Page 2 of 2
Re: Zigate error pairing
Posted: Sunday 09 February 2020 21:18
by pfloryann
No success, but I have a suggestion and I don't know if you can to add for the new version of zigate web interface the possibility to select manually type of the sensor with malfunction. I said that because the sensor it is displayed in the Web interface with short Id, ieee but with type sensor(model) field empty and without name but with the status is live. I think that solution could solve this pairing problems for xiaomi or other sensors. Please look at my attachment.
Posted: Sunday 09 February 2020 22:08
by pipiche
It is reported like that in the Web Admin, with the 'Trash' icon so you can remove it, otherwise at the next plugin restart it will automatically be removed.
It is key that we get the Model Name and/or a full discovery of the device, if this is not happen, the plugin do consider that there are some issue and don't move forward.
Posted: Tuesday 11 February 2020 22:55
by pfloryann
Hi Pipiche,
I bought 2 new aqara motion sensors, 1 Xiaomi door sensor and 1 ikea tradfri plug. I tested again with this new devices and same issue for all. They can't be paired. The result is bad pairing for xiaomi and aqara and IKEA tradfri plug is not detected by zigate.
I want to mention that I have the devices paired last year(the same model as new sensors and IKEA plug) , they are working perfectly with zigate.
I don't know what happened why they can't be paired now. However I think somewhere through the new updates may be a bug or something else.
Posted: Tuesday 11 February 2020 23:58
by pipiche
I suggest that you try to test it manual, with the ZGUI tool.
You need to follow the instructions on the zigate.fr (unfortunatly in French).
I have again paired here with latest firmware 3.1c and latest plugin Several Aqara/Xiaomi devices ( switchs, Bulb, door sensor, Motion Sensor, Temp/Hum/Baro sensor) , + Ikea Tradfri + Legrand without a single issues
Posted: Wednesday 12 February 2020 20:13
by pfloryann
I used fresh install for domoticz and zigate plugin...without erase the zigate eprom and i have same issue. Do you think if i will erase the eprom and tring to pair again my all devices it will work?
Posted: Saturday 15 February 2020 13:02
by pfloryann
I solved with fresh raspbian install and erase eeprom end reflash the zigate. Pairing works now but i saw that after i paired xiaomi plug...missing the power measurement(live Usage Electric in Watt) from devices list for the all xiaomi plugs. There is only plug_Voltage and switch.
