Re: Dashticz V3 - Automatic installation
Posted: Thursday 27 June 2019 17:50
@Lokonli : Have a nice holiday
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
Which scripts won't run?gielie wrote: Tuesday 16 July 2019 23:07 I tried v3 and iT looks nice. I have some trouble now with some scripts that won’t run anymore, how do I uninstall v3?
#First go to your dashticz_v3 folder
cd ~/dev/dashticz_v3
#Stop the Docker instance of Dashticz (assuming you used the automatic installation script)
make stop
#Remove the dashticz_v3 folder
cd ..
rm -rf dashticz_v3
#remove the docker images etc. To remove see https://www.digitalocean.com/community/tutorials/how-to-remove-docker-images-containers-and-volumes:
docker system prune
I get a lot of errors during installation and afterworhs my normal dashticz isn't loading anymore.Lokonli wrote: Thursday 18 July 2019 17:29Which scripts won't run?gielie wrote: Tuesday 16 July 2019 23:07 I tried v3 and iT looks nice. I have some trouble now with some scripts that won’t run anymore, how do I uninstall v3?
To uninstall:
After that you can deinstall Docker.Code: Select all
#First go to your dashticz_v3 folder cd ~/dev/dashticz_v3 #Stop the Docker instance of Dashticz (assuming you used the automatic installation script) make stop #Remove the dashticz_v3 folder cd .. rm -rf dashticz_v3 #remove the docker images etc. To remove see https://www.digitalocean.com/community/tutorials/how-to-remove-docker-images-containers-and-volumes: docker system prune
. <(wget -qO - https://raw.githubusercontent.com/dashticzv3/dashticz_v3/beta/scripts/dashticz_install.sh )
This is the installation script for Dashticz V3
The script will create a folder for Dashticz v3 in the following location:
/home/pi/dashticz3
Enter the folder name [dashticz_v3]:
Dashticz will be installed in
dashticz_v3
Dashticz has a master branch (=stable) and a beta branch (=most up-to-date)
Which branch to install? [master]: beta
Now cloning the Dashticz repository https://github.com/dashticzv3/dashticz_v3
Cloning into 'dashticz_v3'...
remote: Enumerating objects: 7076, done.
remote: Counting objects: 100% (7076/7076), done.
remote: Compressing objects: 100% (2383/2383), done.
remote: Total 7076 (delta 4654), reused 7057 (delta 4636), pack-reused 0
Receiving objects: 100% (7076/7076), 29.20 MiB | 5.23 MiB/s, done.
Resolving deltas: 100% (4654/4654), done.
Configuring Dashticz.
What is the IP:port address of your Domoticz server? (example: 192.168.178.18:8080): 192.168.1.133:6060
Finding a free port for Dashticz
Port 8082 is NOT in use
Setting up Dashticz on port 8082
Let's install docker first
wget -qO- https://get.docker.com/ | sh
# Executing docker install script, commit: 6bf300318ebaab958c4adc341a8c7bb9f3a54a1a
+ sudo -E sh -c apt-get update -qq >/dev/null
+ sudo -E sh -c apt-get install -y -qq apt-transport-https ca-certificates curl >/dev/null
+ sudo -E sh -c curl -fsSL "https://download.docker.com/linux/raspbian/gpg" | apt-key add -qq - >/dev/null
Warning: apt-key output should not be parsed (stdout is not a terminal)
+ sudo -E sh -c echo "deb [arch=armhf] https://download.docker.com/linux/raspbian stretch stable" > /etc/apt/sources.list.d/docker.list
+ [ -n ]
+ sudo -E sh -c apt-get install -y -qq --no-install-recommends docker-ce >/dev/null
apt-listchanges: Can't set locale; make sure $LC_* and $LANG are correct!
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_CTYPE = "UTF-8",
LANG = "en_GB.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
+ sudo -E sh -c docker version
Client: Docker Engine - Community
Version: 19.03.0
API version: 1.40
Go version: go1.12.5
Git commit: aeac949
Built: Wed Jul 17 18:25:36 2019
OS/Arch: linux/arm
Experimental: false
Server: Docker Engine - Community
Engine:
Version: 19.03.0
API version: 1.40 (minimum version 1.12)
Git commit: aeac949
Built: Wed Jul 17 18:19:37 2019
OS/Arch: linux/arm
Experimental: false
containerd:
Version: 1.2.6
GitCommit: 894b81a4b802e4eb2a91d1ce216b8817763c29fb
runc:
Version: 1.0.0-rc8
GitCommit: 425e105d5a03fabd737a126ad93d62a9eeede87f
docker-init:
Version: 0.18.0
GitCommit: fec3683
If you would like to use Docker as a non-root user, you should now consider
adding your user to the "docker" group with something like:
sudo usermod -aG docker pi
Remember that you will have to log out and back in for this to take effect!
WARNING: Adding a user to the "docker" group will grant the ability to run
containers which can be used to obtain root privileges on the
docker host.
Refer to https://docs.docker.com/engine/security/security/#docker-daemon-attack-surface
for more information.
Check for git
Installed...
sudo docker build -t dtv3 .
Sending build context to Docker daemon 66.48MB
Step 1/3 : FROM php:apache
---> c6fa8e4bcb26
Step 2/3 : USER root
---> Using cache
---> 4c5ce91b0eaf
Step 3/3 : SHELL ["/bin/bash", "-c"]
---> Using cache
---> 8c66cd348691
Successfully built 8c66cd348691
Successfully tagged dtv3:latest
sudo docker run --name dtv3 -d -p 8082:80 --mount type=bind,source="/home/pi/dashticz3/dashticz_v3",target=/var/www/html dtv3
docker: Error response from daemon: Conflict. The container name "/dtv3" is already in use by container "f2f46cc0b2a11a65bea219ed56681df09a16a3ffb5ab272e58033491f4e2ebcd". You have to remove (or rename) that container to be able to reuse that name.
See 'docker run --help'.
Makefile:38: recipe for target 'start' failed
make: *** [start] Error 125
Trying Domoticz IP...OK!
All done
The last error message indicates that the Dashticz Docker image already exists and is running.gielie wrote: Thursday 25 July 2019 14:36I get a lot of errors during installation and afterworhs my normal dashticz isn't loading anymore.Lokonli wrote: Thursday 18 July 2019 17:29Which scripts won't run?gielie wrote: Tuesday 16 July 2019 23:07 I tried v3 and iT looks nice. I have some trouble now with some scripts that won’t run anymore, how do I uninstall v3?
To uninstall:
#First go to your dashticz_v3 folder cd ~/dev/dashticz_v3 #Stop the Docker instance of Dashticz (assuming you used the automatic installation script) make stop #Remove the dashticz_v3 folder cd .. rm -rf dashticz_v3 #remove the docker images etc. To remove see https://www.digitalocean.com/community/tutorials/how-to-remove-docker-images-containers-and-volumes: docker system prunei tried several times on different systems with no luck, any idea?Code: Select all
. <(wget -qO - https://raw.githubusercontent.com/dashticzv3/dashticz_v3/beta/scripts/dashticz_install.sh ) This is the installation script for Dashticz V3 The script will create a folder for Dashticz v3 in the following location: /home/pi/dashticz3 Enter the folder name [dashticz_v3]: Dashticz will be installed in dashticz_v3 Dashticz has a master branch (=stable) and a beta branch (=most up-to-date) Which branch to install? [master]: beta Now cloning the Dashticz repository https://github.com/dashticzv3/dashticz_v3 Cloning into 'dashticz_v3'... remote: Enumerating objects: 7076, done. remote: Counting objects: 100% (7076/7076), done. remote: Compressing objects: 100% (2383/2383), done. remote: Total 7076 (delta 4654), reused 7057 (delta 4636), pack-reused 0 Receiving objects: 100% (7076/7076), 29.20 MiB | 5.23 MiB/s, done. Resolving deltas: 100% (4654/4654), done. Configuring Dashticz. What is the IP:port address of your Domoticz server? (example: 192.168.178.18:8080): 192.168.1.133:6060 Finding a free port for Dashticz Port 8082 is NOT in use Setting up Dashticz on port 8082 Let's install docker first wget -qO- https://get.docker.com/ | sh # Executing docker install script, commit: 6bf300318ebaab958c4adc341a8c7bb9f3a54a1a + sudo -E sh -c apt-get update -qq >/dev/null + sudo -E sh -c apt-get install -y -qq apt-transport-https ca-certificates curl >/dev/null + sudo -E sh -c curl -fsSL "https://download.docker.com/linux/raspbian/gpg" | apt-key add -qq - >/dev/null Warning: apt-key output should not be parsed (stdout is not a terminal) + sudo -E sh -c echo "deb [arch=armhf] https://download.docker.com/linux/raspbian stretch stable" > /etc/apt/sources.list.d/docker.list + sudo -E sh -c apt-get update -qq >/dev/null + [ -n ] + sudo -E sh -c apt-get install -y -qq --no-install-recommends docker-ce >/dev/null apt-listchanges: Can't set locale; make sure $LC_* and $LANG are correct! perl: warning: Setting locale failed. perl: warning: Please check that your locale settings: LANGUAGE = (unset), LC_ALL = (unset), LC_CTYPE = "UTF-8", LANG = "en_GB.UTF-8" are supported and installed on your system. perl: warning: Falling back to a fallback locale ("en_GB.UTF-8"). locale: Cannot set LC_CTYPE to default locale: No such file or directory locale: Cannot set LC_ALL to default locale: No such file or directory + sudo -E sh -c docker version Client: Docker Engine - Community Version: 19.03.0 API version: 1.40 Go version: go1.12.5 Git commit: aeac949 Built: Wed Jul 17 18:25:36 2019 OS/Arch: linux/arm Experimental: false Server: Docker Engine - Community Engine: Version: 19.03.0 API version: 1.40 (minimum version 1.12) Go version: go1.12.5 Git commit: aeac949 Built: Wed Jul 17 18:19:37 2019 OS/Arch: linux/arm Experimental: false containerd: Version: 1.2.6 GitCommit: 894b81a4b802e4eb2a91d1ce216b8817763c29fb runc: Version: 1.0.0-rc8 GitCommit: 425e105d5a03fabd737a126ad93d62a9eeede87f docker-init: Version: 0.18.0 GitCommit: fec3683 If you would like to use Docker as a non-root user, you should now consider adding your user to the "docker" group with something like: sudo usermod -aG docker pi Remember that you will have to log out and back in for this to take effect! WARNING: Adding a user to the "docker" group will grant the ability to run containers which can be used to obtain root privileges on the docker host. Refer to https://docs.docker.com/engine/security/security/#docker-daemon-attack-surface for more information. Check for git Installed... sudo docker build -t dtv3 . Sending build context to Docker daemon 66.48MB Step 1/3 : FROM php:apache ---> c6fa8e4bcb26 Step 2/3 : USER root ---> Using cache ---> 4c5ce91b0eaf Step 3/3 : SHELL ["/bin/bash", "-c"] ---> Using cache ---> 8c66cd348691 Successfully built 8c66cd348691 Successfully tagged dtv3:latest sudo docker run --name dtv3 -d -p 8082:80 --mount type=bind,source="/home/pi/dashticz3/dashticz_v3",target=/var/www/html dtv3 docker: Error response from daemon: Conflict. The container name "/dtv3" is already in use by container "f2f46cc0b2a11a65bea219ed56681df09a16a3ffb5ab272e58033491f4e2ebcd". You have to remove (or rename) that container to be able to reuse that name. See 'docker run --help'. Makefile:38: recipe for target 'start' failed make: *** [start] Error 125 Trying Domoticz IP...OK! All done
cd /home/pi/dashticz3/dashticz_v3
make stop
make start
Fixed in latest beta.Lokonli wrote: Thursday 27 June 2019 7:48Yesterday I indeed released beta 3.0.1. Thanks for confirming that your garbage issue is solved.jake wrote: Wednesday 26 June 2019 23:34 I did a 'make update' and now the garbage is loading alright. Thankf for fixing!
I noticed something else (very minor issue):
Because I had V3 setup 'manually' and via Docker, I can load them both in different tabs. I skipped between them and found something 'moving' in the calendar. Finally I saw that in the docker version of dashticz V3 the 'all day' events have a 02:00 time after the date, where the normal version doesn't have that.
Again, equal config file, so that doesn't explain.
The 02:00 time issue sounds like an incorrect timezone setting, probably inside the Docker container. I'm afraid I don't have the time to look into this in the coming 3 weeks (holiday). I'll create an issue on Github. Maybe someone else is willing to pick this up.
Thanks for your feedback.
What is the IP address of your pi? The installation script thinks it's running on 192.168.1.96...dstewart275 wrote: Monday 23 December 2019 14:38 Hello - Can someone help me out?
I've a bit of experience with Domoticz and no problems with that. I've just tried to install Dashticz on the same PI and I simply can't make it work. The automatic installer runs fine and at the end I get the message to go to 192.168.1.96:8082 and another 172.x.x.x address but they don't land anywhere. If I go to 192.168.1.1:80 I get the apache holding page and at 192.168.1.1/dashticz/ i'll get an Dashticz error page. The CONFIG.js file is correct as you'd expect.
I'm running Raspbian Buster on a Pi1 Model B.
Any advice appreciated... Thanks Duncan
Thanks - my pi is 192.168.1.96 and I can get to Domoticz on 192.168.1.96:8080 just fine.Lokonli wrote: Monday 23 December 2019 16:06 What is the IP address of your pi? The installation script thinks it's running on 192.168.1.96...
Which error is reported if you go to 192.168.1.1/dashticz/ ?
Can you post your CONFIG.js here?
The 192.1168.1.96 indeed makes more sense ...dstewart275 wrote: Monday 23 December 2019 16:30Thanks - my pi is 192.168.1.96 and I can get to Domoticz on 192.168.1.96:8080 just fine.Lokonli wrote: Monday 23 December 2019 16:06 What is the IP address of your pi? The installation script thinks it's running on 192.168.1.96...
I've made a mistake in the previous post - The page I land on at 192.168.1.96/dashticz/ just says "ERROR - For more information visit Dashticz V3 Documentation"... The 192.168.1.1 reference should be ignored.
Thanks for helping!
That's what I was expecting too - Docker seems to be running (and I presume it is generating the error page mentioned on 192.168.1.96/dashticzLokonli wrote: Monday 23 December 2019 16:57 The 192.1168.1.96 indeed makes more sense ...
If you followed the automatic installation script you should have a Docker image running on port 8082.
Maybe better to test that first.
What do you see if you open 192.168.1.96:8082?
Then apparently the Docker image is not running correctly, at least not on port 8082.dstewart275 wrote: Monday 23 December 2019 17:37That's what I was expecting too - Docker seems to be running (and I presume it is generating the error page mentioned on 192.168.1.96/dashticzLokonli wrote: Monday 23 December 2019 16:57 The 192.1168.1.96 indeed makes more sense ...
However if i navigate to 192.168.1.96:8082 on chrome I get
This site can’t be reached
192.168.1.96 refused to connect.
Search Google for 192 168 8082
ERR_CONNECTION_REFUSED
Does that help?
make stop
make start
Thanks - here's the output from puttyLokonli wrote: Monday 23 December 2019 17:46 Then apparently the Docker image is not running correctly, at least not on port 8082.
Just to be sure, can you type the following in the Dashticz folder:Code: Select all
make stop make start
It stops the current Dashticz container, and restarts it again. It takes approx 1 minute. After start it reports the ip-adres:port.
The error page on 192.168.1.96/dashticz is not generated by the Docker container, but probably by some left overs from a previous manual install?
pi@raspberrypi:~ $ cd dashticz_v3
pi@raspberrypi:~/dashticz_v3 $ make stop
sudo docker stop dtv3
dtv3
sudo docker rm dtv3
dtv3
pi@raspberrypi:~/dashticz_v3 $ make start
Check for git
Installed...
Sending build context to Docker daemon 66.8MB
---> c2dbfc2dd7fc
---> Using cache
---> f1f10f88a333
---> Using cache
---> fd4d3dcf868d
Successfully built fd4d3dcf868d
sudo docker run --name dtv3 -d -p 8082:80 --mount type=bind,source="/home/pi/dashticz_v3",target=/var/www/html dtv3
8505117725c350dc5a76a41b2c60445c110e6612c01d0e3903f8a88382e3b2bd
Dashticz is running at:
http://192.168.1.96:8082
http://172.17.0.1:8082
