Dashticz - v3.4.0 Beta
clinkadink
Re: Dashticz - v3.4.0 Beta
Post by clinkadink »
madradrakie wrote: Thursday 13 February 2020 20:20 on the third page, underneath the energy graph, only the values are shown from the P1 meter. Not from the solar panels anymore.
columns[9] = {}
columns[9]['blocks'] = ['energie_grafiek','76_1','76_2','76_5','413_1','413_2','413_3']
columns[9]['width'] = 9;
When you say values, do mean in the header of the graph, or the graph isn't showing? Can you post an image?
Lokonli
Post by Lokonli »
sieth wrote: Wednesday 12 February 2020 21:18 When using the beta 3.4.0 and defining the blocks as follows:
//Buiten Temperatuur
blocks['367_1'] = {
title: 'Buiten temperatuur',
image: 'temperatuur.png',
width: 6,
//Buiten vochtigheid
blocks['367_2'] = {
title: 'Buiten vochtigheid',
image: 'vochtigheid.png',
width: 6,
Only the first one shows. Not the second one.
Dit Is made a mistake?
Greetings and thanks in advance!
There was a bug in the initial update of subdevices, like 367_1 and 367_2.
Should be fixed in latest beta.
madradrakie
Post by madradrakie »
clinkadink wrote: Thursday 13 February 2020 20:45
columns[9] = {}
The first picture is from the frontpage, the second from the third page. Maybe i should define my blocks different?
madradrakie
after changing the blocks and an new git pull everything is working again.
sieth
Post by sieth »
Anyone facing this issue also?
Strange behaviour since latest update.
The wiped part is webcam. This image is also repeated 3 times
Greetings!
Lokonli
Post by Lokonli »
sieth wrote: Sunday 16 February 2020 6:16 Anyone facing this issue also?
Greetings!
When exactly did you download Dashticz?
Can you post your CONFIG.js?
BonZai
Post by BonZai »
Sunrise time is not correct since I installed v.3.4.0 beta. The sunrise time seems to use the sunset time.
Lokonli
Post by Lokonli »
BonZai wrote: Sunday 16 February 2020 15:15 Sunrise time is not correct since I installed v.3.4.0 beta. The sunrise time seems to use the sunset time.
This was fixed yesterday. You can update Dashticz with 'git pull' or download the latest version from Github.
BonZai
Post by BonZai »
Wow.. That's a fast response. Git pull indeed solved the sunrise/sunset time.
sieth
Post by sieth »
Lokonli wrote: Sunday 16 February 2020 8:31
Greetings!
I downloaded the latest update via "make update" 16/02/2020
This is my config.js
var config = {}
config['domoticz_ip'] = 'XXXXXX';
config['app_title'] = 'Domotica';
config['domoticz_refresh'] = '1';
config['dashticz_refresh'] = '300';
config['loginEnabled'] = 0;
//config['standby_after'] = 3000000;
config['auto_positioning'] = 0;
config['language'] = 'nl_NL';
config['speak_lang'] = 'nl_NL';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['wu_api'] = 'XXXXXX';
config['wu_city'] = 'XXXXXX';
config['wu_country'] = 'Belgium';
config['wu_name'] = '';
config['wu_country'] = 'BE';
config['settings_icons'] = ["fullscreen"];
config['no_rgb'] = 0;
config['slide_effect'] = 'fade';
config['last_update'] = 0;
var screens = {}
screens['default'] = {}
screens['default']['maxwidth'] = 1920;
screens['default']['maxheight'] = 1080;
screens['default'][1] = {}
screens['default'][1]['background'] = 'bg14.jpg';
screens['default'][1]['background_morning'] = 'bg14.jpg';
screens['default'][1]['background_noon'] = 'bg14.jpg';
screens['default'][1]['background_afternoon'] = 'bg14.jpg';
screens['default'][1]['background_night'] = 'bg14.jpg';
screens['default'][1]['columns'] = [1,2,3]
screens['4k'] = {}
screens['4k']['maxwidth'] = 3840;
screens['4k']['maxheight'] = 2160;
screens['4k'][1] = {}
screens['4k'][1]['background'] = 'bg14.jpg';
screens['4k'][1]['background_morning'] = 'bg14.jpg';
screens['4k'][1]['background_noon'] = 'bg14.jpg';
screens['4k'][1]['background_afternoon'] = 'bg14.jpg';
screens['4k'][1]['background_night'] = 'bg14.jpg';
screens['4k'][1]['columns'] = [1,2,3]
screens['Tablet'] = {}
screens['Tablet']['maxwidth'] = 1200;
screens['Tablet']['maxheight'] = 800;
screens['Tablet'][1] = {}
screens['Tablet'][1]['background'] = 'bg14.jpg';
screens['Tablet'][1]['background_morning'] = 'bg14.jpg';
screens['Tablet'][1]['background_noon'] = 'bg14.jpg';
screens['Tablet'][1]['background_afternoon'] = 'bg14.jpg';
screens['Tablet'][1]['background_night'] = 'bg14.jpg';
screens['Tablet'][1]['columns'] = [1,2,3]
//afvalophaling
config['garbage_company'] = 'ical';
config['garbage_icalurl'] = 'XXXXXX';
config['garbage_zipcode'] = 'XXXXXX';
config['garbage_street'] = 'XXXXXX';
config['garbage_housenumber'] = 'XXXXXX';
config['garbage_maxitems'] = '5';
config['garbage_use_names'] = true;
config['garbage_use_colors'] = true;
config['garbage_icon_use_colors'] = true;
config['garbage_use_cors_prefix'] = true;
config['garbage'] = {
gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
pmd: {kliko: 'blue', code: '#bef4f4', name: 'PMD', icon: 'img/garbage/pmd.png'},
rest: {kliko: 'yellow', code: '#f9e231', name: 'Restafval', icon: 'img/garbage/gelezak.png'},
papier: {kliko: 'brown', code: '#e6f7aa', name: 'Papier', icon: 'img/garbage/papier.png'},
kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
brown: {kliko: 'green', code: '#375b23', name: 'Glas', icon: 'img/garbage/glas.png'},
kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'},
test: {kliko: 'green', code: '#375b23', name: 'Glazen', icon: 'img/garbage/kliko_green.png'},
milieu: {kliko: 'yellow', code: '#f9e231', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'},
var buttons = {}
//Camera XXXXXX
buttons.webcam1 = {width:12, isimage:true, refresh:500, forcerefresh:2, btnimage: 'XXXXXX', url: 'XXXXXX', framewidth:500, frameheight:400}
//Blokken
var blocks = {}
//Living Dimmer
blocks[919] = {
width: 9,
imageOn: 'schakelaar_aan.png',
imageOff: 'schakelaar_uit.png',
last_update: false
//Staande Lamp
blocks[1132] = {
width: 12,
last_update: false
//TV uit
blocks[329] = {
width: 4,
title: 'TV uit',
imageOn: 'tv_aan.png',
imageOff: 'tv_uit.png',
switch: false,
last_update: false
//Telenet
blocks[330] = {
width: 4,
title: 'Telenet',
switch: false,
last_update: false
//Android TV
blocks[331] = {
width: 4,
title: 'Android TV',
switch: false,
last_update: false
//Garagepoort schakelaar
blocks[1052] = {
width: 6,
title: 'Schakelaar Poort',
last_update: false
//Garagepoort sensor
blocks[103] = {
width: 6,
title: 'Garagepoort',
imageOn: 'garage_open.png',
imageOff: 'garage_dicht.png',
last_update: false
//Hek schakelaar
blocks[975] = {
width: 6,
title: 'Schakelaar Hek',
last_update: false
//Hek sensor
blocks[493] = {
width: 6,
title: 'Hek',
imageOn: 'hek_open.png',
imageOff: 'hek_dicht.png',
last_update: false
blocks[364] = {
width: 6,
blocks[365] = {
width: 6,
//Setpunt
blocks[337] = {
title: 'Setpunt',
width: 5,
last_update: false
//Living Temperatuur
blocks[894] = {
title: 'Huidige temperatuur',
width: 5,
last_update: false
//Brander Vlam
blocks[591] = {
title: ' ',
width: 2,
imageOn: 'vlam_aan.png',
imageOff: 'vlam_uit.png',
protected: true,
hide_data: true,
last_update: false
//Thermostaat Keuze
blocks[344] = {
title: 'Thermostaat Keuze',
width: 12,
last_update: false
//Huidige stand
blocks[345] = {
title: ' ',
width: 12,
last_update: false
//Post tekst
blocks[346] = {
title: ' ',
width: 12,
icon: '',
last_update: false
//Badkamer boostmodus
blocks[347] = {
title: 'Badkamer Boost',
width: 6,
last_update: false
//Badkamer Temperatuur
blocks[805] = {
width: 6,
last_update: false
//Fijn stof 2.5µm
blocks[726] = {
title: 'Fijn Stof 2.5um',
image: 'stof.png',
width: 6,
last_update: false
//Fijn stof 10µm
blocks[727] = {
title: 'Fijn Stof 10um',
image: 'stof.png',
width: 6,
last_update: false
//Fijn text
blocks[728] = {
title: ' ',
width: 12,
image: 'stof.png',
last_update: false
//Titels
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Schakelaars';
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['title'] = 'Thermostaat';
blocks['blocktitle_3'] = {}
blocks['blocktitle_3']['type'] = 'blocktitle';
blocks['blocktitle_3']['title'] = 'Het weer';
blocks['blocktitle_4'] = {}
blocks['blocktitle_4']['type'] = 'blocktitle';
blocks['blocktitle_4']['title'] = 'Multimedia';
var columns = {}
columns[1] = {},
columns[1]['blocks'] = ['blocktitle_1',1132,1052,103,975,493,346,'garbage']
columns[1]['width'] = 4;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_2',344,345,337,894,591,347,'805','blocktitle_4',329,330,331]
columns[2]['width'] = 4;
columns[3] = {}
columns[3]['blocks'] = ['blocktitle_3',364,365,726,727,728,buttons.webcam1]
columns[3]['width'] = 4;
This is my custom.css
/* Algemeen -----------------------------------------*/
.titlegroups {
text-align: center !important;
.transbg.col-xs-1,
.transbg.col-xs-2,
.transbg.col-xs-3,
.transbg.col-xs-4,
.transbg.col-xs-5,
.transbg.col-xs-6,
.transbg.col-xs-7,
.transbg.col-xs-8,
.transbg.col-xs-9,
.transbg.col-xs-10,
.transbg.col-xs-11,
.transbg.col-xs-12 {
box-shadow: 0px 0px 0px #000000;
/* Blokken ------------------------------------------*/
/*Scenario thermostaat */
.block_345 .title {
//float: left !important;
margin-left: 5px;
font-size: 25px;
/*Post weergave*/
.block_346 .title {
font-size: 25px;
color:#FF6A00;
/*Afvalblok wat vergroten*/
.trash {
height: 155px !important;
/*webcam wat vergroten en beeld centreren in het vak*/
.button {
height: 239px !important;
padding: 30px 0 !important;
/*Afval ---------------------------------------------*/
.trash .state div.trashrow {
font-size: 12px;
.trash .state div.trashtoday {
font-size: 23px;
.trash .state div.trashtomorrow {
font-size: 20px;
Lokonli
Post by Lokonli »
Thanks for reporting.
It has been fixed. Can you test?
sieth
Post by sieth »
Lokonli wrote: Monday 17 February 2020 19:56 Thanks for reporting.
Thank you very much. It's working now! No more repeating items.
gielie
Domoticz version: latest β
Post by gielie »
Since the latest beta I have a bug in the “show update” it doesn’t show when a button is last updated. I only use this for the presence detection button with an extra text home/away but it doesn’t show this. It only show this when i press the button but then after a refresh it is gone again.
Can someone help me with this.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
Lokonli
Post by Lokonli »
gielie wrote: Friday 21 February 2020 7:39 Since the latest beta I have a bug in the “show update” it doesn’t show when a button is last updated. I only use this for the presence detection button with an extra text home/away but it doesn’t show this. It only show this when i press the button but then after a refresh it is gone again.
Do you mean the extra text home/way doesn't show correctly, or do you mean the last update time stamp?
You use custom.js to set the text?
Can you share your custom.js?
Which Domoticz version do you have?
gielie
Post by gielie »
Lokonli wrote: Friday 21 February 2020 8:25
I use this code
thuis
function getBlock_138(device,idx,result){.
   var html='';
   html+='<div class="col-xs-4 col-icon">';
      if(device['Status']=='Off') html+=iconORimage(idx,'fa-toggle-off','','off icon'
      else html+=iconORimage(idx,'fa-toggle-on','','on icon');
   html+='</div>';
   html+='<div class="col-xs-8 col-data">';
   html+='<strong class="title">'+device['Name']+'</strong><br />';
   if(device['Status']=='Off') html+='<span class="state">AFWEZIG</span>';
   else html+='<span class="state">AANWEZIG</span>';
    if((settings['last_update']==1 && (typeof(blocks[idx])=='undefined' || typeof(blo
    (settings['last_update']==0 && (typeof(blocks[idx])!=='undefined' && typeof(block
<------>html+='<br /><span class="lastupdate">'+moment(device['LastUpdate']).format(s
   html+='</div>';
   return html;
and it look like this
[video]http://machieljansen.nl/video/Domoticz[/video]
- FIBARO FGS223
- Toon
- Kodi Media Server
Lokonli
Post by Lokonli »
gielie wrote: Friday 21 February 2020 10:45
I use this code
thuis
   var html='';
   html+='</div>';
   html+='</div>';
   return html;
Thanks for the video, clear :)
Edit:
I can reproduce it. Will be solved within an hour.
Lokonli
Post by Lokonli »
Lokonli wrote: Friday 21 February 2020 11:10
Edit:
Fixed in latest beta. Update with 'git pull'
gielie
Post by gielie »
Lokonli wrote: Friday 21 February 2020 12:26
Edit:
Oh yeah, it works again, thanks for the lighting speed solution.
- FIBARO FGS223
- Toon
- Kodi Media Server
Jimster
Post by Jimster »
I've updated to the latest beta today. The power graph isn't showing the used energy anymore at the top, but is shows the different meter values as shown in Domoticz. Gas works fine.
I also have this code to change the font for the garbage collector, but somehow this doesn't seem to work anymore.
    font-size: 12px;
    font-size: 14px;
    font-size: 13px;
Lokonli
Post by Lokonli »
Jimster wrote: Saturday 22 February 2020 12:30
    font-size: 12px;
    font-size: 14px;
    font-size: 13px;
The garbage dates are shown correctly?
I've tried your css code, and it's working on my system. Can you double check your custom.css? Or post it here, and I'll test.
