Page 2 of 3
Re: Dutch local covid-19 figures
Posted: Friday 21 August 2020 10:16
by waaren
Xenomes wrote: Friday 21 August 2020 9:07
Tested your new script. The same error exits
but now some counters are populated.
Thx for testing. really appreciated.
Almost there. Updated version in top post. Total number for today will only be available after around 15:00 until then it is shown as 0
Numbers you see on your other counters / text device are from yesterday morning when script is executed before RIVM has updated their data.
Posted: Friday 21 August 2020 11:48
by Xenomes
waaren wrote: Friday 21 August 2020 10:16
Run the new version, no problem testing
2020-08-21 11:27:19.838 Error: dzVents: Error: (3.0.2) covidTrigger: Error parsing json to LUA table: /home/pi/domoticz/scripts/dzVents/../lua/JSON.lua:808: expected string argument to JSON:decode(), got table
2020-08-21 11:27:19.838 Error: dzVents: Error: (3.0.2) covidTrigger: An error occurred when calling event handler covidTrigger
2020-08-21 11:27:19.838 Error: dzVents: Error: (3.0.2) covidTrigger: ...oticz/scripts/dzVents/generated_scripts/covidTrigger.lua:216: attempt to index a nil value (local 't')
Log:
- Spoiler: show
2020-08-21 11:26:00.368 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/covidTrigger.lua
2020-08-21 11:26:00.468 Status: dzVents: Info: covidTrigger: ------ Start internal script: covidTrigger:, trigger: "at 11:26"
2020-08-21 11:26:00.487 Status: dzVents: Debug: covidTrigger: Processing device-adapter for covid-19 in Steenbergen: Text device
2020-08-21 11:26:00.489 Status: dzVents: Debug: covidTrigger: Processing device-adapter for Reported covid-19 in Steenbergen: Counter device adapter
2020-08-21 11:26:00.490 Status: dzVents: Debug: covidTrigger: Processing device-adapter for Deceased covid-19 in Steenbergen: Counter device adapter
2020-08-21 11:26:00.491 Status: dzVents: Debug: covidTrigger: Processing device-adapter for Hospitalized covid-19 in Steenbergen: Counter device adapter
2020-08-21 11:26:00.492 Status: dzVents: Debug: covidTrigger: Processing device-adapter for Reported covid-19 in Netherlands: Counter device adapter
2020-08-21 11:26:00.493 Status: dzVents: Debug: covidTrigger: dzVents version is 3.0.2. Must use base64 encoding
2020-08-21 11:26:00.507 Status: dzVents: Debug: covidTrigger: curl -o /tmp/rivmDataCumulative https://data.rivm.nl/covid-19/COVID-19_aantallen_gemeente_cumulatief.json &
2020-08-21 11:26:00.507 Status: dzVents: Info: covidTrigger: ------ Finished covidTrigger
2020-08-21 11:27:06.082 Status: dzVents: Info: Handling Domoticz custom event for: "covidTrigger_curlReady"
2020-08-21 11:27:06.082 Status: dzVents: Info: covidTrigger: ------ Start internal script: covidTrigger: Custom event: "covidTrigger_curlReady"
2020-08-21 11:27:06.084 Status: dzVents: Debug: covidTrigger: Processing device-adapter for covid-19 in Steenbergen: Text device
2020-08-21 11:27:06.085 Status: dzVents: Debug: covidTrigger: Processing device-adapter for Reported covid-19 in Steenbergen: Counter device adapter
2020-08-21 11:27:06.086 Status: dzVents: Debug: covidTrigger: Processing device-adapter for Deceased covid-19 in Steenbergen: Counter device adapter
2020-08-21 11:27:06.087 Status: dzVents: Debug: covidTrigger: Processing device-adapter for Hospitalized covid-19 in Steenbergen: Counter device adapter
2020-08-21 11:27:06.088 Status: dzVents: Debug: covidTrigger: Processing device-adapter for Reported covid-19 in Netherlands: Counter device adapter
2020-08-21 11:27:06.088 Status: dzVents: Debug: covidTrigger: dzVents version is 3.0.2. Must use base64 encoding
2020-08-21 11:27:06.132 Status: dzVents: Debug: covidTrigger: preProcessorCommand: not needed for Steenbergen
2020-08-21 11:27:06.132 Status: dzVents: Debug: covidTrigger: jqFilterCommand: jq ' .[] | select (.Municipality_name == "Steenbergen" )' /tmp/rivmDataCumulative | jq -s '.[-1] | @base64' > /tmp/rivmFiltered &
2020-08-21 11:27:06.132 Status: dzVents: Debug: covidTrigger: jqTotalCommand: jq ' .[] | select ( .Date_of_report > "2020-08-21" and .Municipality_name != null ) ' /tmp/rivmDataCumulative | jq -s 'map(.Total_reported) | add ' > /tmp/rivmTotal &
2020-08-21 11:27:06.132 Status: dzVents: Info: covidTrigger: ------ Finished covidTrigger
2020-08-21 11:27:19.278 Status: dzVents: Info: Handling Domoticz custom event for: "covidTrigger_jqReturn"
2020-08-21 11:27:19.279 Status: dzVents: Info: covidTrigger: ------ Start internal script: covidTrigger: Custom event: "covidTrigger_jqReturn"
2020-08-21 11:27:19.314 Status: dzVents: Debug: covidTrigger: Processing device-adapter for covid-19 in Steenbergen: Text device
2020-08-21 11:27:19.315 Status: dzVents: Debug: covidTrigger: Processing device-adapter for Reported covid-19 in Steenbergen: Counter device adapter
2020-08-21 11:27:19.316 Status: dzVents: Debug: covidTrigger: Processing device-adapter for Deceased covid-19 in Steenbergen: Counter device adapter
2020-08-21 11:27:19.318 Status: dzVents: Debug: covidTrigger: Processing device-adapter for Hospitalized covid-19 in Steenbergen: Counter device adapter
2020-08-21 11:27:19.319 Status: dzVents: Debug: covidTrigger: Processing device-adapter for Reported covid-19 in Netherlands: Counter device adapter
2020-08-21 11:27:19.319 Status: dzVents: Debug: covidTrigger: dzVents version is 3.0.2. Must use base64 encoding
2020-08-21 11:27:19.378 Status: dzVents: Debug: covidTrigger: getFilteredDataCommand: curl "http://127.0.0.1:8085/json.htm?type=command¶m=customevent&event=covidTrigger_jqFilterReady&data=$(cat /tmp/rivmFiltered)"
2020-08-21 11:27:19.378 Status: dzVents: Info: covidTrigger: ------ Finished covidTrigger
2020-08-21 11:27:19.491 Status: dzVents: Info: Handling Domoticz custom event for: "covidTrigger_jqFilterReady"
2020-08-21 11:27:19.491 Status: dzVents: Info: covidTrigger: ------ Start internal script: covidTrigger: Custom event: "covidTrigger_jqFilterReady"
2020-08-21 11:27:19.511 Status: dzVents: Debug: covidTrigger: Processing device-adapter for covid-19 in Steenbergen: Text device
2020-08-21 11:27:19.512 Status: dzVents: Debug: covidTrigger: Processing device-adapter for Reported covid-19 in Steenbergen: Counter device adapter
2020-08-21 11:27:19.514 Status: dzVents: Debug: covidTrigger: Processing device-adapter for Deceased covid-19 in Steenbergen: Counter device adapter
2020-08-21 11:27:19.515 Status: dzVents: Debug: covidTrigger: Processing device-adapter for Hospitalized covid-19 in Steenbergen: Counter device adapter
2020-08-21 11:27:19.517 Status: dzVents: Debug: covidTrigger: Processing device-adapter for Reported covid-19 in Netherlands: Counter device adapter
2020-08-21 11:27:19.517 Status: dzVents: Debug: covidTrigger: dzVents version is 3.0.2. Must use base64 encoding
2020-08-21 11:27:19.524 Status: dzVents: Debug: covidTrigger: updateCounterDevices: {["Municipality_name"]="Steenbergen", ["Municipality_code"]="GM0851", ["Deceased"]=13, ["Province"]="Noord-Brabant", ["Total_reported"]=105, ["Hospital_admission"]=13, ["Date_of_report"]="2020-08-20 10:00:00"}
2020-08-21 11:27:19.527 Status: dzVents: Info: covidTrigger: ------ Finished covidTrigger
2020-08-21 11:27:19.834 Status: dzVents: Info: Handling Domoticz custom event for: "covidTrigger_updateText"
2020-08-21 11:27:19.835 Status: dzVents: Info: covidTrigger: ------ Start internal script: covidTrigger: Custom event: "covidTrigger_updateText"
2020-08-21 11:27:19.836 Status: dzVents: Debug: covidTrigger: Processing device-adapter for covid-19 in Steenbergen: Text device
2020-08-21 11:27:19.838 Status: dzVents: Debug: covidTrigger: Processing device-adapter for Reported covid-19 in Steenbergen: Counter device adapter
2020-08-21 11:27:19.838 Status: dzVents: Debug: covidTrigger: dzVents version is 3.0.2. Must use base64 encoding
2020-08-21 11:27:19.838 Status: dzVents: Debug: covidTrigger: updateTextDevice: nil
2020-08-21 11:27:19.838 Status: dzVents: Info: covidTrigger: ------ Finished covidTrigger
Posted: Friday 21 August 2020 13:13
by waaren
Xenomes wrote: Friday 21 August 2020 11:48
Switching method to parse data between script executions
Now use dzVents persistent data . Should be handled correctly by all dzVents versions >= 3.0
history:
20200816 Start coding
20200817 Initial release on forum
20200818 Fixed jq output redirection from stdout to file for version < 1.6
20200818 Only select last date from records
20200818 Add total for the Netherlands (based on all Municipalities)
20200819 Add description how to populate history table
20200819 Fixed unwanted end of comment block
20200820 Update text device in separate execution to collect latest counters
20200820 Add lodash debug lines
20200820 Fixed unexpected behavior with city names containing special chars
20200820 Add latest report time to text sensor
20200820 Make filterdelay configurable and fixed typo
20200821 Use base64 string as data for dzVents < 3.0.9 (curl POST cannot be used to trigger customEvents in these versions)
20200821 Use persistent data to parse filtered data between script executions
Posted: Friday 21 August 2020 13:36
by Xenomes
Posted: Saturday 22 August 2020 23:27
by waaren
Updated version in top post:
history:
20200822 Add total deceased and total hospitalized for the country (2 additional counterdevices)
20200822 Use external bash script to populate history table for all counters (Only needed once)
Posted: Monday 28 September 2020 11:58
by EdwinK
Would it be possible to send the data from one of the text-sensors to Facebook and/or Twitter? Or would this involve IFTT and such? There is no 'notification'-settings for utility devices.
Posted: Monday 28 September 2020 12:32
by waaren
EdwinK wrote: Monday 28 September 2020 11:58
Using IFTTT it is possible but I don't know if Facebook / Twitter allow to post data using a URL.
If the do dzVents can send the data using its openURL command.
Posted: Tuesday 29 September 2020 12:22
by EdwinK
I found this page
https://developers.facebook.com/docs/gr ... ence/post/
It all sounds very technical for me.
Posted: Monday 05 October 2020 17:42
by waaren
Updated the version in the first post.
When data from RIVM does not have today's data yet the script will reschedule itself after appr. 30 minutes.
Posted: Tuesday 06 October 2020 15:22
by Xenomes
waaren, nice job! Updated my script with yours.
Posted: Tuesday 20 October 2020 20:56
by JeroenG
Hi Warren,
trying to use the bash script to import the history ran into issue that my city (Alphen aan den Rijn) contains space which is no fun on linux.
Fixed it by changing the following 4 lines (placed quotes around $city.json):
sudo jq " .[] | select (.Municipality_name == \"$city\" )" $tmpDir/"$prefix"_Complete.json | jq . -s > "$tmpDir"/"$prefix"_"$city.json"
sudo cat $tmpDir/"$prefix"_"$city.json" | jq -r '. | map([ env.deceased, 0, .Deceased, .Date_of_report[:10] ] | @csv)| join("\n")' > "$tmpDir"/"$prefix"_deceased.csv
sudo cat $tmpDir/"$prefix"_"$city.json" | jq -r '. | map([ env.reported, 0, .Total_reported, .Date_of_report[:10] ] | @csv)| join("\n")' > "$tmpDir"/"$prefix"_reported.csv
sudo cat $tmpDir/"$prefix"_"$city.json" | jq -r '. | map([ env.hospitalized, 0, .Hospital_admission, .Date_of_report[:10] ] | @csv)| join("\n")' > "$tmpDir"/"$prefix"_hospitalized.csv
Kind regards,
Jeroen
Posted: Tuesday 20 October 2020 23:14
by waaren
JeroenG wrote: Tuesday 20 October 2020 20:56
Thx for reporting and the fix. I will update the posted script with your mod.
Posted: Sunday 28 February 2021 23:45
by yvonnehx1
Unfortunately the number of reported Covid-19 people in the Netherlands has grown over a million. That number is now represented as 1.08483e+06 on the "Reported covid-19 in the Netherlands" switch in the Domoticz dashboard. How to fix this?
Thanks in advance.
Posted: Monday 01 March 2021 0:54
by waaren
yvonnehx1 wrote: Sunday 28 February 2021 23:45
Thanks in advance.
If you need the number displayed in a none scientific (better human readable) way you will need to display it in a virtual text sensor.
I updated the script in the first post to add this as an option.
Posted: Monday 01 March 2021 21:27
by yvonnehx1
Thanks Waaren, for your quick solution. I'll give it a try.
Kind regards
Posted: Monday 07 June 2021 22:44
by Xenomes
My 'Reported covid-19 in' is 7 days not updated? Do anyone have this issue to?
Posted: Tuesday 08 June 2021 8:18
by waaren
Xenomes wrote: Monday 07 June 2021 22:44
covid script is still working for me. (see below)
Do you see anything in the log?
- covid.png (139.88 KiB) Viewed 4145 times
- covidC.png (262.79 KiB) Viewed 4145 times
Posted: Tuesday 08 June 2021 16:28
by Xenomes
I change the script 2 days a go to the latest version, before that is was running for months.
In the log it show this:
2021-06-08 16:16:06.129 Status: dzVents: Info: Handling Domoticz custom event for: "CovidTrigger_checkDate"
2021-06-08 16:16:09.379 Status: dzVents: Info: Handling Domoticz custom event for: "CovidTrigger_curlReady"
2021-06-08 16:16:40.803 Status: dzVents: Info: Handling Domoticz custom event for: "CovidTrigger_jqReturn"
2021-06-08 16:16:41.271 Status: dzVents: Info: Handling Domoticz custom event for: "CovidTrigger_jqFilterReady"
2021-06-08 16:16:41.856 Status: dzVents: Info: Handling Domoticz custom event for: "CovidTrigger_updateText"
- 2021-06-08 16_21_28-Domoticz - Overige.png (276.81 KiB) Viewed 4133 times
- 2021-06-08 16_26_16-Domoticz - Devices_638_Log.png (231.24 KiB) Viewed 4133 times
Posted: Tuesday 08 June 2021 20:07
by waaren
Xenomes wrote: Tuesday 08 June 2021 16:28
if you change line
level = domoticz.LOG_ERROR, -- change to domoticz.LOG_ERROR when all ok.
to
level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all ok.
You should see much more relevant information
Posted: Tuesday 08 June 2021 20:21
by Xenomes
Here is the extended log.
2021-06-08 20:11:51.775 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/CovidTrigger.lua
2021-06-08 20:12:00.298 Status: dzVents: Info: CovidTrigger: ------ Start internal script: CovidTrigger:, trigger: "at 20:12"
2021-06-08 20:12:00.345 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for covid-19 in Steenbergen: Text device
2021-06-08 20:12:00.350 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Reported covid-19 in Steenbergen: Counter device adapter
2021-06-08 20:12:00.352 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Deceased covid-19 in Steenbergen: Counter device adapter
2021-06-08 20:12:00.353 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Hospitalized covid-19 in Steenbergen: Counter device adapter
2021-06-08 20:12:00.355 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Reported covid-19 in Netherlands: Counter device adapter
2021-06-08 20:12:00.357 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Deceased covid-19 in Netherlands: Counter device adapter
2021-06-08 20:12:00.360 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Hospitalized covid-19 in Netherlands: Counter device adapter
2021-06-08 20:12:00.363 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for covid-19 in Netherlands: Text device
2021-06-08 20:12:00.397 Status: dzVents: Debug: CovidTrigger: curl -o /tmp/rivmDataCumulative https://data.rivm.nl/covid-19/COVID-19_aantallen_gemeente_cumulatief.json &
2021-06-08 20:12:00.402 Status: dzVents: Info: CovidTrigger: ------ Finished CovidTrigger
2021-06-08 20:13:07.570 Status: dzVents: Info: Handling Domoticz custom event for: "CovidTrigger_checkDate"
2021-06-08 20:13:07.571 Status: dzVents: Info: CovidTrigger: ------ Start internal script: CovidTrigger: Custom event: "CovidTrigger_checkDate"
2021-06-08 20:13:07.592 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for covid-19 in Steenbergen: Text device
2021-06-08 20:13:07.594 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Reported covid-19 in Steenbergen: Counter device adapter
2021-06-08 20:13:07.595 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Deceased covid-19 in Steenbergen: Counter device adapter
2021-06-08 20:13:07.597 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Hospitalized covid-19 in Steenbergen: Counter device adapter
2021-06-08 20:13:07.599 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Reported covid-19 in Netherlands: Counter device adapter
2021-06-08 20:13:07.601 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Deceased covid-19 in Netherlands: Counter device adapter
2021-06-08 20:13:07.603 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Hospitalized covid-19 in Netherlands: Counter device adapter
2021-06-08 20:13:07.605 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for covid-19 in Netherlands: Text device
2021-06-08 20:13:07.660 Status: dzVents: Debug: CovidTrigger: Today is available (3
2021-06-08 20:13:07.661 Status: dzVents: Info: CovidTrigger: ------ Finished CovidTrigger
2021-06-08 20:13:10.853 Status: dzVents: Info: Handling Domoticz custom event for: "CovidTrigger_curlReady"
2021-06-08 20:13:10.855 Status: dzVents: Info: CovidTrigger: ------ Start internal script: CovidTrigger: Custom event: "CovidTrigger_curlReady"
2021-06-08 20:13:10.876 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for covid-19 in Steenbergen: Text device
2021-06-08 20:13:10.878 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Reported covid-19 in Steenbergen: Counter device adapter
2021-06-08 20:13:10.881 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Deceased covid-19 in Steenbergen: Counter device adapter
2021-06-08 20:13:10.882 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Hospitalized covid-19 in Steenbergen: Counter device adapter
2021-06-08 20:13:10.884 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Reported covid-19 in Netherlands: Counter device adapter
2021-06-08 20:13:10.888 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Deceased covid-19 in Netherlands: Counter device adapter
2021-06-08 20:13:10.891 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Hospitalized covid-19 in Netherlands: Counter device adapter
2021-06-08 20:13:10.892 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for covid-19 in Netherlands: Text device
2021-06-08 20:13:11.065 Status: dzVents: Debug: CovidTrigger: preProcessorCommand: not needed for Steenbergen
2021-06-08 20:13:11.069 Status: dzVents: Debug: CovidTrigger: jqFilterCommand: jq ' .[] | select (.Municipality_name == "Steenbergen" )' /tmp/rivmDataCumulative | jq .[-1] -s > /tmp/rivmFiltered &
2021-06-08 20:13:11.070 Status: dzVents: Debug: CovidTrigger: jqTotalReportedCommand: jq ' .[] | select ( .Date_of_report > "2021-06-08" and .Municipality_name != null ) ' /tmp/rivmDataCumulative | jq -s 'map(.Total_reported) | add ' > /tmp/rivmTotalReported &
2021-06-08 20:13:11.077 Status: dzVents: Info: CovidTrigger: ------ Finished CovidTrigger
2021-06-08 20:13:42.616 Status: dzVents: Info: Handling Domoticz custom event for: "CovidTrigger_jqReturn"
2021-06-08 20:13:42.617 Status: dzVents: Info: CovidTrigger: ------ Start internal script: CovidTrigger: Custom event: "CovidTrigger_jqReturn"
2021-06-08 20:13:42.622 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for covid-19 in Steenbergen: Text device
2021-06-08 20:13:42.623 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Reported covid-19 in Steenbergen: Counter device adapter
2021-06-08 20:13:42.625 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Deceased covid-19 in Steenbergen: Counter device adapter
2021-06-08 20:13:42.630 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Hospitalized covid-19 in Steenbergen: Counter device adapter
2021-06-08 20:13:42.632 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Reported covid-19 in Netherlands: Counter device adapter
2021-06-08 20:13:42.634 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Deceased covid-19 in Netherlands: Counter device adapter
2021-06-08 20:13:42.636 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Hospitalized covid-19 in Netherlands: Counter device adapter
2021-06-08 20:13:42.639 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for covid-19 in Netherlands: Text device
2021-06-08 20:13:42.901 Status: dzVents: Debug: CovidTrigger: getFilteredDataCommand: curl -d '@/tmp/rivmFiltered' 'http://127.0.0.1:8085/json.htm?type=command¶m=customevent&event=CovidTrigger_jqFilterReady'
2021-06-08 20:13:42.903 Status: dzVents: Info: CovidTrigger: ------ Finished CovidTrigger
2021-06-08 20:13:43.259 Status: dzVents: Info: Handling Domoticz custom event for: "CovidTrigger_jqFilterReady"
2021-06-08 20:13:43.259 Status: dzVents: Info: CovidTrigger: ------ Start internal script: CovidTrigger: Custom event: "CovidTrigger_jqFilterReady"
2021-06-08 20:13:43.262 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for covid-19 in Steenbergen: Text device
2021-06-08 20:13:43.264 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Reported covid-19 in Steenbergen: Counter device adapter
2021-06-08 20:13:43.284 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Deceased covid-19 in Steenbergen: Counter device adapter
2021-06-08 20:13:43.290 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Hospitalized covid-19 in Steenbergen: Counter device adapter
2021-06-08 20:13:43.296 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Reported covid-19 in Netherlands: Counter device adapter
2021-06-08 20:13:43.311 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Deceased covid-19 in Netherlands: Counter device adapter
2021-06-08 20:13:43.315 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Hospitalized covid-19 in Netherlands: Counter device adapter
2021-06-08 20:13:43.320 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for covid-19 in Netherlands: Text device
2021-06-08 20:13:43.321 Status: dzVents: Debug: CovidTrigger: updateCounterDevices: {["Date_of_report"]="2021-06-08 10:00:00", ["Municipality_name"]="Steenbergen", ["Total_reported"]=2278, ["Province"]="Noord-Brabant", ["Municipality_code"]="GM0851", ["Deceased"]=19, ["Hospital_admission"]=33}
2021-06-08 20:13:43.323 Status: dzVents: Info: CovidTrigger: nil
2021-06-08 20:13:43.324 Status: dzVents: Info: CovidTrigger: nil
2021-06-08 20:13:43.328 Status: dzVents: Info: CovidTrigger: ------ Finished CovidTrigger
2021-06-08 20:13:43.904 Status: dzVents: Info: Handling Domoticz custom event for: "CovidTrigger_updateText"
2021-06-08 20:13:43.905 Status: dzVents: Info: CovidTrigger: ------ Start internal script: CovidTrigger: Custom event: "CovidTrigger_updateText"
2021-06-08 20:13:43.908 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for covid-19 in Steenbergen: Text device
2021-06-08 20:13:43.910 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Reported covid-19 in Steenbergen: Counter device adapter
2021-06-08 20:13:43.912 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Deceased covid-19 in Steenbergen: Counter device adapter
2021-06-08 20:13:43.914 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for Hospitalized covid-19 in Steenbergen: Counter device adapter
2021-06-08 20:13:43.916 Status: dzVents: Debug: CovidTrigger: Processing device-adapter for covid-19 in Netherlands: Text device
2021-06-08 20:13:43.917 Status: dzVents: Debug: CovidTrigger: updateTextDevice: {["Date_of_report"]="2021-06-08 10:00:00", ["Municipality_name"]="Steenbergen", ["Total_reported"]=2278, ["Province"]="Noord-Brabant", ["Municipality_code"]="GM0851", ["Deceased"]=19, ["Hospital_admission"]=33}
2021-06-08 20:13:43.920 Status: dzVents: Info: CovidTrigger: ------ Finished CovidTrigger
