In Kodi enable setting "Allow programs on other systems to control Kodi". (Setting > Services > Remote Control)Brutus wrote: Are there some settings to be made in Kodi?
Then it would work i hope.
Do you have any firewalls enabled ? Running kodi on windows too?Brutus wrote:Thanks for your reply. I have those options enabled already.
Still nothing hapens when you hit the test button.
The webserver has nothing to do with it? because that is usename and password protected.
You can not enter those in domoticz.
Did some checking on the internet, should the multicast address be 224.0.0.0 ? (i tried but it did not work) I also tried 192.168.1.0, 192.168.1.255 and 192.168.1.* those did not workpvm wrote:Nice improvement on Domoticz. I did a quick test with the default settings. It did not work. So i changed the ip to one of my 2 Kodi installs and it works fine, nice!
I do not know how to configure it back to multicast... i do not remember the default setting. How should it be configured? My machines are 192.168.1.4 and 192.168.1.5, i would like to reach them both
I had the same problem so I made a clean domoticz installation on another computer and looked for the default settings: IP adres: 224.0.0.1, port: 9777.pvm wrote:Did some checking on the internet, should the multicast address be 224.0.0.0 ? (i tried but it did not work) I also tried 192.168.1.0, 192.168.1.255 and 192.168.1.* those did not workpvm wrote:Nice improvement on Domoticz. I did a quick test with the default settings. It did not work. So i changed the ip to one of my 2 Kodi installs and it works fine, nice!
EventServer is the part of Kodi that accepts remote device input on all platforms.
Thanks for your reply. I think your are maybe right. To answer your questions:Dnpwwo wrote:I'm interested to know if anyone has it working on Windows (multicast or specific IP)? this may be a broader issue.
I don't have Domoticz or Kodi on Windows but can suggest some areas to investigate:From the documentation (http://kodi.wiki/view/EventServer) it should work on Windows:
- On the Kodi machine perform a 'netstat -a' and confirm that Kodi is listening on port 9777
- Turn off windows firewall on source and destination machines and retest
- If possible cable the machines together directly to make sure any switches/firewalls aren't dropping traffic
Dnpwwo wrote:Native Kodi notifications have been added to the Beta version from build 2448 onwards, tested against Kodi Helix.
By default it will multi-cast to all Kodi's on the local network (or you can target one specifically). Just enable it under Settings\Notifications and hit 'Test'. If you have a complicated network you may need to bump the number of 'Hops' so that the notification will go further.
I also used the localhost IP yesterday. That didn't work also.Dnpwwo wrote:Okay so it looks like Kodi is listening which is a good, even better I think I may have worked this out.
The current code doesn't loop multicast back to the local host, I'll add that to the next version.
In the mean time, try using 127.0.0.1 as the IP Address rather that the machine's external IP. Can't hurt...
Thank you. When the a new Windows Domoticz Setup file is online I will test this.Dnpwwo wrote:I uploaded a new version that has a change to the multicast to force messages to loopback and be visible to the machine that sends them. That should help people who run Kodi and Domoitcz on the same server.
Also added some logic to push the correct device icon with the message. Custom icons will be in the next version.
It still will not work as I install Domoticz as a service...Dnpwwo wrote:I uploaded a new version that has a change to the multicast to force messages to loopback and be visible to the machine that sends them. That should help people who run Kodi and Domoitcz on the same server.
