Adding Somfy blinds to domoticz using 433.92 crystal Topic is solved
FireWizard
Re: Adding Somfy blinds to domoticz using 433.92 crystal
Post by FireWizard »
@Havym
Let us conclude first.
The fact that you get the log file means that the exec.sh script is executed.
It is the same, if you execute it from the command line. This was expected.
I assume that in case it is activated from Domoticz, the actions is not carried out.
Both closing and opening?
If you do it from the command line it is carried out?
What is the owner ship of the log files? (ls -l)
Can you try to modify the exec.sh script, so that the last line moves up?
#!/bin/sh
/usr/bin/python /home/pi/domoticz/scripts/$1.py $2 $3 > /dev/null 2>&1 &
NOW=$(date +"%Y-%m-%d")
LOGFILE=/home/pi/controller.$NOW.log
echo $(date +"%Y-%m-%d %H:%M:%S") controller | tee -a $LOGFILE
Another question.
A directory called "remotes" is used. What are the ownership and access rights of this directory?
Awaiting your results.
Havym
Domoticz version: 2024.7
Post by Havym »
FireWizard wrote: Monday 20 April 2020 12:31 I assume that in case it is activated from Domoticz, the actions is not carried out.
#!/bin/sh
Another question.
In command line i only tried the close action and nothing happend to the screen with this script in exec.sh.
The folder 'remotes' is owned by pi
drwxr-xr-x 2 pi pi 4096 Apr 18 12:22 remotes
When i change the exec.sh in command line and nothing happens with the screen.
pi@raspberrypi:~ $ /home/pi/domoticz/scripts/exec.sh Overkapping close
2020-04-20 14:55:21 controller
The log file:
First 2 are made in commandline and second 2 in domoticz
2020-04-20 14:54:49 controller
2020-04-20 14:57:01 controller
2020-04-20 14:57:06 controller
FireWizard
@Havym
We keep on trying :(
This means that using the latest exec.sh file both Domoticz and the command line are not able to open/close the screen?
If you run the following command as user pi, the screen should open/close
/usr/bin/python /home/pi/domoticz/scripts/controller.py Overkapping open > /dev/null 2>&1 &
or
/usr/bin/python /home/pi/domoticz/scripts/controller.py Overkapping close > /dev/null 2>&1 &
If this is the case, we should try to modify the script to:
#!/bin/sh
Let us try
Havym
Post by Havym »
Thank you for you patience :oops:
This works!
pi@raspberrypi:~ $ /usr/bin/python /home/pi/domoticz/scripts/controller.py Overkapping close > /dev/null 2>&1 &
[1] 28694
pi@raspberrypi:~ $ /usr/bin/python /home/pi/domoticz/scripts/controller.py Overkapping open > /dev/null 2>&1 &
[2] 30027
[1]   Done                    /usr/bin/python /home/pi/domoticz/scripts/controller.py Overkapping close > /dev/null 2>&1
I changed the exec.sh file and now the screen closes! :D
2020-04-20 17:04:17 controller
I even tried it in domoticz as i would expect you ask me to try. Unfortunate in domoticz it doenst work.
2020-04-20 17:06:48.624 Status: User: Admin initiated a switch command (153/Zonnescherm/Off)
2020-04-20 17:06:48.858 Status: Executing script: /home/pi/domoticz/scripts/exec.sh
FireWizard
@Havym
So the command
works.
I assume that
also works.
If you control it via the exec.sh script with the contents of "close", it closes and creates a log file?
You should rename the exec.sh file to e.g. exec_close.sh.
Similar create an identical file e.g exec_open.sh with the second command (open) in it.
Run it first from the command line and test that both commands function, if you run ./exec_close.sh or ./exec_open.sh from the scripts directory.
Next try to control it from Domoticz: with the ON and OFF scripts.
1. ON: ///home/pi/domoticz/scripts/exec_close.sh
2. OFF: ///home/pi/domoticz/scripts/exec_open.sh
Check also that a log file is created.
Lets try
Havym
Post by Havym »
Correct both commands worked and creates a log line in the file of today.
[1] 28694
Line in log file:
2020-04-20 17:06:48 controller
[2] 30027
But '/home/pi/domoticz/scripts/controller.py Overkapping close' workes too, the screen closes because i moved the 'remotes' folder:
pi@raspberrypi:~ $ /home/pi/domoticz/scripts/controller.py Overkapping close
Action       : close
Room         : Overkapping
Remote       : 0x267043
Button       : 0x04
Rolling code : 287
Frame        : 0xA7 0x40 0x01 0x1F 0x26 0x70 0x43
With cks     : 0xA7 0x42 0x01 0x1F 0x26 0x70 0x43
Obfuscated   : 0xA7 0xE5 0xE4 0xFB 0xDD 0xAD 0xEE
But moving on with your suggestion.
I changed the file exec.sh to exec_close.sh and created exec_open.sh
Running the command with ./exec_close.sh gives me a log file but the screen wont work.
pi@raspberrypi:~/domoticz/scripts $ ./exec_close.sh
2020-04-20 21:43:31 controller
Running the command with /home/pi/domoticz/scripts/exec_close.sh give me the same log file and the screen works.
pi@raspberrypi:~ $ /home/pi/domoticz/scripts/exec_close.sh
2020-04-20 21:45:30 controller
The open command gives me an error.
pi@raspberrypi:~ $ /home/pi/domoticz/scripts/exec_open.sh
/home/pi/domoticz/scripts/exec_open.sh: 2: /home/pi/domoticz/scripts/exec_open.sh: cannot create /de$: Permission denied
Never mind.... typo
I think there something with the 'remote' folder. In the beginning i had to bind the sending code to the Somfy device and the code is stored in the 'remotes' folder.
FireWizard
@Havym
If you suspect the remotes folder, I suggest that you remove the Sompi and remotes folder out of the Domoticz scripts folder.
A good place will be the pi home folder, so /home/pi/Sompi and /home/pi/Sompi/remotes.
Try to pair again and then we will look again.
Havym
Post by Havym »
Ok, so i deleted everything and started over.
The script and the remotes folder like https://github.com/alxlaxv/SomPi are in /home/pi/SomPi and the controller is paired using
./controller.py Overkapping register
Using in command line
./controller.py Overkapping close
gives me the following and the screens goes down.
pi@raspberrypi:~/SomPi $ ./controller.py Overkapping close
Action       : close
Room         : Overkapping
Remote       : 0x267043
Button       : 0x02
Rolling code : 226
Frame        : 0xA7 0x20 0x00 0xE2 0x26 0x70 0x43
With cks     : 0xA7 0x27 0x00 0xE2 0x26 0x70 0x43
Obfuscated   : 0xA7 0x80 0x80 0x62 0x44 0x34 0x77
/home/pi/SomPi/controller.py Overkapping close
gives me this ..... and nothing happens to the screen.
pi@raspberrypi:~ $ /home/pi/SomPi/controller.py Overkapping close
Action       : close
Room         : Overkapping
  File "/home/pi/SomPi/controller.py", line 164, in <module>
    send(sys.argv[1], sys.argv[2])
  File "/home/pi/SomPi/controller.py", line 43, in send
    with open("remotes/" + room + ".txt", 'r') as file:
IOError: [Errno 2] No such file or directory: 'remotes/Overkapping.txt'
The error is there because there is no 'remotes' folder in /home/pi from which the command is run from.
When i copy the 'remotes' folder to /home/pi i need to repair Somfy and the other paired one doenst work anymore.
So i think its in the script that causes issues from running in Domoticz
FireWizard
This means that the "remotes" directory has to be in the same directory as where the command is run? I thought, it was a subdir in Sompi.
Let think about it.
Havym
Post by Havym »
Correct, remotes is a subdir in Sompi and the script refers to Overkapping.txt where the Somfy code is stored.
Verstuurd vanaf mijn ONEPLUS A6013 met Tapatalk
FireWizard
@Havym
Is this something, you did look at?
https://github.com/Nickduino/Pi-Somfy
Havym
Post by Havym »
Yes i tried that one and it worked for a short time, but my raspberry crashed using this script.
This one is more complex then the SomPi scripts... but i can try again.
But i havent got any idea how to implement this one into domoticz either. :roll:
FireWizard
@Havym
The last script looks more advanced and with much more possibilities, but we try once more.
Let's summing up:
The script runs as being executed as pi user and only from the directory (in this case) /home/pi/Sompi.
Let us try to modify the exec_open.sh and exec_close.sh by adding (both): cd /home/pi/Sompi
#!/bin/sh
cd /home/pi/Sompi
/usr/bin/python ./controller.py Overkapping close > /dev/null 2>&1 &
Havym
Post by Havym »
Thank again.... i created the exec_open and exec_close.sh files with you comments.
Close works!
pi@raspberrypi:~/SomPi $ ./exec_close.sh
2020-04-22 17:04:39 controller
Open works too!
pi@raspberrypi:~/SomPi $ ./exec_open.sh
2020-04-22 17:04:45 controller
And now.... the great finale.....
This one works too!
pi@raspberrypi:~ $ /home/pi/SomPi/exec_close.sh
2020-04-22 17:07:42 controller
And i put in domoticz... script:///home/pi/SomPi/exec_close.sh
And it works!!!! :P :P :P :P :P
Thank you very much for you patience with me and figuring out this problem.
To skip the log part i should just delete this part from exec_open.sh?
FireWizard
@Havym
Great. It was a lot of try and error.
And it was more or less my last guess.
You can now clean-up the directories.
Remove all created log files, that has been created during all the tests.
Indeed, you can also remove the log lines from both scripts.
Otherwise a lot of log files will be created, if you use it.
Have a lot of fun, with your Blinds.
Best regards
