If you send the complete JSON and the mapping from the names in the JSON to the deviceNames in domoticz I will have a look if this can be coded in a more generic way.Ragdag wrote: Wednesday 06 May 2020 11:47 Unfortunately after a restart of the server the Temperatures array in the json has a different order.
Is there a way for me to loop through the array and pick a value if the name is correct?
Read Dell iDRAC values through Redfish Topic is solved
- waaren
Re: Read Dell iDRAC values through Redfish
- Ragdag
This is the entire json payload.waaren wrote: Wednesday 06 May 2020 12:12If you send the complete JSON and the mapping from the names in the JSON to the deviceNames in domoticz I will have a look if this can be coded in a more generic way.Ragdag wrote: Wednesday 06 May 2020 11:47 Unfortunately after a restart of the server the Temperatures array in the json has a different order.
"@odata.context": "/redfish/v1/$metadata#Thermal.Thermal",
"@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Thermal",
"@odata.type": "#Thermal.v1_4_0.Thermal",
"Description": "Represents the properties for Temperature and Cooling",
"Fans": [
"@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Sensors/Fans/0x17%7C%7CFan.Embedded.1",
"@odata.type": "#Thermal.v1_4_0.Fan",
"Assembly": {
"@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Assembly"
"FanName": "System Board Fan1 RPM",
"LowerThresholdCritical": 360,
"LowerThresholdFatal": 360,
"LowerThresholdNonCritical": 600,
"MaxReadingRange": null,
"MemberId": "0x17||Fan.Embedded.1",
"MinReadingRange": 360,
"Name": "System Board Fan1 RPM",
"PhysicalContext": "SystemBoard",
"Reading": 4440,
"ReadingUnits": "RPM",
"Redundancy": [],
"[email protected]": 0,
"RelatedItem": [
"@odata.id": "/redfish/v1/Chassis/System.Embedded.1"
"[email protected]": 1,
"Status": {
"Health": "OK",
"State": "Enabled"
"UpperThresholdCritical": null,
"UpperThresholdFatal": null,
"UpperThresholdNonCritical": null
"@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Sensors/Fans/0x17%7C%7CFan.Embedded.2",
"Assembly": {
"FanName": "System Board Fan2 RPM",
"MemberId": "0x17||Fan.Embedded.2",
"Name": "System Board Fan2 RPM",
"Reading": 4440,
"Redundancy": [],
"RelatedItem": [
"Status": {
"Health": "OK",
"State": "Enabled"
"@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Sensors/Fans/0x17%7C%7CFan.Embedded.3",
"Assembly": {
"FanName": "System Board Fan3 RPM",
"MemberId": "0x17||Fan.Embedded.3",
"Name": "System Board Fan3 RPM",
"Reading": 4440,
"Redundancy": [],
"RelatedItem": [
"Status": {
"Health": "OK",
"State": "Enabled"
"@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Sensors/Fans/0x17%7C%7CFan.Embedded.5",
"Assembly": {
"FanName": "System Board Fan5 RPM",
"MemberId": "0x17||Fan.Embedded.5",
"Name": "System Board Fan5 RPM",
"Reading": 4440,
"Redundancy": [],
"RelatedItem": [
"Status": {
"Health": "OK",
"State": "Enabled"
"@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Sensors/Fans/0x17%7C%7CFan.Embedded.6",
"Assembly": {
"FanName": "System Board Fan6 RPM",
"MemberId": "0x17||Fan.Embedded.6",
"Name": "System Board Fan6 RPM",
"Reading": 4440,
"Redundancy": [],
"RelatedItem": [
"Status": {
"Health": "OK",
"State": "Enabled"
"@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Sensors/Fans/0x17%7C%7CFan.Embedded.4",
"Assembly": {
"FanName": "System Board Fan4 RPM",
"MemberId": "0x17||Fan.Embedded.4",
"Name": "System Board Fan4 RPM",
"Reading": 4320,
"Redundancy": [],
"RelatedItem": [
"Status": {
"Health": "OK",
"State": "Enabled"
"[email protected]": 6,
"Id": "Thermal",
"Name": "Thermal",
"Redundancy": [
"@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Thermal/Redundancy/iDRAC.Embedded.1%23SystemBoardFanRedundancy",
"@odata.type": "#Redundancy.v1_3_0.Redundancy",
"MaxNumSupported": null,
"MemberId": "iDRAC.Embedded.1#SystemBoardFanRedundancy",
"MinNumNeeded": null,
"Mode": "N+m",
"Name": "System Board Fan Redundancy",
"RedundancyEnabled": true,
"RedundancySet": [],
"Status": {
"Health": "OK",
"State": "Enabled"
"Temperatures": [
"@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Sensors/Temperatures/iDRAC.Embedded.1%23SystemBoardInletTemp",
"@odata.type": "#Thermal.v1_4_0.Temperature",
"LowerThresholdCritical": -7,
"LowerThresholdFatal": -7,
"LowerThresholdNonCritical": 3,
"MaxReadingRangeTemp": 47,
"MemberId": "iDRAC.Embedded.1#SystemBoardInletTemp",
"MinReadingRangeTemp": -7,
"Name": "System Board Inlet Temp",
"ReadingCelsius": 19,
"RelatedItem": [
"SensorNumber": 4,
"Status": {
"Health": "OK",
"State": "Enabled"
"UpperThresholdCritical": 47,
"UpperThresholdFatal": 47,
"UpperThresholdNonCritical": 42
"@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Sensors/Temperatures/iDRAC.Embedded.1%23SystemBoardExhaustTemp",
"LowerThresholdCritical": 0,
"LowerThresholdFatal": 0,
"LowerThresholdNonCritical": 0,
"MaxReadingRangeTemp": 75,
"MemberId": "iDRAC.Embedded.1#SystemBoardExhaustTemp",
"MinReadingRangeTemp": 0,
"Name": "System Board Exhaust Temp",
"ReadingCelsius": 34,
"RelatedItem": [
"SensorNumber": 1,
"Status": {
"Health": "OK",
"State": "Enabled"
"UpperThresholdCritical": 75,
"UpperThresholdFatal": 75,
"UpperThresholdNonCritical": 70
"@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Sensors/Temperatures/iDRAC.Embedded.1%23CPU1Temp",
"LowerThresholdCritical": 3,
"LowerThresholdFatal": 3,
"LowerThresholdNonCritical": 8,
"MaxReadingRangeTemp": 87,
"MemberId": "iDRAC.Embedded.1#CPU1Temp",
"MinReadingRangeTemp": 3,
"Name": "CPU1 Temp",
"PhysicalContext": "CPU",
"ReadingCelsius": 58,
"RelatedItem": [
"@odata.id": "/redfish/v1/Systems/System.Embedded.1/Processors/CPU.Socket.1"
"SensorNumber": 14,
"Status": {
"Health": "OK",
"State": "Enabled"
"UpperThresholdCritical": 87,
"UpperThresholdFatal": 87,
"UpperThresholdNonCritical": 82
"[email protected]": 3
local scriptVar = 'iDRAC_Temp'
return
on =
timer =
'every 5 minutes' -- just an example to trigger the request
httpResponses =
scriptVar, -- must match with the callback passed to the openURL command
logging =
--level = domoticz.LOG_DEBUG,
marker = scriptVar,
if (item.isTimer) then
domoticz.openURL({
url = 'https://root:[email protected]/redfish/v1/Chassis/System.Embedded.1/Thermal',
method = 'GET',
callback = scriptVar, -- see httpResponses above.
if (item.isHTTPResponse) then
if (item.ok) then
if (item.isJSON) then
local inletTemp = item.json.Temperatures[1].ReadingCelsius
local ExhaustTemp = item.json.Temperatures[2].ReadingCelsius
domoticz.log('Inlet: ' .. inletTemp, domoticz.LOG_DEBUG)
domoticz.log('Exhaust: ' .. ExhaustTemp, domoticz.LOG_DEBUG)
if (domoticz.devices(268).updateTemperature(inletTemp) == 0.0 ) then
domoticz.log('There was a problem getting an 0.0 reading for Inlet', domoticz.LOG_ERROR)
-- update some device in Domoticz
if (domoticz.devices(269).updateTemperature(ExhaustTemp) == 0.0 ) then
domoticz.log('There was a problem getting an 0.0 reading for Exhaust', domoticz.LOG_ERROR)
domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
domoticz.log(item, domoticz.LOG_ERROR)
- waaren
Can you try this one?Ragdag wrote: Wednesday 06 May 2020 11:47 Unfortunately after a restart of the server the Temperatures array in the json has a different order.
return
on =
timer =
'every 5 minutes', -- just an example to trigger the request
httpResponses =
logging =
marker = scriptVar,
execute = function(dz, item)
if item.isTimer then
dz.openURL({
method = 'GET',
return
if item.isJSON then
local inletTemp = -999
local exhaustTemp = -999
subTable = item.json.Temperatures
for index, record in ipairs(subTable) do
if record.Name:find('Inlet Temp') then
inletTemp = record.ReadingCelsius
elseif record.Name:find('Exhaust Temp') then
exhaustTemp = record.ReadingCelsius
if inletTemp == -999 then
dz.log('There was a problem getting a reading for Inlet', dz.LOG_ERROR)
dz.devices(268).updateTemperature(inletTemp)
dz.log('Inlet: ' .. inletTemp, dz.LOG_DEBUG)
if exhaustTemp == -999 then
dz.log('There was a problem getting a reading for exhaust', dz.LOG_ERROR)
dz.devices(269).updateTemperature(exhaustTemp)
dz.log('Exhaust: ' .. exhaustTemp, dz.LOG_DEBUG)
This part is not correct the updateTemperature method only returns a table with the values you just entered
What do you want to check ?
if (dz.devices(268).updateTemperature(inletTemp) == 0.0 ) then
dz.log('There was a problem getting an 0.0 reading for Inlet', dz.LOG_ERROR)
dz.log('There was a problem handling the request', dz.LOG_ERROR)
dz.log(item, dz.LOG_ERROR)
- Ragdag
That part in the if statement was the same thing you are doing with the -999 but mine is completely wrongwaaren wrote: Wednesday 06 May 2020 17:25Can you try this one?Ragdag wrote: Wednesday 06 May 2020 11:47 Unfortunately after a restart of the server the Temperatures array in the json has a different order.
local scriptVar = 'iDRAC_Temp' return { on = { timer = { 'every 5 minutes', -- just an example to trigger the request }, httpResponses = { scriptVar, -- must match with the callback passed to the openURL command }, }, logging = { level = domoticz.LOG_DEBUG, marker = scriptVar, }, execute = function(dz, item) if item.isTimer then dz.openURL({ url = 'https://root:[email protected]/redfish/v1/Chassis/System.Embedded.1/Thermal', method = 'GET', callback = scriptVar, -- see httpResponses above. }) return end if item.isJSON then local inletTemp = -999 local exhaustTemp = -999 subTable = item.json.Temperatures for index, record in ipairs(subTable) do if record.Name:find('Inlet Temp') then inletTemp = record.ReadingCelsius elseif record.Name:find('Exhaust Temp') then exhaustTemp = record.ReadingCelsius end end if inletTemp == -999 then dz.log('There was a problem getting a reading for Inlet', dz.LOG_ERROR) else dz.devices(268).updateTemperature(inletTemp) dz.log('Inlet: ' .. inletTemp, dz.LOG_DEBUG) end if exhaustTemp == -999 then dz.log('There was a problem getting a reading for exhaust', dz.LOG_ERROR) else dz.devices(269).updateTemperature(exhaustTemp) dz.log('Exhaust: ' .. exhaustTemp, dz.LOG_DEBUG) end --[[ This part is not correct the updateTemperature method only returns a table with the values you just entered What do you want to check ? if (dz.devices(268).updateTemperature(inletTemp) == 0.0 ) then dz.log('There was a problem getting an 0.0 reading for Inlet', dz.LOG_ERROR) ]] else dz.log('There was a problem handling the request', dz.LOG_ERROR) dz.log(item, dz.LOG_ERROR) end end }
It looks like success.
2020-05-06 12:54:10.710 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/DZ_iDRAC_Temp.lua
2020-05-06 18:18:00.122 Status: dzVents: Info: iDRAC_Temp: ------ Start internal script: DZ_Test:, trigger: "every 1 minutes"
2020-05-06 18:18:00.122 Status: dzVents: Debug: iDRAC_Temp: OpenURL: url = https://root:[email protected]/redfish/v1/Chassis/System.Embedded.1/Thermal
2020-05-06 18:18:00.122 Status: dzVents: Debug: iDRAC_Temp: OpenURL: method = GET
2020-05-06 18:18:00.122 Status: dzVents: Debug: iDRAC_Temp: OpenURL: post data = nil
2020-05-06 18:18:00.122 Status: dzVents: Debug: iDRAC_Temp: OpenURL: headers = nil
2020-05-06 18:18:00.122 Status: dzVents: Debug: iDRAC_Temp: OpenURL: callback = iDRAC_Temp
2020-05-06 18:18:00.122 Status: dzVents: Info: iDRAC_Temp: ------ Finished DZ_Test
2020-05-06 18:18:05.344 Status: dzVents: Info: iDRAC_Temp: ------ Start internal script: DZ_Test: HTTPResponse: "iDRAC_Temp"
2020-05-06 18:18:05.379 Status: dzVents: Debug: iDRAC_Temp: Processing device-adapter for Server Inlet Temp: Temperature device adapter
2020-05-06 18:18:05.380 Status: dzVents: Debug: iDRAC_Temp: Inlet: 22
2020-05-06 18:18:05.381 Status: dzVents: Debug: iDRAC_Temp: Processing device-adapter for Server Exhaust Temp: Temperature device adapter
2020-05-06 18:18:05.381 Status: dzVents: Debug: iDRAC_Temp: Exhaust: 34
2020-05-06 18:18:05.381 Status: dzVents: Info: iDRAC_Temp: ------ Finished DZ_Test
You're taking the Temperature section of the JSON and putting that in a table and then go through the records to find the correct one and take the Celsius reading of that record find.
- waaren
Allmost: item.json is already a table.Ragdag wrote: Wednesday 06 May 2020 18:21 I think I understand how you did it.
Even before your script starts item.data is analyzed in domoticz/dzVents/Utils/HTTPResonse.lua and if it is recognized as a JSON string it is loaded into a Lua table and passed as item.json
Your script perform the actions you describe on the subtable Temperatures
