Read Dell iDRAC values through Redfish Topic is solved
Ragdag
Post by Ragdag »
I'm trying to figure out how to populate sensors in Domoticz with values from my Dell iDRAC server.
With Redfish I can get temperature and power consumption that I would like to collect in Domoticz but I have no idea how to build this.
Anybody can help me to get started?
The ones I want to capture are:
  • Inlet Temperature
  • Exhaust Temperature
  • CPU Temperature
  • Power Consumption
The following URLs will give me a JSON payload back, with the required data. Not sure what is easier, one URL that will only give back one sensor or one URL that will give back all.
For instance https://192.168.2.202/redfish/v1/Chassi ... dInletTemp
Will give:
    "@odata.context": "/redfish/v1/$metadata#Thermal.Thermal",
    "@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Sensors/Temperatures/iDRAC.Embedded.1%23SystemBoardInletTemp",
    "@odata.type": "#Thermal.v1_4_0.Temperature",
    "LowerThresholdCritical": -7,
    "LowerThresholdFatal": -7,
    "LowerThresholdNonCritical": 3,
    "MaxReadingRangeTemp": 47,
    "MemberId": "iDRAC.Embedded.1#SystemBoardInletTemp",
    "MinReadingRangeTemp": -7,
    "Name": "System Board Inlet Temp",
    "PhysicalContext": "SystemBoard",
    "ReadingCelsius": 20,
    "RelatedItem": [
            "@odata.id": "/redfish/v1/Chassis/System.Embedded.1"
    "[email protected]": 1,
    "SensorNumber": 4,
    "Status": {
        "Health": "OK",
        "State": "Enabled"
    "UpperThresholdCritical": 47,
    "UpperThresholdFatal": 47,
    "UpperThresholdNonCritical": 42
While https://192.168.2.202/redfish/v1/Chassi ... .1/Thermal will give
    "@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Thermal",
    "@odata.type": "#Thermal.v1_4_0.Thermal",
    "Description": "Represents the properties for Temperature and Cooling",
    "Fans": [
            "@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Sensors/Fans/0x17%7C%7CFan.Embedded.1",
            "@odata.type": "#Thermal.v1_4_0.Fan",
            "Assembly": {
                "@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Assembly"
            "FanName": "System Board Fan1 RPM",
            "LowerThresholdCritical": 360,
            "LowerThresholdFatal": 360,
            "LowerThresholdNonCritical": 600,
            "MaxReadingRange": null,
            "MemberId": "0x17||Fan.Embedded.1",
            "MinReadingRange": 360,
            "Name": "System Board Fan1 RPM",
            "Reading": 5880,
            "ReadingUnits": "RPM",
            "Redundancy": [],
            "[email protected]": 0,
            "RelatedItem": [
            "Status": {
                "Health": "OK",
                "State": "Enabled"
            "UpperThresholdCritical": null,
            "UpperThresholdFatal": null,
            "UpperThresholdNonCritical": null
            "@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Sensors/Fans/0x17%7C%7CFan.Embedded.4",
            "Assembly": {
            "FanName": "System Board Fan4 RPM",
            "MemberId": "0x17||Fan.Embedded.4",
            "Name": "System Board Fan4 RPM",
            "Reading": 5640,
            "Redundancy": [],
            "RelatedItem": [
            "Status": {
                "Health": "OK",
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Sensors/Fans/0x17%7C%7CFan.Embedded.2",
            "Assembly": {
            "FanName": "System Board Fan2 RPM",
            "MemberId": "0x17||Fan.Embedded.2",
            "Name": "System Board Fan2 RPM",
            "Reading": 5880,
            "Redundancy": [],
            "RelatedItem": [
            "Status": {
                "Health": "OK",
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Sensors/Fans/0x17%7C%7CFan.Embedded.3",
            "Assembly": {
            "FanName": "System Board Fan3 RPM",
            "MemberId": "0x17||Fan.Embedded.3",
            "Name": "System Board Fan3 RPM",
            "Reading": 5760,
            "Redundancy": [],
            "RelatedItem": [
            "Status": {
                "Health": "OK",
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Sensors/Fans/0x17%7C%7CFan.Embedded.6",
            "Assembly": {
            "FanName": "System Board Fan6 RPM",
            "MemberId": "0x17||Fan.Embedded.6",
            "Name": "System Board Fan6 RPM",
            "Reading": 6000,
            "Redundancy": [],
            "RelatedItem": [
            "Status": {
                "Health": "OK",
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Sensors/Fans/0x17%7C%7CFan.Embedded.5",
            "Assembly": {
            "FanName": "System Board Fan5 RPM",
            "MemberId": "0x17||Fan.Embedded.5",
            "Name": "System Board Fan5 RPM",
            "Reading": 5760,
            "Redundancy": [],
            "RelatedItem": [
            "Status": {
                "Health": "OK",
                "State": "Enabled"
    "[email protected]": 6,
    "Id": "Thermal",
    "Name": "Thermal",
    "Redundancy": [
            "@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Thermal/Redundancy/iDRAC.Embedded.1%23SystemBoardFanRedundancy",
            "@odata.type": "#Redundancy.v1_3_0.Redundancy",
            "MaxNumSupported": null,
            "MemberId": "iDRAC.Embedded.1#SystemBoardFanRedundancy",
            "MinNumNeeded": null,
            "Mode": "N+m",
            "Name": "System Board Fan Redundancy",
            "RedundancyEnabled": true,
            "RedundancySet": [],
            "Status": {
                "Health": "OK",
                "State": "Enabled"
    "Temperatures": [
            "RelatedItem": [
            "SensorNumber": 4,
            "Status": {
                "Health": "OK",
                "State": "Enabled"
            "@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Sensors/Temperatures/iDRAC.Embedded.1%23SystemBoardExhaustTemp",
            "LowerThresholdCritical": 0,
            "LowerThresholdFatal": 0,
            "LowerThresholdNonCritical": 0,
            "MaxReadingRangeTemp": 75,
            "MemberId": "iDRAC.Embedded.1#SystemBoardExhaustTemp",
            "MinReadingRangeTemp": 0,
            "Name": "System Board Exhaust Temp",
            "ReadingCelsius": 38,
            "RelatedItem": [
            "SensorNumber": 1,
            "Status": {
                "Health": "OK",
                "State": "Enabled"
            "UpperThresholdCritical": 75,
            "UpperThresholdFatal": 75,
            "UpperThresholdNonCritical": 70
            "@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Sensors/Temperatures/iDRAC.Embedded.1%23CPU1Temp",
            "LowerThresholdCritical": 3,
            "LowerThresholdFatal": 3,
            "LowerThresholdNonCritical": 8,
            "MaxReadingRangeTemp": 87,
            "MemberId": "iDRAC.Embedded.1#CPU1Temp",
            "MinReadingRangeTemp": 3,
            "Name": "CPU1 Temp",
            "PhysicalContext": "CPU",
            "ReadingCelsius": 67,
            "RelatedItem": [
                    "@odata.id": "/redfish/v1/Systems/System.Embedded.1/Processors/CPU.Socket.1"
            "SensorNumber": 14,
            "Status": {
                "Health": "OK",
                "State": "Enabled"
            "UpperThresholdCritical": 87,
            "UpperThresholdFatal": 87,
            "UpperThresholdNonCritical": 82
    "[email protected]": 3
For Power the URL https://192.168.2.202/redfish/v1/Chassi ... ed.1/Power is available.
    "@odata.context": "/redfish/v1/$metadata#Power.Power",
    "@odata.id": "/redfish/v1/Chassis/System.Embedded.1/Power/PowerControl",
    "@odata.type": "#Power.v1_4_0.PowerControl",
    "MemberId": "PowerControl",
    "Name": "System Power Control",
    "PowerAllocatedWatts": 896,
    "PowerAvailableWatts": 0,
    "PowerCapacityWatts": 896,
    "PowerConsumedWatts": 220,
    "PowerLimit": {
        "CorrectionInMs": 0,
        "LimitException": "HardPowerOff",
        "LimitInWatts": 398
    "PowerMetrics": {
        "AverageConsumedWatts": 0,
        "IntervalInMin": 1,
        "MaxConsumedWatts": 0,
        "MinConsumedWatts": 0
    "PowerRequestedWatts": 398,
    "RelatedItem": [
            "@odata.id": "/redfish/v1/Systems/System.Embedded.1"
    "[email protected]": 2
Re: Read Dell iDRAC values through Redfish
Ragdag wrote: Saturday 11 April 2020 11:15 I'm trying to figure out how to populate sensors in Domoticz with values from my Dell iDRAC server.
If you search this forum with
dzVents json sensor
in the search field you will find a lot of examples on how to do this. Just start with coding and if you get stuck somewhere while doing that I am happy to explain.
If you are going to use dzVents, you could best use one json to retrieve all data in one pass.
When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
Ragdag
Post by Ragdag »
Thanks, will do.
Ragdag
Post by Ragdag »
waaren wrote: Saturday 11 April 2020 12:32
dzVents json sensor
I'm starting from the template HTTPrequest
How do I determine httpResponses should be?
httpResponses = {
			'trigger' -- must match with the callback passed to the openURL command
Is that one of the headers from the request?
Ragdag wrote: Saturday 11 April 2020 14:20 I'm starting from the template HTTPrequest
httpResponses = {
trigger is a string you can choose freely as long it is the same as what you use as callBack in the openURL call.
Ragdag
Post by Ragdag »
waaren wrote: Saturday 11 April 2020 14:22
httpResponses = {
Thanks.
The other question what is the correct JSON ID for instance for the inlet Temp.
I thought it was local inletTemp = iDRAC.Embedded.1#SystemBoardInletTemp but that gives an error
I believe I'm almost there
Have the following but and the sensor I created is getting updated each minute but I'm not yet able to capture the temperature.
		timer = {
			'every 1 minutes' -- just an example to trigger the request
		httpResponses = {
		if (item.isTimer) then
			domoticz.openURL({
				url = 'https://root:[email protected]/redfish/v1/Chassis/System.Embedded.1/Thermal',
				method = 'GET',
				callback = 'trigger', -- see httpResponses above.
		if (item.isHTTPResponse) then
			if (item.ok) then
				if (item.isJSON) then
					local inletTemp = item.json.ReadingCelsius  -- just an example
					-- update some device in Domoticz
					domoticz.devices('Server Inlet Temp').updateTemperature(inletTemp)
				domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
				domoticz.log(item, domoticz.LOG_ERROR)
Ragdag wrote: Saturday 11 April 2020 14:30 The other question what is the correct JSON ID for instance for the inlet Temp.
What do you have sofar and what do you see in the log ?
Ragdag
Post by Ragdag »
waaren wrote: Saturday 11 April 2020 14:51
Let me aggregate all info
Current code
		timer = {
		httpResponses = {
			domoticz.openURL({
				method = 'GET',
			if (item.ok) then
In the log
2020-04-11 14:52:08.904 Status: dzVents: Info: Handling httpResponse-events for: "trigger"
2020-04-11 14:52:08.904 Status: dzVents: Info: ------ Start internal script: iDRAC Temp: HTTPResponse: "trigger"
2020-04-11 14:52:08.934 Status: dzVents: Info: ------ Finished iDRAC Temp
2020-04-11 14:52:08.935 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
I see that the sensor I created is being updated.
Ragdag wrote: Saturday 11 April 2020 14:54 I see that the sensor I created is being updated.
Sounds like good progress !
if you add
domoticz.utils.dumpTable(item.json)
as line 24
(just above
) You will see the complete table and it makes it easier to pick the right values from the json return.
Ragdag
Post by Ragdag »
I have the complete table already with Postman but I can't figure out the correct syntax to pick the inlet temp.
The complete table from Postman is.
    "Fans": [
            "Assembly": {
            "Reading": 4920,
            "Redundancy": [],
            "RelatedItem": [
            "Status": {
                "Health": "OK",
                "State": "Enabled"
            "Assembly": {
            "Reading": 4800,
            "Redundancy": [],
            "RelatedItem": [
            "Status": {
                "Health": "OK",
                "State": "Enabled"
            "Assembly": {
            "Reading": 4920,
            "Redundancy": [],
            "RelatedItem": [
            "Status": {
                "Health": "OK",
                "State": "Enabled"
            "Assembly": {
            "Reading": 4920,
            "Redundancy": [],
            "RelatedItem": [
            "Status": {
                "Health": "OK",
                "State": "Enabled"
            "Assembly": {
            "Reading": 5040,
            "Redundancy": [],
            "RelatedItem": [
            "Status": {
                "Health": "OK",
                "State": "Enabled"
            "Assembly": {
            "Reading": 4920,
            "Redundancy": [],
            "RelatedItem": [
            "Status": {
                "Health": "OK",
                "State": "Enabled"
    "Id": "Thermal",
    "Name": "Thermal",
    "Redundancy": [
            "Mode": "N+m",
            "Status": {
                "Health": "OK",
                "State": "Enabled"
    "Temperatures": [
            "ReadingCelsius": 22,
            "RelatedItem": [
            "SensorNumber": 4,
            "Status": {
                "Health": "OK",
                "State": "Enabled"
            "ReadingCelsius": 37,
            "RelatedItem": [
            "SensorNumber": 1,
            "Status": {
                "Health": "OK",
                "State": "Enabled"
            "ReadingCelsius": 58,
            "RelatedItem": [
            "SensorNumber": 14,
            "Status": {
                "Health": "OK",
                "State": "Enabled"
The output from your addition
2020-04-11 15:24:00.282 Status: dzVents: Info: ------ Start internal script: iDRAC Temp:, trigger: "every 1 minutes"
2020-04-11 15:24:00.283 Status: dzVents: Info: ------ Finished iDRAC Temp
2020-04-11 15:24:00.283 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-04-11 15:24:04.643 (Z-wave) General/kWh (kWh Keuken)
2020-04-11 15:24:04.766 (Z-wave) Usage (Unknown)
2020-04-11 15:24:04.775 (Z-wave) General/kWh (kWh Keuken)
2020-04-11 15:24:04.787 (Power-Gas) P1 Smart Meter (Power)
2020-04-11 15:24:06.972 (Z-wave) General/kWh (kWh Keuken)
2020-04-11 15:24:07.095 (Z-wave) Usage (Unknown)
2020-04-11 15:24:07.104 (Z-wave) General/kWh (kWh Keuken)
2020-04-11 15:24:08.841 Status: dzVents: > Status:
2020-04-11 15:24:08.841 Status: dzVents: > State: Enabled
2020-04-11 15:24:08.841 Status: dzVents: > Health: OK
2020-04-11 15:24:08.841 Status: dzVents: > RelatedItem:
2020-04-11 15:24:08.841 Status: dzVents: > 1:
2020-04-11 15:24:08.841 Status: dzVents: > @odata.id: /redfish/v1/Chassis/System.Embedded.1
2020-04-11 15:24:08.841 Status: dzVents: > MemberId: 0x17||Fan.Embedded.5
2020-04-11 15:24:08.841 Status: dzVents: > LowerThresholdNonCritical: 600
2020-04-11 15:24:08.841 Status: dzVents: > @odata.id: /redfish/v1/Chassis/System.Embedded.1/Thermal
2020-04-11 15:24:08.841 Status: dzVents: > Redundancy:
2020-04-11 15:24:08.841 Status: dzVents: > Name: System Board Fan Redundancy
2020-04-11 15:24:08.841 Status: dzVents: > @odata.type: #Redundancy.v1_3_0.Redundancy
2020-04-11 15:24:08.841 Status: dzVents: > [email protected]: 0
2020-04-11 15:24:08.841 Status: dzVents: > RedundancyEnabled: true
2020-04-11 15:24:08.842 Status: dzVents: > Status:
2020-04-11 15:24:08.842 Status: dzVents: > State: Enabled
2020-04-11 15:24:08.842 Status: dzVents: > Health: OK
2020-04-11 15:24:08.842 Status: dzVents: > Mode: N+m
2020-04-11 15:24:08.842 Status: dzVents: > RedundancySet:
2020-04-11 15:24:08.842 Status: dzVents: > MemberId: iDRAC.Embedded.1#SystemBoardFanRedundancy
2020-04-11 15:24:08.842 Status: dzVents: > @odata.id: /redfish/v1/Chassis/System.Embedded.1/Thermal/Redundancy/iDRAC.Embedded.1%23SystemBoardFanRedundancy
2020-04-11 15:24:08.842 Status: dzVents: > [email protected]: 1
2020-04-11 15:24:08.842 Status: dzVents: > Temperatures:
2020-04-11 15:24:08.842 Status: dzVents: > 1:
2020-04-11 15:24:08.842 Status: dzVents: > Name: System Board Inlet Temp
2020-04-11 15:24:08.842 Status: dzVents: > LowerThresholdFatal: -7
2020-04-11 15:24:08.842 Status: dzVents: > UpperThresholdNonCritical: 42
2020-04-11 15:24:08.842 Status: dzVents: > PhysicalContext: SystemBoard
2020-04-11 15:24:08.842 Status: dzVents: > @odata.id: /redfish/v1/Chassis/System.Embedded.1/Sensors/Temperatures/iDRAC.Embedded.1%23SystemBoardInletTemp
2020-04-11 15:24:08.842 Status: dzVents: > MaxReadingRangeTemp: 47
2020-04-11 15:24:08.842 Status: dzVents: > MinReadingRangeTemp: -7
2020-04-11 15:24:08.842 Status: dzVents: > ReadingCelsius: 23
2020-04-11 15:24:08.842 Status: dzVents: > UpperThresholdFatal: 47
2020-04-11 15:24:08.842 Status: dzVents: > @odata.context: /redfish/v1/$metadata#Thermal.Thermal
2020-04-11 15:24:08.842 Status: dzVents: > RelatedItem:
2020-04-11 15:24:08.842 Status: dzVents: > LowerThresholdNonCritical: 3
2020-04-11 15:24:08.842 Status: dzVents: > LowerThresholdCritical: -7
2020-04-11 15:24:08.842 Status: dzVents: > @odata.type: #Thermal.v1_4_0.Temperature
2020-04-11 15:24:08.842 Status: dzVents: > MemberId: iDRAC.Embedded.1#SystemBoardInletTemp
2020-04-11 15:24:08.842 Status: dzVents: > SensorNumber: 4
2020-04-11 15:24:08.842 Status: dzVents: > UpperThresholdCritical: 47
2020-04-11 15:24:08.842 Status: dzVents: > 2:
2020-04-11 15:24:08.842 Status: dzVents: > Name: System Board Exhaust Temp
2020-04-11 15:24:08.842 Status: dzVents: > LowerThresholdFatal: 0
2020-04-11 15:24:08.842 Status: dzVents: > UpperThresholdNonCritical: 70
2020-04-11 15:24:08.842 Status: dzVents: > @odata.id: /redfish/v1/Chassis/System.Embedded.1/Sensors/Temperatures/iDRAC.Embedded.1%23SystemBoardExhaustTemp
2020-04-11 15:24:08.842 Status: dzVents: > MaxReadingRangeTemp: 75
2020-04-11 15:24:08.842 Status: dzVents: > MinReadingRangeTemp: 0
2020-04-11 15:24:08.842 Status: dzVents: > ReadingCelsius: 36
2020-04-11 15:24:08.842 Status: dzVents: > UpperThresholdFatal: 75
2020-04-11 15:24:08.843 Status: dzVents: > @odata.context: /redfish/v1/$metadata#Thermal.Thermal
2020-04-11 15:24:08.843 Status: dzVents: > RelatedItem:
2020-04-11 15:24:08.843 Status: dzVents: > 1:
2020-04-11 15:24:08.843 Status: dzVents: > @odata.id: /redfish/v1/Chassis/System.Embedded.1
2020-04-11 15:24:08.843 Status: dzVents: > Status:
2020-04-11 15:24:08.843 Status: dzVents: > State: Enabled
2020-04-11 15:24:08.843 Status: dzVents: > Health: OK
2020-04-11 15:24:08.843 Status: dzVents: > LowerThresholdNonCritical: 0
2020-04-11 15:24:08.843 Status: dzVents: > LowerThresholdCritical: 0
2020-04-11 15:24:08.843 Status: dzVents: > @odata.type: #Thermal.v1_4_0.Temperature
2020-04-11 15:24:08.843 Status: dzVents: > MemberId: iDRAC.Embedded.1#SystemBoardExhaustTemp
2020-04-11 15:24:08.843 Status: dzVents: > SensorNumber: 1
2020-04-11 15:24:08.843 Status: dzVents: > UpperThresholdCritical: 75
2020-04-11 15:24:08.843 Status: dzVents: > 3:
2020-04-11 15:24:08.843 Status: dzVents: > [email protected]: 1
2020-04-11 15:24:08.843 Status: dzVents: > Name: CPU1 Temp
2020-04-11 15:24:08.843 Status: dzVents: > LowerThresholdFatal: 3
2020-04-11 15:24:08.843 Status: dzVents: > UpperThresholdNonCritical: 82
2020-04-11 15:24:08.843 Status: dzVents: > PhysicalContext: CPU
2020-04-11 15:24:08.843 Status: dzVents: > @odata.id: /redfish/v1/Chassis/System.Embedded.1/Sensors/Temperatures/iDRAC.Embedded.1%23CPU1Temp
2020-04-11 15:24:08.843 Status: dzVents: > MaxReadingRangeTemp: 87
2020-04-11 15:24:08.843 Status: dzVents: > MinReadingRangeTemp: 3
2020-04-11 15:24:08.843 Status: dzVents: > ReadingCelsius: 59
2020-04-11 15:24:08.843 Status: dzVents: > UpperThresholdFatal: 87
2020-04-11 15:24:08.843 Status: dzVents: > @odata.id: /redfish/v1/Systems/System.Embedded.1/Processors/CPU.Socket.1
2020-04-11 15:24:08.843 Status: dzVents: > LowerThresholdNonCritical: 8
2020-04-11 15:24:08.843 Status: dzVents: > LowerThresholdCritical: 3
2020-04-11 15:24:08.843 Status: dzVents: > MemberId: iDRAC.Embedded.1#CPU1Temp
2020-04-11 15:24:08.843 Status: dzVents: > SensorNumber: 14
2020-04-11 15:24:08.843 Status: dzVents: > UpperThresholdCritical: 87
2020-04-11 15:24:08.843 Status: dzVents: > Id: Thermal
2020-04-11 15:24:08.843 Status: dzVents: > Description: Represents the properties for Temperature and Cooling
2020-04-11 15:24:08.858 Status: dzVents: Info: ------ Finished iDRAC Temp
2020-04-11 15:24:08.858 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
Ragdag
Post by Ragdag »
If I use the URL /redfish/v1/Chassis/System.Embedded.1/Sensors/Temperatures/iDRAC.Embedded.1%23SystemBoardInletTemp to get the JSON payload I get it working actually with this code.
		timer = {
		httpResponses = {
			domoticz.openURL({
				url = 'https://root:[email protected]/redfish/v1/Chassis/System.Embedded.1/Sensors/Temperatures/iDRAC.Embedded.1%23SystemBoardInletTemp',
				method = 'GET',
			if (item.ok) then
It is just when I call https://192.168.2.202/redfish/v1/Chassi ... mperatures and get all values at the same time that I don't know how to get the right one.
Thank you so far for your patience and help.
EDIT:
Also trying something like this does not work.
		timer = {
		httpResponses = {
			domoticz.openURL({
				method = 'GET',
			if (item.ok) then
					local inletTemp = item['json']['Temperatures']['iDRAC.Embedded.1%23SystemBoardInletTemp']['ReadingCelsius']  -- just an example
Ragdag
Post by Ragdag »
I think I have it :D
Should this be it?
		timer = {
		httpResponses = {
			domoticz.openURL({
				method = 'GET',
			if (item.ok) then
					local inletTemp = item.json.Temperatures[1].ReadingCelsius
					local ExhaustTemp = item.json.Temperatures[2].ReadingCelsius
					domoticz.devices('Server Exhaust Temp').updateTemperature(ExhaustTemp)
This give me and looks okay
Ragdag wrote: Saturday 11 April 2020 16:11 I think I have it :D
Looks good 👍
My experience is that once you see how the json translates into the Lua table structure it will make it easier to get the right fields.
Even more so if you look at the domoticz log in OS file. In the GUI it is all flat but on the OS level you also see the indention.
Ragdag
Post by Ragdag »
waaren wrote: Saturday 11 April 2020 16:46
Looks good 👍
Would it also be possible to add the second URL https://root:[email protected]/redfi ... werControl in the same script or would it be better to have them separate?
Ragdag wrote: Saturday 11 April 2020 16:55 Would it also be possible to add the second URL https://root:[email protected]/redfi ... werControl in the same script or would it be better to have them separate?
It's possible.
If the information to be processed is related I would put them in one script. Use different callbacks so you can identify in the script which one of the openURL's returns triggered the script.
Ragdag
Post by Ragdag »
waaren wrote: Saturday 11 April 2020 23:55
It's possible.
Would you have an example of that?
I'm reading through https://www.domoticz.com/wiki/DzVents:_ ... P_requests but that does not make it clear for me.
Ragdag wrote: Monday 13 April 2020 11:49 Would you have an example of that?
Example with different callbacks within HTTPResponse
return
    on =
        devices =
            'HTTPSwitch'  -- just to trigger the script
        httpResponses =
            'trigger_*', -- wildcard trigger
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'httpResponseTest',
    execute = function(dz, item)
        local function sendURL(json, trigger, delay)
            local url = dz.settings['Domoticz url'] .. '/json.htm?'  .. json
            dz.openURL(
                url = url,
                callback = trigger
            }).afterSec(delay or 0)
        if item.isHTTPResponse then
            dz.log('Script now triggered by ' .. item.callback,dz.LOG_DEBUG)
            dz.utils.dumpTable(item.json)
            sendURL('type=command&param=getversion','trigger_getVersion')
            sendURL('type=users','trigger_users',5 ) -- after 5 seconds
            sendURL('type=command&param=getlog','trigger_getlog',10 ) -- after 10 seconds
Ragdag
Post by Ragdag »
Thank you, I'll study it and try to work through it.
Again thank you for your patience and guidance!
Ragdag
Post by Ragdag »
I switched my sensor from Usage (Electric) to Electric (Usage+counter) because I also wanted to get an report in Domoticz.
To update that counter I changed the script to with the help of https://www.domoticz.com/wiki/DzVents:_ ... counter.29
		timer = {
		httpResponses = {
			'iDRACPower' -- must match with the callback passed to the openURL command
			domoticz.openURL({
				url = 'https://root:[email protected]/redfish/v1/Chassis/System.Embedded.1/Power/PowerControl',
				method = 'GET',
				callback = 'iDRACPower', -- see httpResponses above.
			if (item.ok) then
					local ServerPower = item.json.PowerConsumedWatts
					domoticz.devices(271).updateElectricity(ServerPower)
This works but it is only showing Power Usage and Energy Usage stays empty.
How do I get that calculated?
EDIT:
Think I figured it out With the help of this thread https://www.domoticz.com/forum/viewtopic.php?t=31396
Changed my script as follows:
		timer = {
		httpResponses = {
    logging =
        level = domoticz.LOG_DEBUG, -- for debugging
        --level = domoticz.LOG_INFO,
        marker = "Server Power Usage"
			domoticz.openURL({
				method = 'GET',
			if (item.ok) then
					local ServerPowerConsumedWatts = item.json.PowerConsumedWatts
					local ServerUsage = domoticz.devices(271)
					local ServerUsageTotal = ServerUsage.WhTotal + ServerPowerConsumedWatts / 60
					ServerUsage.updateElectricity(ServerPowerConsumedWatts, ServerUsageTotal)
                    domoticz.log ('WpPower = '  ..  ServerPowerConsumedWatts)
                    domoticz.log ('newTotal = '  ..  ServerUsageTotal)
I can now see that it is writing values, will see how it looks after an hour or so.
Ragdag
Post by Ragdag »
Unfortunately after a restart of the server the Temperatures array in the json has a different order.
So this code is now writing the wrong temps in the wrong sensors.
local scriptVar = 'iDRAC_Temp'
return
	on =
	    timer =
		    'every 5 minutes' -- just an example to trigger the request
	    httpResponses =
            scriptVar, -- must match with the callback passed to the openURL command
    logging =
        --level = domoticz.LOG_DEBUG,
        marker = scriptVar,
			domoticz.openURL({
				method = 'GET',
				callback = scriptVar, -- see httpResponses above.
			if (item.ok) then
					domoticz.log('Inlet: ' .. inletTemp, domoticz.LOG_DEBUG)
					domoticz.log('Exhaust: ' .. ExhaustTemp, domoticz.LOG_DEBUG)
                    if (domoticz.devices(268).updateTemperature(inletTemp) == 0.0 ) then
                        domoticz.log('There was a problem getting an 0.0 reading for Inlet', domoticz.LOG_ERROR)
                    if (domoticz.devices(269).updateTemperature(ExhaustTemp) == 0.0 ) then
                        domoticz.log('There was a problem getting an 0.0 reading for Exhaust', domoticz.LOG_ERROR)
Is there a way for me to loop through the array and pick a value if the name is correct?
This is the json part for the temps
    "Temperatures": [
            "ReadingCelsius": 36,
            "RelatedItem": [
            "SensorNumber": 1,
            "Status": {
                "Health": "OK",
                "State": "Enabled"
            "ReadingCelsius": 63,
            "RelatedItem": [
            "SensorNumber": 14,
            "Status": {
                "Health": "OK",
                "State": "Enabled"
            "ReadingCelsius": 19,
            "RelatedItem": [
            "SensorNumber": 4,
            "Status": {
                "Health": "OK",
                "State": "Enabled"
