Dashticz V3 - Automatic installation
HansieNL
Re: Dashticz V3 - Automatic installation
Post by HansieNL »
@Lokonli : Have a nice holiday :-)
Blah blah blah
jake
Post by jake »
@Lokonli : enjoy the time off!
gielie
Domoticz version: latest β
Post by gielie »
I tried v3 and iT looks nice. I have some trouble now with some scripts that won’t run anymore, how do I uninstall v3?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
Lokonli
Post by Lokonli »
gielie wrote: Tuesday 16 July 2019 23:07 I tried v3 and iT looks nice. I have some trouble now with some scripts that won’t run anymore, how do I uninstall v3?
Which scripts won't run?
To uninstall:
#First go to your dashticz_v3 folder
cd ~/dev/dashticz_v3
#Stop the Docker instance of Dashticz (assuming you used the automatic installation script)
make stop
#Remove the dashticz_v3 folder
cd ..
rm -rf dashticz_v3
#remove the docker images etc. To remove see  https://www.digitalocean.com/community/tutorials/how-to-remove-docker-images-containers-and-volumes:
docker system prune
After that you can deinstall Docker.
gielie
Post by gielie »
Lokonli wrote: Thursday 18 July 2019 17:29
To uninstall:
make stop
cd ..
rm -rf dashticz_v3
docker system prune
I get a lot of errors during installation and afterworhs my normal dashticz isn't loading anymore.
. <(wget -qO - https://raw.githubusercontent.com/dashticzv3/dashticz_v3/beta/scripts/dashticz_install.sh )
This is the installation script for Dashticz V3
The script will create a folder for Dashticz v3 in the following location:
/home/pi/dashticz3
Enter the folder name [dashticz_v3]:
Dashticz will be installed in
dashticz_v3
Dashticz has a master branch (=stable) and a beta branch (=most up-to-date)
Which branch to install? [master]: beta
Now cloning the Dashticz repository https://github.com/dashticzv3/dashticz_v3
Cloning into 'dashticz_v3'...
remote: Enumerating objects: 7076, done.
remote: Counting objects: 100% (7076/7076), done.
remote: Compressing objects: 100% (2383/2383), done.
remote: Total 7076 (delta 4654), reused 7057 (delta 4636), pack-reused 0
Receiving objects: 100% (7076/7076), 29.20 MiB | 5.23 MiB/s, done.
Resolving deltas: 100% (4654/4654), done.
Configuring Dashticz.
What is the IP:port address of your Domoticz server? (example: 192.168.178.18:8080): 192.168.1.133:6060
Finding a free port for Dashticz
Port 8082 is NOT in use
Setting up Dashticz on port 8082
Let's install docker first
wget -qO- https://get.docker.com/ | sh
# Executing docker install script, commit: 6bf300318ebaab958c4adc341a8c7bb9f3a54a1a
+ sudo -E sh -c apt-get update -qq >/dev/null
+ sudo -E sh -c apt-get install -y -qq apt-transport-https ca-certificates curl >/dev/null
+ sudo -E sh -c curl -fsSL "https://download.docker.com/linux/raspbian/gpg" | apt-key add -qq - >/dev/null
Warning: apt-key output should not be parsed (stdout is not a terminal)
+ sudo -E sh -c echo "deb [arch=armhf] https://download.docker.com/linux/raspbian stretch stable" > /etc/apt/sources.list.d/docker.list
+ [ -n  ]
+ sudo -E sh -c apt-get install -y -qq --no-install-recommends docker-ce >/dev/null
apt-listchanges: Can't set locale; make sure $LC_* and $LANG are correct!
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
	LANGUAGE = (unset),
	LC_ALL = (unset),
	LC_CTYPE = "UTF-8",
	LANG = "en_GB.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
+ sudo -E sh -c docker version
Client: Docker Engine - Community
 Version:           19.03.0
 API version:       1.40
 Go version:        go1.12.5
 Git commit:        aeac949
 Built:             Wed Jul 17 18:25:36 2019
 OS/Arch:           linux/arm
 Experimental:      false
Server: Docker Engine - Community
 Engine:
  Version:          19.03.0
  API version:      1.40 (minimum version 1.12)
  Git commit:       aeac949
  Built:            Wed Jul 17 18:19:37 2019
  OS/Arch:          linux/arm
  Experimental:     false
 containerd:
  Version:          1.2.6
  GitCommit:        894b81a4b802e4eb2a91d1ce216b8817763c29fb
 runc:
  Version:          1.0.0-rc8
  GitCommit:        425e105d5a03fabd737a126ad93d62a9eeede87f
 docker-init:
  Version:          0.18.0
  GitCommit:        fec3683
If you would like to use Docker as a non-root user, you should now consider
adding your user to the "docker" group with something like:
  sudo usermod -aG docker pi
Remember that you will have to log out and back in for this to take effect!
WARNING: Adding a user to the "docker" group will grant the ability to run
         containers which can be used to obtain root privileges on the
         docker host.
         Refer to https://docs.docker.com/engine/security/security/#docker-daemon-attack-surface
         for more information.
Check for git
Installed...
sudo docker build -t dtv3 .
Sending build context to Docker daemon  66.48MB
Step 1/3 : FROM php:apache
 ---> c6fa8e4bcb26
Step 2/3 : USER root
 ---> Using cache
 ---> 4c5ce91b0eaf
Step 3/3 : SHELL ["/bin/bash", "-c"]
 ---> Using cache
 ---> 8c66cd348691
Successfully built 8c66cd348691
Successfully tagged dtv3:latest
sudo docker run --name dtv3 -d -p 8082:80 --mount type=bind,source="/home/pi/dashticz3/dashticz_v3",target=/var/www/html dtv3
docker: Error response from daemon: Conflict. The container name "/dtv3" is already in use by container "f2f46cc0b2a11a65bea219ed56681df09a16a3ffb5ab272e58033491f4e2ebcd". You have to remove (or rename) that container to be able to reuse that name.
See 'docker run --help'.
Makefile:38: recipe for target 'start' failed
make: *** [start] Error 125
Trying Domoticz IP...OK!
All done
i tried several times on different systems with no luck, any idea?
- FIBARO FGS223
- Toon
- Kodi Media Server
Lokonli
Post by Lokonli »
gielie wrote: Thursday 25 July 2019 14:36
To uninstall:
make stop
cd ..
rm -rf dashticz_v3
docker system prune
/home/pi/dashticz3
dashticz_v3
+ [ -n  ]
	LANGUAGE = (unset),
	LC_ALL = (unset),
	LC_CTYPE = "UTF-8",
 Version:           19.03.0
 API version:       1.40
 Git commit:        aeac949
 OS/Arch:           linux/arm
 Experimental:      false
 Engine:
  Version:          19.03.0
  Git commit:       aeac949
  OS/Arch:          linux/arm
  Experimental:     false
 containerd:
  Version:          1.2.6
 runc:
  Version:          1.0.0-rc8
 docker-init:
  Version:          0.18.0
  GitCommit:        fec3683
         docker host.
Check for git
Installed...
 ---> c6fa8e4bcb26
 ---> Using cache
 ---> 4c5ce91b0eaf
 ---> Using cache
 ---> 8c66cd348691
All done
The last error message indicates that the Dashticz Docker image already exists and is running.
To rebuild the image:
cd /home/pi/dashticz3/dashticz_v3
make stop
make start
Can you post the output of these commands?
Lokonli
Post by Lokonli »
Lokonli wrote: Thursday 27 June 2019 7:48
jake wrote: Wednesday 26 June 2019 23:34 I did a 'make update' and now the garbage is loading alright. Thankf for fixing!
I noticed something else (very minor issue):
Because I had V3 setup 'manually' and via Docker, I can load them both in different tabs. I skipped between them and found something 'moving' in the calendar. Finally I saw that in the docker version of dashticz V3 the 'all day' events have a 02:00 time after the date, where the normal version doesn't have that.
Again, equal config file, so that doesn't explain.
Yesterday I indeed released beta 3.0.1. Thanks for confirming that your garbage issue is solved.
The 02:00 time issue sounds like an incorrect timezone setting, probably inside the Docker container. I'm afraid I don't have the time to look into this in the coming 3 weeks (holiday). I'll create an issue on Github. Maybe someone else is willing to pick this up.
Fixed in latest beta.
Omehenne
Post by Omehenne »
Interesting to see that Dashticz is still being developed, hence I attempt to install it om my raspberry again.
However when I do an install of the beta, I will get a failure as shown below with docker-ce (apologies for the dutch text)
dpkg: fout bij verwerken van pakket docker-ce (--configure):
subproces post-installation script geïnstalleerd gaf een foutwaarde 1 terug
Fouten gevonden tijdens verwerken van:
docker-ce
A downgrade to docker with the below command
sudo apt-get install docker-ce=18.06.1~ce~3-0~raspbian
fixes the error but the "make start" command executes an upgrade of docker and the error comes back again.
Is there a solution for this?
Cheers,
Omehenne
Lokonli
Post by Lokonli »
Thanks for the feedback.
I'll adapt the script and make the automatic installation of Docker optional.
kevinvantuyl
Domoticz version: 4.9700
Post by kevinvantuyl »
Works fine for now on a rpi 3b+.
1x RPi 3 b+
6x KaKu switches
1x rooted Toon
1x P1 cable
4x Wifi Lights
Lokonli
Post by Lokonli »
kevinvantuyl wrote: Friday 25 October 2019 11:38 Works fine for now on a rpi 3b+.
Thanks for your feedback.
JacKok
Domoticz version: V4.10717
Post by JacKok »
Works fine! And save a lot of time. Please share with "robgeerts" the creator of dashticz
dstewart275
Post by dstewart275 »
Hello - Can someone help me out?
I've a bit of experience with Domoticz and no problems with that. I've just tried to install Dashticz on the same PI and I simply can't make it work. The automatic installer runs fine and at the end I get the message to go to 192.168.1.96:8082 and another 172.x.x.x address but they don't land anywhere. If I go to 192.168.1.96:80 I get the apache holding page and at 192.168.1.96/dashticz/ i'll get an Dashticz error page. The CONFIG.js file is correct as you'd expect.
I'm running Raspbian Buster on a Pi1 Model B.
Any advice appreciated... Thanks Duncan
(edited because I made a mistake including the IP address 192.168.1.1.)
Last edited by dstewart275 on Monday 23 December 2019 16:49, edited 1 time in total.
Lokonli
Post by Lokonli »
dstewart275 wrote: Monday 23 December 2019 14:38 Hello - Can someone help me out?
I've a bit of experience with Domoticz and no problems with that. I've just tried to install Dashticz on the same PI and I simply can't make it work. The automatic installer runs fine and at the end I get the message to go to 192.168.1.96:8082 and another 172.x.x.x address but they don't land anywhere. If I go to 192.168.1.1:80 I get the apache holding page and at 192.168.1.1/dashticz/ i'll get an Dashticz error page. The CONFIG.js file is correct as you'd expect.
What is the IP address of your pi? The installation script thinks it's running on 192.168.1.96...
Which error is reported if you go to 192.168.1.1/dashticz/ ?
Can you post your CONFIG.js here?
dstewart275
Lokonli wrote: Monday 23 December 2019 16:06 What is the IP address of your pi? The installation script thinks it's running on 192.168.1.96...
Thanks - my pi is 192.168.1.96 and I can get to Domoticz on 192.168.1.96:8080 just fine.
I've made a mistake in the previous post - The page I land on at 192.168.1.96/dashticz/ just says "ERROR - For more information visit Dashticz V3 Documentation"... The 192.168.1.1 reference should be ignored.
Thanks for helping!
CONFIG.js
(2.07 KiB) Downloaded 134 times
Last edited by dstewart275 on Monday 23 December 2019 16:46, edited 1 time in total.
martin82
Post by martin82 »
install is great .works fine but the rest. it is hard to setup everthing .
i hop that i can learn it
Lokonli
Post by Lokonli »
dstewart275 wrote: Monday 23 December 2019 16:30
Thanks for helping!
The 192.1168.1.96 indeed makes more sense ...
If you followed the automatic installation script you should have a Docker image running on port 8082.
Maybe better to test that first.
What do you see if you open 192.168.1.96:8082?
dstewart275
Lokonli wrote: Monday 23 December 2019 16:57 The 192.1168.1.96 indeed makes more sense ...
That's what I was expecting too - Docker seems to be running (and I presume it is generating the error page mentioned on 192.168.1.96/dashticz
However if i navigate to 192.168.1.96:8082 on chrome I get
This site can’t be reached
192.168.1.96 refused to connect.
Search Google for 192 168 8082
ERR_CONNECTION_REFUSED
Does that help?
Lokonli
Post by Lokonli »
dstewart275 wrote: Monday 23 December 2019 17:37
Does that help?
Then apparently the Docker image is not running correctly, at least not on port 8082.
Just to be sure, can you type the following in the Dashticz folder:
	make stop
	make start
It stops the current Dashticz container, and restarts it again. It takes approx 1 minute. After start it reports the ip-adres:port.
The error page on 192.168.1.96/dashticz is not generated by the Docker container, but probably by some left overs from a previous manual install?
dstewart275
Lokonli wrote: Monday 23 December 2019 17:46 Then apparently the Docker image is not running correctly, at least not on port 8082.
	make stop
	make start
Thanks - here's the output from putty
pi@raspberrypi:~ $ cd dashticz_v3
pi@raspberrypi:~/dashticz_v3 $ make stop
sudo docker stop dtv3
dtv3
sudo docker rm dtv3
dtv3
pi@raspberrypi:~/dashticz_v3 $ make start
Check for git
Installed...
Sending build context to Docker daemon   66.8MB
 ---> c2dbfc2dd7fc
 ---> Using cache
 ---> f1f10f88a333
 ---> Using cache
 ---> fd4d3dcf868d
Successfully built fd4d3dcf868d
sudo docker run --name dtv3 -d -p 8082:80 --mount type=bind,source="/home/pi/dashticz_v3",target=/var/www/html dtv3
8505117725c350dc5a76a41b2c60445c110e6612c01d0e3903f8a88382e3b2bd
Dashticz is running at:
http://192.168.1.96:8082
http://172.17.0.1:8082
But still the same error on chrome....
Appreciate your efforts.
