Notification script  [Solved]
madpatrick
Domoticz version: 2026.1
Re: Notification script
Post by madpatrick »
I've rebuild this script for my purpose, but just need one additional functionality.
When i'm switch on the alarm mode i'm still standing in the room and of course the PIR will be activated.
Is it possible to have a delay to give time to leave the room without making any dummy switches ?
This is my script so far
local scriptVar = '-=# inbraak #=-'
		devices = {
			'Sensor - Achterdeur',                     -- door contact in de woonkamer
			'Sensor - Garagedeur',                     -- door contact in de garage
			'PIR Sensor',                              -- PIR Sensor
	ustomEvents =
            scriptVar,
	logging =
        level = domoticz.LOG_DEBUG,
        marker = '-=# inbraak #=-',
	execute = function(dz, item)
	    local Achterdeur = dz.devices('Sensor - Achterdeur')
	    local Garagedeur = dz.devices('Sensor - Garagedeur')
	    local PIR = dz.devices('PIR Sensor')
	    local alarmmode = dz.devices('Alarm mode')
	    local lamp = dz.groups('Woonkamer')  -- Alle lampen in woonkamer
	            local delay = 10
		if (Achterdeur.state == 'On' or Garagedeur.state == 'On' or PIR.state == 'On' ) and alarmmode.state == 'On' then
		                    dz.emitEvent(scriptVar).afterSec(delay)
		    lamp.switchOn()
		    --dz.log('Inbraak (thuis)!!',item.name .. ' geactiveerd',dz.LOG_DEBUG)
		    dz.log(item.name .. ' Alarm switched On',dz.LOG_DEBUG)
		    dz.notify('Inbraak (thuis)!!',item.name .. ' geactiveerd',dz.PRIORITY_HIGH)
madpatrick wrote: Saturday 24 October 2020 10:45 Is it possible to have a delay to give time to leave the room without making any dummy switches ?
A solution could look like
return
    on =
        devices =
    logging =
        marker = scriptVar,
        local alarmMode = dz.devices('Alarm mode')
        local delay = 10
        if (Achterdeur.state == 'On' or Garagedeur.state == 'On' or PIR.state == 'On' ) and alarmMode.state == 'On' then
            if alarmMode.lastUpdate.secondsAgo > delay then
                lamp.switchOn()
                dz.log(item.name .. ' was activated but ' .. alarmMode.name .. ' was activated only ' .. alarmMode.lastUpdate.secondsAgo .. ' seconds ago',dz.LOG_DEBUG)
madpatrick
Thanks Waaren !.
Is it possible to change the logging ?
Now everytime when the alarmmode is not switched on and you walk across the PIR, you will see a log entry.
This will grow to much and makes no sense.
LOG
[code]2020-10-24 17:34:33.651 Status: dzVents: Debug: -=# inbraak #=-: Processing device-adapter for Sensor - Garagedeur: Switch device adapter
2020-10-24 17:34:33.651 Status: dzVents: Debug: -=# inbraak #=-: Processing device-adapter for Alarm mode: Switch device adapter
2020-10-24 17:34:33.652 Status: dzVents: Debug: -=# inbraak #=-: Processing device-adapter for Woonkamer: Group device adapter
2020-10-24 17:34:33.652 Status: dzVents: Info: -=# inbraak #=-: ------ Finished Burglar
2020-10-24 17:35:00.541 Status: LUA: (Buienradar) Get data from Buienradar
[/code]
I've changed:
--    logging =
        level = domoticz.LOG_ERROR,
        marker = scriptVar,
But this gives not logging at all when the alarm get's triggered.
for example this line
madpatrick
I've changed it to LOG_INFO and now I see the log lines in the log.
Only it woud be nice to see it only when the alarm mode is ON
madpatrick wrote: Saturday 24 October 2020 18:52 I've changed it to LOG_INFO and now I see the log lines in the log.
return
    on =
        devices =
    logging =
        marker = scriptVar,
        local delay = 10
        if alarmMode.state == 'On' then
            dz.log('alarmMode geactiveerd',dz.LOG_FORCE)
                lamp.switchOn()
                --dz.log('Inbraak (thuis)!!',item.name .. ' geactiveerd',dz.LOG_FORCE)
                dz.log(item.name .. ' Alarm switched On',dz.FORCE)
Jan Jansen
Domoticz version: Stable
Post by Jan Jansen »
@Waaren,
Thanks for your support, it works as desired.
madpatrick
I have the script running, but i like make the notification samrter when a doorsensor is activate.
Currently I've a message on my screen when a door is openend and also indicating which one.
I'm extenting the amount of doorsensors, so maybe it is easier to hanle the messaging and combined it in the script ?
I've activating the message in custom.js and custom.css, but need to make a seperate message block for each sensor.
Now only 2 sensors, but will extend to 4-5 pcs
custom.js
function handleMessage() {
   if (trigger_182 && trigger_188)
        Dashticz.setBlock('emptyblock1', { addClass: 'message4' });
   else if (trigger_182)
        Dashticz.setBlock('emptyblock1', { addClass: 'message2' });
   else if (trigger_188)
        Dashticz.setBlock('emptyblock1', { addClass: 'message3' });
        Dashticz.setBlock('emptyblock1', { addClass: '' });
custom.css
.warning2 {
  	visibility: visible;
.warning2:before {
  	content: "Alarm Activated";
	background: rgba(255,0,0,0.6) !important;
	background-clip: padding-box;
	border: 3px solid white !important;
	border-radius: 15px!important;
	font-size: 20px !important;
	position: absolute;
	top: 15px;
	right: 15px;
	width: 200px;
	padding: 10px;
	text-align : center;
.message1 {
	background: rgba(255,255,0,0.3) !important;
.message2 {
.message2:before {
  	content: "Deur Erker Open";
	position: absolute;
	top: 15px;
	left: 15px;
	width: 200px;
	padding: 10px;
.message3 {
.message3:before {
  	content: "Deur Garage Open";
	position: absolute;
	top: 15px;
	left: 15px;
	width: 200px;
	padding: 10px;
.message4 {
.message4:before {
  	content: "Deur Erker en Garage Open";
	position: absolute;
	top: 15px;
	left: 15px;
	width: 200px;
	padding: 10px;
Is it possible to generate 1 block which will display the name of the sensor(s) ?
I believe the text is possible to generate for a variable : content : var(--name type-or-unit)
Or something like this
