Page 2 of 3
Re: Install a new server
Posted: Tuesday 31 December 2019 13:22
by Egregius
Sorry, stupid webshops
https://www.coolblue.be/nl/product/8160 ... ifications indicates a M2 SSD size of 80mm of wich I concluded that a M2 slot was available.
Posted: Saturday 04 January 2020 0:10
by dzjr
I have the NUC running ...
It was quite a challenge.
The proposed Ubuntu Mate does not work for a NUC, but after some searching, a correct ubuntu version can be found on the Intel site.
I only missed that the firmware also needs to be updated, otherwise the nuc doesn't "understand" what you want with the burned iso on the USB.
Eventually succeeded, only ubuntu got stuck, so installed again, and then it turned out to be stable.
After some searching I found an explanation via google to install Oracle VirtualBox, but do not get in error to install the ready version, you really need the version of the website, otherwise you cannot install the extension pack.
And reading is also something a technician sometimes forgets.
I made a viruele machine for domoticz, first with a Ubuntu version, but I didn't get Domoticz installed on it, so I went for the raspbian desktop, hoping that the easy installation method would work ..
Well that does not work, so eventually installed via the "not so easy way", that was ultimately successful.
After domoticz was running I made an attempt to load the configuration of one of the pi's, I succeeded, but with this configuration domoticz keeps crashing, the log says that something would go wrong in the MySensors plugin .. so I started using the Pi again, considering that it was all about (yes, I had stopped Domoticz on the Pi).
I only think now that I have the pi also run as a slave, maybe it goes wrong there ..
The "point" is that I have quite a bit of historical (weather) sensor data in domoticz that I don't want to throw away, but maybe that I will eventually do so.
In short, after many hours of work, I finally have the configuration running, but I wanted to throw the NUC through the window a few times because everything didn't work ....
As a monitor I used a TV which is on my desk as an extra screen, but it did not occur when I rebooted, which I finally solved by reducing the resolution.
Furthermore, I have not yet managed VirtualBox and the Virtual machines to start automatically after a reboot.
Do you perhaps know if there is a way to import historical sensor data into a new config?
Posted: Saturday 04 January 2020 0:34
by waaren
dzjr wrote: Saturday 04 January 2020 0:10
I followed a different approach and installed Debian buster on the NUC and that went surprisingly smooth. Also installing domoticz out of the box "the easy way" worked first time. The only real issue I experienced was that I ordered the wrong storage as there was no slot for the NVM storage so I ended up using my spare SSD. I have not tested any USB connected hardware (Zwave stick / RFLink / P1) yet.
Compiling and testing are a bit faster on this system (with 8GB Ram) then on a RPI-4 with 4 Gbyte using Synology NAS as storage but for normal domoticz use, the Raspberry will do just fine.
You can use the procedure as described
in this topic
Posted: Saturday 04 January 2020 12:05
by Egregius
So you installed Ubuntu to get virtualbox running and then a virtual machine for domoticz?
Why not installed a real hypervisor like Proxmox?
Posted: Saturday 04 January 2020 12:42
by ben53252642
Egregius I also use Proxmox (with Domoticz running as a VM), really like the easy backup and restore to / from my NAS.
I agree if the goal is just to run Domoticz as a VM then I'd suggest using Proxmox.
Posted: Sunday 05 January 2020 0:53
by dzjr
Egregius wrote: Saturday 04 January 2020 12:05
Just becouse i am not a Linux engineer, and i dont Know Proxmox or other server software, sorry for that
I searched for virtual machines so i can run two servers on one machine, and Google came up with VirtualBox.
I was already happy that I had the nuc up and running with two servers / controller software packages.
perhaps it was/is a better idea to use the Pi4 instead of a NUC.
Posted: Sunday 05 January 2020 1:00
by dzjr
waaren wrote: Saturday 04 January 2020 0:34
in this topic
probably i copied the wrong rules, got the message that the server where the domoticz software came from today.
again, I was glad that I had everything running, especially considering that outside of some things on a raspberry pi I have no linux and server experience.
I had seen your response to the post of importing old data, thank you for your response, i removed the question there, i am very sorry dit the crossposting.
Posted: Sunday 05 January 2020 8:22
by Egregius
dzjr wrote: Sunday 05 January 2020 0:53
It's quite simple. Boot from USB stick, follow some basic steps. Once installed everything is webbased so you can move the nuc away from a monitor.
But hey, if it's up and running and it's stable why do it over.
Posted: Sunday 05 January 2020 11:51
by dzjr
Egregius wrote: Sunday 05 January 2020 8:22
I will delve into the benefits of Proxmus compared to the current configuration.
Posted: Tuesday 07 January 2020 22:53
by dzjr
I have taken the step, and installed Proxmox, which is indeed more convenient than the old config with virtualbox, thank you for thank you for pointing it out to me.
Starting a VM at Boot is also very easy.
I tried to set up a VM for Domoticz, but I can't get it working.
I tried it in a Ubuntu 16.04.6 LTS container, it looks like domoticz is installed (built from source), but I can't reach the webpage.
I also tried it via raspbian desktop, here I could even install it on the "Easy way", but here too I can't reach it in the webpage, not even in the browser in the VM itself.
On both machines I see an IP address, on the Raspbian I even have internet, so there is a connection ...
Furthermore I tried a debian container and with unbutu mate, but it didn't even work to install ....
Is there a recommended solution for domoticz in Proxmox?
Or perhaps a tutorial how to tackle it?
Another VM with its own OS and web server is working properly.
Thanks in advance!
dzjr
Posted: Tuesday 07 January 2020 23:28
by ben53252642
You don't want to be using a "container", I'm assuming you chose LXC for running Domoticz which is not ideal since it won't be easy to pass through USB devices.
Delete the container and create a VM, upload the ISO for debian or ubuntu whichever you want and go through the installation on screen in Proxmox.
I'd suggest Debian Buster or Ubuntu Mate.
Posted: Tuesday 07 January 2020 23:49
by sancla
Here you go:
Domoticz on virtual Debian 10.2 (Buster) with VMware vSphere
https://sancla.com/domoticz/domoticz-on ... e-vsphere/
Works just as well on Proxmox
Posted: Tuesday 07 January 2020 23:55
by ben53252642
sancla I don't think telling the dzjr to switch to another virtualization platform is the answer.
read the thread..
Posted: Wednesday 08 January 2020 1:17
by sancla
ben53252642 wrote:sancla I don't think telling the dzjr to switch to another virtualization platform is the answer.
read the thread..
Totally agree, but remind me again, who is telling dzjr to switch to another virtualization platform?
Not really sure if you have read the article...
If you did you would know that the article is just as much a guide for using Debian Buster for Domoticz, per your suggestion. Based on your comment I created that guide. You're welcome...
Now, if I can add to that with more information about Proxmox and how to create an virtual machine, I am more then willing to provide support on that subject... How can I help?
Sent from mobile phone
Posted: Wednesday 08 January 2020 6:34
by Egregius
edit: Just saw your first reaction on mobile and responded on computer without reading the other replies. Sancla's how-to looks pretty good. The hypervisor platform doesn't really matter, weither it's on vSphere or ProxMox or wathever. The most important part about it is that you use a real hypervisor and not Virtualbox on top of another OS. Virtualbox is great for testing something on a Desktop. A hypervisor is good for the long run.
I choose Proxmox because we use it at work so I don't need to now multiple systems and it never failed me in 10 years.
Is's been a long time ago, but I think something like this:
Download the amd64 ISO from Debian:
https://cdimage.debian.org/debian-cd/cu ... 64/iso-cd/
Upload it to Proxmox
Create a new VM. I give it 4 cores and 4GB of RAM. Choose the HD size, mine is at 20GB. Choose the Debian ISO for CD and a bridged network device.
- Screenshot at jan. 08 06-30-11.png (38.64 KiB) Viewed 2288 times
Boot and install Debian, a desktop version is not needed as this is a server. Once installed give it a fixed IP address, or make a reservation in the DHCP server. On the hardware details of the VM you can add the USB devices.
Domoticz must be available on the chosen IP as there's no firewall by default.
Posted: Wednesday 08 January 2020 19:00
by dzjr
Both as @sancla and @Egregius thank you very much for the help,
I have the domoticz server up and running in Proxmox, entirely according to the explanation of @sancla
It was simple and quick to install.
So for me the thumbs up for the two of you!
Thanks again!
Posted: Wednesday 08 January 2020 19:07
by dzjr
sancla wrote: Wednesday 08 January 2020 1:17
read the thread..
Friends, arguing is not necessary it is better to have a cup of coffee!
The explanation of @sancla was very clear, and if the settings of @Egregius can be added, is it perhaps a welcome addition to a wiki?
for example if: installing Domoticz on a Virtual Machine on minipc.
Posted: Wednesday 08 January 2020 19:32
by Egregius
Feel free to add it, it’s fresh in your memory
Posted: Wednesday 08 January 2020 19:44
by dzjr
A small addition,
You have to install pip3 manually
sudo apt install python3-pip
and than you can add the plugin manager.
Posted: Wednesday 08 January 2020 23:11
by sancla
dzjr wrote:A small addition,
I'll add this to the guides soon, thanks for the feedback!
