Page 2 of 19
Re: Domoticz-Google-Assistant (dzga)
Posted: Monday 06 April 2020 7:37
by DewGew
Justintime wrote: Saturday 04 April 2020 11:51
DewGew wrote:Justintime wrote: Tuesday 31 March 2020 21:11
Still i get the message "there is an unknown fault" (in dutch) I know this is a language thing. Is this on the roadmap to solve?
Otherwise i know what to do in Domiticz to quiet this.
I dont get that message. When do you get it?
When I give a command "zet Eettafellamp aan" (turn on dining light)
Google is turning on the light. She gives confirmation but than she says there is an unknown error / fault.
I have solved this to put this text in domoticz switch.
<voicecontrol>
nicknames = Eettafellamp
report_state = False
</voicecontrol>
But i have to do with every switch. Except curtains.
Another question. When I say synchronize devices. Domoticz google home is calling it "my test app" where can is change the name?
what dzga version do you use? But i think you smart-home-key.json is not valid. Make sure its for correct project.
In Actions on Google you can change name to somthing like mycoolvoice under develop/Invocation. Then it will show [test]mycoolvoice in google home app
Posted: Monday 06 April 2020 9:27
by EdwinK
DewGew wrote: Monday 06 April 2020 7:35
EdwinK wrote: Saturday 04 April 2020 19:26
One day I will understand all this. I promise.
For domain name, can I use something like noip.com or should it be more as
www.mydomain.com?
You can use noip.com or similar with reverse proxy
okay, Going to pretend that I understand this
Posted: Tuesday 07 April 2020 16:55
by dizzyweb
I just can't even get this to run.... Installed it, trying to set a display name for invocation at the Actions Console and *everything* I try is restricted. My name contains a restricted word. sdhfgadsyufgafghadsgfdsl contains a restricted word. 12345 contains a restricted word. Every single combination of letters and numbers I enter contains a restricted word. Or it's a protected brand.
So seriously... how?!
Posted: Wednesday 08 April 2020 10:44
by ressof
I wonder if you can somehow pass to domoitcz the name or IP of the google home device that sent the order.
I would need this to my NodeRed implementation to speak when a certain thing happens in Domoticz.
Posted: Wednesday 08 April 2020 15:54
by DewGew
ressof wrote: Wednesday 08 April 2020 10:44
No I dont think I can. For that I think we need Local fulfillment. Thats not implemted in dzga.
Posted: Wednesday 08 April 2020 15:55
by DewGew
dizzyweb wrote: Tuesday 07 April 2020 16:55
Dont set any display name.
Posted: Thursday 09 April 2020 7:36
by ressof
DewGew wrote: Wednesday 08 April 2020 15:54
Ok. Thank you for your reply.
Posted: Friday 08 May 2020 9:11
by DewGew
It seems like Google have fixed the issues with language support for ack and pin. It works for me in swedish. Can anyone else confirm?
Posted: Monday 11 May 2020 15:12
by EddyG
Posted: Monday 11 May 2020 19:22
by JediMax
Thank you for your work.
I try to install dzga on my Ubuntu. It have to be installed only to /user/<username> directory. But dzga service not start.
Then I manually execute install scripts
bash /scripts/install.sh
bash /scripts/service-installer.sh
reload daemon
end start dzga servise
Posted: Tuesday 12 May 2020 13:25
by scrabble
Is there currently a way to read utility sensor values from a Google Assistant command, like "what's my current energy usage"?
Posted: Tuesday 12 May 2020 16:10
by Xavier82
since upgrade of DZGA and Domoticz-Google-Assistent I encounter the following problem:
raspberrypi:~ $ sudo systemctl status dzga
● dzga.service - Domoticz-Google-Assistant Service
Loaded: loaded (/etc/systemd/system/dzga.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2020-05-12 16:00:09 CEST; 1min 7s ago
Process: 12176 ExecStart=/home/pi/Domoticz-Google-Assistant/env/bin/python3 /home/pi/Domoticz-Google-Assistant/ (code=exited, status=1/FAILURE)
Main PID: 12176 (code=exited, status=1/FAILURE)
mei 12 16:00:09 raspberrypi systemd[1]: dzga.service: Service RestartSec=100ms expired, scheduling restart.
mei 12 16:00:09 raspberrypi systemd[1]: dzga.service: Scheduled restart job, restart counter is at 5.
mei 12 16:00:09 raspberrypi systemd[1]: Stopped Domoticz-Google-Assistant Service.
mei 12 16:00:09 raspberrypi systemd[1]: dzga.service: Start request repeated too quickly.
mei 12 16:00:09 raspberrypi systemd[1]: dzga.service: Failed with result 'exit-code'.
mei 12 16:00:09 raspberrypi systemd[1]: Failed to start Domoticz-Google-Assistant Service.
Can anyone please help me how to fix this?
Posted: Tuesday 12 May 2020 16:23
by Xavier82
Xavier82 wrote: Tuesday 12 May 2020 16:10
Sorry, fixed it by manually execute install scripts as described by JediMax
Posted: Monday 18 May 2020 20:29
by DewGew
scrabble wrote: Tuesday 12 May 2020 13:25
Would be useful but dont find any trait that matches that in google assistant. We have to wait if google wants to add this
Posted: Monday 18 May 2020 21:37
by FireWizard
As far as I'm aware, this is on Google's list (already for a longer time).
The sensor trait action.devices.types.Sensor is not officially available, as far as I know, but I found some info.
I found some documents at:
https://developers.google.com/assistant ... ome/guides
and
https://developers.google.com/assistant ... ome/traits
Currently only a Temperature Sensor is supported.
The queryOnlyTemperatureSetting is available on TemperatureSettings trait, so temperature sensor can be implemented as a thermostat with queryOnlyTemperatureSetting attribute. But that is, because thermostat is supported. @DewGew,
Again the thermostat.
But the function for us is in a very early state, as you can also see at:
https://www.reddit.com/r/GoogleAssistan ... ice_types/
Posted: Tuesday 19 May 2020 11:25
by JuanUil
Nice
Posted: Tuesday 19 May 2020 16:46
by DarkG
Is it a Problem that port 443 is in use with domoticz?
Posted: Tuesday 19 May 2020 17:36
by DewGew
DarkG wrote: Tuesday 19 May 2020 16:46
No not really, depends how you setup your servers. I recommend to setup a reverse proxy.
Posted: Sunday 07 June 2020 22:40
by DewGew
New master version out. Try it and give us feedback
Posted: Monday 08 June 2020 9:34
by SterkeJerke
Did a compleet fresh install on a new Ubuntu server.
All looking pretty OK, apart from the NGROK part.
As soon as I set the using of NGROK to true in the config file dzga fails to start.
Turned on debuging and loggin.
The only thing I see is:
2020-06-08 07:26:22 - INFO - Installing package pyngrok
2020-06-08 07:26:23 - INFO - Installing package pyngrok
2020-06-08 07:26:24 - INFO - Installing package pyngrok
2020-06-08 07:26:25 - INFO - Installing package pyngrok
2020-06-08 07:30:26 - INFO - Installing package pyngrok
2020-06-08 07:30:27 - INFO - Installing package pyngrok
2020-06-08 07:30:28 - INFO - Installing package pyngrok
2020-06-08 07:30:29 - INFO - Installing package pyngrok
Looks like something missing in the install? how to install this package?
