 223
2020-11-18 20:28:46.100 Status: dzVents: Debug: deur: Processing device-adapter for Thuis: Switch device adapter
2020-11-18 20:28:46.102 Status: dzVents: Debug: deur: Processing device-adapter for WCD: Switch device adapter
2020-11-18 20:28:46.102 Status: dzVents: Debug: deur: state of WCD is Off
2020-11-18 20:28:46.102 Status: dzVents: Debug: deur: state of Thuis is On; atHome is true
2020-11-18 20:28:46.102 Status: dzVents: Debug: deur: Constructed timed-command: Off
2020-11-18 20:28:46.102 Status: dzVents: Info: deur: ------ Finished Deur open melding telegram
2020-11-18 20:28:55.392 Status: dzVents: Info: Handling events for: "Testdeur", value: "Normal"
2020-11-18 20:28:55.392 Status: dzVents: Info: deur: ------ Start internal script: Deur open melding telegram: Device: "Testdeur (RFX)", Index: 223
2020-11-18 20:28:55.395 Status: dzVents: Debug: deur: Processing device-adapter for Thuis: Switch device adapter
2020-11-18 20:28:55.397 Status: dzVents: Debug: deur: Processing device-adapter for WCD: Switch device adapter
2020-11-18 20:28:55.397 Status: dzVents: Debug: deur: state of WCD is Off
2020-11-18 20:28:55.397 Status: dzVents: Debug: deur: state of Thuis is On; atHome is true
2020-11-18 20:28:55.397 Status: dzVents: Debug: deur: Constructed timed-command: Off
2020-11-18 20:28:55.398 Status: dzVents: Info: deur: ------ Finished Deur open melding telegram
Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Trixie - Domoticz 2025.2
RFLink - RFXCom - Zigbee (CC2531)
P1 Smart Meter - KaKu
Fredom wrote: Wednesday 18 November 2020 22:12 In below text you can see dat it is sending an message when atHome is active
I really don't see it. Which line do you think shows that a message is send?
Fredom
Post by Fredom »
waaren wrote: Wednesday 18 November 2020 22:19
Hi Waaren,
I think I found the problem.
The notification comes from domoticz and the switch.
I changed the script's message slightly and I don't see it in Telegram.
I have to remove the notifications from the switches I think
Is this correct?
It was the name of the script that I mistook for a message (sorry).
Yours sincerely,
Fred
Fredom wrote: Wednesday 18 November 2020 22:37 I have to remove the notifications from the switches I think
Is this correct?
If you only want notifications from the script then you should indeed remove them from the devices.
Fredom
Re: Help needed with script  [Solved]
Post by Fredom »
waaren wrote: Wednesday 18 November 2020 22:43
Is this correct?
Hi Waaren,
The text I get from the script in Telegram is
"device Voordeur is open"
I have now removed all notifications from the devices and now (as you already knew) it
works as I wish.
Learned something new.
Thank you for your effort
Gr
Fred
Yours sincerely,
Fred
