XBMC notify
Raspberry Piet
XBMC notify
Post by Raspberry Piet »
Made this little script to use in my Domoticz scripts:
xbmc_notify.sh
#!/bin/sh
# Settings
title=$1
message=$2
image=$3
user="xbmc"
pw="password"
port="8080"
time=15000
# XBMC PC
(wget -O /dev/null "http://$user:[email protected]:$port/jsonrpc?request={%22jsonrpc%22:%222.0%22,%22method%22:%22GUI.ShowNotification%22,%22params%22:{%22title%22:%22$title%22,%22message%22:%22$message%22,%22image%22:%22$image%22,%22displaytime%22:$time},%22id%22:1}" >/dev/null 2>&1) &
# XBMC Projector
# XBMC TV
Change settings and IP addresses
Invoke this script like:
xbmc_notify.sh "Title" "Message" "http://URL-to-picture"
Example:
xbmc_notify.sh " - Brievenbus - " "Er is nieuwe post bezorgd" "http://c.fsdn.com/allura/p/domoticz/icon"
D'rMorris
XBMC notify
Post by D'rMorris »
Awesome! I'm busy with a script from XBMC to domoticz to set the playing / paused / stopped states of XBMC.
I know the X10 commander plug-in for XBMC can do that, but I found that the switch is not always triggered when I stop playback.
Also, I'm trying to keep everything in 1 language. Either bash or lua, preferably not mixed.
pvm
Domoticz version: 4.10538
Re: XBMC notify
Post by pvm »
Gave it a try, nice
roblom
Re: XBMC notify
Post by roblom »
Nice!
HoLeeShiet
XBMC notify
Post by HoLeeShiet »
Nice! I was already using this to get camera into Xbmc and it worked pretty good! http://homeawesomation.wordpress.com/20 ... mc-update/
I tried to figure out how to combine the scripts but didn't succeed. But if someone could integrate with your script it would be very nice!
Using Tapatalk
Raspberry Piet
Re: XBMC notify
HoLeeShiet wrote:Nice! I was already using this to get camera into Xbmc and it worked pretty good! http://homeawesomation.wordpress.com/20 ... mc-update/
That would be nice indeed.
I remember i read a post on this forum a while ago:
http://www.domoticz.com/forum/viewtopic ... 21&t=1338&
Will have a look at it later.
Edit:
Installed this addon for xbmc:
http://forum.xbmc.org/showthread.php?tid=182540
Fill in the image url in the setting of this addon
eg
http://192.168.1.17:8080/camsnapshot.jpg?idx=1
^ (ipcam added to Domoticz)
Changed my xbmc_notify.sh a little:
#!/bin/sh
# Settings
snapshot=$1
title=$2
message=$3
image=$4
user="xbmc"
pw="password"
port="8080"
time=15000
# Check IP-Cam Status
if ping -c 1 192.168.1.24 > /dev/null ; then
	echo "IP-Cam Online"
	snapshot=0
fi
# XBMC PC
if ping -c 1 192.168.1.10 > /dev/null ; then
fi
# IPCAM SNAPSHOT to  XBMC PC
if [ $snapshot -eq 1 ] && ping -c 1 192.168.1.10 > /dev/null  ; then
(wget -O /dev/null "http://$user:[email protected]:8080/jsonrpc?request={%22jsonrpc%22:%222.0%22,%22method%22:%22Addons.ExecuteAddon%22,%22params%22:{%22addonid%22:%22script.securitycam%22},%22id%22:%221%22}}") &
fi
# XBMC Projector
if ping -c 1 192.168.1.12 > /dev/null ; then
fi
# IPCAM SNAPSHOT to  XBMC Projector
if [ $snapshot -eq 1 ] && ping -c 1 192.168.1.12 > /dev/null  ; then
fi
# XBMC TV
if ping -c 1 192.168.1.23 > /dev/null ; then
fi
# IPCAM SNAPSHOT to  XBMC TV
if [ $snapshot -eq 1 ] && ping -c 1 192.168.1.23 > /dev/null  ; then
fi
If you want to send a snapshot by this script:
xbmc_notify.sh "1" " - Brievenbus - " "Er is nieuwe post bezorgd" "http://c.fsdn.com/allura/p/domoticz/icon"
Else change 1 to something different like 0
xbmc_notify.sh "0" " - Brievenbus - " "Er is nieuwe post bezorgd" "http://c.fsdn.com/allura/p/domoticz/icon"
Heisenberg
Re: XBMC notify
Post by Heisenberg »
I want to try to integrated the security cam script with my Doorbell.sh but couldn't get the camera feed in XBMC (Gotham).
Telegram does work and send a snapshot to my phone correctly if doorbell is pushed.
Also in XBMC when I click the security cam add-on it shows the camera feed without problems.
So i think it must be in the code below but I can't figure it out. Maybe someone here can point me in the right direction?
#!/bin/sh
#Settings
today=$(date)
# XBMC Slaapkamer
(wget -O /dev/null "http://xbmc:[email protected]:8088/jsonrpc?request={%22jsonrpc%22:%222.0%22,%22method%22:%22GUI.ShowNotification%22,%22params%22:{%22title%22:%22$title%22,%22message$
# Check if ip-cam is up:
if ping -c 1 $IP > /dev/null
then
# Telegram sends msg if ping successful.
/home/pi/scripts/Telegram.sh msg Heisenberg "Er is aangebeld op $today!"
# Telegram takes snapshot if ping successful:
/usr/bin/curl -s http://admin:[email protected]:9922/Streaming/channels/1/picture > /tmp/snapshot.jpg
# Telegram sends snapshot to the following recipient(s):
/home/pi/scripts/Telegram.sh send_photo Heisenberg /tmp/snapshot.jpg
# Delete snapshot:
/bin/rm /tmp/*.jpg
/home/pi/scripts/Telegram.sh msg Heisenberg " Camera $IP is offline."
fi
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
Raspberry Piet
Re: XBMC notify
Heisenberg wrote:
#!/bin/sh
# XBMC Slaapkamer
Why don't invoke the xbmc_notify.sh script inside your own script?
#!/bin/sh
# XBMC Slaapkamer
/home/pi/domoticz/scripts/bash/xbmc_notify.sh "1" " - Deurbel - " "Er wordt aangebeld" "http://c.fsdn.com/allura/p/domoticz/icon"
Heisenberg
Re: XBMC notify
Thnx Raspberry Piet! I invoke the xbmc_notify.sh script inside my script and it works!
Another question is if it's possible to pause a movie when the xbmc_notify script is activated.
(e.g. If someone is at the door and the photo slides in, movie should pause, and when photo slides out XBMC resumes to play movie).
Raspberry Pi Type B
RFXCOMtrx433e
Raspberry Piet
Re: XBMC notify
Heisenberg wrote:Thnx Raspberry Piet! I invoke the xbmc_notify.sh script inside my script and it works!
You can add to your script:
#!/bin/sh
# XBMC Slaapkamer
curl -v -H "Accept: application/json" -H "Content-type: application/json" -X POST -d '{"id":1,"jsonrpc":"2.0","method":"Player.PlayPause","params":{"playerid":1}}' http://xbmc:[email protected]:8088/jsonrpc
Or you might want to choose the stop command instead of the play/pause toggle command:
curl -v -H "Accept: application/json" -H "Content-type: application/json" -X POST -d '{"id":1,"jsonrpc":"2.0","method":"Player.Stop","params":{"playerid":1}}' http://xbmc:[email protected]:8088/jsonrpc
Heisenberg
Re: XBMC notify
Great! It works!
Raspberry Pi Type B
RFXCOMtrx433e
Raspberry Piet
Re: XBMC notify
Changed my xbmc_notify script a little.
Works better for me. Does'nt lock things when invoking xbmc_notify via other scripts. (Tnx Heisenberg for testing)
xbmc_notify.sh
    #!/bin/sh
    snapshot=$1
    title=$2
    message=$3
    image=$4
    # Settings
    TIME="15000"    # Time the notification is displayed
    USER="xbmc"
    PW="xbmc"
    PORT="8080"
    XBMC1_IP="192.168.1.10"  #XBMC PC
    XBMC2_IP="192.168.1.12"  #XBMC Projector
    XBMC3_IP="192.168.1.23"  #XBMC TV
    CAM_IP="192.168.1.24"
    if ping -c 1 $CAM_IP > /dev/null ; then
       echo "IP-Cam ($CAM_IP) Online"
       echo "IP-Cam Offline"
       snapshot=0
    fi
    # Check XBMC1 Status
    nc -w 1 $XBMC1_IP $PORT
       if [ $? -eq 0 ] ; then
          echo "XBMC1 ($XBMC1_IP) Online"
          xbmc1=1
          echo "XBMC1 Offline"
          xbmc1=0
       fi
    # XBMC1
    if [ $xbmc1 -eq 1 ] && [ $snapshot -eq 0 ]; then
       (wget -O /dev/null "http://$USER:$PW@$XBMC1_IP:$PORT/jsonrpc?request={%22jsonrpc%22:%222.0%22,%22method%22:%22GUI.ShowNotification%22,%22params%22:{%22title%22:%22$title%22,%22message%22:%22$message%22,%22image%22:%22$image%22,%22displaytime%22:$TIME},%22id%22:1}" >/dev/null 2>&1) &
    elif [ $xbmc1 -eq 1 ] && [ $snapshot -eq 1 ]; then
    # IPCAM SNAPSHOT to  XBMC1
       (wget -O /dev/null "http://$USER:$PW@$XBMC1_IP:$PORT/jsonrpc?request={%22jsonrpc%22:%222.0%22,%22method%22:%22Addons.ExecuteAddon%22,%22params%22:{%22addonid%22:%22script.securitycam%22},%22id%22:%221%22}}")
    fi
    # Check XBMC2 Status
    nc -w 1 $XBMC2_IP $PORT
       echo "XBMC2 ($XBMC2_IP) Online"
       xbmc2=1
       echo "XBMC2 Offline"
       xbmc2=0
    fi
    # XBMC2
    if [ $xbmc2 -eq 1 ] && [ $snapshot -eq 0 ]; then
       (wget -O /dev/null "http://$USER:$PW@$XBMC2_IP:$PORT/jsonrpc?request={%22jsonrpc%22:%222.0%22,%22method%22:%22GUI.ShowNotification%22,%22params%22:{%22title%22:%22$title%22,%22message%22:%22$message%22,%22image%22:%22$image%22,%22displaytime%22:$TIME},%22id%22:1}" >/dev/null 2>&1) &
    elif [ $xbmc2 -eq 1 ] && [ $snapshot -eq 1 ]; then
    # IPCAM SNAPSHOT to  XBMC2
       (wget -O /dev/null "http://$USER:$PW@$XBMC2_IP:$PORT/jsonrpc?request={%22jsonrpc%22:%222.0%22,%22method%22:%22Addons.ExecuteAddon%22,%22params%22:{%22addonid%22:%22script.securitycam%22},%22id%22:%221%22}}")
    fi
    # Check XBMC3 Status
    nc -w 1 $XBMC3_IP $PORT
       echo "XBMC3 ($XBMC3_IP) Online"
       xbmc3=1
       echo "XBMC3 Offline"
       xbmc3=0
    fi
    # XBMC3
    if [ $xbmc3 -eq 1 ] && [ $snapshot -eq 0 ]; then
       (wget -O /dev/null "http://$USER:$PW@$XBMC3_IP:$PORT/jsonrpc?request={%22jsonrpc%22:%222.0%22,%22method%22:%22GUI.ShowNotification%22,%22params%22:{%22title%22:%22$title%22,%22message%22:%22$message%22,%22image%22:%22$image%22,%22displaytime%22:$TIME},%22id%22:1}" >/dev/null 2>&1) &
    elif [ $xbmc3 -eq 1 ] && [ $snapshot -eq 1 ]; then
    # IPCAM SNAPSHOT to  XBMC3
       (wget -O /dev/null "http://$USER:$PW@$XBMC3_IP:$PORT/jsonrpc?request={%22jsonrpc%22:%222.0%22,%22method%22:%22Addons.ExecuteAddon%22,%22params%22:{%22addonid%22:%22script.securitycam%22},%22id%22:%221%22}}")
    fi
Dnpwwo
Re: XBMC notify
Post by Dnpwwo »
Native Kodi notifications have been added to the Beta version from build 2448 onwards, tested against Kodi Helix.
By default it will multi-cast to all Kodi's on the local network (or you can target one specifically). Just enable it under Settings\Notifications and hit 'Test'. If you have a complicated network you may need to bump the number of 'Hops' so that the notification will go further.
jin
Re: XBMC notify
Post by jin »
Great great new feature! Just tested and works like a charm and out of the box via multicast!!!
Thank you very much Dnpwwo and Gizmocuz!
chimit
Domoticz version: master
Re: XBMC notify
Post by chimit »
I think one could even use the custom http notification settings for this.
Dnpwwo
Re: XBMC notify
Post by Dnpwwo »
Technical users probably could (not sure about updating multiple devices that way (I have 3))
This is actually the first step of making Domoticz Kodi aware, next step will be to push the icons of the device itself, then add it as a supported device to save people writing bash scripts for detecting if they are on and what they are doing etc.
Baby steps dude, I don't get much dev time.
Raspberry Piet
Re: XBMC notify
Thanks Dnpwwo for implement it in Domoticz!
Multicast works except for one of my (3) Kodi machines. (have to investigate the cause)
Awesomeness would be complete if Domoticz could trigger the Security CAM Overlay add-on natively. :geek:
Dnpwwo
Re: XBMC notify
Post by Dnpwwo »
Try bumping the 'Hops' count. Every time a multicast goes through a switch it decrements this counter (which is technically the TTL parameter) and drops the broadcast when it hits zero.
I needed to set Hops to '2' for one of my mine to work because it went through a switch and a hub.
Haven't decided on a target feature set because I'm still working through what is possible (I'm quite new to Kodi) . I can certainly see the value in streaming one or more images to one. Is there a way of doing it without installing an add-in?
Raspberry Piet
Re: XBMC notify
Dnpwwo wrote:Try bumping the 'Hops' count. Every time a multicast goes through a switch it decrements this counter (which is technically the TTL parameter) and drops the broadcast when it hits zero.
Tried that but no joy. Will investigate further later.
Dnpwwo wrote:Haven't decided on a target feature set because I'm still working through what is possible (I'm quite new to Kodi) . I can certainly see the value in streaming one or more images to one. Is there a way of doing it without installing an add-in?
Without installing an add-in i think that would not be possible. (at least not that i know of)
The security cam overlay add-on works very nice. (how to trigger see my script somewhere in this thread)
Brutus
Re: XBMC notify
Post by Brutus »
I saw this nice new feature been added to one of the latest releases.
So I updated my Windows Installation to version: V2.2456
When I leave the settings default and enable the Kodi Notification then enter different numbers and hit the test button nothing comes up.
When I enter the IP adres of my only Kodi server: 192.168.1.5 still nothing.
What can be wrong.
Are there some settings to be made in Kodi?
Thnx for any help.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
