Progress has been slow, its been manic at work - no excuse
I have added dial numbers, as an optional parameter, based on the min/max range (also optional parameters). It is still work in progress, but I thought I would share some screenshots of how its shaping up.
Evohome, Heating, Thermostat or Toon dial:
There is also an optional "setpoint" parameter than you can add to the following dials. This will control what ring color is displayed. For example, I have "setpoint: 15" in the dials below. If its above 15 degrees, it will show orange (or any custom color). If below, it will show blue (or any custom color).
"Temp + Humidity" dial:
"Temp + Humidity + Baro" dial:
"Wind" dial: this took a bit of effort, as its a 360 degree dial. I had added an 'offset' parameter so the dial needle can either point towards where the wind originates from, or the direction it is blowing in. Personally, I prefer the latter (which what is set below). It also uses the wind unit if set in Domoticz. Mine is set to "mph". Like above, because its above 15 degrees temperature, the dial ring is orange. That can be toggled on or off in the block.
"Dimmer" dial (on): nothing really new here, except the numbers.
"On/Off" dial (left = off, right = on): this is a new block I am working on specifically for "On/Off" devices. Technically, it isn't a dial, but I want all my switches/dials to match
Obviously, these are configured to my settings, the decimal for example is a dot on mine. But for all you NL folks, it will show a comma. All icons can be replaced on the block, with other icons or images. These are not finished yet, so they won't be in the beta for a while yet.
Cheers
