Python Plugin: Omnik Inverter local webinterface
Re: Python Plugin: Omnik Inverter local webinterface
Hi @parallax, @henkie
did you fix the "waiting 0s" problem ?
Br,
Majo
Br,
Majo
manjh
- Domoticz version: 2020.2
I am puzzled.
Have been using the Omnik-Data-Logger for a long time now, logging the total energy on a daily basis.
I seldom look at this, as always statistics only become valuable when there is a lot of data.
This morning I looked at the log file, and noticed that the PV system has not delivered any energy since Feb 10.
Not really, the online monitoring tool shows that the system is still going strong.
A small bit of research shows me an error: import of ConfigParser failed. I found on the web that this module has been renamed to configparser.
Changed that in OmnikExport.py, but then I see other errors....
So I found this alternative for getting data from the inverter.
Question, before I start setting this up.
It says it will pull data from the web interface of the inverter. But I am not aware of such web UI. When I go into the inverter via the IP address, I get a fairly rudimentary panel with some network settings, but that's it. No data about power.
At the bottom of the screen it says "Ver:4.01.9.d1".
Does this ring any bells?
File "/home/pi/Omnik-Data-Logger/LiveStats.py", line 7, in <module>
import OmnikExport
File "/home/pi/Omnik-Data-Logger/OmnikExport.py", line 14, in <module>
import InverterMsg # Import the Msg handler
File "/home/pi/Omnik-Data-Logger/InverterMsg.py", line 73
print self.__get_short(59)
SyntaxError: Missing parentheses in call to 'print'. Did you mean print(...)?Question, before I start setting this up.
Hans
- sincze
- Domoticz version: 2024.4
Version 2.0.0 of the plugin has been released.
Works with 2023 versions of Domoticz now.
https://github.com/sincze/Domoticz-Omni ... Web-Plugin
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
manjh
Doesn't work for me. My inverter only supports the /home.html extension to the IP.sincze wrote: Tuesday 05 September 2023 20:57 Version 2.0.0 of the plugin has been released.
I installed the plugin and tried different combinations, and 4 devices are created. But values remain zero.
Hans
- sincze
did you check the pre requirements first??manjh wrote: Wednesday 06 September 2023 9:26Doesn't work for me. My inverter only supports the /home.html extension to the IP.sincze wrote: Tuesday 05 September 2023 20:57 Version 2.0.0 of the plugin has been released.
Omnik inverters store the data in different values. Check http://inverter-ip/js/status.js
Without providing more info about fw version screenshots, things you already tried it it's pretty hard to help out.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
manjh
I can install the plugin. But when I try to find the info about different values using http://10.0.0.198/js/status.js I getsincze wrote: Wednesday 06 September 2023 9:40did you check the pre requirements first??manjh wrote: Wednesday 06 September 2023 9:26Doesn't work for me. My inverter only supports the /home.html extension to the IP.sincze wrote: Tuesday 05 September 2023 20:57 Version 2.0.0 of the plugin has been released.
404 Not Found
File not found.
Hans
- sincze
Is that official OMNIK Inverter??manjh wrote: Wednesday 06 September 2023 11:15I can install the plugin. But when I try to find the info about different values using http://10.0.0.198/js/status.js I getsincze wrote: Wednesday 06 September 2023 9:40did you check the pre requirements first??manjh wrote: Wednesday 06 September 2023 9:26
Without providing more info about fw version screenshots, things you already tried it it's pretty hard to help out.Code: Select all
404 Not Found File not found.
What type and what FW is installed??
To have a closer look.
Can you install FIDDLER.
Visit your inverter as normal.
Fiddler should show you all the traffic between your inverter and your browser.
Capture the traffic to see how the data flows into your html.
See if there is some separate file that we should be using for your inverter.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
manjh
It is an official Omnik, but it is old: about 10 years.
Later today I will check out Fiddler and show results here.
Hans
manjh
OK, I installed Fiddler and it gives me a long list of info, will have to look into that.
Meanwhile, I made a screenshot of the one and only screen that the inverter has for me. Not sure if that will help, though...
- Omnik screen.png (126.33 KiB) Viewed 2400 times
Hans
- sincze
Looks like the standard interface indeed. Please look for a .js extension just click through the items one at a time.manjh wrote: Wednesday 06 September 2023 11:35 OK, I installed Fiddler and it gives me a long list of info, will have to look into that.
Wat helpss
Press the red cross in fiddler.
Open your browser and click straight on the overview of your inverter W / kwH.
The thing you are looking for will then be somewhere near the top. Saves you some time.
Or else send me the captured file and I can help you. (do not send login credentials)
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
manjh
I never found such a page on the local interface. Screenshot I sent is the only one, it can be used for technical setup only. And I donot see any links to other pages!sincze wrote: Wednesday 06 September 2023 11:42 Open your browser and click straight on the overview of your inverter W / kwH.
I also tried logging in directly to the AP of the inverter, no luck.
Found this manual:
https://geaskb.nl/wp-content/uploads/20 ... 2kW_TL.pdf
Hans
- sincze
That is interesting indeed.
Normally Omnik would look like this:
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
manjh
manjh wrote: Wednesday 06 September 2023 13:06I never found such a page on the local interface. Screenshot I sent is the only one, it can be used for technical setup only. And I donot see any links to other pages!sincze wrote: Wednesday 06 September 2023 11:42 Open your browser and click straight on the overview of your inverter W / kwH.
Found this manual:
Hans
manjh
looks more like the Solarman online interface...sincze wrote: Wednesday 06 September 2023 13:51 That is interesting indeed.
Also interesting is the version number. Mine says it is Ver:4.01.9.d1!
Hans
manjh
Although I did not really dive deep into the python code, I think that the data logger here:
https://github.com/Woutrrr/Omnik-Data-Logger
pulls data directly from the inverter. Unfortunately the code has not been maintained for many years. When I install and run it, it comes back with a lot of errors. I tried correcting them, but am stuck with an improper "decode" which I donot know how to correct.
Pity, since it looks like a nice usable plugin...
Hans
- sincze
I kniw that one. I use the php version of that script.
I can have a look to convert it into a Domiticz plugin.
It works only with inverters that have specific serial numbers.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
manjh
Sounds great, looking forward to testing. Thank you!sincze wrote: Wednesday 06 September 2023 18:41 I kniw that one. I use the php version of that script.
Hans
- sincze
manjh wrote: Wednesday 06 September 2023 14:33 looks more like the Solarman online interface...
- Most inverters have a JS file, try accessing http://<your omnik ip address>/js/status.js in your browser. (Not working for you)
- Some inverters use a JSON status file to output the values. Check if your inverter outputs JSON data by navigating to: http://<your omnik ip address>/status.json?CMD=inv_query.
- A few inverters don't have JS or JSON but output the values directly in a HTML files. Check if your inverter supports the following URL: http://<your omnik ip address>/status.html. Note that this will work for almost all inverters, but you need to check the HTML source for a <script> tag that contains the relevant webData.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
manjh
All three come back with "404 - file not found" ...sincze wrote: Monday 11 September 2023 21:08manjh wrote: Wednesday 06 September 2023 14:33 looks more like the Solarman online interface...
Did any of these work for you?
In the mean time I have removed all traces of installed Omnik related plugins and programs, and started fresh with the python program that has worked for me before, but stopped working suddenly early august.
After installing, Inverter-Data-Logger works OK and gives me the values. So there must be a way to pull info, somehow...
Hans
- sincze
Tnx. for testing.manjh wrote: Tuesday 12 September 2023 7:57All three come back with "404 - file not found" ...sincze wrote: Monday 11 September 2023 21:08manjh wrote: Wednesday 06 September 2023 14:33 looks more like the Solarman online interface...
After installing, Inverter-Data-Logger works OK and gives me the values. So there must be a way to pull info, somehow...![]()
Yes I still think it should work with the magic packet method.
I found this one: https://github.com/klaasnicolaas/python-omnikinverter
Also noticed this one: https://github.com/sincze/solarman-mqtt
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
