Page 2 of 3
Re: need a loop for reading messages for logging
Posted: Sunday 30 June 2019 20:33
by pvklink
it is the dashticz environment....
Posted: Sunday 30 June 2019 21:54
by pvklink
in the domoticz env it is ok...
strange thing is that my old scripts also write to this text device with
msgtxt = 'Alarm is uitgezet, scenes worden gedeactiveerd....'
timertekst = dz.time.rawDate .. ' ' .. dz.time.rawTime .. ' : ' .. msgtxt .. '<br>' .. dz.devices('timerlog').text
dz.devices('timerlog').updateText(timertekst)
and with this it works in dashticz and domoticz...
Posted: Sunday 30 June 2019 22:22
by pvklink
Lines attached is only when the script has executed more than one
globalMessage(add, message .. ' AVOND AAN: huiskamerverlichting wordt AAN gezet...')
before globalMessage() -- dump
When it concerns only one globalMessage(add, message .. ' AVOND AAN: huiskamerverlichting wordt AAN gezet...')
all went OK!
Posted: Sunday 30 June 2019 22:25
by waaren
pvklink wrote: Sunday 30 June 2019 22:22 Lines attached is only when the script has executed more than one
all went OK!
Next try.
return
    data =
        myGlobalVar = { initial = 12 }
    helpers =
        alertLidl = function(dz, action, period)
            local controlVar = dz.variables("controlVar")
            local value = controlVar.value
            if controlVar.value ~= action then
                controlVar.set(action)
                if period then
                    controlVar.set(value).afterSec(period)
                    dz.log("alert requested; controlVar set to " .. action .. ". It will return to ".. value .. " after " .. period .. " seconds." ,dz.LOG_FORCE)
                    dz.log("alert requested; controlVar set to " .. action  ,dz.LOG_FORCE)
                dz.log("No changed needed; controlVar is already set to " .. value,dz.LOG_DEBUG)
    end,
    addMessage =
        function(dz, item, info, message, messages)
            local trigger =  item.isDevice and (", Device: " .. item.name ) or (", Timer: " .. item.trigger)
            messages[#messages + 1] = {}
            messages[#messages].log  = 'scriptname: ' .. info.scriptName .. trigger .. ' ' .. message
            messages[#messages].text = dz.time.rawDate .. '  ' .. dz.time.rawTime .. ' : ' .. message
            return messages
		end,
    dumpMessages =
        function(dz, messages)
            local maxLines = 8                               -- user configurable
            local dashticz = true                            -- true or false
            local textDevice = dz.devices('timerlog')        -- user configurable
            local currentText = textDevice.text
            local newText = currentText
            local lf = "\r\n"
            local dashticzLF = "<br>"
            for i, record in ipairs(messages) do
                dz.log(record.log, dz.LOG_INFO)
                lf = dahshticz and (lf .. dashticzLF) or lf
                newText = record.text .. lf .. newText
            dz.log(newText, dz.LOG_INFO)
            if newText ~= currentText then
                lines = dz.utils.stringSplit(newText, lf)  -- create lines table from newText string
                newText = table.concat(lines,lf, 1, (math.min(maxLines,#lines))) -- recreate newText string from first maxLines
                textDevice.updateText(newText)
    	end,
Posted: Sunday 30 June 2019 22:30
by pvklink
Got it working!
I added a <br>, does that makes sence ?
messages[#messages].text = dz.time.rawDate .. ' ' .. dz.time.rawTime .. ' : ' .. message .. '<br>'
return
    data =
    helpers =
                if period then
    end,
    addMessage =
            --messages[#messages].text = dz.time.rawDate .. '  ' .. dz.time.rawTime .. ' : ' .. message -- deze werkt met local if <br> en lines en newText disablen
            return messages
        end,
    dumpMessages =
	    --local lf = '<br>'
            --local lf = "\n"
            local lf = "\r\n"
            local maxLines = 8
                newText = table.concat(lines, lf, 1, (math.min(maxLines,#lines))) -- recreate newText string from first maxLines
        end,
Posted: Monday 01 July 2019 18:00
by pvklink
ok, that did not work even... my domoticz textfield gets extra linefeeds....
I have one config that both domoticz and dashticz are ok:
It works, so no need for digging :-)
I have still two other issues:
one is releated to this log functionality.
When my script logs with ADD messages and calls another script with the same add messages calls, i loose some info....
looks difficult to solve that! a script can add more then one logs and write onetime and calls another script that also has more logs and also writes onetime. Logging must work in comination and seperate...
other is a new topic and more an advise how to split my script in parts
I will post it after my son is ready (needs my pc for exams..)
working global_data:
return
    data =
    helpers =
                if period then
    end,
    addMessage =
            --messages[#messages].text = dz.time.rawDate .. '  ' .. dz.time.rawTime .. ' : ' .. message .. '<br>'
            return messages
        end,
    dumpMessages =
	    local lf = '<br>'
            --local lf = "\n"
            --local lf = "\r\n"
            local maxLines = 8
                --lines = dz.utils.stringSplit(newText, lf)  -- create lines table from newText string
                --newText = table.concat(lines, lf, 1, (math.min(maxLines,#lines))) -- recreate newText string from first maxLines
        end,
Posted: Wednesday 03 July 2019 10:14
by pvklink
Logging works OK!
I am rewriting all my scripts to use this..
Only with ifttt control var script i cant find why it is missing a value!
i renamed action to actionx because ifttt and globalmessage uses action
I think that it has something to do with global_data
iftttvar i not a device or timer..
2019-07-03 10:08:06.001 Error: dzVents: Error: (2.4.24) ifttt: An error occurred when calling event handler DZ_ifttt
2019-07-03 10:08:06.001 Error: dzVents: Error: (2.4.24) ifttt: /home/pi/domoticz/scripts/dzVents/scripts/global_data.lua:28: attempt to concatenate field 'trigger' (a nil value)
local iftttvar = "iftttvar"
return
    on =
    { variables = { iftttvar },
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'ifttt',
    execute = function(dz, item, info)
        local validBaseTypes = { device=true, group=true, scene=true, uservariable=false, camera=false }
        local validActions = { ON=true, OFF=true }
        result = dz.utils.stringSplit(item.value,'/')
        local name = result[1]
        local action = string.upper(result[2])
        local parm1 = result[3]
        local stype = result[4]
    local messageTable = {}
    local add = 'add'
    local function globalMessage(actionx, message )
        if actionx == add then
            messageTable = dz.helpers.addMessage(dz, item, info, message, messageTable )
            dz.helpers.dumpMessages(dz, messageTable)
        if parm1 == nil then parm1 = 'undefined' end -- par1 is de selectornaam of selectorlevel
        if stype == nil then stype = 'undefined' end -- stype is of par naam 1 of level is 2
        local function getBaseType(name)
            for i, tuple in ipairs(_G.domoticzData) do
                if tuple.name == name then
                    return tuple.baseType, tuple.id
        local baseType, idx = getBaseType(name)
        if baseType and validBaseTypes[baseType] then
            local target
            if baseType == 'device' then
                target = dz.devices(name)
            elseif baseType == 'group' then
                target = dz.groups(name)
            elseif baseType == 'scene' then
                target = dz.scenes(name)
                validActions.OFF = nil -- No Off action for scenes
            if validActions[action] then
                if action == 'ON' then
                    if parm1 ~= 'undefined' then
                        if stype == '1' or stype == 'undefined' then
                            globalMessage(add, ' IFTTT AAN: ,settings: ' .. item.value)
                            target.switchSelector(parm1) --parm selector_name
                        elseif stype == '2' then
                            target.switchSelector(tonumber(parm1)) --parm selector_id
                        else -- foute waarde
                            globalMessage(add, ' IFTTT AAN: ,foute waarde: settings: ' .. item.value)
                        target.switchOn()
                elseif action == 'OFF' then
                    globalMessage(add, ' IFTTT AAN: ,settings: ' .. item.value )
                    target.switchOff()
                else -- no other actions implemented yet
                    globalMessage(add, ' IFTTT AAN: ,foute action waarde: settings: ' .. action)
                globalMessage(add, ' IFTTT AAN: , action: '  .. action .. ' is not implemented for '  .. baseType .. ' Name ' .. name .. '!')
        elseif baseType then
            globalMessage(add, ' IFTTT AAN: , onbekende basetype: ' .. baseType)    --  dz.LOG_ERROR evt ook doorgeven
            globalMessage(add, ' IFTTT AAN: , name not found!: ' .. name )
return
    data =
    helpers =
                if period then
    end,
    addMessage =
            return messages
        end,
    dumpMessages =
	    local lf = '<br>'
            --local lf = "\n"
            --local lf = "\r\n"
            local maxLines = 8
        end,
Posted: Wednesday 03 July 2019 11:00
by waaren
pvklink wrote: Wednesday 03 July 2019 10:14 Only with ifttt control var script i cant find why it is missing a value!
Yes, that is indeed why you see the error. Try and replace that part of global data with
addMessage =
            local trigger
            if item.isDevice then trigger = ", Device: " .. item.name
            elseif item.isTimer then trigger = ", Timer: " .. item.trigger
            elseif item.isVariable then trigger = ", Variable: " .. item.name
            else trigger = ", Unknown trigger"
            return messages
        end,
Posted: Wednesday 03 July 2019 14:20
by pvklink
Yessssssssss, IFTTT now also works with the new logging...
Also made a script with a command to clean the log..
dz.devices('timerlog').updateText(dz.time.rawDate .. ' ' .. dz.time.rawTime .. ' :' .. ' TIMERLOG CLEAN: timerlog wordt geschoond...')
Or is it better to place this in your helper function ?
local function globalMessage(action, message )
if action == add then
elseif action == del then
dz.devices('timerlog').updateText(message)
or even in the global_data ?
logging looks great!
looks great!
Nested script, messages lost
Posted: Thursday 04 July 2019 10:03
by pvklink
Last problem, is a hard one.
I have nested scripts an both scripts uses the globamessages at their own and in combination.
When this test scripts calls the usb lamp, only the usb lamps logs are shown not 0-1-2 from the testscript and when i remark the usb lamp, i do get the 0-1-2 from the testscript/
I thought this was easy to fix by adding extra globalMessage() -- dump before calling the nested script so all the current logs where written...
but no !
    on = { devices = { 'test' }},
    local add = 'add'
    end        -- dz.devices('timerlog').updateText(dz.time.rawDate .. '  ' .. dz.time.rawTime .. ' : leeg')
        globalMessage(add, ' test 0 voor usb')
        --globalMessage() -- dump
        dz.devices('usb lamp').switchSelector(40)   -- the script for usb lamp also writes to the log !!!when is is not remarked out the other logs are not visible
        --dz.devices('Bewegingsservice').switchOff()
        globalMessage(add, ' test 1 na usb')
        globalMessage(add, ' test 2 na usb')
Posted: Thursday 04 July 2019 13:49
by pvklink
A temporary solution for the nested scripts is to set some logging off
logcode 0 message rule not written, 1 = dom log, 2 txtbox log, 3 =all written
dont now if this is the way to do it....
global_data
addMessage =
        function(dz, item, info, message, messages, logcode)
	-- logcode 0=no message written, 1= message domoticz log written, 2 =message = textbox, 3= all written
	-- what if logcode nil is, then default = 3
	if logcode > 0 then
	            local trigger
		if logcode =1 or logcode = 3 then
		if logcode =2 or logcode = 3 then
           return messages
        end,
    dumpMessages =
	    local lf = '<br>'
            --local lf = "\n"
            --local lf = "\r\n"
            local maxLines = 8
        end,
example test to see if loglevels working
    local logcode = 3
    local add = 'add'
    local del = 'del'
    local chg = 'chg'
    local function globalMessage(action, message, logcode)
        if logcode == nil then logcode = 3 end
        if action == add and logcode > 0 then
            messageTable = dz.helpers.addMessage(dz, item, info, message, messageTable, logcode)
        elseif action == chg then
        --globalMessage(del, 'nu verwijderen') -- delete
        globalMessage(add, ' test 0 voor usb',0)
--        globalMessage() -- dump
        --dz.devices('usb lamp').switchSelector(40)   -- the script for usb lamp also writes to the log !!!when is is not remarked out the other logs are not visible
        globalMessage(add, ' test 1 na usb',0)
        globalMessage(add, ' test 2 na usb',0)
        globalMessage(add, ' test 3 na usb',0)
        globalMessage(add, ' test 4 na usb',0)
        globalMessage(add, ' test 5 na usb',logcode)
        globalMessage(chg) -- dump
Re: Nested script, messages lost
Posted: Thursday 04 July 2019 15:17
by waaren
pvklink wrote: Thursday 04 July 2019 10:03 Last problem, is a hard one.
There is no such thing as nested scripts in the domoticz Eventsystem.
The Eventsystem is single threaded meaning that a script needs to be finished before a next script can start.
Posted: Thursday 04 July 2019 15:37
by pvklink
mmm,strange my testscript writes log messages ok when activate test and disabling the usb lamp that is calling its own script also with log messages...
but when enabling the usb lamp in the test script, the test logs get lost and only the usb lamp one appear
see the test script above...
Posted: Thursday 04 July 2019 15:43
by waaren
pvklink wrote: Thursday 04 July 2019 15:37 mmm,strange my testscript writes log messages ok when activate test and disabling the usb lamp that is calling its own script also with log messages...
Probably because they both use the same domoticz object so there 'currenttext' is the same for both. A way to prevent this type of conflict is to get 'currenttext' from a variable in global data and not from the text device.
Posted: Thursday 04 July 2019 18:21
by pvklink
Got it working! THANKS again @WAAREN
The usb logging is showing up now!
Strange thing is that the USB logs are logged later!
1. is this a good way to add the delete function ? it is working...
2. do i need the dz parameter in
globalMessage(dz,del, dz.time.rawDate .. ' ' .. dz.time.rawTime .. ' :' .. ' TIMERLOG CLEAN: timerlog wordt geschoond...') -- delete
3. last thing is to add logcode 1,2,3 to addMessage to 1= log domoticz.log, 2= log global, 3 log both
then time for a holiday and no more scripting. I can check remote (via logs) if everything works ok!
my test script
    local logcode = 3
    local add = 'add'
    local del = 'del'
    local chg = 'chg'
    local function globalMessage(dz, action, message, logcode)
            dz.globalData.mylogging = message
        --globalMessage(dz,del, dz.time.rawDate .. '  ' .. dz.time.rawTime .. ' :' .. ' TIMERLOG CLEAN: timerlog wordt geschoond...') -- delete
        globalMessage(dz,del, dz.time.rawDate .. '  ' .. dz.time.rawTime .. ' :' .. ' TIMERLOG CLEAN: timerlog wordt geschoond...' .. '<br>') -- delete
        globalMessage(dz,add, ' test 0 voor usb',1)
        globalMessage(dz,add, ' test 1 voor usb',1)
        globalMessage(dz,add, ' test 2 na usb',0)
        globalMessage(dz,add, ' test 3 na usb',0)
        globalMessage(dz,add, ' test 4 na usb',3)
        globalMessage(dz,add, ' test 5 na usb',0)
        globalMessage(dz,add, ' test 6 na usb',logcode)
        globalMessage(dz,chg) -- dump
my global_data.lua
return
    data =
        myGlobalVar = { initial = 12 },
        mylogging = {initial = 'Eerst aanmaak van global variable mylogging in global_data.lua'},
    helpers =
                if period then
    end,
    addMessage =
            local trigger
            return messages
        end,
    dumpMessages =
	    local currentText = dz.globalData.mylogging
	    local lf = '<br>'					--local lf = "\n" 	--local lf = "\r\n"	--PVK \n of \r\n UITGEZET ANDERS werkt dashticz niet
            local maxLines = 8
                --lines = dz.utils.stringSplit(newText, lf)  -- create lines table from newText string						--PVK UITGEZET ANDERS werkt dashticz niet
                --newText = table.concat(lines, lf, 1, (math.min(maxLines,#lines))) -- recreate newText string from first maxLines 		--PVK UITGEZET ANDERS werkt dashticz niet
		dz.globalData.mylogging = newText  -- ADDED
        end,
Posted: Friday 05 July 2019 14:39
by waaren
pvklink wrote: Thursday 04 July 2019 18:21 2. do i need the dz parameter in
No. You don't need it.
don't forget to remove it from both the calls to the function and from the function declaration.
Posted: Saturday 06 July 2019 1:29
by pvklink
Works!
Posted: Saturday 06 July 2019 14:01
by pvklink
Busy with the last part.
want to call the logfunctie with the logcode: 0 no log, 1 = domoticz log, 2 = global var log, 3 = all
0 and 3 works ok!
globalMessage(add, ' BASISVOORZIENING AAN: ...',1)
this is the function:
    local logcode = 3
    local add = 'add'
    local del = 'del'
    local chg = 'chg'
logcode = 0 is working ok.
When using logcode 1 (only domoticz) i get:
019-07-06 13:53:05.460 (zwavepluspvk) Light/Switch (printer)
2019-07-06 13:53:05.416 Error: dzVents: Error: (2.4.24) Timers: An error occurred when calling event handler DZ_schakelgroepen
2019-07-06 13:53:05.416 Error: dzVents: Error: (2.4.24) Timers: /home/pi/domoticz/scripts/dzVents/scripts/global_data.lua:58: attempt to concatenate field 'text' (a nil value)
this is my global_data.lua
return
    data =
    helpers =
                if period then
    end,
    addMessage =
        function(dz, item, info, message, messages,logcode)
            local trigger
	    if logcode == 1 or logcode == 3 then
	    if logcode >= 2 then
            return messages
        end,
    dumpMessages =
            local maxLines = 8
        end,
Posted: Saturday 06 July 2019 23:16
by waaren
pvklink wrote: Saturday 06 July 2019 14:01 globalMessage(add, ' BASISVOORZIENING AAN: ...',1)
When using the parm 1, you don't enter anything in the text field of the messages record in function addMessage but in function dumpMessages you still expect something to be there. dzVents (Lua) is quite powerful but without a wand it cannot perform magic :D
Just curious why you would want to use these functions if you only want to send something to the logfile.
Posted: Sunday 07 July 2019 10:34
by pvklink
i have lot of devices (100) and lot of scripts and i am rewriting them all in dzvents, 99% is working but can be organized better...
so no more groups, triggers timers in domoticz, all in dzvents :-)
So i have made a lot of checkpoints where i write to the logs when testing my script.
I write to domoticz (but that has a lot of entries and hard to search and i have my own log with the most important entries, events etc.
Some events i want to see in domoticz, some in my log and sometime when scripts are not working ok, i changes these logrules from ,0 to ,3 to see what is going wrong..
I am very happy with it and it works ok!
i understand the problem with value 1 and 2 now...when only write to domoticz and not to global i dont get something back...
so my local logging function has to split domoticz and global logging in two executing parts...?
