Anyway, just minutes after I posted my reply I came across a topic which mentioned copying the paho folder to the dist-packages in Python2.7. This actually did the trick for me.
But thank you for your response, much appreciated!
Perhaps it is complicated for you.For saying "hey google show me my domoticz", I do not know why you need to do so complicated things.
For me, dummy switch + one line script + IFTTT work perfectly.
local captors = {
["T intérieur salle à manger"]="delasallemanger danslasallemanger lintrieur delintrieur intrieure",
["T extérieur salle à manger"]="lextrieur delextrieur extrieure devantlafentre dehors dudehors",
["T Congélateur"]="duconglateur dansleconglateur conglateur", Code: Select all
elseif command == 'get' then
local appconnut=false
local text = get(deviceValue, 3):gsub("%W", ""):lower()
for captor,words in pairs(captors) do
for word in words:gmatch("%w+") do
if text == word then
local temperaturerelevee = otherdevices[captor]
cmd="curl -s --globoff \"http://192.168.1.104:1880/temp?valeur=" .. temperaturerelevee .. "\"" -- this is node red with cast node, just to say what is the temperature
os.execute(cmd)
os.execute("catt cast_site http://192.168.1.104:8080/#/Devices/" .. tonumber(otherdevices_idx[captor]) .. "/Log") -- casting domoticz device page
appconnut=true
if appconnut==false then
os.execute('curl -s --globoff "http://192.168.1.104:1880/nodered?mess=4"') -- oral message: not found this device
elseif command == 'cam' then
os.execute("catt cast_site http://admin:[email protected]/cgi-bin/snapshot.cgi?channel=" .. tonumber(get(deviceValue, 3)))
No, that is not completely true. Yes, I support my solution, and it would have been strange, if I didn't.I fully understand you want to promote your solution.
#!bin/bash
catt -d 'Woonkamer' cast_site http://192.168.68.201:8082/ >/dev/null &
Thanks, that was exactly what i`m looking forwaltervl wrote: Saturday 11 January 2025 10:22 See https://community.home-assistant.io/t/u ... 130332/161
Put the volume down before sending
